i need help with using the pluggin Curvs+, i haven't find any tutorials how to use it. can someone please make a tut how to use it in tutorial forum?
//killer93yo//
http://www.getpaint.net/doc/latest/en/Curves.html
Curves+ does all that, and more. But you should start there.
EDIT: This tutorial, by Tanel, also helps illustrate some of the concepts that will help you understand how to use Curves+ to its full potential. viewtopic.php?f=15&t=5570&st=0&sk=t&sd=a
ambigram signature by Kemaru
[i write plugins and stuff]
  • 3 weeks later...
Oh... My... Pfargtl.
So, is this the plugin of which you spoke when you said your favorite plugin is "The one I'm building right now"? This is an incredible update. Well done, and good fun!
So yeah, a-Stickied.
*ahem*
  • 4 weeks later...
Question, does this plugin not work with the new version or is there an update I have missed? There are a few plugins I have been getting an error message with and have to restart. Polar inversion+ is another.
"One can't complain. I have my friends. Someone spoke to me only yesterday." EEYORE
Shouldn't matter where you save it, as long as it's a location that you can save other stuff in too.
Is it doing this consistently? Or is it just the once?
If consistently, where are you trying to save it?
consistanly,
I've tried to save both luminosity curves and alpha curves as xml
in both my documents and my pictures.
there isn't a error report on my desk top or I'd have sent that.
when I check my documents and my pictures afterwards there is a xml file there but it will not load.
when I try to open with xml editor I'm blocked by IE activex blocker message cliking to allow access does nothing at all. so it might be an IE issue? I'm at a loss how to fix that if it is.
ciao
Try restarting your computer, and see if that helps.
Later today, I'll make a version that provides more detailed information about what's going wrong. "Error saving curve" is certainly not very helpful...
