revision date: 1 May 2013
Hidden Content:
1px Expansion - dpy. Expands areas of color by one pixel. dpy's Pack
2D-ImageFilter Library - Hawkynt. Library of algorithms used in various emulators (VirtualGB, Mame, DOSBox, SNES9x, ZSNES, etc,). Also known as Pixel Art Scaling Plugin.
3D Heightmap v1.0 - Spikehead777. Two plugins which take current image as a height map & shines a light on it, returning the intensity of reflected rays as another image (similar to Emboss).
3D Object (BETA) - evanolds. Wrap the canvas around a box, torus or topographical graph (with custom equation). Preview is used to drag and rotate shape. (Part of Evan's Effects.
AA's Assistant - dpy. Used to soften the edges of an object in order to blend it with a background. Object must be surrounded by transparent pixels to find the edges.
Add Depth - maccas. Two plugins which add (the appearance of) depth to a 2D shape on a transparent layer. Add Depth adds an apparent thickness by adding a 'trail'. Offset Shadow is a displacement plugin for moving a shadow after it's been created.
Add Noise + - MadJik. Adds digital 'noise' to a selection. Included in the native 'Add Noise' effect. Note: forum thread no longer exists.
Add/Remove/Recover Watermark - Evan Wallace. Removed by author due to possible copyright abuses. Note: forum thread no longer exists.
Advanced Color Replacement - silverhammer. Recolors every pixel a different amount based on how similar it is to the secondary color. Also known as Advanced Recoloring.
Advanced Greyscale - Illnab1024. Desaturates an image to grayscale. RGB channel bias is individually configurable. Found in Illnab1024's Plugins
Advanced Rotate - sradforth. Rotate an image or selection from the center with options on how the devoid pixels will be treated (clamp, wrap, mirror, Primary Color, Secondary color, untouched). Included in Stu's Effects.
Ahmed's Plugins - AhmedElyamani. Effects: Apply Color, Cartoonize, Color Switch, Clarifaction+, InkSketch+, Posterize+, Quick Gravity & Vibration
Alias - Mike Ryan. Removes antialiasing. Useful prior to feathering. Part of Mike Ryan's Plugins
Align Object - moc426. Align an object on a transparent layer to the corners, sides or center of the layer or selection. A newer version with it's own submenu is available as part of KrisVDM's Plugin Pack
Alpha 32-bit Bitmap - FremyCompany. Allows you to open and save file in 32-bit bitmap. You must rename the file to *.bmpx (to avoid conflict with the existing PDN's BMP handler). If you try to open non-BMP files, you should receive an error (24bpp bitmaps are loaded correctly)
Alpha Blur v2 - Tanel. Updated version of Alpha Blur, this effect performs a Gaussian blur on alpha channel (transparency). Useful for fading / blending irregular shapes. V2 has enhanced performance & option to shift blur. Part of Tanel's Photo and Color Plugins
Alpha Contrast - sradforth. Blur or sharpen the Alpha channel. Included in Stu's Effects.
Alpha map - Boude. Convert color to transparency & vice versa.
Alpha Mask - Illnab1024. Turn an image into an alpha mask. If the image has color, it is converted to greyscale. Updated to add clipboard functionality. Found in Illnab1024's Plugins
Alpha Mask Import (1.2) - Illnab1024. Turn an image into an alpha mask. If the image has color, it is converted to greyscale. Updated to add clipboard functionality. Find a new version in Illnab1024's Plugins
Alpha to 0 - dpy. Set the alpha channel to zero (transparent). dpy's Pack
Alpha to 255 - dpy. Set the alpha channel to 255 (opaque). dpy's Pack
Alpha to Dots - davidf. Resets alpha values in the image to 0 or 255, based on the original alpha value. The result is a 'dotty' transition instead of a blended one (imagine old newpaper images)
Alpha Transform 1.1 - DW-dev. Pixels below the lower limit get alpha set to 0 (fully transparent). Pixels above the upper limit get alpha set to 255 (fully opaque). Pixels in between get alpha between 0 and 255 depending on their brightness.
Alpha Transform v1.0 - DW.dev. Superseded by a later release: Alpha Transform 1.1
AlphaMask Brush v1.7 - Simon Brown. Draw an alpha mask directly onto an image. Found in Simon Brown's Legacy Plugin Pack.
AlphaSpace - MaR-V-iN. Converts a white/black background into transparency. Recognizes shadows and makes them semi-transparent.
Alpha-Threshold - Red ochre. Allows manipulation of transparency (Alpha) in a layer which already has a range of alpha values. Part of Red Ochre's Plugin Pack
Anaglyphs - Itso. Creations of anaglyphs (3D stereo pictures).
Animated Image 1.7 - Simon Brown. Open and save animated GIFs & PNGs, one frame into each layer. Simon Brown's Plugin Pack.
Animation Helper v0.81 - recursor. Allows you to view any sequence of animations within a sprite sheet.
Another Raw File Loader - Telesto. Support for loading RAW files. No longer supported or available for download.
Anti-alias v1.5 - jsonchiu. Use to smooth edges, keeping them clear, not blurred.
Apply Color - AhmedElyamani. Apply a filter to recolor or tint an image. Part of Ahmed's Plugin Pack
Apply Texture - niwax. Applies a texture to any selected object, saving the brightness.
Arrow - BoltBait. Effect is now included in Paint.NET from version 3.07+
ASCII Art - Simon Brown. Obsolete, use: Another ASCII Art File Type Plugin.
ASCII Art File Type Plugin - I Like Pi. ASCII art generator. Transform your image into an ascii art masterpiece!
Asmageddon Tools Pack v3 - Asmageddon Prince. Numerous color & distort effects: Asmageddon_Alpha works, Asmageddon_Channel multiplier, Asmageddon_Channel_Shift, Asmageddon_Channel_Works_Plus, Asmageddon_Color_Percentage_Plus, Asmageddon_From P to S Grey, Asmageddon_From P to S, Asmageddon_HSV inversion, Asmageddon_Hue Channeling multiply, Asmageddon_Hue Red Psychodelic, Asmageddon_Image coder, Asmageddon_Inverto_pushing, Asmageddon_Inverto_pushing_Caleidoscope, Asmageddon_Inverto_pushing_plus, Asmageddon_Multiplo uniqua, Asmageddon_PS Mega, Asmageddon_PS Only, Asmageddon_Pseudo water, Asmageddon_Quadro disorter B, Asmageddon_Quadro disorter, Asmageddon_Render-Border, Asmageddon_Render-Quadro bumperoo, Asmageddon_Render-Quadro inverto, Asmageddon_Render-Quadro sharper, Asmageddon_RGB tricks, Asmageddon_Strange Bulger B, Asmageddon_Strange Bulger, Asmageddon_Strange_Bulger Kaleidoscope.
Asmageddon_Alpha works - Asmageddon Prince. Enhance or reduce Alpha channel. Found in Asmageddon Tools Pack
Asmageddon_Channel multiplier - Asmageddon Prince. Enhance colorization by multiplying the RGB color channels by a factor of up to 20. Multiplication is quirky to say the least. Found in Asmageddon Tools Pack
Asmageddon_Channel_Shift - Asmageddon Prince. Selectively move an RGB, Alpha or All color channel a nuber of pixels in X or Y directions. Found in Asmageddon Tools Pack
Asmageddon_Channel_Works_Plus - Asmageddon Prince. Enhance or reduce the color information in an RGB, Alpha or combined RGB color channel. Found in Asmageddon Tools Pack
Asmageddon_Color_Percentage_Plus - Asmageddon Prince. Alter the R, G or B color channels by percentage. Found in Asmageddon Tools Pack
Asmageddon_From P to S - Asmageddon Prince. Assumed to shift the specified color channel(s) in some way between Primary and Secondary colors. Found in Asmageddon Tools Pack
Asmageddon_From P to S Grey - Asmageddon Prince. Assumed to shift the specified color channel(s) in some way between Primary and Secondary colors. Found in Asmageddon Tools Pack
Asmageddon_HSV inversion - Asmageddon Prince. Think three checkboxes to invert the Hues, Saturation and Value. Found in Asmageddon Tools Pack
Asmageddon_Hue Channeling multiply - Asmageddon Prince. Red, Green & Blue channel multiplier. Found in Asmageddon Tools Pack
Asmageddon_Hue Red Psychodelic - Asmageddon Prince. Change the Red in an image to another Hue. Red channel only. Found in Asmageddon Tools Pack
Asmageddon_Image coder - Asmageddon Prince. Turn an image into heavily distorted pattern. No decoder or author provided description of algorithm. Found in Asmageddon Tools Pack
Asmageddon_Inverto_pushing - Asmageddon Prince. Basic image warping by 'pushing' the image from its center toward one of the corners. Found in Asmageddon Tools Pack
Asmageddon_Inverto_pushing_Caleidoscope - Asmageddon Prince. Similar to Asmageddon_Inverto_pushing with the addition of kaleidoscopic duplicates. Found in Asmageddon Tools Pack
Asmageddon_Inverto_pushing_plus - Asmageddon Prince. As for Asmageddon_Inverto_pushing with the additional option to tile the image across the canvas. Found in Asmageddon Tools Pack
Asmageddon_Multiplo uniqua - Asmageddon Prince. Apparently another channel multiplier. Author: 'makes strange colors?'. Found in Asmageddon Tools Pack
Asmageddon_PS Mega - Asmageddon Prince. A previous version of From P to S. Yields some interesting greyscale results. Found in Asmageddon Tools Pack
Asmageddon_PS Only - Asmageddon Prince. Recolors image to Primary and Secondary colors (only). Found in Asmageddon Tools Pack
Asmageddon_Pseudo water - Asmageddon Prince. Distorts an image with a watery waveform. Effect is very powerful. Menu title is simply 'Water'. Found in Asmageddon Tools Pack
Asmageddon_Quadro disorter - Asmageddon Prince. Breaks image into sharp pieces and scatters them. Found in Asmageddon Tools Pack
Asmageddon_Quadro disorter B - Asmageddon Prince. Breaks image into sharp pieces and scatters them. Found in Asmageddon Tools Pack
Asmageddon_Render-Border - Asmageddon Prince. Renders a strange Primary colored border not unlike a raindrop covered window. Found in Asmageddon Tools Pack
Asmageddon_Render-Quadro bumperoo - Asmageddon Prince. Greyscale distortion/patterning effect. Found in Asmageddon Tools Pack
Asmageddon_Render-Quadro inverto - Asmageddon Prince. More greyscale distortion/patterning effects. Reminiscent of Sierpinksi triangles. Found in Asmageddon Tools Pack
Asmageddon_Render-Quadro sharper - Asmageddon Prince. Still more greyscale distortion/patterning effects. Found in Asmageddon Tools Pack
Asmageddon_RGB tricks - Asmageddon Prince. Mirror or invert the RGB channels. Found in Asmageddon Tools Pack
Asmageddon_Strange Bulger - Asmageddon Prince. Effect generates an error. Found in Asmageddon Tools Pack
Asmageddon_Strange Bulger B - Asmageddon Prince. Effect generates an error. Found in Asmageddon Tools Pack
Asmageddon_Strange_Bulger Kaleidoscope - Asmageddon Prince. Tiles image with mirroring in horisontal and vertical axes. Somewhat settings are similar to Polar Inversion type trnasformations. Found in Asmageddon Tools Pack
AutoChroma - MadJik. Generates fill or unfilled circles. Has preview issues. Magical Plugins Megapack.
Autochrome Noise - MadJik. Autochrome is a technique to recolor photos using colored grain or noise. Magical Plugins Megapack.
Average Blur - KrisVDM. Blur which averages all pixels within a certain radius. Each pixel counts as much as any other. Part of Kris VDM's Plugin Pack.
Average Color (HSL) - Neil Cassidy. Averages the color of a selection with regard to human perception of color.
Average Color of Selection - MJW. Averages the color over a selection.
Average Edge Blur - Cookies. Edge blur. Samples colors at the edge of an 8-way circle and returns the average.
AVI Frame Importer: AVIImport - Simon Brown. Allows Paint.NET to open an AVI (movie) file and choose which frame to open as an image. Files should be supported by the Windows AVI library. NB not all video files will work.
Barcode Plugin - eladkarako. Recompiled version of the original Barcode plugin. This generate barcodes from user input. Supports Code 39, Code 39 Mod 43, Full ascii code 39 and Postnet.
Barcode Plugin - Sepcot. Generate barcodes from user input. Original has been recompiled by eladkarako find it here Barcode Plugin (recompiled). This version is therefore flagged as depreciated.
Bars - MadJik. Generate colored bars from a border of the image with a random length. Magical Plugins Megapack.
Basic Antialias v1.1 - pyjo. Reduces aliasing of an object which borders transparent pixels without altering the sharpness of the edge. No configurable options hence no dialog appears when the effect is run.
Basic morphologic operations - PhilipLB. Performs basic morphologic operations: dilate and erode. Dilatation is a simple way to remove scratches and noise from a uniform background. Erode is similar to the Median Blur effect.
Basic Photo Adjustments v2.0 - Tanel. Color and tone enhancement tools (levels, curves) in a simple intuitive package. Tanel's Plugin Pack.
Batch Processor - PROTOTYPE - jxp. Removed by Rick Brewster. Prototype batch processor. Forum thread no longer exists.
Benchmark Utility (PdnBench) - Rick Brewster. Superseded by a later release. Forum thread no longer exists.
*NEW* Bevel Object - Red ochre. Apply different shaped bevels to an object, with either parallel or perspective lighting at a full range of angles. Bevels types: convex round, inset convex, convel bevel, convex chamfer, double convex, convex linear-flat, convex flat-linear, concave round, inset concave, flat.
Bevel Plugin v1.4 - jsonchiu. Applies a beveled edge to an image. Thread contains another (later) version which bevels irregular shapes.
Bevel Selection - BoltBait. Adds a bevelled effect to the edges of a selection with contrasting highlight and shadowing colors faking a lighting effect. Part of BoltBait's Plugin Pack
Bidirectional Blur - Tanel. This blur is a gaussian blur with the ability to separately modify the horizontal and vertical direction. Tanel's Plugin Pack.
Bilateral Filter - smax. Edge preserving noise reduction and blur. Crashes Paint.NET. Requires user to run MSI installer which installs the effect and creates a sub-folder /ru to house resources (Bilateral.resources.dll and Bilateral.resources.dll.VisualState.xml).
Bizarro-Negation v1.0 - Xhin. Creates abstract art using a technique which effectively duplicates the layer, flips it horizontally and vertically, then sets it to negation.
Black and Alpha+ - dpy. Changes an image into black and white , and changes brightness into transparency. dpy's Pack
Black and White Converter - Tanel. Convert image to black and white (greyscale), with many options for setting white/black level, tone & contrast, color & tint. Tanel's Plugin Pack.
BlendModes Plus v1.3 - APShredder. Apply a host of new blend modes: Normal, Average, Blue, Color, Cyan, Divide, Exclusion, Grain Extract, Grain Merge, Green, Hard Light, Hard Mix, Hue, Linear Burn, Linear Dodge, Linear Light, Luminosity, Magenta, Maximum, Minimum, Phoenix, Pin Light, Red.
BLP Converter Plugin - Evan Wallace. File support for loading Blizzard Picture files (*.blp). Requires Microsoft Visual C++ 2008 SP1 Redistributable Package.
Blue/Green Screen Remover - Bleek II. Remove green screen / blue screen (background) from an image. Note: semi-broken
Blur Map - Curtis. Blur the image by the value taken from the map image. Found in Curtis' Plugin Pack. Three DLL's contain a number of effects.
Blur Selection Edge - BoltBait. Blurs the edge of a selection. Part of BoltBait's Plugin Pack
BoltBait's Pack - BoltBait. Effects: Color Balance, Transparency, Flip (Horizontal or Vertical), Dream, Pastel, Gaussian Blur Plus, Feather, OldFeather, Outline, Paste Alpha, Switch Alpha to Gray, Switch Gray to Alpha, Combined Adjustments, Sharpen Landscape, Polygon/Stars, Flames, Bevel Selection, Blur Selection edge, Feather selection, Outline Selection.
Border / Stroke Effect - moc426. Draw a border around image or selection with your primary color.
Borders N' Shapes v1.6 - pyrochild. Draws a variety of borders and shapes. Pyrochild's Plugins
Bricks - jchunn. Creates brick patterns with mortar. Jesse Chunn Plugin Pack.
Brightness/ Darkness to Alpha - Mike Ryan. Turns Brightness (or Darkness) into pure transparent goodness! Can be found in Mike Ryan's Plugins. Topic is locked by request: use Color to Alpha.
Bullet - Simon Brown. No longer supported: renders bullet holes in your image.
Buttons - MadJik. Create beautiful colored buttons with or without text & symbols. Now with border width & text AA. Magical Plugins Megapack.
Camera lens distortion correction - kbarni. Correct the barrel or pincushion distortions in digital photos. AKA Lens Distortion
CannedBrush 1.5 - Simon Brown. Automates the process of creating repeat brush strokes for Custom Brushes plugin. Removed by author.
Cartoonize - AhmedElyamani. Applies dithering to simplify color differences and turn photos into cartoons. Part of Ahmed's Plugin Pack
Cell Texture - davidf. Produces a myriad of neighboring 'cells'. Hugely configurable.
CellMaker - Ego Eram Reputo. Renders x,y sized cells whose edges are entirely within a given selection. Use CellMaker Rev, the improved version.
CellMaker Rev - zoonel. Improved Cellmaker plugin with more options.
Channel Mask - Curtis. Similar to Alpha Mask but has more control over which channels to apply the mask to, and which channels to create the mask from. Found in Curtis' Plugin Pack. Three DLL's contain a number of effects.
Channel Mixer Greyscale - Illnab1024. Mix the Red, Green, and Blue channels separately as you convert an image to greyscale. Also known as Advanced Greyscale. Illnab1024's Plugins.
Channels v2.0 - Simon Brown. Modify colors by channel (Red, Green Blue & Alpha). Formerly InvertColours+. Found in Simon Brown's Legacy Plugin Pack.
Chart White Balance - yvdh. Adjust the white balance of a picture based on the white and black patch a standard color chart in the scene.
Checkboard - Simon Brown. Draws a checkboard similar to the one used by Paint.NET to show transparency.
ChessFEN - Ego Eram Reputo. Draws chessboard and position from scratch or by parsing a FEN string. Requires the Chess Merida font be installed.
Chroma Key (Green) - tarheit. For removing the green background from an image. Updated to include Blue.
Circle Text - dpy. Writes text into a circle, or on an angle. dpy's Pack
Clarifaction+ - AhmedElyamani. Enhance detail in a photograph by adjusting the detail and saturation. Part of Ahmed's Plugin Pack
Clipwarp - Red ochre. Deforms a clipboard image 'around' an object. Useful for creating glass and metallic effects.
Clouds Plugin - Sepcot. Creates cloud like effects using the Perlin Noise routine.
CodeLab v1.8 - Tom Jackson. Internal Paint.NET tool for creating your own plugins. Code & apply your own effects on the fly. Updated and maintained by BoltBait.
Color Aberration - MadJik. Allows you to move separately RGB channels in % or in pixels. It could be a used to create 3D pictures. Magical Plugins Megapack.
Color Accent - KrisVDM. Retint an image towards greyscale using the specified hue to control the recoloring. Part of Kris VDM's Plugin Pack.
Color Balance - BoltBait. Easy color correcting or tinting effect.
Color Balance MIX - DeathStar. Add more color or darken/lighten the image.
Color Balance+ - dpy. Enhanced color balance with Highlight, Shadow & Mid Tonal adjustments. dpy's Pack
Color Channel Mixer - SeriousSam. RGBA channel mixer with addition and scaling.
Color Count - stuff_gnome. Counts the number of colors (or number of times a color is used) in an image.
Color Dimmer - Xhin. Dims the individual RGB channels.
Color Filter - Ed Harvey. Apply a colored filter with options to configure Hue, Density and Preserve Highlights. Part of Ed Harvey Effects v3.5
Color Flip/Rotate - Ed Harvey. Quickly apply a color change to the image by clicking on one of many recolored thumbnails. Also known as Color Channel Flip/Rotate. Part of Ed Harvey Effects v3.5
Color inpainting v1.0 - zarathoustra. Colors gray areas in a picture where colors are only known in few parts of the picture.
Color Match v1.0 - pyrochild. Uses an existing image as a color template to recolor your image. Works best on photos. Pyrochild's Plugins
Color Mixer v1.2 - Tanel. Make fine color adjustments with values for Red, Yellow, Green, Cyan, Blue, Magenta & Base. Selectively apply to shadows, midtones or highlights. Tanel's Plugin Pack.
Color Modulo - MadJik. Creates a highly colored and configurable banded multiple gradient. Magical Plugins Megapack.
Color Replace - jchunn. Color filter with the ability to fine tune the color and alpha channels.
Color Stretch - rwp80. Color Stretch v1.0 stretch color values of pixels within specified threshold limits. Part of Color Target Plugin Pack
Color Target - rwp80. Color Target v1.3 retains pixels of a similar color and brightness, all other pixels are made transparent. Part of Color Target Plugin Pack
Color Target Plugin Pack - rwp80. Effects: Color Target, Color Stretch & Target Panel
Color Tint - Ed Harvey. Apply a color tint to the image. Options: Hue & Tint amount. Part of Ed Harvey Effects v3.5
Color to Alpha Advanced (PR1) - Mike Ryan. Adjust the alpha level of your selected color while similar colors are adjusted as well. Has known bugs. Alternative: Tanel's Color to Alpha
Color to Alpha v2.2 - Tanel. Extracts a color range from image, by leaving pixels of selected color opaque and making the rest transparent. Only alpha values are altered, color remains intact. Part of Tanel's Plugin Pack.
Color Trimming - Mike Ryan. Used for color correction in photographs when too much of a particular color is present. Removes a defined range of a particular color allowing for more vibrant colors to be displayed. Part of Mike Ryan's Plugins
Color Zoom Blur - MadJik. Based on the zoom blur effect, but you are able to handle the color channels separately. Magical Plugins Megapack.
Colour Chop - n d. Similar to other colour cutting effects, but this creates a smoother transition from transparent <-> opaque
Colour Distort - Anaco. Subtracts the red blue green by x+y or x-y or x*y depending on the option you select and then divides it by the amount you specified.
Colourblind Simulation - n d. Ensure your image is legible for colour blind.
Combined Photo Adjustments - BoltBait. Combines a number of photo adjustments (like Noise Reduction, Brightness/Contrast, Hue, Saturation) within one handy to use effect.
Composition tool - Red ochre. Tool to help with cropping/rotating of photos (i.e. composition grids to help line up important features). Also has configurable aspect ratio with a range of preset sizes. Part of Red Ochre's Plugin Pack
Conditional Effects - Cookies. Gives you the ability to run 6 effects, in the order, and only affect the colors matching the set conditions.
Conditional Hue/Saturation - evanolds. Adjust hue and saturation by setting range and conditions. Evan's Effects v1.1.
ConditionalPen 1.1 - Simon Brown. Provides a brush that will only function when a pixel is within the given min/max threshold. Found in Simon Brown's Legacy Plugin Pack.
Contour - Red ochre. Splits an image into bands based on the tone value, with a variety of colouring options. Part of Red Ochre's Plugin Pack
Convolution Effect - SeriousSam. Modifies each pixel by comparison to neighboring pixels. 3x3 matrix is fully configurable.
Create Image-Map - Simon Brown. Provides an interface for constructing an HTML image map. Found in Simon Brown's Legacy Plugin Pack.
Cross-Processing - Ed Harvey. Classic film effect; Increased contrast, weird color shifts & tints. Part of Ed Harvey Effectsv3.5. DLL contains numerous effects.
Curly Lines - davidf. Render all kinds of curly (and straight) lines. Intimidating UI is well explained in companion PDF.
Curtis' Plugin Pack - Curtis. Effects: Tile image, Jumble, Selective palette, Equations, Effects Lab, Fern Fractal, Channel Mask, Displacement Map, Blur Map, Dots, Rounded Rectangle. To install, extract and place all three DLL files in your Paint.Net/Effects/ folder.
Curves+ v2.10 - pyrochild. A more powerful version of the Curves adjustment that comes with Paint.NET. Pyrochild's Plugins
Custom Brushes 5.1.5 - Simon Brown. Obsolete. Use CustomBrushesMini.
CustomBrushesMini 1.0 RC3 - Simon Brown. Superseded. Use CustomBrushesMini.
CustomBrushesMini v1.0 - Simon Brown. Draw with customized brushes. Replaces previous incarnations of Custom Brushes. Simon Brown's Plugin Pack.
CustomFrame 1.5 - Simon Brown. Add a pre-created frame to your image.
CustomTexture v1.0 - Simon Brown. Apply a custom texture to an image while maintaining the saturation. Simon Brown's Plugin Pack.
Cut Color - xmario. Cuts one color & shades of it from your image. Choose color to leave & pixels of a different color are changed to transparent (or black and white).
Cutout Effect - Illnab1024. Broken. Use the newer version in Illnab1024's Plugins.
Cutout Effect - Illnab1024. Broken. Part of Illnab1024's Plugins
Cyanotype - KrisVDM. Recolor an image to white + cyan. Part of Kris VDM's Plugin Pack.
Found the Plugin Index useful? Show YOUR support!
Plugin Index - Epub Edition - Scott Stringer.zip 143.17K
336 downloads
Plugin Index - Kindle Edition - Scott Stringer.zip 194.62K
156 downloads
Plugin Index - May 2013.pdf 189.99K
1370 downloads
