Image Hospital: Help With Image Problems Here!
Please help me, thanks.
My friends gave me some tips in improving my signatures. But I didn't know how to do them.
1.How do I sharpen my render?
2. How do I smudge my render in to the blackground?
These are the signatures that I'm going to use the tips on.
Link to post
@Oma: i like your brush. Its could be used to create leafy things, e.g. ferns, plants and leaves. It could also be adapted to create other fancy flowery things. I see a good idea there, but i dont have a clue on how to adapt it.
Made a PSP on Paint.NET recently (99% on PDN, with images used for reference and the screenshot is an image too)
I was wondering on how to make it look more glossy and shiny as if it has a reflection on it, to make it more realistic.
Any tips how?
Thanks
Merry Christmas
Link to post
On the screen, you could make another layer, then add in a curvy white object and lower the opacity. I'm not sure how to say this in words...Let's try this:
On the screen layer, magic wand select anywhere outside the screen
Then invert the selection (ctrl-I)
Make a new layer (make sure your area is still selected)
draw a white line anywhere from the bottom to the top (and curve it too if you want)
fill the half you want the gloss in with white
then lower the opacity
Unselect the area
That could work for the basic PSP frame too. I hope that helped :)
If I was at home, I would post a screenshot or summin, seeing as my explanation seems kinda coarse..
You should add in a drop shadow too :wink:
Link to post
Worldnewser, Sabrown100, Ash:
Thanks for your tips.
@worldnewser: i vaguely get what your trying to say, but it would be very helpful of you posted an image, as it seems a bit "coarse" as you said.
@Sabrown100: i like the glare things you did, looks a bit more realistic..and i think i know to to make them.
@Ash: any ideas on how to create the shine on the image you posted? I'm clueless on how to do that.
Thanks all
Merry Christmas
Link to post
Ok I've been working on my very first sig for a couple of days and I need some help on how to make it look better,
specificly I think the text needs some work..not sure what to change it to though, or mabye i should move it, I'm not sure. Im open to all suggestions though.
My subconscious is consciously aware that I am subconsciously unconscious.
Link to post
Kaiden I like it, I like the colours and the layout. Only suggestion is fix the border by making it a solid colour.
I need to know how to make the blood cells transparent (like Jello) and get that curve in the middle. Plus I also need some more suggestions on how to make it better.
My Internet Explorer 8 Concept....
My Deviant Art
My Forum
Link to post
Thanks for the input, I'll try out your suggestion and see how it looks
Link to post
