MegaNight Posted December 21, 2008 Share Posted December 21, 2008 MegaNight: Perhaps the planet in the background could be either made brighter or darker, as right now it's at an uncomfortable middle that directs the eye to where the portal and the planet overlap. I Redid some lighting and, darkend the Planet a bit.. Redid the Hud (Green Thing), Removed Text and updated the Logo. Looks a bit Clean and Simple now.. better.. Quote --|-- My DeviantArt--|--My Gallery--|-- Link to comment Share on other sites More sharing options...
Thanksgiving Posted December 22, 2008 Share Posted December 22, 2008 How can I improve this? Same as above use the feather plugin (Boltbait addon) Actually. I don't think it's going to work. It's saved as .PNG and it's falttened. So it won't jsut feather that layer, I think. Quote Started Paint.net on Sunday, December 21, 2008 Link to comment Share on other sites More sharing options...
MegaNight Posted December 22, 2008 Share Posted December 22, 2008 How can I improve this? Same as above use the feather plugin (Boltbait addon) Actually. I don't think it's going to work. It's saved as .PNG and it's falttened. So it won't jsut feather that layer, I think. Not to burst your bubble, but you might need to redo it.. Always save your work as .PND with all the layers not Flattend before you Publish it.. Quote --|-- My DeviantArt--|--My Gallery--|-- Link to comment Share on other sites More sharing options...
Boude Posted December 23, 2008 Share Posted December 23, 2008 @welshblue: I found out that to give things depth you should adjust the light and/or morph it so that the texture curves around the object, basicly shape 3d+. If you need any more help pm me, I suggest that you pm me anyway. Quote History repeats itself, because nobody was paying attention the first time. Link to comment Share on other sites More sharing options...
Kemaru Posted December 23, 2008 Share Posted December 23, 2008 I'm stuck. It looks like the render has been just slapped on, what should I do to blend it in some more? Also, what kind of text should I use? Should I use katakana or just normal letters? Quote Hatred does not cease by hatred, but only by love; this is the eternal rule. |fb(page)|portfolio|blog| Link to comment Share on other sites More sharing options...
Flow55 Posted December 23, 2008 Share Posted December 23, 2008 I'm stuck. It looks like the render has been just slapped on, what should I do to blend it in some more? Also, what kind of text should I use? Should I use katakana or just normal letters? Put some of the fx in the bg over the render. Quote My Gallery Link to comment Share on other sites More sharing options...
Kemaru Posted December 23, 2008 Share Posted December 23, 2008 Okay, thanks. I'll try it tomorrow, I'm going to bed now. Quote Hatred does not cease by hatred, but only by love; this is the eternal rule. |fb(page)|portfolio|blog| Link to comment Share on other sites More sharing options...
Boude Posted December 24, 2008 Share Posted December 24, 2008 @welshblue: for the lines gaussin blur and lower opacity and for the light my advise would be to paintbrush and blur on several layers and different amounts, lots of work, but the best way to get it done properly, don't forget to get an alphamask if you are going to do it that way and you might have to get rid of the bevel. Quote History repeats itself, because nobody was paying attention the first time. Link to comment Share on other sites More sharing options...
Drum_gurl Posted December 24, 2008 Share Posted December 24, 2008 My friend has a band so i wanted to try making a logo design for them its a rock band and i dont know just looks off or somthing i thing the guys im the back are a little dark and you can't see them to much anywho, give me some suggestions or how to fix it! Thanks! Bigger View! Quote -FaNaCtIcS--ChAt- Link to comment Share on other sites More sharing options...
Kemaru Posted December 28, 2008 Share Posted December 28, 2008 Thanks, welshblue, I'll try that. How did you do the wooden texture on your Headcase? It looks very realistic. Great work! Quote Hatred does not cease by hatred, but only by love; this is the eternal rule. |fb(page)|portfolio|blog| Link to comment Share on other sites More sharing options...
oma Posted January 4, 2009 Share Posted January 4, 2009 I think my drawing of grapes is getting much closer but there is something off in this picture. I'm not sure what it is. :?: is it the perspective ? is it the shadows? or the colors? is it something in the composition? if so what should be added? help Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
LFC4EVER Posted January 4, 2009 Share Posted January 4, 2009 In my eyes, the something thats off, is that the grapes look flat-ish. Maybe some more work on shadows, and if you look at a real picture of grapes, they are slightly reflective. That could make it look better. Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
oma Posted January 4, 2009 Share Posted January 4, 2009 thanks think I've solved the flatness problem. posted update in my gallery. ciao once again thanks again. another set of eyes is a wonderful thing. Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
survulus Posted January 5, 2009 Share Posted January 5, 2009 My Image This is really important, it's for school and it's pretty much a games magazine cover, but the flow just isn't right. Any help is SERIOUSLY appreciated!! Quote Check out all my newest stuff on my dA I iz bassist here Link to comment Share on other sites More sharing options...
LFC4EVER Posted January 6, 2009 Share Posted January 6, 2009 Now that i look at it again, the "Also" text looks a bit lost. I have no idea where to put it, but i'd make it "un-lost". Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
survulus Posted January 6, 2009 Share Posted January 6, 2009 Thanks very much Yeh, the sloping text was a random attempt to draw the reader's eye down the page, and the bloodsplat is a device for flow too, though it still seems a bit stuck. Though I fit also into a gap in the bloodsplat closer to the text, it looks a little better now. Quote Check out all my newest stuff on my dA I iz bassist here Link to comment Share on other sites More sharing options...
LFC4EVER Posted January 6, 2009 Share Posted January 6, 2009 If you think about it, we read from left to right. So, thats sorta you're flow. You want the main concept of the magazine on the left, and others on the right. Maybe a top left to bottom right flow would work better. Just make sure you organise the cover so on first sight the main topic is seen, then the title (should still be at the top), then other random stuff. Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
survulus Posted February 7, 2009 Share Posted February 7, 2009 I'm having trouble again- my signature and avatar- the background is off, I know it is, I've tried 6 different backgrounds and it's starting to drive me up the wall. Any help? Quote Check out all my newest stuff on my dA I iz bassist here Link to comment Share on other sites More sharing options...
007 Nab Posted February 8, 2009 Share Posted February 8, 2009 It doesn't quite work because the foreground and background are two different styles. The backgrounds you use are typically stocks, or at least, they appear to be. The foregrounds, however, are line art - type of images. To make the two genres blend better, I would either incorporate some stock into the foreground, or some line art into the background. Quote "pyrochild, you're my favorite person ever. We should go snowboarding some time."~ 007 Nab. Ish. PDN Gallery | I Made a Deviant Art! Link to comment Share on other sites More sharing options...
survulus Posted February 8, 2009 Share Posted February 8, 2009 I've had a go at bringing the background's style into the fore as well, but it's kind of tricky, unless it just ends up becoming tomuch of a focal point in itself. Though the background in this case isn't a stock, all PDN, but I understand what you're saying. So maybe if the background were in the same style as the skull, sort of a wierd vector cartoon-y thing? Quote Check out all my newest stuff on my dA I iz bassist here Link to comment Share on other sites More sharing options...
Blooper Posted February 8, 2009 Share Posted February 8, 2009 @Survulus: At the risk of making a very short post, yes. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to comment Share on other sites More sharing options...
kayos25 Posted February 14, 2009 Share Posted February 14, 2009 Hey! My first post woot :twisted: Ive been browsing these forums but this is the first time i needed to post. anyway, this image just seems a bit wrong. any suggestions? Quote Link to comment Share on other sites More sharing options...
Aull Arkenbon Posted February 18, 2009 Share Posted February 18, 2009 Hey! My first post woot :twisted: Ive been browsing these forums but this is the first time i needed to post. anyway, this image just seems a bit wrong. any suggestions? In my humble opinion, The text looks somewhat off, if it was closer together (like Shadow and Kahos both in the top corners) It would look fine. Some of it could be the photobucket compression... but to me it looks like it needs a little more contrast like it's too grey/bland. Try Tanel's "Local Contrast Enhancement" plugin and mess with the sliders. Other than that it looks good. 8) (Not sure if you have it so I provided link.) Tanel's Photo and Color Plugins Quote "Better to reign in hell than serve in heaven" ~John Milton Link to comment Share on other sites More sharing options...
Jayed Posted February 20, 2009 Share Posted February 20, 2009 Hey! My first post woot :twisted: Ive been browsing these forums but this is the first time i needed to post. anyway, this image just seems a bit wrong. any suggestions? hmm... :?: ... ... ... . :idea: :idea: ID It looks great! You don't need to change much imo It's not that off actually, the text is where it's suppost to be O.o *if you see it's shadow and kayos in the picture, shadow's the main guy so he gets the bigger font, kayos is the smaller guy so he gets the smaller font, and they're where they're suppost to be* The font matches pretty well... but... I can see a problem in this. The "Access Denied" paragraph looks screaming out of place, try changing the font to match the BG, but make it pop out slightly. Like lighter grey or blackish with a soft white/red/black outline? Think that would work? Other then that it's pretty darn good You might want to soften up shadow's arm, it's in Kayos's face Shadow's name could be smaller, and I think that would be about it Have fun in whatever you do, and do what you want to Rosa Parks did, MLK Jr did, hell, Obama did what he wanted to and look where the USA is now! *ok, that was a bad example...* Quote Power comes to those who least expect it, Ambition comes to those who want it. Sometimes Ambition rules the Powerful, many times Ambition Is Power. Remember that Frodo, that ring could have been yours! Link to comment Share on other sites More sharing options...
K_I_N_G Posted February 20, 2009 Share Posted February 20, 2009 @ Survulus, try some grey paint-looking brushes on the background. Like, splatter it on there. Should help to give it the flow, or you could just blur it to hell and that'll give it flow. Course I wouldnt know much about magazine covers.... Quote Bloody Tentacles Tut (fixed link) My gallery Link to comment Share on other sites More sharing options...
