TR's Radial Extruder (May 11th, 2015)
I'm cleverly pasted in as an Alpha Mask :mrgreen:
Pixey, Remake: I am glad you like it.
It was not my idea, while playing with Tr's Radial Extruder plugin, this photo on the web, came to my mind.
TR: It reminds me of your Paste frame " Custom frame maker" plugin. I wonder if the alignment option (leading edge, center and trailing edge) could be added. Being able to change the rotation from clockwise to counterclockwise would be nice too.
Possible,I'm working on 2 other projects so it may not be right away
TRsSig.png?raw=1
A clever plugin. Perhaps it would be easier to use if instead of having a Width control it had a Repetitions control, since normally the user would want an integer number of repetitions. If it were a double slider, the perverse user could still get a non-integer result.
Also (and I realize this might not be easy to add), it might be useful to have a Reflect option that would reflect every other repetition so they'd match up at the seams.
Edited by MJW
Repetitions would be dependent on the image, Subdivisions is what your describing and that sounds like a good idea.
TRsSig.png?raw=1
This is another cool one TR. Not sure if it's me or the plugin but the small section on the left is near impossible to eliminate. Any tricks? Or a glitch?
