Sign in to follow this
MJW
Texture Merger
Dear Pixey! <3
Excellent work. My result. Is something wrong. I feel really stupid. Sorry for the late response. You are far too kind.
Thank you so much.
Edited by Seerose
Share this post
Link to post
Seerose, you have the wrong image in the clipboard. Instead of the black-and-white grid, you need to have the height map of the sphere with the grid added. I.e,
TextureMergerGridSphereMap_zpsmlpmaizc.p
(This is the height map produced in Part II of the tutorial.)
Share this post
Link to post
1 minute ago, MJW said:
Dear MJW! <3
Despite video I have done it wrong. Slowly I'm with the nerves at the end. :P
Share this post
Link to post
@MJW - I am working on a revised video and will show what you suggest, about clicking on another slider when adding the values.  I had figured that out, but didn't want to put it in the video in case it was confusing.
@Seerose - don't feel bad ............ I made the same mistake a few days ago and got the same result.  I had put the Texture Height Scale 255 in the wrong place :roll:
It is easy to make a mistake as this Plugin is very complex.  When making the video I got confused - at the time on the video of 9:30 - where I add 'Subtract' first and then change it to the correct setting of 'Canvas'.
Share this post
Link to post
Seerose, try it again, using the image I just posted. I think you will be successful.
As Pixey says, it's a very complex plugin, with many, many things to keep track of. Believe me, I still get confused by things not working how I expected them to work. (Usually it's because I forgot to change a control back to the default value after changing it in a previous step.)
Share this post
Link to post
Dear Pixey and Dear MJW!  <3 <3
I tried again. Look, it worked. From the heart a thousand thanks. :cake: :coffee:
Edited by Seerose
Image forget
  • Upvote 3
Share this post
Link to post
19 hours ago, Seerose said:
KISSKISS.gif Dear Pixey and Dear MJW!  <3 <3
Seerose, I am delighted you finally were able to make the sphere!
Good for you, looks great!!!     :mtdew:  :cake:     :)
Share this post
Link to post
Yay @Seerose - what a lovely result!  So glad you got it in the end :D.
Share this post
Link to post
Dear Pixey!  <3
Thanks for this great tutorial. :trophy:  Excellent guide! :cake:  :coffee:
Edited by Seerose
Share this post
Link to post
Oh MY =O ...... they are fabulous results.  Well done @Woodsy :D .
Share this post
Link to post
Thank you Lynxster4 and Pixie! Just playing around! The top one was a picture of a rug. The lower one was a picture of a glass window.
Share this post
Link to post
Dear @Woodsy!  <3
Your work is fabulous. :trophy:  Thank you very much.  :cake:  :coffee:
Sorry! I'm out of rep points, catch you tomorrow! B)
Edited by Seerose
Share this post
Link to post
MJW, is it possible for you to give us some settings in this plugin to make a round object look spherical. I've played around with it and I can't get the color right. Or even a tut that a layman can understand. I don't understand mapping displacement or merged height-map. I'm still learning!
Share this post
Link to post
I think it would probably help to start with the Texture Shader plugin. In terms of complexity, the Texture Merger is like the Texture Shader squared.
Nevertheless, I'll briefly explain mapping displacement and merged height maps.
A merged height map is a combination of two different height maps. There are a number of ways they can be combined. The most common is probably to add a texture, like a leather texture, to an object, such as a sphere. The goal is to produce a sphere that appears to be covered with leather, like a basketball. The Texture Merger is intended to allow textures to be combined.
Mapping Displacement is the way the object affects the image that's mapped onto it. I'll use Texture Shader examples. If you paint an image onto a sphere, the image bulges, which is what makes the sphere look round. That's what the Surface Offset mapping modes try to do. On the other hand, if a sphere reflects an image in front of it, the result will be very different. That's what the various Reflection mapping modes try to do. In each case, the image in the clipboard is distorted by the height map in the canvas. That distortion is what I call the mapping displacement.
Note: The default Mapping Mode for the Texture Merger is None, which is probably why the object didn't look round. The default mode for the Texture Shader is Surface Offset 1, so it will probably look round with the default settings. You also need to make sure the Texture Height is appropriate. If it's too small, the object will look flat.
Share this post
Link to post
Thanks but I still don't understand. I've always been one that learns from an example not by reading. Say you have a green oval, how would I turn it into a green egg without distorting the color? What settings on which texture plugin?
Share this post
Link to post
Okay, now I understand better.
The short answer is that that's not what the Texture Merger or Texture Shader do. You need to have a Height Map. For the egg, preferably a 24-bit map, which means that the R,G, and B channels are treated as a single number. The Texture Merger is intended to make it easier to produce height maps.
For an egg, I'd start with a sphere height map, like this:
You can use the Texture Merger to make it oval instead of round.
First, copy it to the clipboard
Run the Texture Merger.
Set the Merge Method to Clipboard (No Displacement).
Set the XY Proportion to 0.12.
Set the Merged Height Scale to 240. (Note: this only affects the shading, not the final height map.)
Enable Show Shading, and you will be able to see what the shaded height map looks like.
Now you can disable Show Shading and exit the Texture Merger and you'll have an egg height map.
If you want to shade the egg green, set the Primary Color to green and run the Texture Shader.
Set the Image to Primary Color. (Image is the image that's mapped onto the height map. It can be a fixed color, or from the clipboard.)
Set the Texture Height to 240.
Position the Directional Light to improve the results. (The default straight-on light direction is pretty boring!)
You can adjust the speculariy controls if you want to make the egg shinier.
If you want to make an Easter egg, you can put an pattern in the clipboard and set the Image to Clipboard.
Share this post
Link to post
Thank you MJW! I'll digest this info and play around with it some. I was not disabling the shading and exiting Texture Merger before. That's probably the reason for the color being distorted.
Congrats on your Galleria Nomination! If you had a gallery I would have mentioned it in there. The galleria is a well deserved place for your pocket watch!
Share this post
Link to post
@MJW ... you owe me some paracetamols ! :P  (... but then I can't use the microwave or washing machine either ...)
A powerful plugin, some interesting results  when playing around and what I find great for me, the finished textures on some settings are great for adding colour to
Share this post
Link to post
@MJW
Sorry for the double post but I wanted to ask a question ... how difficult would it be to add a Render Square Height map with the Sphere one ?
Failing that - the best way to get the same height map effect into different shapes ?  I've tried the textures in Effects >>> Textures but nothing seems to work the same ...  @ least for me :/
I'm having so much fun with this ... being a bit weird, but was even thinking about it in the shower ...
Getting to grips with the controls
Edited by welshblue
Share this post
Link to post
 @welshblue, I like answering questions about the height-map plugins, so ask away!
I'm not sure what you're asking for with the Render Square request. Do you want something that will render a cube with different rotations? I need to improve my plugin that renders sphere height maps, so I would certainly consider adding additional features, or perhaps creating a new plugin.
I'm currently working on a  new plugin that will render certain kinds of height maps. It should be quite useful, I think. I keep getting distracted by other things, but hope to finish it soon. There's one -- somewhat significant -- problem I'd like to solve first. Maybe I'll release a beta version of what I have now.
Right now, there's no universal solution to producing different height maps, so producing a specific one is rather ad hoc. The proportions of a height map can be modified by copying the map to clipboard, then running Texture Merger with the Height Merge Method set the Clipboard (No Displacement). Two height maps can be combined by setting the Height Merge Method to Maximum.  For example, if you have a height map of a long cylinder, like a tube, and a height map of a sphere, the sphere can be added to the end of the tube by using the Maximum Height Merge Method. It is often helpful when using this method to enable the rather obscure feature, Weight Clipboard Heights by Opacity. This allows the clipboard height to be offset (to move the clipboard object forward) without the heights in the transparent areas figuring into the maximum comparison. (Possibly this should be enabled by default.)
A trick I've used if I have a height-map that's almost the shape want, but not quite, is to distort it with a tool like Grid Warp. The problem is, this mis-interpolates the heights as if they were colors, so the resultant map is rough and ugly. Often, though, it can be smoothed using the Texture Smoother plugin. That's the idea I used to produce the apple shape for my OOTF apple entry.
Many of the Height maps I've used have been produced by making the profile I want, filling the outside of the profile with black and the inside with white, then blurring to round the edges. Very often, I blur a little (a pixel or two), copy the image to the clipboard, blur some more, then use BoltBait's Paste Alpha to make the region outside the object transparent. I then use Texture Smoother to smooth the height map. Different blurs produce different results. Two Motion Blurs and right angles to each other, can be useful.
Another trick is to start with a height-map shape with rounded edges, then Multiply it by a sphere (or ovoid sphere) in the clipboard.  That's the method used to make the heart example on the first page. The outside will fade to zero height, while the inside will be spherical.
If you have a specific shape you'd like to produce, describe it on this thread, and I'll try to come up with a method to produce it. We'd both probably learn some things.
Share this post
Link to post
