Download all plugins and source code in StusPluginsWithSource.zip below
Contains
- Advanced Rotate
- Alpha Contrast
- iPhone Icon maker
- RGB Remapper
Advanced Rotate:
This plugin does rotation on the selected area.
A great advantage is this rotation plugin operates around the center of your selection as compared to Paint.NET's rotation plugin which always uses the center of your whole image.
The main purpose is what to do with the unauthored areas of the rotation....
I.e. you can select to mirror the image, clamp it, use the default colour, leave it as untouched, and repeat. Mirroring is probably the most useful for general photo tidying as it fills the area with appropriate pixels as you can see below...
It is also possible to turn on/off the bilinear interpolation should it get in the way or you want a faster update on larger pictures
Here's a picture of it in action.
Alpha Contrast:
Vignette:
RGB Remapper:
RGB Intensity to Alpha(iPhone icon maker):
Attached File(s)
StusPluginsWithSource.zip (29.3K)
This post has been edited by sradforth: 10 June 2010 - 10:54 AM
Sign In
Register
Help
MultiQuote
