Power Stretch 2.0 Beta (updated May 3 2008)
pyjo
That's strange... can you reproduce the error? Which are the canvas size and the plugin settings that lead to the error?
Thanks
Pyjo.
The error occured in this situation:
The source image is 418x984, the size of the selection seems to be unimportant. If I move the slider down the value of -18, the error occurs immediately when rendering the preview. If I use -18 or higher, it occurs when rendering the result - as far as I see it.
It appears in the "+ area" as well. I never had such a problem with that plugin before. If the plugin would use IndirectUI, there would be no problem because you could work without that selection. :wink:
Edit: From CodeLab to VS C# using IndirectUI by MadJik
Thanks for this plugin.
While difficult to use, I was able to change a photo of one of my kids from not smiling to smiling. This made my wife happy.
(It always seems that when taking a family photo at least one of the kids is not smiling.)
BTW, I did see some random pixels come up while I was sliding the top slider around. They did not show up at all percentages, and when I saw some I just changed the slider + or - one to get rid of them.
Click to play:
I'm glad to help someone increase the happyness of his family.
Unfortunately, the likelihood of a kid not smiling in a photo is proportional to the number of kids. High number of kids means there is always someone crying or pouting.
Bye
Pyjo.
  • 3 weeks later...
wonderful ! this is really nice change from the first version. I can see possibilities already. thanks for the plugin and sharing it with us.
are you going to release a source code? I'd like to see it if you do.
one thing not a biggy , but something that you can keep in mind for future updates. I'm not sure if this is possible to do maybe an add of something like the polar inversion where they have wrap/transparent/ etc.
Much easier to use, I like best of all is the "guide lines" funtion!
Thanks!
By the way...I broke it :P :?
File: C:\Program Files\Paint.NET\Effects\PowerStretch.dll
     Version: 1.9.3045.14671
     Author: Pyjo
     Copyright: Copyright © Pyjo
     Website: http://www.getpaint.net/redirect/plugins.html
     Full error message: PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.ArgumentOutOfRangeException: Coordinates out of range, max={Width=799, Height=479}
Parameter name: (x,y)
Actual value was {X=800,Y=223}.
  at PaintDotNet.Surface.get_Item(Int32 x, Int32 y)
  at PowerStretch20Beta.PowerStretch20BetaPlugin.Render(Surface dst, Surface src, Rectangle rect)
  at PowerStretch20Beta.PowerStretch20BetaPlugin.OnRender(Rectangle[] rois, Int32 startIndex, Int32 length)
  at PaintDotNet.Effects.Effect`1.Render(Rectangle[] renderRects, Int32 startIndex, Int32 length)
  at PaintDotNet.Effects.Effect`1.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length)
  at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderImpl()
  at PaintDotNet.Effects.BackgroundEffectRenderer.Join()
  at PaintDotNet.Effects.BackgroundEffectRenderer.Start()
  at PaintDotNet.Menus.EffectMenuBase.<>c__DisplayClassa.b__8(Object sender, EventArgs e)
The only good thing about the source code is that it works. I'd like to clean it and then publish it, but i don't know when this will happen. Keep waiting... maybe I'll PM it to you.
About trasparency: the "empty" areas are filled with primary color, so you need only to select a fully trasparent color as primary. And about wrap... If you think it may be useful I'll try to add it as an option.
Are you considering using visual studio to create future versions of this plugin?
Now Codelab is very powerful. I'll consider VS when I'll try to do something that cannot be done in Codelab.
Thanks!
Thanks, and... congratulations! Perhaps my plugin still needs some hardening...
Is it possible to have an option that allows you to have a decreasing level of intensity as it gets further away from the chosen center of distortion?
Impossible is nothing. But The formula should be completely changed. When I started working on this plugin, I had your example in mind, but i judged it a bit too difficult (for me) to implement. Maybe in a future release (such as 117.0 or something).
See you later (with the next, full release of the 2.0 version)
Bye
Pyjo.
so am I correct when I use this plugin on transparent layer it drops in the primary color (black in this case ) and I have to just cut away that portion afterwards to maintain the transparency portion of this layer?
1st color Alpha=0
Reported already
Thanks!
     Author: Pyjo
  • 7 months later...
  • 4 weeks later...
Tried using Power Stretch 2 Beta to shape an apple using the vertical stretch option and four times it failed and I had to restart PDN. I think I`ll revert to version 1 .
If it`s any help here`s the details-
Author: Pyjo
Full error message: PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.ArgumentOutOfRangeException: Coordinates out of range, max={Width=599, Height=599}
Actual value was {X=224,Y=600}.
at PaintDotNet.Menus.EffectMenuBase.<>c__DisplayClassb.b__8(Object sender, EventArgs e)
I know it`s still Beta so maybe this will help iron out any problems.Not being into code I have no idea what all this actually means :oops: Up to now it`s been OK.
And my Alternatives to PDN
  • 5 months later...
I'm trying to create arched text, and to do it properly, I have to slide the radius bar all the way down to 100. but when I try to slide the vertical bar, it glitches up. Is this a bug in the programming or what?
Edit: Error message:
File: D:\Program Files\Paint.NET\Effects\PowerStretchh.dll
     Effect Name: PaintDotNet.Effects.UserScript
     Full error message: PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.ArgumentOutOfRangeException: Coordinates out of range, max={Width=274, Height=205}
Actual value was {X=107,Y=206}.
  at PaintDotNet.Effects.UserScript.Render(Surface dst, Surface src, Rectangle rect)
  at PaintDotNet.Effects.UserScript.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length)
  at PaintDotNet.Effects.BackgroundEffectRenderer.Abort()
I have both versions. I'm using 1 right now though.
  • 4 weeks later...
  • 8 months later...
I sincerely hope the author would be able to update the plugin for v3.5. It crashes when I play with the settings, and yes, I'm using v2.0 beta.
Here's the crash log:
Hidden Content: Crash Log
Author: Pyjo
Full error message: PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.ArgumentOutOfRangeException: Coordinates out of range, max={Width=799, Height=599}
Actual value was {X=514,Y=600}.
at PaintDotNet.Surface.get_Item(Int32 x, Int32 y) in D:\src\pdn\pdn_35x\src\Core\Surface.cs:line 750
at PaintDotNet.Effects.Effect`1.Render(Rectangle[] renderRects, Int32 startIndex, Int32 length) in D:\src\pdn\pdn_35x\src\Effects\Effect`1.cs:line 57
at PaintDotNet.Effects.Effect`1.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length) in D:\src\pdn\pdn_35x\src\Effects\Effect`1.cs:line 100
at PaintDotNet.Effects.Effect.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois) in D:\src\pdn\pdn_35x\src\Effects\Effect.cs:line 211
at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.Renderer(EffectConfigToken token) in D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 127
at PaintDotNet.Effects.BackgroundEffectRenderer.DrainExceptions() in D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 372
at PaintDotNet.Effects.BackgroundEffectRenderer.Join() in D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 363
at PaintDotNet.Effects.BackgroundEffectRenderer.Abort() in D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 327
at PaintDotNet.Effects.BackgroundEffectRenderer.Start() in D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 274
at PaintDotNet.Menus.EffectMenuBase.<>c__DisplayClass1d.<>c__DisplayClass21.<RunEffectImpl>b__10() in D:\src\pdn\pdn_35x\src\PaintDotNet\Menus\EffectMenuBase.cs:line 827
Officially retired from this forum. Have a nice day.
