null54
G'MIC (9-07-2019)
Great Work null54!
It works just fine and up to the 4096 pixels square resolution for my project to Render a 3D Image Object Cube.
Thank you!
Share this post
Link to post
Thanks null54 for the 64-bit version. Much better...
Some of my favorite filters include Brushify and DreamSmooth.
Source image :
Edited by dipstick
Share this post
Link to post
Just a heads up, I use GIMP as well as PDN, and G'MIC is updated quite often, so be prepared to have the updated versions handy with PDN and its updated versions. :)
Edited by mackenzieh
Share this post
Link to post
Is there a way to edit PDN .gmic file? I mean, the PDN .gmic has to be somewhere. Without access to it, you can't code new filters by editing .gmic file.
Edited by Reptillian
Share this post
Link to post
Thanks for the heads up. 😃
I subscribed to the G'MIC-Qt release notifications on GitHub.
I will also open an issue on GitHub to see if the G'MIC-Qt maintainers want to integrate the Paint.NET host code.
According to this issue on GitHub G'MIC stores its filters in %appdata%\gmic.
Share this post
Link to post
You're welcome! :)
Share this post
Link to post
Oh I see it now. It just that I use g'mic in different softwares, and had thought it would put to another place. And I was using a different version on PDN. So, in that case, gmic that are on the same versions in different software would share them.
Share this post
Link to post
The GIMP, Krita and Paint.NET plugins are all based on G'MIC-Qt.
It was much easier to add a host interface for Paint.NET to G'MIC-Qt than it would have been to use libgmic.
Share this post
Link to post
What a wonderful program. I looked at all areas and clicked on them. Just great and it works superb.
I'm setting here the result of a picture - around and at 1880 , which I used in my homepage. It's nice.
Thanks for the great plugin.
Share this post
Link to post
Hi Folks
I must say this Plug-in (G-Mic) is incredible! I have been experimenting with it all afternoon, the special effects are better than Alien Skin or Xenofex.
Kindest regards
Roger the Dodger 😊
Share this post
Link to post
Could someone please tell me what style the Painting filter (under the Artistic submenu) renders? Would it be some form of modern abstract art, or maybe pop art?
Share this post
Link to post
There is a problem with the interface between this plugin and PDN. It won't create new layers. To make 3-D animations, you must tick the option Make New Files, then import the files as layers into PDN. It's an added couple of steps, but it works.
Share this post
Link to post
That is a limitation of the Paint.NET plugin API.
Effect plugins cannot create new layers or access other layers in the document.
I do not see how this would work.
The plugin uses a randomly generated output file name that is automatically deleted, so it would be somewhat difficult to copy the final image in order to import it into a new Paint.NET document.
Share this post
Link to post
@null54 Look for the "Output as files" tick box and change output mode to New Image.
Sequence/3D Elevation (Animated).
Depending on the size and qty of frames the PNG files can take about ten minutes to generate (1024X1024X30).
Edited by AndrewDavid
strikeout
Share this post
Link to post
