Blooper Posted May 24, 2008 Posted May 24, 2008 You did on page 8. Good memory! :shock: About a PSP screen. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me
marc Posted May 31, 2008 Posted May 31, 2008 I need some help on finishing my wizard... he needs hair and the beard doesn't look right.. And maybe the nose is a little long... Quote Firefox - take back the web | My gallery | Photoucket | Marc Ville (My Minicity)
livewrong811 Posted June 2, 2008 Posted June 2, 2008 Try doing rough clouds for the beard, and then smudging it on another layer, and turning the opacity down. You could do that for the hair, too. Also try throwing some noise onto the hair and beard, to make it look more rough. And on the staff, and other parts of the body, the fill isn't complete and has some open spaces near the edges. Try a higher tolerance for paint bucket/magic wand, to get the whole selection in. Nice work so far, though. Quote
Chris Deston Posted June 3, 2008 Posted June 3, 2008 Is what i'm hoping to make. This is my first post and i plan on posting my gallery soon but for the moment i was hoping anyone could give me help/advice/hints/tips Heres what i have so far: http://tinypic.com/view.php?pic=wireas&s=3 Heres a nice li'l list of things i'd appreciate advice on :Angel: The top bit of the ship, i want either rectangular sections with lighting? How would i go about this?The, what i'll describe as a "Cockpit" to be more, real? I will be putting an alien in there but i want it more Glass-like than Bubble-likeThe grass to be a bit better (I may rely on Photography [or stock image] which may be easier as i want the stickman to be Me when i get around to it )And i was wondering with the outline, there is a slight white mark where the colour has been edited, and you can see nearer the bottom of the ship i've been touching it up, but is there not a quicker method? Currently it's literally :ZoomIn: :ColorPicker: haha..Also, is there a kind of distortion similar to Bulge but with more options? For the tracterbeam I used Polar Inversion on a straight laser to make it spread wider towards the bottom, but it's only got me so far and i want to be able to stretch it with an unlimited capacity, or like (realistically) to a 1200px bottom line (in white) with the yellow blur being constant upwards. Any help there? And one final thing? Criticisms and Suggestions Please and Thank You Anything will be useful he says hopefully --------------- And My First Post Is Over Quote Striving For Excellence Motivates You; Striving For Perfection Will Demoralise.
ZizOiz Posted June 3, 2008 Posted June 3, 2008 I believe this tutorial will help you with the bubble-like top to your UFO Quote Click on my signature image for my gallery | hmmmm...
-Expiration- Posted June 3, 2008 Posted June 3, 2008 Actually, ZiZoiz, he doesn't want it to look like a bubble, more like glass. :wink: Forgive me if these possible solutions are out of order, I just typed them up as they came to me. 1.For your coloring problems (the white spaces), you should try a new approach to coloring. What I usually do when I'm in this situation is: New LayerDraw the outline of a shape. Any color works, because you can always change it later.Fill in the outline of the shape with the same color, with 69-70% tolerance, depending on line thickness. There may be some gaps that you will have to fill in in the outline.Then, if you choose to change the color, you can use the Recolor tool, set to 0% tolerance, because everything is the same color.Try to do all the pieces and shapes on separate layers, so it is easy to recolor. 2.For the grass, there are numerous tutorials on how to create grass in the Tutorials section. ZiZoiz himself even created some realistic grass, you may want to ask him for pointers. :wink: 3.When you say, "rectangular sections with lighting," I'm not sure what you mean. Kind of like windows with light coming out from them? If not, could you please elaborate more? 4.I'm not sure there is a more advanced version of Bulge, but I think there probably is some plugin out there that could work for you, although I wouldn't know, I'm not very involved in plugins, some of the I still haven't updated for v3.3. 5.Glass is hard to replicate because of all the reflections/refractions, only a few members of these forums have mastered this material as of yet, and they are reluctant to share their secrets (not that they're being mean, they just want us to learn for ourselves). Hope this helps! Quote Call me expired. Please. Don't go counting your chickens before the pack of rabid ravaging foxes attacks. -Sozo
Ash Posted June 3, 2008 Posted June 3, 2008 Ask for image help in viewtopic.php?f=26&t=22617 Moved & Merged. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ]
ZizOiz Posted June 3, 2008 Posted June 3, 2008 Actually, ZiZoiz, he doesn't want it to look like a bubble, more like glass. hmm. True. That would be more difficult, but the bubble tutorial still might help, as glass and bubbles tend to have highlights in the same places. 2.For the grass, there are numerous tutorials on how to create grass in the Tutorials section. ZiZoiz themself even created some realistic grass, you may want to ask them for pointers. :wink: my method takes a good while, though. :? Quote Click on my signature image for my gallery | hmmmm...
Chris Deston Posted June 3, 2008 Posted June 3, 2008 Sorry for posting in wrong topic Ash "General Discussion & Questions.. ...do you have suggestions, requests, or how-to questions? Post here!" seemed like the right place, i never thought of looking in the Pictorium, but it's found it's way home now my method takes a good while, though. :? What method might that be? I'm open to any suggestions.. And that bubble tut may actually help, although Step 12 will confuse me no doubts (http://paintdotnet.forumer.com/viewtopic.php?f=15&t=2546&st=0&sk=t&sd=a&hilit=bubble) 1.For your coloring problems (the white spaces), you should try a new approach to coloring. What I usually do when I'm in this situation is: New LayerDraw the outline of a shape. Any color works, because you can always change it later.Fill in the outline of the shape with the same color, with 69-70% tolerance, depending on line thickness. There may be some gaps that you will have to fill in in the outline.Then, if you choose to change the color, you can use the Recolor tool, set to 0% tolerance, because everything is the same color.Try to do all the pieces and shapes on separate layers, so it is easy to recolor. Seems like the best bet 2.For the grass, there are numerous tutorials on how to create grass in the Tutorials section. ZiZoiz himself even created some realistic grass, you may want to ask him for pointers. :wink: I used the Fur tut as my basic outline, Rectangles-Gaus Blur-Jitter-SinWaves-Rotate-Layer, and i tried to get the waves in a position where they looked like the pressure is spreading it in a circle 3.When you say, "rectangular sections with lighting," I'm not sure what you mean. Kind of like windows with light coming out from them? That's exactly what i meant, but i was worried that through saying Windows i'd be flooded with more glass/bubble tuts 4.I'm not sure there is a more advanced version of Bulge, but I think there probably is some plugin out there that could work for you I've gone through a few, so far Polar Inversion's the best bet it seems (if i set it right ) 5.Glass is hard to replicate because of all the reflections/refractions That's why i'm thinking the bubble tut may suit, with the whole design being cartoon-like? A realistic bubble'd look like cartoon glass, i think? Hope this helps! Only a lot I'll be sure to give it all a shot when i get home tonight - the Mrs is on her way up, gotta babysit her sibs I believe this tutorial will help you with the bubble-like top to your UFO Thanks to you too, i'll make a version with that too Sorry again Ash, first post and all Quote Striving For Excellence Motivates You; Striving For Perfection Will Demoralise.
Mr.Whiskers Posted June 3, 2008 Posted June 3, 2008 Can Someone help me with methods on how to change hair colour/ sections of hair using paint.net ? thanks Quote Join In My Rate the Desktop Above You Game | TF2 | Youtube
pipp92 Posted June 3, 2008 Posted June 3, 2008 Short tutorial: 1.open your pic 2.make a new layer 3.change the blend mode to overlay or something that matches better 4.on the new layer paint the hair in the color you want. Quote Personal Gallery
ZizOiz Posted June 3, 2008 Posted June 3, 2008 my method takes a good while, though. :? What method might that be? I'm open to any suggestions.. And that bubble tut may actually help, although Step 12 will confuse me no doubts step 12 I don't think is necessary for the sort of glass bubble you're looking to achieve, though. and also, my method goes like this: with 3 custom brushes and 4 colors: really dark green, dark green, green, light green, stamp out the general shape of the grass in the darkest color, using all three shapes. Then, use the next lightest, then some patches of the darkest color, then color with the lighter green, then normal green, then the second darkest green, then the lightest green, then the normal green, then the .. well, you get the picture. If you want the brushes, just PM me Quote Click on my signature image for my gallery | hmmmm...
perfectlyabnormal Posted June 4, 2008 Posted June 4, 2008 I'm totally obsessed with black and white images! Anyway, I have a small problem. I'm trying to make a sig tag for a forum about a game that I am heavily addicted too. Well my problem is... I'm not sure what the see through lines on my image are called and I'm not sure if I'm doing them right. If I at least knew what they were called, I would try a search. Let me just show you all what I mean... Those are the little clear lines that I'm trying to figure out how to do right. I've seen them on other images and I'm not sure if I'm going about doing them the right way. Feel free to give me as many tips, or opinions, or help as you want. I need it. For some reason, I'm not good with sig tags. Quote I sniff scratch and sniff stickers because licking windows is over-rated.
Ash Posted June 4, 2008 Posted June 4, 2008 Draw those lines on a new layer, lower the layer's opacity. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ]
perfectlyabnormal Posted June 4, 2008 Posted June 4, 2008 Draw those lines on a new layer, lower the layer's opacity. I did the othr layer bit, but how much should I lower the opacity to? Quote I sniff scratch and sniff stickers because licking windows is over-rated.
Ash Posted June 4, 2008 Posted June 4, 2008 That is something for you to try, from you image, I'd say lower it about 1/3. But it's up to you. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ]
perfectlyabnormal Posted June 4, 2008 Posted June 4, 2008 Ok, I shall play around with that some more and try out your suggestion. Thank you! Quote I sniff scratch and sniff stickers because licking windows is over-rated.
Crazy Ninja Posted June 10, 2008 Posted June 10, 2008 Well, I'm trying to get back into paint.net again, and after some work, I've come up with a potential new signature. It's getting there but I feel like it could use something more. Looking at it now, I'm definitely thinking it needs some type of border. Any other suggestions? Quote My new dA, with a different name
LFC4EVER Posted June 10, 2008 Posted June 10, 2008 A glass border? Or maybe even something whacky and wild! Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::.
brandon.roeder Posted June 10, 2008 Posted June 10, 2008 I need some help with my sig. I like the style of it but its missing something. any ideas? Quote My DA|My Gallery|My Website
LFC4EVER Posted June 10, 2008 Posted June 10, 2008 Try adding a border, and maybe more "funkier" text. Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::.
Kaiden2 Posted June 13, 2008 Posted June 13, 2008 I think the text should be sketchyer or mabye have some lines form the background overlap it. Other than that i like it. Quote My subconscious is consciously aware that I am subconsciously unconscious.
oma Posted June 14, 2008 Posted June 14, 2008 been trying for ages to get more realistic flowers but still not there need some help how do you make the petals appear to have a bit of thickness but not chunky looking? as they are now they have no substance, they should be thicker than paper! Quote My Deviant Art Gallery Oma's Paint.Net gallery
Ash Posted June 14, 2008 Posted June 14, 2008 been trying for ages to get more realistic flowers but still not there need some help how do you make the petals appear to have a bit of thickness but not chunky looking? as they are now they have no substance, they should be thicker than paper! Something like this? Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ]
