Posted
It is just a copy and paste (my work around). I know that there are many things to be considered and may actually not be possible. It is just a wish.
Posted
It's possible - I need to apply a maze navigating algorithm - figure out the normal (perpendicular direction) for each 1/2 width line segment, draw a rotated image. and advance a full width. To cover gaps I may need a spacing variable applied to the width. All this can be done with the same plugin. Just takes time to program.
TRsSig.png?raw=1
Posted
TR, The only thing I understand is : "It's possible". :lol:
Take your time.
Posted
Perhaps objects along a path would be a broader soloution? (not limited to frames)
Midora's Beta 'Path tools' here:http://forums.getpaint.net/index.php?/topic/26552-peephole-drawing-or-some-path-tools-in-the-future/
can put objects along a path but with no option to orient the objects to the tangent of the line.
Posted
Only beings from far away can comunicate in such a sophisticated but logical language. Pointy ears, dark glasses I have my own suspicions about  Reds provenance. I know you passed Captain Kirk's Liars Paradox but that was a long time ago and bots have evolved since. :)
Posted
Eli.  Please stay where you are.  We're sending someone around.....  :lol:
(Guys!  Get the Rapid Response Unit rolling!!)
  • Upvote 3
Posted
Thanks for the (super - quick) update TR!  B)
Works really well.
Btw the pentangle is only for testing purposes - no goat sacrifices today!  :lol:  http://i.imgur.com/zzzgjNu.png
Red,
I got to hand it to you. You sure know how to manipulate an image. Thanks for showing how Eli's suggestion come in handy. You deserve an applause. Let's all give a big hand for Red Ochre!!!
Origin of obscure reference
Latin: Manipulus  :RightArrowBlue:  English: Manipulation  :RightArrowBlue: Early 19th Century:Manipulate   -Merrian Webster
No goats were harmed in the making of this topic.
TRsSig.png?raw=1
Posted
Red,
Here you go @Red :D
Posted
Thanks for the video explanation. This was the best I could do (the upper right and lower left are slightly off though) I had the border size @ 67.
  • Upvote 2
Posted (edited)
Hello, TR. I have run into this problem. I am trying to create a frame using a png file with transparency but every time I do it a couple of lines appear from nowhere.
This is the png file I used for the frame:
Edited by Eli
