11 minutes ago, NSD said:
Thank you for giving us this great tool for free!
Donations help keep developers motivated. :D
Donate to BoltBait
Donate to toe_head2001
14 minutes ago, NSD said:
Another useful thing would be, in my opinion, the insertion of a space after a comma when formatting the code.
Yes, proper spacing around commas and operators would be ideal.  I've been meaning to do that, but it's tricky, with lots of corner cases.
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
@NSD, I've fixed a few of the scaling issues. However, I don't experience the issue with the Labels overlapping other UI elements.
Which version of Windows 10 are you using? I'm using Windows 10 2004.  I'm not sure if that matters...
@BoltBait, do you see the issue with the overlapping Labels?
No, I do not.  The dialog boxes all work fine for me at all scaling factors.
Maybe he has some other setting that is affecting the layout.
It looks to me like @NSD has changed his system font to Verdana and I'm not going to code around that. He can just fix his system back to normal.
18 minutes ago, anon3 said:
Open Effects/Advanced/CodeLab..., File/Open..., selecting a .cs source I previously saved from the plugin, I explicitly set C# Code Files (*.CS), press Open and it opens it as a text file, so you cannot build, design, preview and so on. My .cs files are not associated with any program.
That means your .CS file was not recognized as an Effect or a FileType.
If that is a mistake, please share your .CS file so we can identify where the issue is coming from.
20 minutes ago, anon3 said:
I mean a tab with any spaces width.
You mean an arbitrary (user-defined) amount of spaces?
21 minutes ago, anon3 said:
Because to use the plugin you need to unzip it and move it to the plugin directory.
We might add an option for this in the future. No guarantees.
24 minutes ago, anon3 said:
I write the code in a text editor, because the build in is not configurable and flexible even that the autocomplete might be useful.
What other build configuration do you need?
Nope. Not doing this.
If you want to test your plugin, just use the live preview right inside of CodeLab.
8 hours ago, toe_head2001 said:
Absolutely not. That would defeat the purpose of using CodeLab. If you want the full source code, you should be using Visual Studio.
I do not have Visual Studio, I use simple command in a .bat file that is enough.
"that is enough"? I don't think so, otherwise you wouldn't be complaining.  Look, Visual Studio is free; download it.  We give you full access to the entire code CodeLab generates by the button on the build screen that makes your script into a VS project; use it.
23 minutes ago, anon3 said:
I didn't know about the new rules.
Not really a new rule. There's a technical reason behind it.
Because we added support for FileType projects, we needed a way to differentiate different .CS files (is it a Effect or a FileType?).  The easiest way was to search for the standard Render method.
If CodeLab uses Scintilla then it would be fairly easy to use tab, set tab size and ident size.
Correct; very easy indeed.
I was talking about the build in editor.
That's what I was referring to as well.
27 minutes ago, anon3 said:
under Element panel it says "Catagory" instead of "Category".
Fun typo. :lol:  We'll fix that.
29 minutes ago, anon3 said:
aren't really worth the hassle of such an environment.
I fail to see the hassle of Visual Studio. It has lots of tooling for many languages and project types.
2 hours ago, anon3 said:
you seem hostile
Deceptive impression of a newbies.
If you had the opportunity to compare the source code of CodeLab 1.8 (not Codelab 1.8 f) with the source code of Codelab 5.0, you would see the Titanic work done by @BoltBait and @toe_head2001 to provide encoders with huge opportunities to create effects.
I don't want to sound like a visionary, but I foresee further development of CodeLab to make it easier to create Shapes, and even use plain text to create Effects and Shapes.
Simple my two cents.
To be fair, it is impossible or difficult to get some FOSS projects to work with visual studio. I heard that there's quirks with compiling, but can't confirm. There's other solutions if anon does not want to use Visual Studio. I actually code with KDE Kate editor myself. Not completely great with generic language like c++, but very easy with scripting languages.
Edited by Reptillian
G'MIC Filter Developer
If there are issues, they're with MSVC or MSBuild.  You aren't force to use those compilers (or build system) if you use Visual Studio though.  In fact, you can use the Terminal that's built into Visual Studio to execute a GCC compilation.
My apologies. The display errors are wholly mine.
I forgot that I changed the font size with the System Font Size Changer application.
Going back to the default settings, everything is fine.
Once again, my apologies and thank you for this wonderful tool.
21 hours ago, toe_head2001 said:
JetBrains Mono
Anyone using these?
JetBrains Mono is really pretty.
If we can convince our editor to display Ligatures, we should add all three to our supported fonts list.
But, honestly, I'm not a big fan of Ligatures as they are not what you actually type... can enabling them be an option or is it just by font?
Yeah. I might have a look at jetbrains. I found it easier to read in side-by-side comparisons.
I'm a big fan of Verdana for the same reason I like JetBrains... the increased lower case 'x' height.
Scintilla has an option to use DirectWrite, which supports Ligatures by default.
However, I'm not sure how to switch off Ligatures when using DirectWrite.   Well, there is a 'font options' setting in DirectWrite to do disable them, but Scintilla doesn't have some easy abstraction for it.
So, I guess if you didn't want Ligatures, you have to switch back to GDI text.
CodeLab 5.1 Released
This is only for Paint.NET 4.2+!
Small (but important) update today...
Changes:
▪ Fix user selected blend op in File New Templates (BoltBait)
▪ Add user selected color to File New Templates (BoltBait)
▪ Fix the fill function with primary/secondary colors (BoltBait)
▪ Add separate word wrap option to TXT documents (toe_head2001)
▪ Add auto complete brace pairs (toe_head2001)
▪ Fix bug in Autocomplete (toe_head2001)
▪ Added 3 new fonts to the View Font menu (toe_head2001)
▪ Cascadia Code, Fira Code, and JetBrains Mono support Programming Ligatures in CodeLab (toe_head2001)
▪ Added help to the View Font menu with links to fonts (BoltBait)
Grab the CodeLab DLL here:
https://www.boltbait.com/pdn/CodeLab/
Screenshots:
New fonts added to the View Font menu:
A new help screen in the View > Fonts menu:
The bug in Autocomplete that toe_head2001 fixed was quite annoying.  Sometimes when typing code, autocomplete wouldn't offer local variables in the list which caused you to have to Esc the list to continue typing.  In previous releases he had put some workarounds in to deal with the issue, but they were less than perfect. For this release he took out the workarounds and fixed it properly. Yea!
  • BoltBait changed the title to CodeLab v5.1 (for advanced users) Released January 19, 2020
Thank you for your update.
BTW, in my environment "Pan Slider" control cannot be added.
After adding "Pan Slider", UI cannot be previewed or executed.
That problem happened with CodeLab v5.0 and v5.1 both.
And, in my home and in my office, same error messages were shown.
I'm using Windows 10 Pro(My office and my home both) x64 1909(18363.592).
.Net Framework 4.8 was installed with Windows update.
Paint.net version is 4.2.8.
(All of them are up-to-date)
Could you give me any hint to fix them?
I wish you had report the issue when you first encountered it, instead of waiting until after v5.1 was released.
I'll bisect the revision history, and find out how this broke.  :(
Thank you for reporting it though.
If you create a pan slider:
It creates it like this:
PanSliderControl Amount4 = Pair.Create(0); // Slider 1 Description
Because of the default.
If you then...
press Ctrl+I to go into the interface designer again and press Enter, it will update the script and it will work fine.
EDIT: I have fixed this for the next release.  In the mean time, just do this :LayersMoveLayerUp:
I've installed 4.3 - 5.0 - 5.1
I think I didn't meet same error before.
BTW, in CodeLab 5.1, after insert PanSliderControl, following code is generated.
PanSliderControl Amount4 = Pair.Create(0); // Slider 3 Description
As you know, that code should be fixed to following:
PanSliderControl Amount4 = Pair.Create(0.000, 0.000); // Slider 3 Description
And, after fixing it, that code works!
