JRSwenson 0 Posted July 18, 2019 Share Posted July 18, 2019 Yes, I have Bullzip installed on both machines. As to upgrading to 2019 LTSC, that is an "if", since upgrades of this type are handled by my IT department. As to my other comment about version 0.8, is there anywhere here I can find it? I am curious to see if the older version would work on the Home Machine. If so, it would indicate to me that there is something within version 0.9 that is not liked by the Home Machine. Quote Link to post Share on other sites
JRSwenson 0 Posted July 20, 2019 Share Posted July 20, 2019 What other information do you need from me in order to get PrintIt working properly? I am currently using ThatOtherApp to print the current image in paint.net with MS Paint. However, this work-around will only work as long as MS Paint is an actual application rather than an Universal Windows App (which Microsoft keeps threatening to change). Also it seems a little strange to use a second image manipulation program to print out something from the first image manipulation program. Quote Link to post Share on other sites
Patrick W 0 Posted October 31, 2019 Share Posted October 31, 2019 I followed the instructions to install the 4 files, but when i try to use the plugin paint.net just freezes and i have to use task manager to kill it. i know i screwed up the install. I just dont now what to do ? please help Quote Link to post Share on other sites
toe_head2001 1,874 Posted October 31, 2019 Share Posted October 31, 2019 2 minutes ago, Patrick W said: I followed the instructions to install the 4 files, but when i try to use the plugin paint.net just freezes and i have to use task manager to kill it. i know i screwed up the install. I just don't now what to do ? please help Sounds like the plugin is just broken. Many people have reported the same issue. There's nothing you can do about that. I suggest using a different program for printing images. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
Ego Eram Reputo 2,838 Posted November 2, 2019 Share Posted November 2, 2019 Nope. It's not broken. I have it running in v4.2.5 Here are the installation instructions again. Check your paint.net installation folder for the two OptionBased files and your \effects folder for the *.dll and *dlc files. Installation - Copy the two files OptionBasedLibrary vX.X.dll/.dlc to the Paint.NET\ folder (NOT to Paint.NET\Effects\ !!!) - Copy the two files PrintIt.Effect.dll/.dlc to the Paint.NET\Effects\ folder - Do not remove older versions of the OptionBasedLibrary if they are required from other plugins. After a restart of Paint.NET you will find the plugin at Menu->Effects->Tools->Print It Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
toe_head2001 1,874 Posted November 2, 2019 Share Posted November 2, 2019 1 hour ago, Ego Eram Reputo said: Nope. It's not broken. I have it running in v4.2.5 It works fine for me too, but there's plenty of anecdotal evidence showing it's broken (hangs/freezes) in certain cases: https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=417032 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=425290 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=520148 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=528213 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=543488 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=544611 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=548350 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=553620 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=560550 https://forums.getpaint.net/topic/28520-print-it-tools-effect/?do=findComment&comment=564356 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
AlexNelson 0 Posted November 18, 2019 Share Posted November 18, 2019 You did not pass the security check. Please try again ??? 5 times - that's enough ... "Sounds like the plugin is just broken." < correct "Many people have reported the same issue." < correct "Nope. It's not broken." < incorrect "I have it running in v4.2.5" - probably so - but the plugin is still broken - installed correctly on 13 of many computers - wXP/7/8/10 - which pdn works fine - with many other plugins installed - and only print it hangs/locks up - on ALL of them. I have been messing with print it since 2014 - requests for older versions/option based libraries were requested from others but got no response. Anyway, on one dell laptop - pdn had been installed since day 1 - multiple printers - multiple pdf printers - print it initially reacts very slow (1 to 2 min) to input or change selection - and after awhile it just locks up - like other users have commented. I keep on top of driver updates - and had installed 3 video driver updates (2016, 2017 and 2018) - and print it still hung-up. But, the latest video driver (in August 2019) was installed and - amazingly - print it now works fine. Other computers had updates (not the same), but this is the only one that works with print it. Intel-HD-Graphics-530-Driver_04WHN_WIN_26.20.100.6859_A15 from Dell on a inspiron-15-5559. Integrated Intel HD Graphics 520. It was a "security" update - so I don't know what was updated - but if you need any other info ... just ask - I'd be happy to get the rest of my computers working, too. Quote Link to post Share on other sites
ogore 0 Posted December 15, 2019 Share Posted December 15, 2019 Subscribed to the forum just to say thank you. You're a lifesaver. You hero Quote Link to post Share on other sites
Djisves 595 Posted April 6, 2020 Share Posted April 6, 2020 (edited) On 10/10/2017 at 7:51 AM, Ego Eram Reputo said: I've rehosted the PrintIt dll. The link in the first post should now take you to my Dropbox where the file can be downloaded. Unfortunately the Dropbox link does not work. EDIT: I've found a saved copy of v.0.9. If it's OK I can upload the zip here to be posted on the first post. Edited April 6, 2020 by Djisves found a copy Quote Link to post Share on other sites
Djisves 595 Posted April 9, 2020 Share Posted April 9, 2020 It looks like it's OK to just upload here and wait for a moderator to take care of things, so here it is. 1 Quote Link to post Share on other sites
Pixey 5,026 Posted April 9, 2020 Share Posted April 9, 2020 1 hour ago, Djisves said: It looks like it's OK to just upload here and wait for a moderator to take care of things, so here it is. Thanks a lot @Djisves Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to post Share on other sites
barison82 0 Posted June 24, 2020 Share Posted June 24, 2020 Hi, it's my first post in the forum. Paint.net has been very good so far, much better than I expected. I do have Adobe Illustrator but wanted to give this a go, and have been able to produce some high quality work with it. One let down has been the "print" function, and lack of any comprehensive dialog/setting. Which led me to this plugin...well, I've had the same problem as many others have already mentioned here - running things in Windows 7, latest version of Paint.net, all plugin files are installed to the correct folders, no issues with printer, or any of the other plugins installed, it's just this plugin that causes Paint.net to hang/crash. Happens every time I've attempted to use it, with a variety of images, small or big. It's a great shame as this looks like a very useful tool indeed. I've designed some 1/400 scale buildings to print as card kits, so getting the actual Print Size is crucially important. It would be great if something else could be developed, to enhance this very basic and fundamental feature. Quote Link to post Share on other sites
barison82 0 Posted June 24, 2020 Share Posted June 24, 2020 On 4/7/2020 at 1:30 AM, Djisves said: Unfortunately the Dropbox link does not work. EDIT: I've found a saved copy of v.0.9. If it's OK I can upload the zip here to be posted on the first post. This sounds very hopeful! However, I cannot see the link here? Quote Link to post Share on other sites
Djisves 595 Posted June 24, 2020 Share Posted June 24, 2020 On 4/6/2020 at 6:30 PM, Djisves said: If it's OK I can upload the zip here to be posted on the first post. 4 hours ago, barison82 said: However, I cannot see the link here? My post was edited by forum moderator @Pixey. She posted the link on the first post of this topic so it's easier for everyone to find. Look for the link at the end of the first post. 1 Quote Link to post Share on other sites
ed555 1 Posted February 17 Share Posted February 17 This error is easily eliminated. We watch the video from the third minute. Quote Link to post Share on other sites
midora 251 Posted February 17 Share Posted February 17 Hi @ed555 'this error' is not a quite good hint. Or do you expect that people should watch in a foreign language to get an idea. At the end you are describing that the OptionBasedLibrary files have to be placed in the paint.net folder and not the Effects folder. The documentation explains this. Quote Link to post Share on other sites
rmcc4444 2 Posted March 20 Share Posted March 20 Hangs for me, too. Quote Link to post Share on other sites
midora 251 Posted March 20 Share Posted March 20 You may try this one PrintIt v0.9b.zip. OBL and PrintIt are still under rework. This is not a new release and PrintIt is still sluggish on Win10. Quote Link to post Share on other sites
