RAW FileType (2023-01-19)
null54
This is a LibRaw-based camera raw filetype  plugin for Paint.NET.
Compatibility: Paint.NET 5.0+
To install place RawFileType.dll, RawFileTypeOptions.txt and the LibRaw folder in the Paint.NET FileTypes folder (usually C:\Program Files\Paint.NET\FileTypes)
The decoding options can be changed by editing RawFileTypeOptions.txt.
The list of options for DCRaw is available here , dcraw_emu supports all DCRaw options except -D, -d, -P, -K, -i or -e.
The list of additional options supported by dcraw_emu can be found here.
By default the plugin loads the RAW images without metadata, to include the image metadata add -T to the command line in RawFileTypeOptions.txt.
Download:
RawFileType.zip
Source Code
https://github.com/0xC0000054/pdn-cameraraw
  • Upvote 5
Hi!
First of all, thank you very much for making this plugin. It helps me A LOT.
I do have one issue though. When the images get imported through dcraw, they seem to be processed with some kind of auto-leveling command. Would it be possible to import them as TIFFs or at least without the automatic adjustments? I do quite a bit of my photography at night and the images get brightened during import, and are, while not completely useless, very hard to work with.
This plugin tells DCRaw to use the camera histogram for color correction when importing raw images.
Ideally Paint.NET would allow FileTypes to show a dialog when loading so that DCRaw could be configured for each image.
As that is not supported I could change the plugin to read the DCRaw options from some type of configuration file.
Thanks for the explanation. I've tried messing about with Codelab but I'm out of my depth here.
I can provide samples if necessary. I know from GIMP that dcraw applies distortion and CA corrections by default (I haven't checked if this is the case here as well, but vignetting correction is definitely applied).
Edited by Giklab
Hello Great plugin but is there a way that you can not have the colour correction active and have to true Raw image loads
Not any that are user friendly. :(
I could put the DCRaw settings into a configuration file in the FileTypes folder, but you would have to load the image again to test the new settings (and modifying the configuration file would require Administrator privileges).
+1 ^
Barring a UI, I don't think it gets any more user-friendly (I mean, we'll just have to string together the arguments we want, right?). And TBH, I never really liked to tweak *everything* before importing the file, like in GIMP and I guess Photoshop. I mean, at that point I might as well be using Rawtherapee.
Added a configuration file to allow the decoding options to be changed.
File version updated to 1.1.0.0.
I keep getting this error:
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Bitmap..ctor(Stream stream)
   at RawFileType.RawFileType.GetRAWImage(String file)
   at RawFileType.RawFileType.OnLoad(Stream input)
   at PaintDotNet.FileType.Load(Stream input) in d:\src\pdn\paintdotnet\src\Data\FileType.cs:line 477
   at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in d:\src\pdn\paintdotnet\src\Base\Functional\Func.cs:line 158
When I try to import my .raw, is anyone else getting this/how can I fix this?
Is it a problem with the image or my installation?
It appears that the TIFF file that DCRaw writes is not supported by GDI+.
Could you upload a RAW file that causes this and PM me a link?
I have  the plugin set to TIFF and I'm not seeing any problems. Are you sure you didn't simply misspell a command?
In any case, here are the settings that work for me: -w -6 -W -T
The plugin always uses TIFF, the -c and -T parameters are appended after the user specified options.
It appears that some generated TIFF files are not supported by GDI+. :(
I considered switching the plugin to use PPM which would eliminate the TIFF loading issues, but the resulting image would not include any metadata.
Right, I can delete the -T then. It would also seem that PDN doesn't support 16bit tiffs, so I can remove that as well lol.
That is really unfortunate... I don't know enough to suggest anything else than a +1 to your PPM idea (2 versions maybe?). Could that be a bug in dcraw, or a currently unsupported camera? I recall having a similar issue a few years back, when my Rawtherapee saved unreadable tiffs - that was corrected in an update that included an updated dcraw.
... It would also seem that PDN doesn't support 16bit tiffs, so I can remove that as well lol.
Correct, Paint.NET only supports 8-bit images.
It could be a bug in dcraw or it could be a bug in GDI+, without the RAW file there is no way for me to check.
Changed the default output format to PNM to fix the GDI+ crashes with TIFF.
File version updated to 1.2.0.0.
  • 9 months later...
Updated to the latest 32-bit version of DCRaw and added a number of additional file extensions.
File version updated to 1.2.1.0.
  • 6 months later...
How do I install this? When I unzipped the file in the FileTypes folder of Paint.NET saving does not give me the option to save as .raw
This plugin only supports loading camera RAW images, it does not allow you to save any raw formats.
  • 3 weeks later...
Perfect, found the older raw-plugin first and it couldn't read the CR2's from my Canon 100D/SL1 correctly (but could read the files from the 400D/XTi).
This one reads both perfectly, thanks.
Hey there, This is the second time for me to try to open raw (cr2 from a canon 5d III) files. It has again cost me a lot of time trying and reading. Incredible what I don't know about digital photography!
I managed to open the raw files with this above posted plugin (thanks!).
But the photos in pdn are much darker than the ones shown on the canon software or in FastStone Image viewer or the jpegs. I did not change anythinf in the camera.
Have you an idea how I could solve that? Is there a way to load the camera's colour profile to pdn?
9 x 13 cm. (4).pdf
Thanks a lot!
PS: It thake looong time to open the photos in pdn.
And now I see: It's not only darker but the raw file seems to contain more picture information in it -> the sky in the Image Viewer is white, in pdn it is blue as it was.
Which is the "right" one that I should use? (if I may ask this question)
cheers
You may need to change the DCRaw options, the list of options is available here.
Paint.NET does not support color management, but DCRaw can convert the image to sRGB.
I do not know.
