Spottedfeather Posted November 21, 2012 Share Posted November 21, 2012 There isn't any Vintage choice in the menu like it says there is supposed to be. Curves+ is there, but there isn't any Vintage choice. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 21, 2012 Share Posted November 21, 2012 Downloadable as an extra from this post: http://forums.getpai...ack-for-curves/ (as mentioned by Pyrochild in post #269 above). See my post (#2 in that thread) for how to use the downloaded extras. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
pyrochild Posted March 4, 2016 Author Share Posted March 4, 2016 Curves+ is now on GitHub! Go contribute! https://github.com/bsneeze/pdn-curvesplus 4 Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
toe_head2001 Posted May 29, 2016 Share Posted May 29, 2016 Bug report: An empty string in the "Save current as preset..." dialog will crash paint.net. Please also add PluginSupportInfo, so I can have a fancy tooltip in the Adjustments menu. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
pyrochild Posted September 21, 2016 Author Share Posted September 21, 2016 On 5/28/2016 at 11:52 PM, toe_head2001 said: Bug report: An empty string in the "Save current as preset..." dialog will crash paint.net. Please also add PluginSupportInfo, so I can have a fancy tooltip in the Adjustments menu. Fixed 2 Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
pyrochild Posted October 2, 2016 Author Share Posted October 2, 2016 Updated to fix 2 bugs in Curves+: Smooth curve smooths all curves, not just the selected one(s) Smooth curve does not eventually give a straight line 3 Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Pratyush Posted January 22, 2018 Share Posted January 22, 2018 Hi @pyrochild , I use Curve++ more than paint.net's own curve. Please make one Dark theme for it so that I can collude with PDN's dark theme. Quote Link to comment Share on other sites More sharing options...
cinks20 Posted February 16, 2021 Share Posted February 16, 2021 I used to have the Curve feature before I downloaded the most recent version from the MS store. The file extension is in the right place according to the instructions, but I don't see the option under my Effects tab. Where would it be placed? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted February 16, 2021 Share Posted February 16, 2021 14 minutes ago, cinks20 said: Where would it be placed? The Adjustments menu. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
cinks20 Posted February 16, 2021 Share Posted February 16, 2021 Ah yes!! Thank you! Quote Link to comment Share on other sites More sharing options...
