Mini-tuts - Discussion
david.atwell
Riddley's mini-tut is our newest: an excellent way to look at shapes and how you can modify simple ones to create complicated ones.  Take a look!
There sure are, and I think the best one is Pixey's Chilly Text mini-tut!  So cool.  (See what I did there? ;-))
Pixey hits a second home run in a row with "Billboarding" One Image onto Another.  Great job, Pixey!  Keep it up and you'll dominate this thread!
Well done Pixey. Long term users of PDN & forumers have often been accused of not sharing information & skills. This just proves them wrong yet again. I just realised that in your yourtube of how you made Halle,(link in your sig) I noticed you use a lot of Smudge. The way you use it is like a soft brush. Gosh you are clever. Is there a way to slow down the playback? It is so intriguing & relaxing to watch art being created.
Thanks so much for sharing Pixey :D
April Jones, 2012
Thanks so much @BBQ :) .  Alas, there is no way to slow down that particular video, but perhaps I'll make another one sometime and make it slower :D .
  • 4 weeks later...
Two new mini-tuts grace our board today!  First, Cc4FH pulls in her second mini-tut showing us how to make transparent layer "windows", while Humility becomes our first self-answerer to be promoted to mini-tut status with an intriguing method to digitally "ink" a pencil drawing.  Enjoy!
  • 4 weeks later...
  • 9 months later...
  • 6 months later...
Mini Tutorial By Eli.
Remove simple backgrounds with the Replace Color Plugin -- http://forums.getpaint.net/index.php?/topic/32538-change-the-background-step-by-step-to-a-portrait/?p=433872
EDIT
In that thread, there were several suggestions and tips. I re-compiled some of them into a more step by step order.
These steps can help to remove simple backgrounds and cut out subjects with hair or fur : http://forums.getpaint.net/index.php?/topic/32538-change-the-background-step-by-step-to-a-portrait/?p=434564
Edited by Cc4FuzzyHuggles
  • 3 months later...
The wonderful Pixey takes us into double-digits in the Mini-Tuts world! (it's also her third mini-tut!)
Cc4FH: I'm going to start updating this again!
Lucky number 13!  Cc4FH has a great roundup of clean cutouts.  Essential tutorial!
This clears out the backlog, as far as I can see!  Please keep submitting mini-tuts to add!  Thank you!
Exclamation points!!!!!
MJW earns his second spot with this great tutorial on making a Star Wars hologram effect!  Check it out, Obi-Wan Kenobi.  You're my only hope.
  • 4 weeks later...
Pixey goes with the 4-peat with this impressive tutorial for shiny objects with internal reflections (that is actually barely a "mini"-tut)!
Cc4FH's excellent description of different erasing methods nets her a fourth spot on the Mini-Tuts thread!
  • 3 weeks later...
Eli has some nice and simple mini tuts :
There is another way to produce Circle text...using the Polar Transformation effect :
1. Type your text on a transparent layer. ( I streched it )
2. Add some horizontal lines above and below.
3. Center everything.
4. Use the Polar Transformation effect with the following settings: Choose in the effect " Transform rectangular to polar"
5. Adjust the size using the "Scale" option.
Hello Atlas,
You can make it this way:
1. Create a square canvas.
2. Make a horizontal selection in the middle and color the inside using the Gradient tool.
3. Use the Polar Transformation effect and check Transform Rectangular to Polar.
  • Upvote 3
I second Cc4FuzzyHuggles's submission for Eli's mini tuts....I was thinking the same thing!     :)
