TechnoRobbo 1,166 Posted October 19, 2014 Report Share Posted October 19, 2014 TechnoRobbo's Paste Frame V1.3.20+ Uses a clipboard image to frame your picture Based on a request from Member @Eli PDN 3.5 Compatible v1.3.20+ math fix v1.3.10+ Greater Adjustment - Smooth Offset v1.3.9+ Some Eli inspired changes (expanded range,Solid Tiling) v1.3.8+ adds offset from edge v1.3.7+ Introduces alignment options Hidden Content: v1.3.6+ Region Bug fix v1.3.5+ Border width bug fixed v1.3.0.+ add selection contouring v1.2.2+ fixes a Re-entrant Token bug. v1.2.1+ fixes artifact in PDN 3.5 Version 1.2.0.+ wrapping control and load a frame file as well as clipboard V1.1 corrects symmetry Menu : Effects -> Selection A few tips When using copy disable antialising selection Paste to it's own image and copy again to avoid any fringing The frame image continuity works best if the frame size and the image have a common divisor 800X600 works great with 10,50,100 Select the graphic at the targetted corner point - in this example, from middle of the heart to the middle of the heart Example of proper alignment (Click to view) https://www.dropbox.com/s/ueo8jqjd32ufagn/Paste%20FrameEli1.png?raw=1 Example of common divisor (Click to view) https://www.dropbox.com/s/bw456g4cgk1bmrr/Paste%20FrameEli2.png?raw=1 . . VS Source Code for Programmers Only Plugin DownloadTRsPasteFrame.zip 8 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Red ochre 1,623 Posted October 20, 2014 Report Share Posted October 20, 2014 Slow down ... I can't keep up! (I'm still exploring what 'Third dimension' can do)Another very useful plugin.Once again many many thanks. 4 Quote Red ochre Plugin pack............................................................... Diabolical Drawings Link to post Share on other sites
TechnoRobbo 1,166 Posted October 20, 2014 Author Report Share Posted October 20, 2014 Thanks Red, great graphics!!! Looks like an amusement Park. Eli suggested it and it sounded relatively simple so.... Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted October 20, 2014 Report Share Posted October 20, 2014 (edited) I went to bed and woke up with a new plugin (Pixey, I think TR is a bot ). TR This is exactly what I wanted. The corners look good. There is a little problem with mirroing however. I also tried on a large canvas and the border size was too thin even at 100. Post Edit: Also, in order to have perfect symmetry at the corners why not start the tiling at the corners and blend the tiled image at the center. Edited October 20, 2014 by Eli 1 Quote Link to post Share on other sites
DrewDale 796 Posted October 20, 2014 Report Share Posted October 20, 2014 Cool plugin TR. Cheers 3 Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted October 20, 2014 Author Report Share Posted October 20, 2014 There is a little problem with mirroing however. I also tried on a large canvas and the border size was too thin even at 100. sorry about that, I missed a 180 flip at the second pass (bottom) and that threw the rest out of sync (I should have tested with a different image). I increased the max border size to 300 - looks wild with smaller images but . V1.1 ready for download!!!!!!!!!!! A few tips When using copy disable antialising selection Paste to it's own image and copy again to avoid any fringing The frame image continuity works best if the frame size and the image have a common divisor 800X600 works great with 10,50,100 Select the graphic at the targetted corner point - in this example, from middle of the heart to the middle of the heart Example of proper alignment (Click to view) https://www.dropbox.com/s/ueo8jqjd32ufagn/Paste%20FrameEli1.png?raw=1 Example of common divisor (Click to view) https://www.dropbox.com/s/bw456g4cgk1bmrr/Paste%20FrameEli2.png?raw=1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Pixey 4,810 Posted October 20, 2014 Report Share Posted October 20, 2014 Holy Moly - I can't believe the prowess of this bot @TR Plugin generator. I don't believe his brain stops, even in his sleep Flowers in her Hair 3 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to post Share on other sites
TechnoRobbo 1,166 Posted October 20, 2014 Author Report Share Posted October 20, 2014 Very Nice Image pixey - I can't believe how popular that mesh is. I'm not a bot, I passed Captain Kirk's Liars Paradox. http://www.youtube.com/watch?v=EzVxsYzXI_Y#t=85 Nice Drew, Sorry about the symmetry - all fixed now. 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Seerose 4,273 Posted October 20, 2014 Report Share Posted October 20, 2014 TechnoRobbo! It is so very very cool. Thank you soo much for this plugin. Sorry! I like all the colors of the world. 2 Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to post Share on other sites
Eli 1,129 Posted October 20, 2014 Report Share Posted October 20, 2014 (edited) It works great! Two more requests to make this great plugin even better : Could you add an option to load a picture (png) and take advantage of transparency? Some people may want just an image tiled all around without any mirroing or flipping. Edited October 20, 2014 by Eli 1 Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted October 20, 2014 Author Report Share Posted October 20, 2014 Two more requests to make this great plugin even better : Could you add an option to load a picture (png) and take advantage of transparency? Some people may want just an image tiled all around without any mirroing or flipping. That's 3 requests. All possible but it would require a more sophisticated interface than Code Lab can give us. I would have to move the project to VS. It shouldn't be too hard. Transparency would only be available from a file. Seerose - Nice frame job- I like those little furbie thingies you used as a frame. Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted October 20, 2014 Report Share Posted October 20, 2014 Wonderful. I do not mind waiting. I hope you all are around when I retire so I can play full time. That is going to be 30 years from now... I should be 80 . Quote Link to post Share on other sites
nitenurse79 690 Posted October 20, 2014 Report Share Posted October 20, 2014 Great new plugin Mister Techno Robbo. Again thank you 2 Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted October 20, 2014 Author Report Share Posted October 20, 2014 Thank you Miss Nite Nurse 79. Nice frame design. If I could +1 you I would. But sadly I am out yet again.I will have to get you when the reputation Gods bless me with more. Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
TechnoRobbo 1,166 Posted October 21, 2014 Author Report Share Posted October 21, 2014 Could you add an option to load a picture (png) and take advantage of transparency? Some people may want just an image tiled all around without any mirroing or flipping. Version 1.2.0+ is ready for download 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
TechnoRobbo 1,166 Posted October 21, 2014 Author Report Share Posted October 21, 2014 V 1.2.1.+ fixes an artifact for PDN 3.5 users Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted October 21, 2014 Report Share Posted October 21, 2014 You did it! With the new features the plugin is versatile. Thanks. I do not know what other feature could be added. Maybe just increase the border size to 500 (for a very large canvas). 1 Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted October 22, 2014 Author Report Share Posted October 22, 2014 For those of you who aren't sure what this is, here's a little video 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted October 22, 2014 Report Share Posted October 22, 2014 Hello, TR I did run into this error message when I tried to run the plugin a second time : File: C:\Program Files\Paint.NET\Effects\TRsPasteFrame.dll Effect Name: TRsPasteFrame.EffectPlugin Full error message: System.ArgumentOutOfRangeException: Value of '150' is not valid for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'.Parameter name: Value at System.Windows.Forms.NumericUpDown.set_Value(Decimal value) at TRsPasteFrame.EffectPluginConfigDialog.InitDialogFromToken(EffectConfigToken effectToken) at PaintDotNet.Effects.EffectConfigDialog.InitDialogFromToken() in d:\src\pdn\paintdotnet\src\Effects\EffectConfigDialog.cs:line 200 at PaintDotNet.Effects.EffectConfigDialog.set_EffectToken(EffectConfigToken value) in d:\src\pdn\paintdotnet\src\Effects\EffectConfigDialog.cs:line 251 at PaintDotNet.Menus.EffectMenuBase.RunEffectImpl(Type effectType) in d:\src\pdn\paintdotnet\src\PaintDotNet\Menus\EffectMenuBase.cs:line 970 Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted October 22, 2014 Author Report Share Posted October 22, 2014 File: C:\Program Files\Paint.NET\Effects\TRsPasteFrame.dll Effect Name: TRsPasteFrame.EffectPlugin Full error message: System.ArgumentOutOfRangeException: Value of '150' is not valid for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'. easy fix - I'll do it tonight Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Goonfella 220 Posted October 22, 2014 Report Share Posted October 22, 2014 Another wonderful plugin TR ! Pure genius. Quote Please feel free to visit my Gallery on PDNFans And my Alternatives to PDN Link to post Share on other sites
TechnoRobbo 1,166 Posted October 22, 2014 Author Report Share Posted October 22, 2014 Eli all fixed , and I increased max border size to 500 V1.2.2 + ready for download Another wonderful plugin TR ! Pure genius. It was Eli's suggestion - I guess that makes mean impure one? Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted October 23, 2014 Report Share Posted October 23, 2014 (edited) I agree with Goonfella, ALL credit goes to TR. I only sent a wish and TechnoRobbo granted it. Christmas came early for me. Thanks TR for the fix and increasing the border size. I find that the quality of the frame is better when applied to a large canvas. Just in case you are curious... What else do I have on my wishing list? Well... another pluging that will work on irregular shapes, selections or objects more or less like drawing an outline but instead of drawing a solid line, it will allow the insertion of images like Paste Frame does. I think I am being too greedy. Edited October 23, 2014 by Eli Quote Link to post Share on other sites
TechnoRobbo 1,166 Posted October 23, 2014 Author Report Share Posted October 23, 2014 Look at my paste warp plugin http://forums.getpaint.net/index.php?/topic/28298-trs-paste-warp/?p=408418 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to post Share on other sites
Eli 1,129 Posted October 23, 2014 Report Share Posted October 23, 2014 I mean something like this : Quote Link to post Share on other sites
