midora Posted October 11, 2013 Share Posted October 11, 2013 'Chop Up and Save' Tools Effect Plugin - (Moderator Note - this plugin 3/15/24 is not working in 5.0.13) Summary Chop up the current layer into tiles and save them to files. The resulting files may be packed into a single zip archive. Supported tile image formats: PNG - ARGB PNG w/o transparency - RGB BMP - ARGB BMP w/o transparency - RGB GIF JPG You may restrict the area to chop up by the current selection. Keywords Tiles, Save Tiles Author Martin Osieka Download >> Chop & Save 2.zip Installation Follow the instructions carefully Unzip "ChopUp.Effect vX.X.zip" Copy the two files OptionBasedLibrary vX.X.dll/.dlc to the Paint.NET Effects Folder. "C:\Program Files\Paint.NET\Effects". Copy the two files 'ChopUp.dll/dlc' to the Paint.NET\Effects\ folder. A typical location is "C:\Program Files\Paint.NET\Effects". Do not remove older versions of the OptionBasedLibrary if they are required from other plugins. After a restart of Paint.NET you will find the plugin under Menu->Effects->Tools. Compatibility Paint.NET 3.5.11 and 4.0.5 and 4.2.10 Supported languages The language used in the plugin depends on the language setting of Paint.NET and the support of this language by the plugin. The fallback is the first supported language of the plugin. Languages are defined in the .dlc files. This plugin supports the following languages in the moment: English Deutsch You may add your own translation to the .dlc file. Dialog options http://www.comsquare.ch/files/images/ChopUp.Dialog.jpg This software includes the class ZipOutputStream from DotNetZip distribution to do the zipping. See DotNetZip.License.Combined.rtf. Known issues None Examples None History 1.1 (11.10.2013) - Added zipping to archive 1.0 (10.10.2013) - Initial version 1 3 Quote Link to comment Share on other sites More sharing options...
sashwilko Posted October 11, 2013 Share Posted October 11, 2013 (edited) Looks useful Edited October 11, 2013 by sashwilko Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted October 11, 2013 Share Posted October 11, 2013 Looks really useful for a few projects I have in mind. Now just need time to play Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
midora Posted October 15, 2013 Author Share Posted October 15, 2013 Update v1.2 (15.10.2013)- Patches to support Paint.NET 4.0 1 Quote Link to comment Share on other sites More sharing options...
DrewDale Posted October 15, 2013 Share Posted October 15, 2013 You sir are a Thank you for the update 1 Quote Link to comment Share on other sites More sharing options...
Eli Posted January 9, 2017 Share Posted January 9, 2017 (edited) The first post is not readable and Martin Osieka's download page is not available. EDIT: I was able to download it from this site. RE-EDIT: Thank you administrators for fixing it : ) Edited January 9, 2017 by Eli Quote Link to comment Share on other sites More sharing options...
ingwer Posted October 12, 2017 Share Posted October 12, 2017 Unfortunately, this link isn't working anymore. Is there any chance to get this plugin? Quote Link to comment Share on other sites More sharing options...
lynxster4 Posted October 12, 2017 Share Posted October 12, 2017 (edited) Here you are @ingwer Maybe @Ego Eram Reputo can add it to the first post? Thank you. See first post for updated link. Edited October 30, 2017 by lynxster4 1 Quote My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 13, 2017 Share Posted October 13, 2017 Will do. Many thanks @lynxster4 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
ingwer Posted October 13, 2017 Share Posted October 13, 2017 Thank you, lynxster4 and ERR, you are very kind 1 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 14, 2017 Share Posted October 14, 2017 Link to the DLL added. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Stevo Posted April 19, 2019 Share Posted April 19, 2019 I just get completely black images with 4.1.6, dll v1.2 Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 19, 2019 Share Posted April 19, 2019 8 minutes ago, Stevo said: I just get completely black images with 4.1.6, dll v1.2 Works fine for me. Which settings are you using? Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Pixey Posted April 10, 2020 Share Posted April 10, 2020 I have added a new ZIP file for @midora's 'Chop & Save Plugin'. Now the Optional Based Library .dlc and .dll go into the Effects Folder and NOT the Paint.net Folder as before Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Sammy6 Posted April 10, 2020 Share Posted April 10, 2020 Windows says it's a virus. What about it would trigger that? Quote Link to comment Share on other sites More sharing options...
Pixey Posted April 10, 2020 Share Posted April 10, 2020 4 minutes ago, seljgames@gmail.com said: Windows says it's a virus. What about it would trigger that? That does happen sometimes, but it's okay to allow it when you know it comes from a source you know EDIT: I'm going to upload a new one as I notice a rar file is in there, that's not needed. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Sammy6 Posted April 10, 2020 Share Posted April 10, 2020 Okay. It works well, although when the canvas is less than 128 pixels tall the plugin crashes when you use it. Quote Link to comment Share on other sites More sharing options...
Pixelmage Posted March 13 Share Posted March 13 This plugin seems to not work correctly in the current version, any transparency is made black regardless of the file type you save it as. Is there any chance this plugin can get an update? Quote Link to comment Share on other sites More sharing options...
Pixey Posted March 15 Share Posted March 15 On 3/13/2024 at 5:47 PM, Pixelmage said: This plugin seems to not work correctly in the current version, any transparency is made black regardless of the file type you save it as. Is there any chance this plugin can get an update? I concur this Plugin is not working in 5.0.13. Unfortunately @midora has not logged in for while and this may not be fixed until he does. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
