pyrochild 362 Posted January 11, 2009 Author Report Share Posted January 11, 2009 EDIT: nevermind Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
pyrochild 362 Posted January 11, 2009 Author Report Share Posted January 11, 2009 Updates: [*:dv24y6fn]Curves+:[*:dv24y6fn]Accepting once and then canceling would result in changes being saved in the dialog[*:dv24y6fn]Dialog checkbox states not remembered between Curves+ sessions[*:dv24y6fn]Rendering issue with checkboxes when redrawn (e.g. from moving offscreen and back on)[*:dv24y6fn]Typo fixed from 2.7[*:dv24y6fn]Smudge: [*:dv24y6fn]Several plugin crashes and PdN crashes fixed that could occur when canceling Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
Tanel 7 Posted January 11, 2009 Report Share Posted January 11, 2009 Thanks pyrochild! Control state recalling works well. However, the UI now crashes PdN at certain situation: 1. Open Curves+ (Do nothing in curves panel) 2. Select "Advanced" from drop-down list (Do nothing in curves panel) 3. Select "Luminosity" or any other item from the same (upper) drop-down list again =Crash! This text file was created because Paint.NET crashed. Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem. Application version: Paint.NET v3.36 (Final Release build 3.36.3158.38068) Time of crash: 11.01.2009 11:10:07 Application uptime: 00:01:16.9843750 OS Version: 5.1.2600.196608 Service Pack 3 Workstation x86 .NET version: CLR 2.0.50727.3053 x86, FX 2.0 2.0SP1 2.0SP2 3.0 3.0SP1 3.0SP2 3.5 3.5SP1 3.5SP1_Client Processor: 1x "AMD Sempron(tm) Processor 2500+" @ ~1403MHz (DEP, SSE, SSE2) Physical memory: 1535 MB UI DPI: 96,00 dpi (1,00x scale) Tablet PC: no Updates: false, 4.11.2006 Locale: pdnr.c: en-US, hklm: en-US, hkcu: n/a, cc: et-EE, cuic: en-US Features log: UpdatesState(StartupState), ShowDialog(PaintDotNet.SplashForm), ShowDialog(PaintDotNet.ToolsForm), ShowDialog(PaintDotNet.ColorsForm), ShowDialog(PaintDotNet.HistoryForm), ShowDialog(PaintDotNet.LayerForm), ShowDialog(PaintDotNet.MainForm), Load(PaintDotNet.PngFileType), SetTool(PaintDotNet.Tools.ColorPickerTool), UpdatesState(ReadyToCheckState), PopulateFonts(), HM(NullHistoryMemento), Menu.Layers.Adjustments, Effect(pyrochild.effects.curvesplus.CurvesPlus), ShowDialog(pyrochild.effects.curvesplus.CurvesPlusConfigDialog) ----- ----- Exception details: System.NullReferenceException: Object reference not set to an instance of an object. at pyrochild.effects.curvesplus.CurvesPlusConfigDialog.InitTokenFromDialog() at PaintDotNet.Effects.EffectConfigDialog.FinishTokenUpdate() at pyrochild.effects.curvesplus.CurvesPlusConfigDialog.modeComboBox_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m) at System.Windows.Forms.ComboBox.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ------------------------------------------------------------------------------ Quote Link to post Share on other sites
pyrochild 362 Posted January 11, 2009 Author Report Share Posted January 11, 2009 Fixed. Ugh. Embarrassing. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
pyrochild 362 Posted January 12, 2009 Author Report Share Posted January 12, 2009 Another dumb bug fixed. (This is what beta testers are for...) Crash when loading xml file when the current transfer map mode is not the same as the file's. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
LFC4EVER 4 Posted January 12, 2009 Report Share Posted January 12, 2009 :shock: v2.9 to v2.10 (couldn't help noticing) Quote ☆★☆★Merry Christmas★☆★☆  .::.My Gallery.::.Make Gold Text!.::. Link to post Share on other sites
pyrochild 362 Posted January 12, 2009 Author Report Share Posted January 12, 2009 couldn't help noticing what? that the version number increased? Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
bEPIK 13 Posted January 13, 2009 Report Share Posted January 13, 2009 2.10 = 2.1 < 2.9 that's what he means Quote Water, Wood and Hair Tutorial Link to post Share on other sites
pyrochild 362 Posted January 13, 2009 Author Report Share Posted January 13, 2009 Version numbers are not decimals. They are composed of 4 sections, delineated by a period. Major.Minor.Build.Revision A decimal numeric value can't contain 4 decimal points... 2.1 = 2.10, yes, but 2.1.3280.213489 ≠2.10.3280.213489. The way I have my build environment set up, the build and revision numbers are generated automatically based on the time and date, so I only set the major and minor. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
LFC4EVER 4 Posted January 13, 2009 Report Share Posted January 13, 2009 Oh ok, but i still dont get why the version number went down from 2.9 to 2.1 . Shouldn't it be 3.1 ? Quote ☆★☆★Merry Christmas★☆★☆  .::.My Gallery.::.Make Gold Text!.::. Link to post Share on other sites
Simon Brown 44 Posted January 13, 2009 Report Share Posted January 13, 2009 Oh ok, but i still dont get why the version number went down from 2.9 to 2.1 . Shouldn't it be 3.1 ? It's not 2.1 it's 2.10, Pyro is saying that each number between the "points" in a version number are separate numbers, not part of the same one and thus version number 2.10 != 2.1. Quote Link to post Share on other sites
LFC4EVER 4 Posted January 13, 2009 Report Share Posted January 13, 2009 Ohhh, i understand now. This coding version stuff is half-confusing. :shock: I was just applying maths to the version numbers, in maths 2.10 is basically 2.1 (unless you're using upper and lower bounds - thats something else), so i was confused at how 2.10 > 2.9 . I get it now, sort of. Quote ☆★☆★Merry Christmas★☆★☆  .::.My Gallery.::.Make Gold Text!.::. Link to post Share on other sites
Rick Brewster 1,755 Posted January 14, 2009 Report Share Posted January 14, 2009 Oh ok, but i still dont get why the version number went down from 2.9 to 2.1 . Shouldn't it be 3.1 ? Read ... Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
LFC4EVER 4 Posted January 14, 2009 Report Share Posted January 14, 2009 Read what? The post you quoted? I get it now, sort of. Quote ☆★☆★Merry Christmas★☆★☆  .::.My Gallery.::.Make Gold Text!.::. Link to post Share on other sites
Alex0856 0 Posted February 10, 2009 Report Share Posted February 10, 2009 Am I just stupid or is the download button is not there? :? Quote Link to post Share on other sites
Alex0856 0 Posted February 10, 2009 Report Share Posted February 10, 2009 Ah I thought that was the download button for the pyrochild.effects.common.dll file . My bad . Quote Link to post Share on other sites
person_321 2 Posted May 17, 2009 Report Share Posted May 17, 2009 I've been having some problems with curves+... everytime I open the plugin there is an error and It says that PND needs to be restarted ..Any help appreciated.. Quote Link to post Share on other sites
pyrochild 362 Posted May 17, 2009 Author Report Share Posted May 17, 2009 What's the error? What version of Paint.NET are you using? Do you have pyrochild.effects.common.dll in the Effects folder? Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
person_321 2 Posted May 17, 2009 Report Share Posted May 17, 2009 It says: File: C:\Program Files\Paint.NET\Effects\Curves+ (2).dll Effect Name: pyrochild.effects.curvesplus.CurvesPlus Full error message: System.IO.FileNotFoundException: Could not load file or assembly 'pyrochild.effects.common, Version=2.5.3298.41851, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. File name: 'pyrochild.effects.common, Version=2.5.3298.41851, Culture=neutral, PublicKeyToken=null' at pyrochild.effects.curvesplus.CurvesPlus.CreateConfigDialog() at PaintDotNet.Menus.EffectMenuBase.RunEffect(Type effectType) WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. I am using version 3.36 Quote Link to post Share on other sites
MyChemicalSnowman 0 Posted May 17, 2009 Report Share Posted May 17, 2009 It says: File: C:\Program Files\Paint.NET\Effects\Curves+ (2).dll Effect Name: pyrochild.effects.curvesplus.CurvesPlus Full error message: System.IO.FileNotFoundException: Could not load file or assembly 'pyrochild.effects.common, Version=2.5.3298.41851, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.File name: 'pyrochild.effects.common, Version=2.5.3298.41851, Culture=neutral, PublicKeyToken=null' at pyrochild.effects.curvesplus.CurvesPlus.CreateConfigDialog() at PaintDotNet.Menus.EffectMenuBase.RunEffect(Type effectType) WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. I am using version 3.36 I'm not an expert on the matter...but it appears that it can't find the pyrochild.effects.common.dll... Did you put that in your effects folder too? Quote Link to post Share on other sites
person_321 2 Posted May 17, 2009 Report Share Posted May 17, 2009 Awesome! It worked now Quote Link to post Share on other sites
pyrochild 362 Posted May 17, 2009 Author Report Share Posted May 17, 2009 In other words, no you do not have pyrochild.effects.common.dll in your Effects folder. You need this file for Curves+ and most of my other plugins to work. ALso, why do you have 2 copies of the Curves+ plugin installed? Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
Simon Brown 44 Posted May 17, 2009 Report Share Posted May 17, 2009 I'm not sure how much work this would be but I suggest loading P.E.C via reflection and alerting users when they don't have it/have an old version. Quote Link to post Share on other sites
pyrochild 362 Posted May 17, 2009 Author Report Share Posted May 17, 2009 Simon....no.... Weird: the forum is not notifying me of new posts between the time I start writing a reply and the time I post it (hence the seemingly delayed reaction earlier). Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
wiirus 0 Posted June 21, 2009 Report Share Posted June 21, 2009 I love this. I use it for every pic I make. I love this. Did I say that I love this? Thank you! Quote I'm still learning, trying to get better. Critics, even bad ones, help me. Join Premium Renders! Link to post Share on other sites
