archlingo Posted June 7 Share Posted June 7 Hello, it is well-known that paint.net is loading/starting extremely slowly. Reason are the hundreds (!) of plugins, insufficiently described, and therefore partly overlapping with often several others. Example: I find two plugins for '"flip" - even one for horizontal and one for vertical - completely unnecessary because already contained in the program under "picture". Deleting a "Flip.dll" did not change anything (!). Because of their cryptic names it is nearly impossible to identify the dll in order to delete them. It is a pity. We URGENTLY need a better list with 1- A clear and understandable description of the purpose 2- AND the name appearing in the program 3- AND the name of the dll (or other ending). Momentarily it simply cruelly. Hans J. Holm Relatively experienced user. Quote Link to comment Share on other sites More sharing options...
Solution ardneh Posted June 7 Solution Share Posted June 7 (edited) If you hover over a menu entry it will give you the name of the .dll. The built-in Flip will flip the entire image. The Flip plugin flips a layer or the contents of a selection. Edited June 7 by ardneh 1 Quote Link to comment Share on other sites More sharing options...
Rle Posted June 7 Share Posted June 7 59 minutes ago, archlingo said: Hello, it is well-known that paint.net is loading/starting extremely slowly. Reason are the hundreds (!) of , insufficiently described, and therefore partly overlapping with often several others. Example: I find two plugins for '"flip" - even one for horizontal and one for vertical - completely unnecessary because already contained in the program under "picture". Deleting a "Flip.dll" did not change anything (!). You as a "Relatively experienced user" have not understood anything (!) 1. read here again . 2. you have installed the hundreds of plugins. 3. see the answer above my . Quote We URGENTLY need a better list with 1- A clear and understandable description of the purpose 2- AND the name appearing in the program 3- AND the name of the dll (or other ending). Momentarily it simply cruelly. 0. Not we but you . I find it an impertinence to make demands : 1. for a program what is free - 2. to the plugins writers (who do all this in their spare time and also for free) - Maybe you start all over again from the beginning. -> here _____________________________________________________________________________________ Sorry @Ego Eram ReputoI could not do otherwise . 😉 Quote Link to comment Share on other sites More sharing options...
BDP Posted June 7 Share Posted June 7 Well, I must be extremely lucky, or just done everything right when updating the program or in adding plugins. I have loads of added plugins (okay, I don't use all of them), but my Paint.Net only takes a max two seconds to load. I can live with that! Brian 1 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 7 Share Posted June 7 If Paint.NET is starting very slowly when you have hundreds of plugins installed, the likely culprit is your antivirus. For instance, I've seen Windows Defender cause abysmally slow startup times on my Ryzen 5950X. The app appears fairly quickly but is very sluggish and becomes unresponsive when accessing the Effects, Adjustments, or even the File -> Open Recent menus, for as long as a few minutes. Not always, but especially right after installing a new update, after restarting the PC, or after installing all of the plugins themselves (that is, going from 0 installed to all of them installed). With antivirus disabled, Paint.NET loads in just a second or two or three, even with over 1000 plugins installed. I'm not comfortable recommending that you disable your antivirus, or that you add the plugins folder as an excluded folder, but that does resolve the performance issue. 2 1 3 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Pixey Posted June 7 Share Posted June 7 11 hours ago, archlingo said: I find two plugins for '"flip" - even one for horizontal and one for vertical - completely unnecessary because already contained in the program under "picture". Deleting a "Flip.dll" did not change anything (!). Please know that some Plugs, like Flip Horizontal and verticle, are already "built in" to paint.net and cannot be removed. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Red ochre Posted June 7 Share Posted June 7 4 hours ago, Rick Brewster said: add the plugins folder as an excluded folder, but that does resolve the performance issue. Many thanks @Rick Brewster Excluding the paint.net folder from Defender makes a huge difference! (I scan everything I download before installing). I had previously excluded the Pdn folder but due to re-naming, when I had two versions installed, the current version was not excluded. I now have the standard folder name added to exclusions and it gets to a useable state so much quicker! - none of those annoying 'hangs' when just selecting Effects. 2 Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
Djisves Posted June 8 Share Posted June 8 Yes, it does make a huge difference, thank you @Rick Brewster. I've added both the Effects and File Types folders to Defender exceptions. They are the only exceptions I have and, like @Red ochre, I do scan everything I download, immediately after the download completes. However, I understand Rick's hesitation in recommending this and, I believe, the moderators have to be very careful how they handle similar questions. Quote Link to comment Share on other sites More sharing options...
archlingo Posted June 8 Author Share Posted June 8 Thanks for the helpful comments, in particular the two solutions: 1. The hovering is ok, but sometimes needs a second attempt. 2. Excluding the "Effects" - under the due cautions - from MS Defender is the perfect idea. (De blaseerte Buten-Hamborger shall sien Mul holn). archlingo Quote Link to comment Share on other sites More sharing options...
AndrewDavid Posted June 8 Share Posted June 8 I remember talking about that fix a few years ago. 1 Quote Link to comment Share on other sites More sharing options...
Djisves Posted June 14 Share Posted June 14 On 6/8/2022 at 10:41 AM, AndrewDavid said: I remember talking about that fix a few years ago Now that you mentioned it, I remember reading it. So, kudos to @AndrewDavid. But it did not concern me at the time. My start-up times became annoyingly slow when I followed other good advice on this forum, did away with AVG and now rely on Defender. Perhaps AVG is smarter than Defender when it comes to plugins, perhaps I had added an exception to AVG I do not remember. Quote Link to comment Share on other sites More sharing options...
