Plugin Index
I just moved to a new PC and this thread was absolutely awesome. It made tracking down those obscure plug-ins that I use all too often so easy. Sure I could've copied the files over, but many new versions have come out and it's kinda hard to keep track of them all. :)
Thanks dude.
Three updates and 10 new plugins this revision.
Note that I've not had time to update the entry for MadJik's plugin pack - due to the large number of plugins he has released this month. Will be fixed next month for sure ;)
I've not considered this before, so no there is no list specifically for filetypes.
If you want such a list I can generate one and post it here, or PM it to you.
Bear in mind that I'm not going to commit to updating such a list boltbait.tongue.pngboltbait.smile.png
The list of filetype plugins is up. Enjoy :)
This list is awesome, it needs a search function.
Btw: could you add http://forums.getpai...80entry332380
Updates are done around the first of each month. I have the PNG preprocessor and three other plugins flagged for inclusion at this stage ;)
Search: CTRL + F in most browsers works well, but you'll have to unhide the hidden sections before you run it.
New update for September. Seven new plugins have been added to the list.
As there are no new Filetypes, the list dated 12 August remains current.
  • 5 weeks later...
October update: Five new plugins and three plugin packs updated.
Note that all of @Simon Brown's legacy plugin pack has been flagged as 'No longer Supported':
AlphaMaskBrush
Bullet
Channels
ConditionalPen
CreateImageMap
DesktopBackgroundPreview
FilmNoir
FindEdges
Fire
Flags
JPEGEffect
PDNWatermark
PixelatedFrame
StockLibrary
SubtleEffect
Texture
Transitional Brush
AVIImport
SVGImport
The latter two plugins are filetypes and have been removed from the Filetypes list.
