Water Reflection (ymd:100725)
yea sorry if im posting a lot but im having a few problems. i do everything correct but it neverr seems to show up. most of the other plugins ive tried have worked but this seems to be like the other few. i think it may just be me but ive tried around 5 times now. :cry:
psn id: R3V-fiR3
Link to post
It should show up in Effects > Distortions.
Are you positive that you have the newest version of Paint.NET? That's the only reason I can think of that this plugin doesn't appear.
Link to post
im just a kid so i have no idea wat a thread is... and yes im downloading the dll but it dusnt show up
I'm having an issue with this as well. I'm using 3.22 Beta and it won't load into PdN.
File: C:\Program Files\Paint.NET\Effects\WaterReflection.dll
     Effect Name: PaintDotNet.Pair`2
     Full error message: System.TypeLoadException: Could not load type 'PaintDotNet.Pair`2' from assembly 'PaintDotNet.Base, Version=3.8.2708.22782, Culture=neutral, PublicKeyToken=null'.
I still have the previous "water.dll" installed, but I would like to use the new version.
R3VENGE:
In PdN, go to File>Plugin Load Errors and see if anything is there.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former"
[ dA Paint.NET Chat :: Yata on dA ]
Link to post
was it a link to bolt baits site cos thats wat i use and its worked on most things. its jus that some of the things dont show up some times so i cant use them :( ive only got half of madjiks things to work. most others seem to work though... strange?
psn id: R3V-fiR3
Link to post
@R3VENGE :
Why do you start a new topic as you already rise the (your) problem of Water reflection in the plugins' topic and by PM?
viewtopic.php?f=10&t=21980
Why the title says problemS with effectS?
Could you explain the about otherS!
1.This period of year doesn't give me a lot of free time for PDN, be patient...
2.Could you ask someone around you (friends/family/neighbour/...) to help you to install the DLL?
3.See tatinha77 viewtopic.php?p=129291#p129291 first post and no problem with this plugin!
4.Could you provide a screenshoot of your Paint with the Effect/Distort menu open?
5.This is an old version DLL that works with PDN v3.22beta as well. Test it! http://jcljay.free.fr/pdn/Water.zip
My screenshot:
Link to post
i think i know why it hasnt worked now. its due to the point of a bad link. you see i clicked on a link to download 3.2 and thats what i was supposed to get but it seems it has actually got me to download 3.1. i got an upgrade for my computer so 3,2 would work and it turns out i didnt even have it. the link i used was the very top one thats under beta.*i wanted to have a look at it* but it also had a link for 3.2 i used that and i now seem to have 3.1. this mistake has been due to a misunderstanding. i am sorry if i have bugged you a lot. could someone actually check that link out though because of my problems with it?? sorry for bugging you :)
psn id: R3V-fiR3
Link to post
The link works fine.
Link to post
What version of Paint.NET are you using?
Link to post
