Ash 10 Posted April 27, 2008 Share Posted April 27, 2008 I need to know how to make the blood cells transparent (like Jello) and get that curve in the middle. Plus I also need some more suggestions on how to make it better. Here you go. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
Rainsy 0 Posted April 27, 2008 Share Posted April 27, 2008 I need to know how to make the blood cells transparent (like Jello) and get that curve in the middle. Plus I also need some more suggestions on how to make it better. Here you go. How did you do that? I'm interested ^^ Quote Link to post Share on other sites
Tillerman 0 Posted April 27, 2008 Share Posted April 27, 2008 Here you go. Thanks Ash. How did you do it? Here's my try: Quote My Internet Explorer 8 Concept.... My Deviant Art My Forum Link to post Share on other sites
Blooper 0 Posted April 27, 2008 Share Posted April 27, 2008 Here you go. Thanks Ash. How did you do it? Here's my try: Drop Shadows I'll bet. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to post Share on other sites
Tillerman 0 Posted April 27, 2008 Share Posted April 27, 2008 Here you go. Thanks Ash. How did you do it? Here's my try: Drop Shadows I'll bet. My try is somewhat blurry, but I did not do drop shadows. Is it possible to sharpen it? Quote My Internet Explorer 8 Concept.... My Deviant Art My Forum Link to post Share on other sites
Blooper 0 Posted April 27, 2008 Share Posted April 27, 2008 [...]How can I sharpen it? ___ Drop Shadows I'll bet. My try is somewhat blurry, but I did not do drop shadows. Is it possible to sharpen it? Yes, use the sharpen effect and I was saying that Ash's try was probably made using drop shadows. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to post Share on other sites
Tillerman 0 Posted April 27, 2008 Share Posted April 27, 2008 [...]How can I sharpen it? ___ Drop Shadows I'll bet. My try is somewhat blurry, but I did not do drop shadows. Is it possible to sharpen it? Yes, use the sharpen effect and I was saying that Ash's try was probably made using drop shadows. How? Edit: Here is another try: Quote My Internet Explorer 8 Concept.... My Deviant Art My Forum Link to post Share on other sites
Ash 10 Posted April 27, 2008 Share Posted April 27, 2008 Shape3D Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
pipp92 3 Posted April 30, 2008 Share Posted April 30, 2008 what do you think of it? i want it to make more realistic but i don't know how. Quote Personal Gallery Link to post Share on other sites
Simon Brown 46 Posted April 30, 2008 Share Posted April 30, 2008 i want it to make more realistic but i don't know how. Try experimenting with blend modes, Curves and Pyrochild's film plugin. Quote Link to post Share on other sites
Ash 10 Posted April 30, 2008 Share Posted April 30, 2008 what do you thon of it?i want it to make more realistic but i don't know how. Axe handle & Log can use some ditorts. (Check out my Stem/wood/tree tut) Lose the black outline on the axe handle & blade. More metal/chrome for the axe blade. (Check out my Ring or 3d metal/chrome tut) A bit more randomness on the grass. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
Simon Brown 46 Posted April 30, 2008 Share Posted April 30, 2008 Try working on the background and using gradient lightness on the foreground. Quote Link to post Share on other sites
Blooper 0 Posted April 30, 2008 Share Posted April 30, 2008 The axe handle is too contrasty, it shouldn't have that many colors at the same time. Make it brown and just a few details. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to post Share on other sites
livewrong811 0 Posted April 30, 2008 Share Posted April 30, 2008 A minor detail, but at the tree/log's bottom left corner, there is a little part that looks like it is raised off of the ground, maybe you could just fill that part in. I'll post an example to make that clear, in a second. Quote Link to post Share on other sites
pipp92 3 Posted May 1, 2008 Share Posted May 1, 2008 ok i will try :wink: Quote Personal Gallery Link to post Share on other sites
livewrong811 0 Posted May 1, 2008 Share Posted May 1, 2008 What I ended up doing was just putting a piece of the grass texture over the problem part of the stump, here's my try: Edit: This was just a rough example, it would look better if you separated the pieces of grass that I put over the log. Quote Link to post Share on other sites
Tillerman 0 Posted May 1, 2008 Share Posted May 1, 2008 What I ended up doing was just putting a piece of the grass texture over the problem part of the stump, here's my try:Image Removed to conserve space Edit: This was just a rough example, it would look better if you separated the pieces of grass that I put over the log. I don't like the grass, looks too unrealistic. I suggest you try the Grass Turutorial. The wood texture on the stump is no good either. I suggest using a surface blur of 1 to 2 pixels (or whatever looks good) in order to make the noise less visble. Trying creating the wood texture using the polar to rect method. (I may post an example tomorrow.) Here is a quick example of a stump and some grass: In order to make this Use the bucket tool and add the colour you want, then use noise and add a motion blur at 90 degrees, followed by a polar to rect. This will create this effect. I suggest using this on anything that has wood (like the Stump and the Axe.) For the axe take out the black outline. Quote My Internet Explorer 8 Concept.... My Deviant Art My Forum Link to post Share on other sites
Yising 0 Posted May 2, 2008 Share Posted May 2, 2008 Wait... Quote No. Link to post Share on other sites
Blooper 0 Posted May 2, 2008 Share Posted May 2, 2008 What I ended up doing was just putting a piece of the grass texture over the problem part of the stump, here's my try:Image Removed to conserve space Edit: This was just a rough example, it would look better if you separated the pieces of grass that I put over the log. I don't like the grass, looks too unrealistic. I suggest you try the Grass Turutorial. The wood texture on the stump is no good either. I suggest using a surface blur of 1 to 2 pixels (or whatever looks good) in order to make the noise less visble. Trying creating the wood texture using the polar to rect method. (I may post an example tomorrow.) Here is a quick example of a stump and some grass: In order to make this Use the bucket tool and add the colour you want, then use noise and add a motion blur at 90 degrees, followed by a polar to rect. This will create this effect. I suggest using this on anything that has wood (like the Stump and the Axe.) For the axe take out the black outline. It would work for the axe but not the stump. Not detailed enough, and not random enough either -- the stump wouldn't look like a clear cut cylinder. It'd be much clearer in the middle, by the way. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to post Share on other sites
LFC4EVER 4 Posted May 2, 2008 Share Posted May 2, 2008 My new avatar, but i'm not sure what colour i should keep the text. its black now, but its a bit unclear IMO. Any ideas on what colour i should make the text? Quote ☆★☆★Merry Christmas★☆★☆  .::.My Gallery.::.Make Gold Text!.::. Link to post Share on other sites
Ash 10 Posted May 2, 2008 Share Posted May 2, 2008 My new avatar, but i'm not sure what colour i should keep the text. its black now, but its a bit unclear IMO. Any ideas on what colour i should make the text? Try rainbow, but invert the colors? Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
Crimson 4 Posted May 2, 2008 Share Posted May 2, 2008 not sure if this is the place to post this, but...would someone happen to know how to create a semi-realisitc rock with a shape somewhat like this (enclosed)? Thanks in advance . EDIT: well, look at that! I didn't even attatch an image. here it is. Quote Create A Professional-Looking Product Advertisment Mockup flickr | Deviant Art Link to post Share on other sites
pipp92 3 Posted May 2, 2008 Share Posted May 2, 2008 mhh i think my grass looks more realistic like yours tillerman and the stem is out of the tut from Ash, so it's realistic i have overworked(?) the handle of the axt, but i have problems with the chrome/metal thing although i have read all tutorials for that Quote Personal Gallery Link to post Share on other sites
Ash 10 Posted May 2, 2008 Share Posted May 2, 2008 mhh i think my grass looks more realistic like yours tillerman and the stem is out of the tut from Ash, so it's realistic i have overworked(?) the handle of the axt, but i have problems with the chrome/metal thing although i have read all tutorials for that You should try my grass brush Make the color of the grass a bit more random. You need to use a little distorts on your wood, like I've said before. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
pipp92 3 Posted May 2, 2008 Share Posted May 2, 2008 :oops: I searched your devianart account but i couldn't find the brush Quote Personal Gallery Link to post Share on other sites
