G'MIC (09-04-2024)
null54
Works for me - G'MIC 3.2.6. Have you tried updating the filters?
Oh, I get it now. It was changing to all black. The way I got out of it was to quit PDN, and reload the image into G'MIC - worked then
Brian
  • null54 changed the title to G'MIC (09-04-2023)
This needs a recompile for PDN 5.0.11+. I changed the ContainerFormats properties from ref readonly to just regular value returns, and I missed that G'MIC was using them.
I got this crash report from someone using v3.3.0 of the plugin:
System.MissingMethodException: Method not found: 'PaintDotNet.Imaging.ContainerFormat ByRef PaintDotNet.Imaging.ContainerFormats.get_Png()'.
   at GmicEffectPlugin.OutputImageUtil.SaveAllToFolder(IImagingFactory imagingFactory, IReadOnlyList`1 outputImages, String outputFolder, String gmicCommandName)
   at GmicEffectPlugin.GmicConfigDialog.ProcessOutputImages()
   at GmicEffectPlugin.GmicConfigDialog.GmicThreadFinished(DialogResult result)
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
   at System.Reflection.MethodInvoker.Invoke(Object obj, IntPtr* args, BindingFlags invokeAttr)
  • null54 changed the title to G'MIC (10-19-2023)
Release version 3.3.0.1.
Changes:
Updated the plugin for Paint.NET 5.0.11.
  • Like 2
  • Thanks 1
  • Upvote 2
  • null54 changed the title to G'MIC (10-24-2023)
3 hours ago, null54 said:
Updated G'MIC to version 3.3.1.
As of 10/24/23 at 11.38 EST the links to the updated version are not working for me 😱  Fixed by @null54 - many thanks :)
Hi @Pixey - same for me with the main link - just says page not found BUT I found the download by following the source code link here.
https://github.com/0xC0000054/pdn-gmic/releases/tag/v3.3.1
(Gmic_Win64.zip)
Installed, updated and found the new twisted rays and it worked!
  • Thanks 1
Thank you @Red ochre and @null54 😍
FYI - I had to use 'Right click' and open in new tab to get the download to work.  Computers 🤪
  • null54 changed the title to G'MIC (11-10-2023)
  • 2 months later...
G'MIC 3.3.3 released!
  • Hooray 1
G'MIC Filter Developer
I am away from this forum for undetermined amount of time: If you really need anything related to my PDN plugin or my G'MIC filter within G'MIC plugin, then you can contact me via Paint.NET discord, and mention me.
3 minutes ago, BDP said:
Downloaded, still showing as 3.3.2
Brian
On G'MIC website, it's 3.3.3, this is just to let the author of the G'MIC plugin for PDN to update it to 3.3.3. So, if you see any one other than @null54 saying G'MIC has been released, it's for letting him know.
  • Thanks 1
  • null54 changed the title to G'MIC (01-12-2024)
53 minutes ago, BDP said:
Nothing happens when I select the G'MIC option
I just updated and it's working fine.  Did you restart paint.net after installing the latest version?
Also, did you put both .dll and the G'MIC Folder into Effects?
Did you manage to solve the issue, BDP?
I also closed Paint.NET, copied .dll and the folder into the Effects folder, and no cookie. A small launching message window shows up for an easy-to-miss microsecond, but then disappears and the main G'MIC window fails to launch.
Hi,
I jam currently using PDN 5.0.11 and G'MIC 3.3.1 quite successfully. I deleted both the folder and .dll and replaced with 3.3.3. Now I get an error in effects
plugin errors. Then when I try G'MIC I get a long list of the issues. Should I have just copied 3.3.3 over 3.3.1 ?
Edited by flash
The old gmic folder should be deleted, not replaced. Replacing the folder could cause DLL conflicts.
Also, you will need to update to Paint.NET 5.0.12 to use the plugin.
  • Thanks 1
