How to use CustomBrushesMini
Gansqa
I gave up on the mini brush or any brush in PDN a long time ago. Brusheezy is not free and is difficult to navagate. The brushes I did manage to download and install when I went to use them I just could not figure out how a picture could be used as a brush,not the type of brush we are accustomed to. Although all the info on here makes it sound easy it is not and in the end not worth it in my opinion.
Don't give up so easily, skullbonz! Just recently, null54 made a filetype plugin that allows you to open photoshop brush images to be saved as .png files. That means you can simply go to Deviantart.com and download photoshop brush packs and use them in paint.net!
I do agree with you, though...the custombrushesmini plugin is really more of a "custom stamps" plugin. All I really use it for is quick mass-pasting of a single colored image.
But really. It is a whole lot easier than you would think.
1. Install plugin
2. Download/make brushes
3. Move brushes to folder
4. Use brushes
I really never gave up pdnnoob,just found ways around it. What I do miss from time to time is a spray paint tool but again there are ways around it.  ;)
  • 4 months later...
No there isn't.  The default tools are hard coded and unavailable for modification beyond their Tool Bar options.
  • 1 year later...
  • toe_head2001 changed the title to How to use CustomBrushesMini
