Ed Harvey Effects v 5.0 (2022-12-24)
Ed Harvey
Hi @Tarazha - you can still find his older version on the web here but please be cautious when downloading.  I tested it and it's was OK, but you should be aware of potential viruses too.
I wanted to use the Weave plugin, but while looking for it I realized none of Ed Harvey's render effects are showing up in my paint.net. I even tried to run a search for them with the plugin browser, the only thing the browser came up with were links to the forums under the "Plugin Information".
So at the moment the known plugins I don't have are :
  • Dither
  • Lattice
  • Textile
  • Weave
However, I also did a search by author using the plugin browser, it came up with 33 Ed Harvey plugins installed. I'm pretty sure there are more than 33 plugins in this plugin pack.
It's true.  I just upgraded this plugin pack from 3.5 to 4.0 & lost three effects.  This helps explain where two of them went ...
Removed because they were rubbish!
[shout out loud if you REALLY want them back]
  • Render->Dither [ by popular demand, 'Dither' now in the Archives :) ]
  • Texture->Textile
As for Lattice and Weave, I don't know why they haven't made the cut.
  • 3 months later...
Hello guys. Moderartor suggested I should try Ed's plugin for what I want to accomplish. What I want to accomplish is commercial photography by applying proper touch up for photos I made with my old digital camera. My photos even when shooting on sunlight do not have enough lighting plus it feels as camera also leaves green tint on photos. The process is removing background, putting object on white background and adjusting it by raising light levels so although artificially, it looks like it was shot with enough lighting. Applying color adjustment later would be bonus and not as required as lighting. To give you example for what I am looking for, here's a link to "Before - After" photo:
http://imgur.com/a/0vlqM
Can you view them?
Another problem is that I am not savvy in knowing terms and adjusting parameters. Would that be obstacle?
Edited by TechnicGeek
I notice you state the lattice effect is in this effects pack, but I do not see it anywhere in the Effects->Render... was it removed/renamed? if so how can I re-get it?! The only reason I got this pack was because I need a lattice effect and am having trouble finding. and now this pack deosn't even contain one :/
Edited by Jambox5
  • 7 months later...
I've just replaced the 2012 version of EdHarvey.Effects.dll with the 1/20/2014 version, and now when I start Paint.Net I don't seem to have any of the plugins in it.  (E.g.,  soft saturation is gone, which I would have expected, but I don't have vibrance either.)
Is the problem simply that I'm still using Paint.Net  v3.5.11, rather than upgrading to 4?  (If not, any ideas what the problem is?)
Red ochre, thanks for confirming my suspicions.
Rick: Yeah, I know, but I fear change (insert half a smiley here).  Too many times I've been burned by upgrading a program or operating system to the next version and finding that half of what I knew about it no longer applies and half the add-ons and plug-ins I loved with the old version don't work under the new one.  But yes, I will upgrade Real Soon Now, I promise.
Does anyone know the Windows 7 technique for installing Paint.Net 4 while still keeping 3.5.11 around and usable just in case (rather than outright replacing 3.5.11 with 4)?
I also feel this way, always fixing what isn't broken.
I suggest you do what Red and Eli suggested you do. Thankfully for my sanity I did this a long time ago.
     Unfortunately quite a few plugins that I use a lot do not work in the newer versions of PDN and a few built in ones work differently than they have in the older versions. I honestly try to use the new version of PDN from time to time but always give up because something is missing, or does not work the same, or the still occasional crash of the program. Frankly it is quite annoying.
    A couple plugins that I use frequently in the old version that do not work in the newest versions, are Radial Blur Deluxe, Polar Inversion Deluxe, Jumble, and the Mirror effect no longer mirrors top over bottom or bottom over top, it just flips the image over like the Flip Vertical tool under the Layers tab.
If you're experiencing crashes in the new version, then report them. I can't fix what I don't know about. When you see the list of bug fixes in each update, that is hugely a direct result of people sending me those crash logs.
Over time I'm going to have to be more stringent about the "no old versions" rule here on the forum. If you're sticking to the old version and not reporting bugs, then you're actively hurting Paint.NET.
  • 4 weeks later...
I have a series of photos that were all taken with the white balance setting for the light.  When using photoshop (and NEF files) there is a real easy way to adjust the color temperature - the calibration, even seems accurate.   How can I adjust using Ed Harvey white balance?   I'm playing with it, but can't seem to get the continuous gradations to fix properly.  Am I using the wrong tool?  Alternatively, could anyone point me to a link that explains the relationship between the settings on the White Balance tool (ie, Hue and Amount) and color temperature?
Thanks so much in advance
  • BoltBait unpinned this topic
  • 3 months later...
Here's a new crash playing with the settings of siesmograph. Just experienced it using the tut for The Haxxor Effect!
A Plugin rarely used. It worked at first - but crashed when playing with the settings.
Application version: paint.net 4.0.17 (Final 4.17.6411.1908)
Time of crash: 2017-07-26 9:10:35 AM
Application uptime: 05:09:31.5876730
Application state: Running
Working set: 384,756 KiB
Handles and threads: 3630 handles, 76 threads, 964 gdi, 585 user
Install type: Classic
Application directory: C:\Program Files\paint.net
Current directory: C:\Program Files\paint.net
Install directory: C:\Program Files\paint.net
AppSettings storage handler: RegistryStorageHandler
OS Version: 10.0.15063.0 Workstation x64
.NET version: CLR 4.0.30319.42000 x64, FX 4.6
Processor: "Intel(R) Core(TM) i5-4460  CPU @ 3.20GHz" @ ~3193MHz (4C/4T, DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE)
Physical memory: 8143 MB
Video card: NVIDIA GeForce GT 720 (v:10DE, d:1286, r:161), Microsoft Basic Render Driver (v:1414, d:8C, r:0)
Hardware acceleration: True (default: True)
UI animations: True
UI theme: Aero/Aero + DWM (Aero.msstyles)
Updates: True, 2017-07-25
Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: en-CA, cuic: en-US
Flags:
Exception details:
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
   at System.Drawing.Graphics.DrawLines(Pen pen, PointF[] points)
   at EdHarvey.Edfects.Effects.SeismographEffect.PaintHorizontalSingleColor(Graphics g, Rectangle rect, Pen pn) in C:\PDN4-20140107\src\Ed-fects\Stylize\Seismograph.cs:line 238
   at EdHarvey.Edfects.Effects.SeismographEffect.OnRender(Rectangle[] renderRects, Int32 startIndex, Int32 length) in C:\PDN4-20140107\src\Ed-fects\Stylize\Seismograph.cs:line 115
   at PaintDotNet.Effects.Effect`1.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length) in D:\src\pdn\src\Effects\Effect`1.cs:line 98
   at PaintDotNet.Effects.BackgroundEffectRenderer.RenderWithClipMask(Effect effect, EffectConfigToken token, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, IRenderer`1 clipMaskRenderer) in D:\src\pdn\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 170
   at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderTile(EffectConfigToken token, Int32 tileIndex) in D:\src\pdn\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 150
   at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderNextTile(EffectConfigToken token) in D:\src\pdn\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 142
   at PaintDotNet.Effects.EffectRendererWorkItemQueue.OnExecuteNextWorkItem() in D:\src\pdn\src\PaintDotNet\Effects\EffectRendererWorkItemQueue.cs:line 131
   at PaintDotNet.Threading.MultithreadedWorkItemDispatcher.WorkThreadProc(Object context) in D:\src\pdn\src\Core\Threading\MultithreadedWorkItemDispatcher.cs:line 514
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart(Object obj)
Managed assemblies:
    mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll
    PaintDotNet, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.exe
    PaintDotNet.Base, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Base.dll
    PaintDotNet.Core, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Core.dll
    PaintDotNet.SystemLayer, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.dll
    PaintDotNet.Framework, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Framework.dll
    PaintDotNet.Resources, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Resources.dll
    PaintDotNet.Data, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Data.dll
    PaintDotNet.Effects, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Effects.dll
    PaintDotNet.SystemLayer.Native.x64, Version=4.17.6411.1908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll
    2dImageFilter, Version=1.1.3.3, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\2dImageFilter-r133.dll
    "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AA's_Assistant.dll
    Aardvark, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Aardvark.dll
    Add Depth, Version=1.0.4247.30168, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Add Depth.dll
    AddDepth, Version=1.0.6337.31153, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AddDepth.dll
    AdvancedRotate, Version=1.0.3663.28009, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AdvancedRotate.dll
    advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\advcolorrep.dll
    AdvGrey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AdvGrey.dll
    AForge, Version=2.2.5.0, Culture=neutral, PublicKeyToken=c1db6ff4eaa06aeb @ C:\Program Files\paint.net\Effects\AForge.dll
    AForge.Imaging, Version=2.2.5.0, Culture=neutral, PublicKeyToken=ba8ddea9676ca48b @ C:\Program Files\paint.net\Effects\AForge.Imaging.dll
    Alias, Version=2.0.3167.14578, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alias.dll
    AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlignPlugin.dll
    Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha-Displacement Mask.dll
    Alpha2Gray, Version=4.2.5691.27800, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha2Gray.dll
    AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlphaBlur.dll
    AlphaContrast, Version=1.0.3813.18307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlphaContrast.dll
    AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlphaMask.dll
    AlphaThreshold, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlphaThreshold.dll
    Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha_to_0.dll
    Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha_to_255.dll
    Angled Gradient, Version=1.0.6166.41233, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Angled Gradient.dll
    AnimationEffect, Version=1.0.0.10, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AnimationEffect.dll
    AnimGIF, Version=2.4.4119.28305, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AnimGIF.dll
    Anti-Alias by jsonchiu, Version=1.0.4348.36767, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Anti-Alias by jsonchiu.dll
    Apply Color, Version=1.0.4406.25220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Apply Color.dll
    Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Apply Texture.dll
    ArtyThing, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ArtyThing.dll
    AutoChrome, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AutoChrome.dll
    AutoChromeNoise, Version=1.0.3847.37353, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AutoChromeNoise.dll
    AverageEdgeBlur, Version=1.0.3991.32409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AverageEdgeBlur.dll
    AverageSelectionColor, Version=1.1.3256.33886, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AverageSelectionColor.dll
    AxInterop.WMPLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AxInterop.WMPLib.dll
    Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Bars.dll
    Basic Edge Detector, Version=1.0.5347.22706, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Basic Edge Detector.dll
    BasicAntialias11, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BasicAntialias11.dll
    BasicPhotoAdjustments, Version=2.1.4020.485, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BasicPhotoAdjustments.dll
    Bevel, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Bevel_v1.4.0.0.dll
    Bezncurve, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Bezncurve.dll
    Bidirectional Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Bidirectional Blur.dll
    BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Black and White Converter.dll
    BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlackandAlpha+.dll
    BlackAndWhite+, Version=1.1.6234.38378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlackAndWhite+.dll
    BlendModesPlus, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlendModesPlus.dll
    BlurFill, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlurFill.dll
    "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Borders N' Shapes.dll
    Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Boutons.dll
    boxfitting, Version=1.1.6164.32856, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\boxfitting.dll
    BrushFactory, Version=1.3.0.41507, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BrushFactory.dll
    Bullet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Bullet.dll
    BulletinBoardTrim, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BulletinBoardTrim.dll
    BumpChecker, Version=1.4.4399.25606, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BumpChecker.dll
    Burninate, Version=4.2.5691.27860, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Burninate.dll
    CalliColour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CalliColour.dll
    CameraTrouserFlareV3, Version=1.1.4600.41268, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CameraTrouserFlareV3.dll
    Cartoonize, Version=1.0.4629.37393, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Cartoonize.dll
    CellMaker, Version=1.1.6139.29120, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CellMaker.dll
    CellMakerRev, Version=2.21.6377.6081, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CellMakerRev.dll
    CellTexture, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CellTexture.dll
    ChannelOperation, Version=1.0.6350.2522, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ChannelOperation.dll
    ChessFEN, Version=1.1.6139.31083, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ChessFEN.dll
    circleFractal2, Version=1.1.5613.38521, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\circleFractal2.dll
    CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CircleText.dll
    ClampedGaussianBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ClampedGaussianBlur.dll
    Clarifaction+, Version=1.0.4406.25898, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Clarifaction+.dll
    Clarify, Version=1.0.4349.19613, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Clarify.dll
    ClipDisplaceAA, Version=1.2.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ClipDisplaceAA.dll
    ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ClipWarpNew.dll
    Clock, Version=1.1.6245.30896, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Clock.dll
    CloudEffect, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CloudEffect.dll
    CMY Ghost, Version=1.0.4909.35063, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CMY Ghost.dll
    Cobweb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Cobweb.dll
    CodeLab, Version=2.22.6415.37877, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CodeLab.dll
    Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Color Match.dll
    coloraberation, Version=1.0.3859.18981, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\coloraberation.dll
    ColorBalance, Version=4.2.5691.27921, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorBalance.dll
    ColorClearer, Version=1.1.6009.41762, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorClearer.dll
    ColorHarmonies.Effect, Version=0.7.0.155, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorHarmonies.Effect.dll
    ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorMixer.dll
    ColorModulo, Version=1.1.3643.38108, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorModulo.dll
    ColorRange_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorRange_en.dll
    ColorSketch_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorSketch_en.dll
    ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorToAlpha.dll
    ColorTrimming, Version=1.0.3167.14623, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorTrimming.dll
    ColorZoomBlur, Version=1.1.3873.36417, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorZoomBlur.dll
    CompoGrids, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CompoGrids.dll
    Compotool, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Compotool.dll
    Contour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Contour.dll
    CoordinatePlanePoints, Version=1.0.6034.29864, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CoordinatePlanePoints.dll
    CopyAlpha, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CopyAlpha.dll
    Cuboids, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Cuboids.dll
    LightningCurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CurlyLines.dll
    CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CurtisBlack.Common.dll
    CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CurtisBlack.Effects.dll
    CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CurtisBlack.Resources.dll
    Curves+, Version=4.0.6119.31044, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Curves+.dll
    CustomBrushesMini, Version=2.2.5286.39584, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CustomBrushesMini.dll
    CycleHSV, Version=1.0.4909.35068, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CycleHSV.dll
    DHShapeMaker, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DHShapeMaker.dll
    Diagonal Lines, Version=1.0.4800.36619, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Diagonal Lines.dll
    Diffuse, Version=1.0.3254.27766, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Diffuse.dll
    Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Displacement.dll
    DisplayColorChangeDirection, Version=2.0.5621.37825, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DisplayColorChangeDirection.dll
    DispMap, Version=2.0.4919.36181, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DispMap.dll
    DistortingMirror, Version=1.0.4281.30602, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DistortingMirror.dll
    DistortThis, Version=2.7.5.37343, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DistortThis.dll
    Donut, Version=1.1.6406.36312, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Donut.dll
    Dot, Version=1.0.4673.202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Dot.dll
    DotAtCenter, Version=1.0.6377.7050, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DotAtCenter.dll
    DotAtCenterFromTut, Version=1.0.6337.23500, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DotAtCenterFromTut.dll
    DotMatrix, Version=1.0.6178.27733, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DotMatrix.dll
    dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\dpyColorBalance.dll
    DraganEffect_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DraganEffect_en.dll
    DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DragFrom.dll
    Dream, Version=4.2.5691.27988, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Dream.dll
    Droste, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Droste.dll
    DrPrepper, Version=1.4.4399.25637, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DrPrepper.dll
    Dryad, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Dryad.dll
    EarthsAndGreys, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EarthsAndGreys.dll
    EdgeExpander, Version=1.0.5863.38192, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdgeExpander.dll
    EdgeFader, Version=5.3.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdgeFader.dll
    EdgeShaderMJW, Version=1.0.5717.35999, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdgeShaderMJW.dll
    EdHarvey.Effects.Archives.DentsClassic, Version=3.5.3777.3380, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdHarvey.Effects.Archives.DentsClassic.dll
    EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdHarvey.Effects.dll
    EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EditableText.dll
    EigenBlur, Version=1.3.3555.24648, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EigenBlur.dll
    EliminateDarkLight, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EliminateDarkLight.dll
    EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EngraveEmboss.dll
    EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EOEffects.dll
    ErodeDilate, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ErodeDilate_v0.2.dll
    ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ExtendBorder.dll
    Eyeshine, Version=1.0.3700.25905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Eyeshine.dll
    Facet, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Facet.dll
    FibonacciFill, Version=1.1.6139.28851, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FibonacciFill.dll
    FillFromClipboard, Version=4.4.5816.21650, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FillFromClipboard.dll
    FillFromFile, Version=4.4.5815.35149, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FillFromFile.dll
    Film, Version=4.0.4642.26607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Film.dll
    FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FindEdges.dll
    Fisheye, Version=2.2.5533.12794, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Fisheye.dll
    Flip, Version=4.2.5691.28262, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Flip.dll
    Flourish, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Flourish.dll
    FloydSteinbergDithering, Version=4.2.5691.28309, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FloydSteinbergDithering.dll
    Fractal Attractor, Version=1.0.6388.26241, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Fractal Attractor.dll
    Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Frame.dll
    FSPost, Version=1.0.4913.8979, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FSPost.dll
    FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FurBlur.dll
    Edge Detect And Affect3, Version=1.0.5885.13123, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FuzzyEdgeDetect.dll
    GaussianBlurPlus, Version=4.2.5691.27401, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GaussianBlurPlus.dll
    Gears, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gears.dll
    GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GenTree.dll
    Gingham, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gingham.dll
    Gossamer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gossamer.dll
    Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gradient Bars.dll
    Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gradient Blocks.dll
    GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gradient Blur.dll
    Gradient Mapping, Version=4.0.6107.40059, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gradient Mapping.dll
    GradientsGalore, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GradientsGalore.dll
    GraphPaper, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GraphPaper.dll
    Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gravity.dll
    Gray2Alpha, Version=4.2.5691.29355, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gray2Alpha.dll
    Grid Warp, Version=4.0.5873.25124, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Grid Warp.dll
    GridCheckerboard, Version=3.0.5297.18928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GridCheckerboard.dll
    GridMaker, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GridMaker.dll
    GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GrimColorReaper.dll
    Heightmap plugin v1, Version=1.3.4261.22267, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Heightmap v1.3.dll
    HeightToNormal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HeightToNormal.dll
    Helix, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Helix.dll
    HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HexaGrid.dll
    Highlight, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Highlight.dll
    HighPass_rec, Version=1.3.6135.23156, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HighPass_rec.dll
    HotMetalGlow, Version=1.2.5985.32923, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HotMetalGlow.dll
    HsvEraser, Version=1.1.5625.39352, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HsvEraser.dll
    HSVGradients, Version=4.2.5691.29438, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HSVGradients.dll
    HueSatPlus, Version=4.2.5915.37091, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HueSatPlus.dll
    ImgurUploader, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ImgurUploader.dll
    IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\IniFile.dll
    InkSketch+, Version=1.0.4629.39900, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\InkSketch+.dll
    InputToOutput, Version=1.0.3167.14695, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\InputToOutput.dll
    InsetBoxShadow, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\InsetBoxShadow.dll
    Interop.WMPLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Interop.WMPLib.dll
    InvertAlpha, Version=1.0.3040.33378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\InvertAlpha.dll
    iPhoneTabbarIconMaker, Version=1.0.3659.22550, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\iPhoneTabbarIconMaker.dll
    IsometricCuboid, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\IsometricCuboid.dll
    PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\jchunn.dll
    JigsawPuzzle, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\JigsawPuzzle.dll
    Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Jitter.dll
    KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\KaleidoGen.dll
    Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Kaleidoscope.dll
    KlumpNoiz, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\KlumpNoiz.dll
    Lameography, Version=4.0.5285.19635, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Lameography.dll
    Landscape, Version=4.3.5815.35326, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Landscape.dll
    LaplacianPyramidFilter, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LaplacianPyramidFilter.dll
    LavEnt.Effects.RoundedRectangle, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LavEnt.Effects.RoundedRectangle.dll
    Layer Cake, Version=1.0.4911.8147, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Layer Cake.dll
    LensFlare, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LensFlare.dll
    LevelHorizon, Version=4.3.5815.35379, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LevelHorizon.dll
    Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Lightning.dll
    LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LightRays.dll
    Line Tracer, Version=1.0.4911.29141, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Line Tracer.dll
    LinesGrid, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LinesGrid_en.dll
    Linocut_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Linocut_en.dll
    Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Liquify.dll
    LocalContrast, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LocalContrast.dll
    LocalNoise, Version=1.0.4674.29909, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LocalNoise.dll
    Lomography, Version=1.1.3182.31441, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Lomography.dll
    LongiStripes, Version=1.0.6338.18614, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LongiStripes.dll
    LookAtIt.Effect, Version=0.6.0.779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LookAtIt.Effect.dll
    Magnifier, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Magnifier.dll
    Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Majority.dll
    mandala, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\mandala.dll
    MarkupRenderer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MarkupRenderer.dll
    MathNet.Iridium, Version=2007.3.8.35795, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MathNet.Iridium.dll
    Matrice, Version=1.0.3810.11744, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Matrice.dll
    MeasureObject, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MeasureObject.dll
    MeasureSelection, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MeasureSelection.dll
    MemeMaker, Version=1.3.6077.21525, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MemeMaker.dll
    Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Metallize.dll
    MirrorRotate, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MirrorRotate.dll
    MirrorRotateMenu, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MirrorRotateMenu.dll
    ModifyChannels, Version=1.0.1.3233, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ModifyChannels.dll
    Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Moire.dll
    MosaicManiac, Version=1.0.906.8, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MosaicManiac.dll
    MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MotionSharpen.dll
    MultiColorGradient, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MultiColorGradient.dll
    MultiSpline, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MultiSpline.dll
    MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MultiThreshold.dll
    MyBlur, Version=1.0.6408.33168, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MyBlur.dll
    MyEdgeShaderMJW, Version=1.0.6405.9783, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MyEdgeShaderMJW.dll
    MyKaleidoscope, Version=1.0.6314.25387, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MyKaleidoscope.dll
    MyNormalMapPlus, Version=1.3.6410.521, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MyNormalMapPlus.dll
    MyRemoveBlackDust, Version=1.0.6411.25475, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MyRemoveBlackDust.dll
    MyRemoveDust, Version=1.0.6411.25029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MyRemoveDust.dll
    Nebulous, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Nebulous.dll
    NeonEdges_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NeonEdges_en.dll
    NeutralWire, Version=1.0.6333.34789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NeutralWire.dll
    NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NewtonFractal.dll
    NoiseBleach, Version=1.0.4909.35542, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NoiseBleach.dll
    NoiseChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NoiseChoice.dll
    Normalizer, Version=1.8.4399.25698, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Normalizer.dll
    NormalMapPlus, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NormalMapPlus.dll
    Norm_Render, Version=7.3.4484.27012, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Norm_Render.dll
    Object2Colour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Object2Colour.dll
    ObjectBevel, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ObjectBevel.dll
    ObjectEdge, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Objectedge.dll
    ObjectTools, Version=4.2.6028.22521, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ObjectTools.dll
    Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Oblique.dll
    Offset Shadow, Version=1.0.4247.30184, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Offset Shadow.dll
    Offset, Version=1.0.4914.19410, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Offset.dll
    OffsetAlternatingStripes, Version=1.0.6025.41452, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\OffsetAlternatingStripes.dll
    OilPaintingPlus, Version=0.9.6035.29240, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\OilPaintingPlus.dll
    Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\OldFeather.dll
    Organigram, Version=1.2.6273.36121, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Organigram.dll
    Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Outline Object.dll
    Overblur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Overblur.dll
    Overliner, Version=1.2.3888.29226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Overliner.dll
    PageCurl, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PageCurl.dll
    Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Panelling.dll
    PaperKaleidocycles, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PaperKaleidocycles.dll
    ParallelLines.Effect, Version=1.6.0.575, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ParallelLines.Effect.dll
    Paste Warp Plus, Version=1.0.6244.33283, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Paste Warp Plus.dll
    PasteAlpha, Version=4.3.5815.35469, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PasteAlpha.dll
    PasteFill, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PasteFill.dll
    PasteFromClipboard, Version=1.2.6350.39917, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PasteFromClipboard.dll
    Pastel, Version=4.2.5691.30177, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Pastel.dll
    PDNSpriteSheetAnim, Version=1.0.0.3, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PDNSpriteSheetAnim.dll
    PerlinTexture, Version=2.0.6411.25796, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PerlinTexture.dll
    Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Perspective.dll
    PerspectiveTransformation, Version=1.2.5795.41799, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PerspectiveTransformation.dll
    phips_fill_gaps, Version=1.0.3307.18956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\phips_fill_gaps.dll
    phips_kill_color, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\phips_kill_color.dll
    PhotoAdjustments, Version=4.3.6255.42202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PhotoAdjustments.dll
    Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Pixelate+.dll
    PixSetRepl, Version=1.0.0.20200, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PixSetRepl.dll
    Planetoid, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Planetoid.dll
    PlugInData, Version=1.2.0.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PlugInData.dll
    PointBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PointBlur.dll
    pointwarp, Version=1.2.5709.42172, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PointWarpEffect.dll
    Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Polar.dll
    PolariodFrame, Version=1.0.4017.21452, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PolaroidFrame.dll
    PolyGlitch.Effects, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PolyGlitch.Effects.dll
    Polygon Tool, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Polygon Tool.dll
    Polygon, Version=4.2.5691.30288, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Polygon.dll
    Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Polygones.dll
    PostageStamp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PostageStamp.dll
    Poster, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Poster.dll
    posterize+, Version=1.0.4629.2600, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\posterize+.dll
    PSFilterPdn, Version=1.0.6.3, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PSFilterPdn.dll
    Psychocolour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Psychocolour.dll
    pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\pxEexpansion.dll
    QuadrilateralCorrection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\QuadrilateralCorrection.dll
    Quick Gravity, Version=1.0.4408.25818, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Quick Gravity.dll
    Radialcolors, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Radialcolors.dll
    RadialFade, Version=1.0.6374.3793, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RadialFade.dll
    RadiusFillCorners, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RadiusFillCorners.dll
    rainball, Version=1.0.4907.41850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\rainball.dll
    RainbowTwist, Version=1.1.6410.28789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RainbowTwist.dll
    Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Random Effect.dll
    RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Random lines.dll
    RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Random Maze1.dll
    RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Random Maze2.dll
    Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Random Shape Fill.dll
    Recolor Using Palette, Version=1.0.6382.573, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Recolor Using Palette.dll
    RecolourChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RecolourChoice.dll
    RedEyeQuickFix, Version=1.1.3161.39688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RedEyeQuickFix.dll
    RemoveBrightDark, Version=1.1.3063.36415, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RemoveBrightDark.dll
    RemoveDust, Version=4.2.5691.30327, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RemoveDust.dll
    RenderColorWheel, Version=1.1.3258.28607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RenderColorWheel.dll
    RenderSphereHeightMap, Version=1.0.6145.37460, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RenderSphereHeightMap.dll
    Replace Colors, Version=1.1.5767.26297, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Replace Colors.dll
    Reticulation, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Reticulation.dll
    ReverseColors, Version=1.0.4121.15722, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ReverseColors.dll
    ReverseFisheye, Version=1.0.5146.26176, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ReverseFisheye.dll
    RGB_Remap4, Version=1.0.3538.24311, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RGB_Remap4.dll
    Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Rosaces.dll
    RotateTextSUI, Version=1.1.4415.32713, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RotateTextSUI.dll
    Rotate_Zoom+, Version=1.11.5237.17779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Rotate_Zoom+.dll
    RoundedRectToe, Version=0.9.6337.37258, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RoundedRectToe.dll
    RoundedRectXOD, Version=1.0.6337.37520, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RoundedRectXOD.dll
    Ruler, Version=1.0.6034.31429, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Ruler.dll
    SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SBCommon.dll
    Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Scintillate.dll
    ScratchArt_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ScratchArt_en.dll
    ScreenPixel, Version=1.1.5534.1997, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ScreenPixel.dll
    Scribble, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Scribble.dll
    ScriptLab, Version=4.0.6107.18914, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ScriptLab.dll
    SeamCarving, Version=2.2.5815.34278, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SeamCarving.dll
    SeamlessHelper, Version=1.0.6337.37936, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SeamlessHelper.dll
    SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SeamlessTextureMaker.dll
    Selection2Clear, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Selection2Clear.dll
    SelectionObscure, Version=1.1.4602.34476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SelectionObscure.dll
    SelectionTools, Version=4.2.5691.30400, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SelectionTools.dll
    ShadowEffect, Version=1.3.0.23429, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ShadowEffect.dll
    ShadowHighlight, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ShadowHighlight.dll
    Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Shape3D.dll
    shapegradient, Version=1.5.3886.6574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\shapegradient.dll
    Shapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Shapes.dll
    Sharpen+, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Sharpen+.dll
    SharpenLandscapeAndrewDavid, Version=1.0.6357.22734, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SharpenLandscapeAndrewDavid.dll
    EffectsPluginTemplate2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Shatters_0.55beta.dll
    Sierpinski, Version=2.1.6389.29730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Sierpinski.dll
    silhouetteplus, Version=1.1.3131.17586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\silhouetteplus.dll
    SimpleColorChange, Version=1.0.6339.25003, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SimpleColorChange.dll
    SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SinWaves.dll
    Slinky, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Slinky.dll
    SmartSharpen, Version=1.5.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SmartSharpen.dll
    Smooth, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Smooth.dll
    Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Smudge.dll
    SpacedTextPlugin, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpacedTextPlugin.dll
    Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Sparkles.dll
    Specular, Version=1.0.3254.27778, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Specular.dll
    SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpeechBubble.dll
    Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Spiral.dll
    SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpiralText.dll
    SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpiroGraph.dll
    SpiroShapes, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpiroShapes.dll
    Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Splashes.dll
    Splatter, Version=4.0.5873.25083, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Splatter.dll
    SplitHueAndBrightness, Version=1.0.5800.37276, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SplitHueAndBrightness.dll
    SpokedWheel, Version=1.1.5908.19821, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpokedWheel.dll
    Squirkle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Squirkle.dll
    SquirkleWarp, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SquirkleWarp.dll
    StarGlow, Version=1.0.3839.21249, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\StarGlow.dll
    Starry, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Starry.dll
    Stars, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Stars.dll
    Stickman, Version=1.2.2.30005, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Stickman.dll
    Stipple, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Stipple.dll
    Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Stitch.dll
    StrayPixelRemover, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\StrayPixelRemover.dll
    StringAndPin, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\StringAndPin.dll
    SubLCD, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SubLCD.dll
    SubtractColor, Version=1.0.4679.26877, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SubtractColor.dll
    Table, Version=1.1.5847.38905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Table.dll
    Tartan, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tartan.dll
    Tattersall, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tattersall.dll
    Temperature, Version=1.4.6255.42224, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Temperature.dll
    Tesserae, Version=1.0.6200.27517, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tesserae.dll
    TextPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Textplus.dll
    TextPro, Version=1.0.3614.36023, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextPro.dll
    Texture Scaler, Version=1.1.6217.32880, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Texture Scaler.dll
    TextureMerger, Version=1.1.6159.40169, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextureMerger.dll
    TextureShader, Version=2.1.6276.42488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextureShader.dll
    TextureSmoother, Version=1.0.6096.31689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextureSmoother.dll
    Texturize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Texturize.dll
    TextWindow, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextWindow.dll
    TGAngle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TGAngle.dll
    TGMagnitude, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TGMagnitude.dll
    ThermalHeatMapEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ThermalHeatMapEffect.dll
    Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tiles.dll
    TileWorld, Version=1.0.0.30524, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TileWorld.dll
    TintReductionPhoto, Version=0.1.6369.6996, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TintReductionPhoto.dll
    TJacksonEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TJacksonEffects.dll
    Toon Shader, Version=1.0.3470.28696, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Toon Shader.dll
    Toon, Version=1.0.6337.20213, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Toon.dll
    Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Trail.dll
    trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\trail3d.dll
    Transitional Brush, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Transitional Brush.dll
    Transparency, Version=4.2.5691.30441, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Transparency.dll
    trix400, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\trix400.dll
    TRs Scatter, Version=1.3.4949.23250, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRs Scatter.dll
    TRsAlphaCutter, Version=3.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsAlphaCutter.dll
    TRsColorReducer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsColorReducer.dll
    TRsCustomRandomFill, Version=1.5.1.31287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsCustomRandomFill.dll
    TRsThirdDimension, Version=1.7.13.38717, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsThirdDimension.dll
    TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TubeOblique.dll
    TurbulentCircles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TurbulentCircles.dll
    TurbulentLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TurbulentLines.dll
    Tweaktrans2, Version=2.0.4252.27152, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tweaktrans2.dll
    Twist, Version=4.0.5873.25056, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Twist.dll
    TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TwistZ.dll
    TwoPointPerspective, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TwoPointPerspective.dll
    TwoToneThreshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TwoToneThreshold.dll
    Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll
    Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll
    Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.dll
    Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll
    Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll
    Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll
    Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll
    Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Grid.dll
    Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll
    Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll
    VanishPoint, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\VanishPoint.dll
    Vibration, Version=1.0.4407.34043, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vibration.dll
    Vibrato, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vibrato.dll
    ViewFramer, Version=1.0.6074.42436, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ViewFramer.dll
    Vignette1, Version=1.0.3538.14367, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vignette1.dll
    VignettePlus, Version=4.3.5815.35548, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\VignettePlus.dll
    Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Volutes.dll
    WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WaterReflection.dll
    Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Waves.dll
    WaveTextSUI, Version=1.2.4415.33440, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WaveTextSUI.dll
    WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WetFloor.dll
    WhichSymbolRedux, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WhichSymbolRedux.dll
    XYCoords, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\XYCoords.dll
    ZoomBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ZoomBlurDeluxe.dll
    OptionBasedLibrary v0.7.3, Version=0.7.0.229, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\OptionBasedLibrary v0.7.3.dll
    System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll
    OptionBasedLibrary v0.7.9, Version=0.7.9.1561, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\OptionBasedLibrary v0.7.9.dll
    Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\Microsoft.VisualBasic\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
    OptionBasedLibrary v0.6, Version=0.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\OptionBasedLibrary v0.6.dll
    ABRFileType, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\ABRFileType.dll
    AsciiArtFileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\AsciiArtFileType.dll
    CSVFiletype, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\CSVFiletype.dll
    IcoCur, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\IcoCur.dll
    ImAGIF.FileType, Version=0.12.0.1084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\ImAGIF.FileType.dll
    ImPS\,EPS\,AI.Open.FileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\ImPS,EPS,AI.Open.FileType.dll
    PatternFileType, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\PatternFileType.dll
    PNGSpriteMatrix, Version=1.0.2.32048, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\PNGSpriteMatrix.dll
    SpriteSheet, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\FileTypes\SpriteSheet.dll
    Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
    nkujo33n, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
    Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ <Location?>
    Interop.WIA, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Interop.WIA.dll
Native modules:
    C:\Program Files\paint.net\PaintDotNet.exe, version=4.17.6411.1908
    C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNEL32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcrt.dll, version=7.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\sechost.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\RPCRT4.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.7.2046.0 built by: NET47REL1
    C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\combase.dll, version=10.0.15063.296 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ucrtbase.dll, version=10.0.15063.413 (WinBuild.160101.0800)
    C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\GDI32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\gdi32full.dll, version=10.0.15063.413 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcp_win.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\USER32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\win32u.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\IMM32.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\kernel.appcore.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.7.2101.1 built by: NET47REL1LAST
    C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\e5739cb8e72d2dbcdd05b8b29b19b570\mscorlib.ni.dll, version=4.7.2101.1 built by: NET47REL1LAST
    C:\WINDOWS\System32\ole32.dll, version=10.0.15063.296 (WinBuild.160101.0800)
    C:\WINDOWS\system32\uxtheme.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\96c1c3482ae9a0adf502e447e9421f34\System.ni.dll, version=4.7.2093.0 built by: NET47REL1LAST
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\0da47122244b783aefc31bf9cce91fb4\System.Core.ni.dll, version=4.7.2099.0 built by: NET47REL1LAST
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\a95adc94907a276eecdd8bd4dd2613da\WindowsBase.ni.dll, version=4.7.2099.0 built by: NET47REL1LAST
    C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\rsaenh.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\bcrypt.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\9a25db39864631e47bcb3f118f70f815\System.Drawing.ni.dll, version=4.7.2046.0 built by: NET47REL1
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\6e0591117bc61afbfa446e441a416e6a\PresentationCore.ni.dll, version=4.7.2099.0 built by: NET47REL1LAST
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\4596ac38cea7a9deb441527b440566e3\PresentationFramework.ni.dll, version=4.7.2099.0
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\e01ab88e93743ffb1c2916cc150e2927\PaintDotNet.Base.ni.dll, version=4.17.6411.1908
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\af7416fc844b77d204bd5862de93855e\System.Windows.Forms.ni.dll, version=4.7.2094.0 built by: NET47REL1LAST
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\ea5b76224edcad16e855a8f70bdcbd87\PaintDotNet.SystemLayer.ni.dll, version=4.17.6411.1908
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\d0441224abcb847379ebfb90cf04790d\PaintDotNet.Core.ni.dll, version=4.17.6411.1908
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\cb4484eebc503b994ded55840c0ef993\PaintDotNet.Resources.ni.dll, version=4.17.6411.1908
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\31ab128ffde89a07df8d5950fd743549\PaintDotNet.Framework.ni.dll, version=4.17.6411.1908
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\3a59789ce3066d243ddf7d90af426c66\PaintDotNet.Data.ni.dll, version=4.17.6411.1908
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\f19044e5279c5227f115b6880ccac32c\PaintDotNet.Effects.ni.dll, version=4.17.6411.1908
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\0aba2123209896d60745c380cd0c94da\PaintDotNet.ni.exe, version=4.17.6411.1908
    C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.7.2099.0 built by: NET47REL1LAST
    C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.15063.332 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\D3DCOMPILER_47.dll, version=10.0.15063.447 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\MSVCP120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.7.2099.0 built by: NET47REL1LAST
    C:\WINDOWS\System32\shell32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\shcore.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\windows.storage.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\powrprof.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\profapi.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\b4d306579de4a5a902695792397d379e\System.Configuration.ni.dll, version=4.7.2046.0 built by: NET47REL1
    C:\WINDOWS\SYSTEM32\msvcp140.dll, version=14.00.24215.1 built by: VCTOOLSD14ULDR
    C:\WINDOWS\SYSTEM32\VCRUNTIME140.dll, version=14.00.24215.1 built by: VCTOOLSD14ULDR
    C:\WINDOWS\SYSTEM32\vcomp140.dll, version=14.00.24215.1 built by: VCTOOLSD14ULDR
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\d14361188f85e19bbd86d910f884f481\System.Xml.ni.dll, version=4.7.2046.0 built by: NET47REL1
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.7.2101.1 built by: NET47REL1LAST
    C:\WINDOWS\System32\MSCTF.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\a5fc6cc84f3634c8896c044cfcfde63d\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.17.6411.1908
    C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.17.6411.1908
    C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.15063.483_none_56eb200d4259be70\gdiplus.dll, version=10.0.15063.483 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    C:\WINDOWS\System32\UIAnimation.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dwmapi.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.15063.483_none_26002d27e7c744a2\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.15063.413_none_0e0f5dcc67adff4e\comctl32.dll, version=5.82 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.15063.483 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CRYPT32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\MSASN1.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\879f2ca0217055bcd06c55a4e9c8af91\System.Xaml.ni.dll, version=4.7.2099.0 built by: NET47REL1LAST
    C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dataexchange.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dcomp.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\TextInputFramework.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.15063.483
    C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.15063.0
    C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\wintypes.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\usermgrcli.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop_ref4i.inf_amd64_452f067e80ba0658\nvldumdx.dll, version=22.21.13.8494
    C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop_ref4i.inf_amd64_452f067e80ba0658\nvwgf2umx.dll, version=22.21.13.8494
    C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINMMBASE.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\nvspcap64.dll, version=3.7.0.81
    C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\PSAPI.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINHTTP.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\nvapi64.dll, version=22.21.13.8494
    C:\WINDOWS\system32\explorerframe.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Design\c0ef43ce1cc2a010d8ed1cb5e1a47677\System.Design.ni.dll, version=4.7.2094.0 built by: NET47REL1LAST
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Microsoft.V9921e851#\b447e71e538ea08b482efca3c740d259\Microsoft.VisualBasic.ni.dll, version=14.7.2046.0 built by: NET47REL1
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.7.2046.0 built by: NET47REL1
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrcompression.dll, version=4.7.2046.0 built by: NET47REL1
    C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\comdlg32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\LINKINFO.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\NetworkExplorer.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\MPR.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\drprov.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ntlanman.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\davclnt.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DAVHLPR.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\DUI70.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\DUser.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\thumbcache.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\policymanager.dll, version=10.0.15063.447 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\msvcp110_win.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\Windows.Globalization.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\Bcp47Langs.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\globinputhost.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\OLEACC.dll, version=7.2.15063.447 (WinBuild.160101.0800)
    C:\Windows\System32\uiautomationcore.dll, version=7.2.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\atlthunk.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\StructuredQuery.dll, version=7.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\SspiCli.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\OneCoreUAPCommonProxyStub.dll, version=10.0.15063.483 (WinBuild.160101.0800)
    C:\WINDOWS\System32\wkscli.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\cscapi.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\netutils.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\twinapi.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\dlnashext.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\DevDispItemProvider.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\ntshrui.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\srvcli.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DEVOBJ.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\WINTRUST.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\EhStorShell.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\urlmon.dll, version=11.00.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\iertutil.dll, version=11.00.15063.0 (WinBuild.160101.0800)
    C:\Users\Andrew\AppData\Local\Microsoft\OneDrive\17.3.6917.0607\amd64\FileSyncShell64.dll, version=17.3.6917.0607
    C:\WINDOWS\SYSTEM32\WININET.dll, version=11.00.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\mssprxy.dll, version=7.0.15063.413 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\ktmw32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Accessibility\965857f5fd54245caf3ad9aa5c98edf7\Accessibility.ni.dll, version=4.7.2046.0 built by: NET47REL1
    C:\Windows\System32\ActXPrxy.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\IconCodecService.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\coml2.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\PhotoMetadataHandler.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\MrmCoreR.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Users\Andrew\AppData\Local\Temp\ScintillaNET\2.22.6415\x64\SciLexer.dll, version=3.6.6
    C:\WINDOWS\SYSTEM32\Msimg32.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\rasapi32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\rasman.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\rtutils.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ws2_32.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\mswsock.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\NSI.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\DNSAPI.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINNSI.DLL, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\rasadhlp.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\System32\fwpuclnt.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\system32\windowscodecsext.dll, version=10.0.15063.483 (WinBuild.160101.0800)
    C:\Windows\System32\msxml6.dll, version=6.30.15063.0
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Interop.WIA\5a73bfebad2e83398ff621c852fbf751\Interop.WIA.ni.dll, version=1.0.0.0
    C:\WINDOWS\System32\wiaaut.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\wiatrace.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\Windows\System32\sti.dll, version=10.0.15063.0 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\msiso.dll, version=11.00.15063.138 (WinBuild.160101.0800)
Okay I'm really lost now, I finalllyyyyyyyy FINALLYYYY could upload this effects after like months of trying & giving up & ive finally done it. NOW I realize its missing jitter!! & I need jitter to start what I'm trying to do, I was just trying to add wobble & now jitter is gone. I don't know but is there a way to add jitter to the effects?? I literally had to create an account real quick to ask this, I need this like asap please help
  • 5 months later...
Quote
Pseudo-solarisation (or pseudo-solarization) is a phenomenon in photography in which the image recorded on a negative or on a photographic print is wholly or partially reversed in tone. Dark areas appear light or light areas appear dark. The term is synonymous with the Sabatier effect when referring to negatives. Solarisation and pseudo-solarisation are quite distinct effects.
https://en.wikipedia.org/wiki/Solarisation
  • 2 months later...
  • Ed Harvey changed the title to Ed Harvey Effects v 4.0 (2012-02-13)
  • Ed Harvey changed the title to Ed Harvey Effects v 5.0 (2022-12-24)
