xod Posted July 9, 2019 Share Posted July 9, 2019 This error sometimes appears in the Show Error List panel.Errors do not occur all at once but one at a time as I open the .cs files.I may have some broken registers because I was infected with malware Mail.Ru. Thank you for your patience. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted July 9, 2019 Share Posted July 9, 2019 Sounds like something is interfering with your %temp% directory. If you aren't deleting those .DLL files in %temp%, then maybe your malware is deleting them. Or maybe your anti-malware software deletes them. I don't know. If that's the case, there's really nothing we can fix up in CodeLab to resolve your issue. Under normal circumstances, restarting Paint.NET will fix that error. Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
BobBlack Posted July 12, 2019 Share Posted July 12, 2019 Hi, in some reason , I'd want to download the codelab 4.0 version , Where can I find it ? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted July 12, 2019 Share Posted July 12, 2019 On 7/12/2019 at 3:58 PM, BobBlack said: Hi, in some reason , I'd want to download the codelab 4.0 version , Where can I find it ? CodeLab releases can be found here: https://github.com/BoltBait/CodeLab/releases Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
BobBlack Posted July 13, 2019 Share Posted July 13, 2019 On 7/12/2019 at 4:30 PM, BoltBait said: CodeLab releases can be found here: https://github.com/BoltBait/CodeLab/releases Thank you, I posted after do the search , I will try CodeLabInstaller305 for some luck. Quote Link to comment Share on other sites More sharing options...
xod Posted July 13, 2019 Share Posted July 13, 2019 This error occurs after I build a CodeLab plugin. 1. Choose the icon you want to appear in your plugin(16x16px). 2. Build the plugin 3. Close CodeLab 4. Open the icon and try to save it The icon it can only be saved as SaveAs under another name. Maybe something is broken in my OS? Anyone else can reproduce this error? Otherwise, everything works correctly. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted July 13, 2019 Share Posted July 13, 2019 CodeLab is probably holding the file open. I'll look into this one. EDIT: This will be fixed in the next release of CodeLab. 1 Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
BoltBait Posted July 13, 2019 Share Posted July 13, 2019 CodeLab 4.3 Released This is only for Paint.NET 4.2+! Big update today... Changes: ▪ Redesign File > New screen (BoltBait) ▪ HighDPI icons (toe_head2001) ▪ Add Format, Find, and Replace toolbar buttons (toe_head2001) ▪ Add snippet for Try/Catch (toe_head2001) ▪ Bug fixes to Quick Format (toe_head2001) ▪ Added flexible, themeable, customizable message boxes (BoltBait) ▪ Allow arbitrary names for UI fields, also removed UI Elements Renumber command (toe_head2001) ▪ Added light bulb renaming of fields defined in user's script (toe_head2001) ▪ Redesigned UI Builder screen (BoltBait) ▪ Added support for the new Uri Control (BoltBait) ▪ Update clipboard template code (null54) ▪ Improvements to code completion (toe_head2001) ▪ Intelligent Assistance improvements for Extension Methods, Generic Methods, and Generic Types (toe_head2001) ▪ Fixed build screen to not hold the icon file open (BoltBait) ▪ Various code cleanups and improvements (toe_head2001 and BoltBait) Grab the CodeLab DLL here: http://www.boltbait.com/pdn/CodeLab/ Screenshots: File > New screen redesign: New high resolution icons: Themeable message boxes that can have custom buttons: I was tired of MessageBox being displayed with white backgrounds when running the dark theme. So, I found FlexibleMessageBox source code and fixed it up for use in Paint.NET... added a few features, like customizable buttons and themes... fixed a few bugs. I think they look awesome. UI Designer redesign and new Web Link control: Notice that the Variables can be specified--you no longer need to use Amount1, Amount2, ... You can, if you want, but it is not necessary as the defaults are the same as before. We also have the new Web Link control type. This gives IndirectUI the ability to have a clickable link that opens a browser to a specified URL. If a Display Name is specified it is linked. If no Display Name is specified, the URL is displayed and linked. Rename Variables: Select the variable you wish to rename and start typing... a light bulb will appear. Click on that and you can rename your variable everywhere in the script where it appears. New Clipboard Code: Paint.NET v4.2 has a new helper class for accessing the clipboard. CodeLab has been updated to take advantage of this new service. On the File > New screen, when selecting "Clipboard" in the sample code drop-down box, the following code is now generated: // Name: // Submenu: // Author: // Title: // Version: // Desc: // Keywords: // URL: // Help: #region UICode #endregion private Surface clipboardSurface = null; private bool readClipboard = false; protected override void OnDispose(bool disposing) { if (disposing) { // Release any surfaces or effects you've created. if (clipboardSurface != null) clipboardSurface.Dispose(); clipboardSurface = null; } base.OnDispose(disposing); } void PreRender(Surface dst, Surface src) { if (!readClipboard) { readClipboard = true; clipboardSurface = Services.GetService<IClipboardService>().TryGetSurface(); } } // Here is the main render loop function void Render(Surface dst, Surface src, Rectangle rect) { for (int y = rect.Top; y < rect.Bottom; y++) { if (IsCancelRequested) return; for (int x = rect.Left; x < rect.Right; x++) { ColorBgra CurrentPixel = src[x,y]; if (IsCancelRequested) return; // If clipboard has an image, get it if (clipboardSurface != null) { CurrentPixel = clipboardSurface.GetBilinearSampleWrapped(x, y); } // TODO: Add additional pixel processing code here dst[x,y] = CurrentPixel; } } } This clipboard code is way faster than the older code CodeLab used to generate. Notice that the try/catch blocks are gone. That speeds up our code a lot. 2 3 Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
ReMake Posted July 14, 2019 Share Posted July 14, 2019 CodeLab 4.3 in Russian You can find the new version of CodeLab in Russian here. Вы можете найти новую версию CodeLab на русском языке здесь. Quote Link to comment Share on other sites More sharing options...
xod Posted July 18, 2019 Share Posted July 18, 2019 (edited) CodeLab 4.3 does not retain CheckBox control checked / unchecked status ? Reverted to v4.2 which works correctly. Edited July 19, 2019 by xod Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted July 18, 2019 Share Posted July 18, 2019 1 hour ago, xod said: CodeLab 4.3 does not retain CheckBox control checked / unchecked status ? Indeed. Fixing for next release. 1 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
xod Posted July 18, 2019 Share Posted July 18, 2019 What a shame. I liked the new features of renaming the AmountX variables. I wonder if it's possible to do the same thing with the RadioButtonList or DropDownList options so that using 'switch variableX' we can use 'case variableX.name:' instead of 'case 0 :, case 1:' etc. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted July 18, 2019 Share Posted July 18, 2019 28 minutes ago, xod said: I wonder if it's possible to do the same thing with the RadioButtonList or DropDownList options so that using 'switch variableX' we can use 'case variableX.name:' Possibly, but it would probably be a bit clumsy. But using numbers is clumsy too... I do have idea on how to do it though, and it would require you to define an enum for each RadioButtonList or DropDownList. (right now, CodeLab generates these enums for you) In Visual Studio it's much easier to use enums with RadioButtonList and DropDownList. In CodeLab, the values are just cast to numbers, because that's the easiest thing to do. (Because CodeLab generates the enums for you "behind the scenes", you have no way of knowing what they're named when you're working in the CodeLab editor.) Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
BoltBait Posted July 18, 2019 Share Posted July 18, 2019 9 minutes ago, toe_head2001 said: ...it would probably be a bit clumsy. Starting from the beginning (the very first build of CodeLab that I worked on), I have tried to avoid "clumsy" at all costs. I haven't always been successful, of course, but that's always been my goal--that, and ease of use. 1 Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
toe_head2001 Posted July 18, 2019 Share Posted July 18, 2019 Here's one possible solution, and it would retain the easier way too. #region UICode RadioButtonControl<Positions> position = 0; // [1] Image Position|On the Left|In the Center|On the Right #endregion enum Positions { Left, Center, Right } void Render(Surface dst, Surface src, Rectangle rect) { switch (position) { case Positions.Left: // Code Here break; case Positions.Center: // Code Here break; case Positions.Right: // Code Here break; } dst.CopySurface(src, rect.Location, rect); } If RadioButtonControl<TEnum> is too clumsy or confusing, a person could just continue using RadioButtonControl. 1 2 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
xod Posted July 18, 2019 Share Posted July 18, 2019 Ok, I got it. Thank you for the answers. I really appreciate it your special work for the development of this mini-Visual Studio. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted August 29, 2019 Share Posted August 29, 2019 I've been using Snippets more and more in Visual Studio. I wanted to add a bunch of them to CodeLab, but I don't think people want the same snippets that I do. So... I'm thinking CodeLab could benefit from a Snippet Manager where you can add your own custom snippets. For example, say you're working on your script, and you realize you need to retrieve the current palette. You can have a snippet called curPal (or whatever), and it would expand into: IReadOnlyList<ColorBgra> CurrentColors = Services.GetService<IPalettesService>().CurrentPalette; As it stands, you have to open the Templates (File -> New), and generate a whole new file. Then you have to copy and paste the relevant line of code from one tab to another. Unless of course you have that palette code memorized, and are willing to type it out. Who wants this? Or is it just me? 1 3 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
ReMake Posted August 29, 2019 Share Posted August 29, 2019 I think this feature will be useful, even for a few encoders. Most likely, this feature will help us to quickly master Snippets in Visual Studio. I want this. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 30, 2019 Share Posted August 30, 2019 Me! I want this please. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted August 30, 2019 Share Posted August 30, 2019 On 7/13/2019 at 5:57 PM, BoltBait said: Rename Variables: Select the variable you wish to rename and start typing... a light bulb will appear. Click on that and you can rename your variable everywhere in the script where it appears. Fantastic! That was the one thing that drove me crazy when I was reading the source code. I was confused as heck as to figuring out what Amount1, Amount2, etc, meant without a well described variable name. This is a great change to CodeLab. Quote Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 31, 2019 Share Posted October 31, 2019 Visual Studio has a handy feature where it suggests some generic names for variables. Now CodeLab will have the same feature. 3 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 8, 2019 Share Posted November 8, 2019 Here's an idea for a potentially annoying feature. - It would only show when there's no saved Effect Token. Meaning you haven't opened CodeLab and clicked OK. - There would be an option to completely disable it. See the CheckBox in the lower-right. - It could speed up the time it takes to open CodeLab, since a few things would be deferred (the Scintilla control, the Intelligent Assistive initialization, and code compiling). Although, the next version of CodeLab will already have some improvements to startup time, so the impact may not be grand. - It would (hopefully) make CodeLab easier to use for first-time users. So, a few questions for everyone using Codelab: If this feature was implemented, would you would disable it? How often do you use the default code when CodeLab opens? or do you usually Open an existing file or create a New file? Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
ReMake Posted November 9, 2019 Share Posted November 9, 2019 I like this idea. 5 hours ago, toe_head2001 said: If this feature was implemented, would you would disable it? Probably Yes, because that will accumulate the experience in coding. But in any case, it should be possible to re-enable this feature. 5 hours ago, toe_head2001 said: How often do you use the default code when CodeLab opens? or do you usually Open an existing file or create a New file? I use all three methods equally. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 9, 2019 Share Posted November 9, 2019 5 hours ago, toe_head2001 said: If this feature was implemented, would you would disable it? Nope. I like the hotlist of recent files - VS has something similar and I'll use it in 80% of cases. 5 hours ago, toe_head2001 said: How often do you use the default code when CodeLab opens? Very rarely these days. I used it a lot in the past. 5 hours ago, toe_head2001 said: or do you usually Open an existing file or create a New file? I'm more often opening an existing file. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
BoltBait Posted November 23, 2019 Share Posted November 23, 2019 CodeLab 4.4 Released This is only for Paint.NET 4.2+! Small update today... (This was all @toe_head2001 as I've been super busy with a new job.) Changes: ▪ Added a Snippet Manager ▪ Added suggested names to autocomplete ▪ Added keyboard shortcut ( Ctrl+] ) to go to matching brace ▪ Added option to specify an Enum on RadioButtonControl and ListBoxControlControl ▪ Added argument constraints to tooltips for generic methods and classes ▪ Improved method overload detection: detection of method parameter modifiers (out, ref, params); detection of inferred generic methods ▪ Lots of bug fixes, refactorings, and optimizations Grab the CodeLab DLL here: https://www.boltbait.com/pdn/CodeLab/ 4 Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
