PSFilterPdn (2023-01-25)
null54
doesn't seem to work with redynamix.
the plugin pops and get the image, the image gets processed inside the plugin but it returns the original image (before and after the image is the same).
That plugin might just not be compatible with this host then, when I tried to debug it the proxy host was terminated with a StackOverflowExcecption. :(
A bug in the handling of non-interleaved color channel data fixed, multiple other compatibility bugs fixed.
ReDynamix should now work correctly, and the Filter Factory plugins should now be fixed.
File version updated to 1.0.2.7
Fixed a bug in the color channel processing, AlienSkin's Bevel Boss and Marble filters now work on images larger than 500 pixels.
File version updated to 1.0.2.9. ;)
Do you hate maintaining this plugin yet? :lol:
I probably could have avoided releasing another update so soon if I had tested version 1.0.2.8 on more than one filter, LockBits apparently calculates the stride based on the width of the source image not the width of the rectangle within the image that is actually locked so Marshal.Copy would not work correctly. :roll:
It should be quicker anyway to loop through the image and swap bytes as the data is copied.
Nouns as verbs is a fun. :P
Not when you're playing @BoltBait's Adventure Game..., :D
  • 4 weeks later...
Awesome work!
Heres my issue so far :P
Medhi's Eraser Genuine works for me on simple 2 color images, but on more complex images after i run it and it renders, nothing changes and it crashes.
Heres the crash log:
Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem.
Application version: Paint.NET v3.5.4 (Final Release build 3.54.3708.31975)
Time of crash: 2/26/2011 10:12:50 AM
Application uptime: 00:00:39.6845703
Install directory: C:\Program Files\Paint.NET
OS Version: 6.1.7600.0 Workstation x86
.NET version: CLR 2.0.50727.4952 x86, FX 2.0 2.0SP1 2.0SP2 3.0 3.0SP1 3.0SP2 3.5 3.5SP1 3.5SP1_Client
Processor: 2x "AMD Athlon(tm) 64 X2 Dual Core Processor 4400+" @ ~2600MHz (DEP, SSE, SSE2, SSE3), fps=0x1
Physical memory: 2046 MB
UI Theme: Aero/Aero + DWM (Aero.msstyles)
Updates: false, err
Locale: pdnr.c: en-US, hklm: en-US, hkcu: n/a, cc: en-US, cuic: en-US
Managed assemblies:
   mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll
   PaintDotNet, Version=3.54.3708.31979, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
   PaintDotNet.Base, Version=3.54.3708.31969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
   System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
   WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\assembly\GAC_MSIL\WindowsBase\3.0.0.0__31bf3856ad364e35\WindowsBase.dll
   System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
   System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
   System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Core\3.5.0.0__b77a5c561934e089\System.Core.dll
   PaintDotNet.Core, Version=3.54.3708.31976, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
   PaintDotNet.SystemLayer, Version=3.54.3708.31974, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
   PaintDotNet.Resources, Version=3.54.3708.31975, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
   PaintDotNet.Data, Version=3.54.3708.31976, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
   PaintDotNet.Effects, Version=3.54.3708.31978, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
   PaintDotNet.SystemLayer.Native.x86, Version=3.54.3708.31972, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x86.dll
   msvcm90, Version=9.0.30729.4926, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc0e5a\msvcm90.dll
   "AA's_Assistant", Version=1.0.3697.21415, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll
   AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPlugin.dll
   AlphaBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaBlur.dll
   AlphaSpace, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaSpace.dll
   AnimationEffect, Version=1.0.0.4, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AnimationEffect.dll
   Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Apply Texture.dll
   AutoChromeNoise, Version=1.0.3847.37353, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll
   BasicPhotoAdjustments, Version=1.5.3472.42856, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicPhotoAdjustments.dll
   BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Black and White Converter.dll
   BlackandAlpha+, Version=1.1.3809.21705, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll
   BlendModesPlus, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlendModesPlus.dll
   "Borders N' Shapes", Version=1.8.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll
   Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll
   Burninate, Version=1.1.3182.28956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll
   CircleText, Version=1.2.3586.32801, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircleText.dll
   Color Match, Version=1.1.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll
   ColorBalance, Version=1.1.3182.30196, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll
   ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMixer.dll
   ColorModulo, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll
   ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorToAlpha.dll
   ColorZoomBlur, Version=1.0.3843.28837, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll
   CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll
   CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll
   CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll
   Curves+, Version=3.0.3627.29849, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll
   CustomBrushesMini, Version=1.9.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll
   Dissolve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dissolve.dll
   dpyColorBalance, Version=1.0.3518.25420, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll
   EdHarvey.Edfects.Common, Version=3.36.3160.38013, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Edfects.Common.dll
   EdHarvey.Effects, Version=3.5.3786.8637, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll
   EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll
   EOEffects, Version=1.7.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EOEffects.dll
   ExtendBorder, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtendBorder.dll
   ExtractColor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtractColor.dll
   Feather, Version=3.0.3723.26349, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Feather.dll
   Film, Version=2.0.3612.21577, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll
   FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll
   Flip, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll
   Fractal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fractal.dll
   Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frame.dll
   GaussianBlurPlus, Version=1.1.3182.30307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll
   Gradient Bars, Version=3.0.3627.29850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll
   Gradient Blocks, Version=1.0.3742.38604, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll
   GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll
   Gradient Mapping, Version=3.0.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll
   Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll
   GridMaker, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll
   HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll
   Hue_Saturation+, Version=1.0.3277.32208, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Hue_Saturation+.dll
   ImageShackUpload, Version=2.6.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll
   PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\jchunn.dll
   Jitter, Version=3.0.3612.21576, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll
   KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll
   Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll
   Koch_Snowflake, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Koch_Snowflake.dll
   Landscape, Version=1.1.3593.25344, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll
   Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lightning.dll
   LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll
   LocalContrast, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalContrast.dll
   Lomography, Version=1.1.3182.31441, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lomography.dll
   MakeTransparent, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MakeTransparent.dll
   Metallize, Version=1.1.3504.33530, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Metallize.dll
   Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll
   MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll
   MultiThreshold, Version=1.0.3730.36634, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiThreshold.dll
   NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll
   Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll
   Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll
   Outline Object, Version=2.6.3612.21574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll
   PageCurl, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll
   Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Panelling.dll
   NewPastel, Version=1.2.3182.29587, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll
   PerlinTexture, Version=1.0.3842.30245, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerlinTexture.dll
   Perspective, Version=2.0.3716.33788, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Perspective.dll
   phips_fill_gaps, Version=1.0.3307.18956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_fill_gaps.dll
   PhotoAdjustments, Version=1.1.3670.37697, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll
   Pixelate+, Version=1.2.3742.38634, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll
   PointBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PointBlur.dll
   Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll
   PrinterPlus, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll
   PSFilterPdn, Version=1.0.2.9, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PSFilterPdn.dll
   pyrochild.effects.REQUIRED, Version=3.6.3742.39840, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll
   Radialcolors, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll
   RainbowTwist, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll
   Random Shape Fill, Version=1.5.3621.26292, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll
   RedEyeQuickFix, Version=1.1.3161.39688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RedEyeQuickFix.dll
   RotateText, Version=1.0.3586.32866, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateText.dll
   SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll
   SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll
   SelectionTools, Version=2.0.3746.20418, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll
   ShadowHighlight, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowHighlight.dll
   Sharpen+, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sharpen+.dll
   Smudge, Version=3.0.3742.38657, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll
   SpiralText, Version=1.2.3586.32826, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiralText.dll
   Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll
   Splatter, Version=1.6.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll
   StarGlow, Version=1.0.3839.21249, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StarGlow.dll
   Steganography, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Steganography.dll
   Stitch, Version=1.0.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll
   ThatOtherApp, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll
   ThreadsMarker, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll
   Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll
   TJacksonEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TJacksonEffects.dll
   Trail, Version=1.0.3723.27562, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Trail.dll
   Transparency, Version=1.1.3182.29244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll
   TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll
   Twist, Version=1.0.3742.39641, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Twist.dll
   WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll
   Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll
   WaveText, Version=1.0.3586.32711, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveText.dll
   WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll
   System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
   Microsoft.VisualBasic, Version=8.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\Microsoft.VisualBasic\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
   System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll
   AnimGIF, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AnimGIF.dll
   IcoCur, Version=3.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\IcoCur.dll
   OptiPngFileType, Version=8.11.30.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\OptiPngFileType.dll
   PhotoShop, Version=1.5.1.23908, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll
Native modules:
   C:\Windows\SYSTEM32\ntdll.dll
   C:\Windows\SYSTEM32\MSCOREE.DLL
   C:\Windows\system32\KERNEL32.dll
   C:\Windows\system32\KERNELBASE.dll
   C:\Windows\system32\ADVAPI32.dll
   C:\Windows\system32\msvcrt.dll
   C:\Windows\SYSTEM32\sechost.dll
   C:\Windows\system32\RPCRT4.dll
   C:\Windows\system32\SHLWAPI.dll
   C:\Windows\system32\GDI32.dll
   C:\Windows\system32\USER32.dll
   C:\Windows\system32\LPK.dll
   C:\Windows\system32\USP10.dll
   C:\Windows\system32\IMM32.DLL
   C:\Windows\system32\MSCTF.dll
   C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
   C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\MSVCR80.dll
   C:\Windows\system32\shell32.dll
   C:\Windows\system32\ole32.dll
   C:\Windows\system32\profapi.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\mscorlib\f58ab951b57c8526430486dcf7ee38fd\mscorlib.ni.dll
   C:\Windows\system32\CRYPTBASE.dll
   C:\Windows\system32\uxtheme.dll
   C:\Windows\system\HsSrv.dll
   C:\Windows\system32\WINMM.dll
   C:\Windows\system32\DSOUND.dll
   C:\Windows\system32\POWRPROF.dll
   C:\Windows\system32\SETUPAPI.dll
   C:\Windows\system32\CFGMGR32.dll
   C:\Windows\system32\OLEAUT32.dll
   C:\Windows\system32\DEVOBJ.dll
   C:\Windows\system32\VERSION.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\System\500ddd904b1099f95552a81b54223b7f\System.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Core\b1a619266964bede98b18ef83eb1c559\System.Core.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\WindowsBase\3c0fbe23fa37ca50fea3dbe200b40f7a\WindowsBase.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\fdeec42fa02f3d789c42be2e33b130eb\System.Drawing.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\f92c882fd4e7005c005e208daa04c28d\System.Windows.Forms.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Base\39f2976c43cb31050841caa447598bcd\PaintDotNet.Base.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.SystemL#\178169ac2eeb330422e33e0b8c147126\PaintDotNet.SystemLayer.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Resourc#\198079031daa1c31264520b27b05b5ec\PaintDotNet.Resources.ni.dll
   C:\Windows\system32\CRYPTSP.dll
   C:\Windows\system32\rsaenh.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Core\febc6524084c3acc1c88b171a0328a3e\PaintDotNet.Core.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Data\c5fc705e8b47139f1540eb8f9e9ea5b0\PaintDotNet.Data.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet\bb46adb9f1a39232501eab0254a810b2\PaintDotNet.ni.exe
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.SystemL#\4b75b9e9ba4982da2d96f7c5694bd44f\PaintDotNet.SystemLayer.Native.x86.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\Interop.WIA\70d1a07d350c1fc7a3c221e85a6a3682\Interop.WIA.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Effects\72dc66b0a81af71d413f25d8acc25c27\PaintDotNet.Effects.ni.dll
   C:\Program Files\Paint.NET\Native.x86\PaintDotNet.Native.x86.dll
   C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc0e5a\MSVCR90.dll
   C:\Windows\WinSxS\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.4148_none_80b7c8a91e9dd16a\VCOMP90.DLL
   C:\Windows\system32\dwmapi.dll
   C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7cbf861225ca\gdiplus.dll
   C:\Windows\system32\WindowsCodecs.dll
   C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_420fe3fa2b8113bd\comctl32.dll
   C:\Windows\WinSxS\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4148_none_51ca66a2bbe76806\ATL90.DLL
   C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
   C:\Windows\system32\d2d1.dll
   C:\Windows\system32\dwrite.dll
   C:\Windows\system32\RpcRtRemote.dll
   C:\Windows\system32\wtsapi32.dll
   C:\Windows\system32\WINSTA.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Design\11768b1a056f85182e774a21dd920347\System.Design.ni.dll
   C:\Windows\assembly\NativeImages_v2.0.50727_32\Microsoft.VisualBas#\401d4cd2a06122a32cf094d541dcdd63\Microsoft.VisualBasic.ni.dll
   C:\Windows\system32\RichEd20.DLL
   C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Xml\3060dfcdecbeb8ee65077fb29b217c3d\System.Xml.ni.dll
   C:\Windows\Microsoft.NET\Framework\v2.0.50727\diasymreader.dll
   C:\Windows\system32\apphelp.dll
   C:\Windows\system32\CLBCatQ.DLL
   C:\Windows\system32\explorerframe.dll
   C:\Windows\system32\DUser.dll
   C:\Windows\system32\DUI70.dll
   C:\Windows\system32\WINTRUST.dll
   C:\Windows\system32\CRYPT32.dll
   C:\Windows\system32\MSASN1.dll
   C:\Windows\system32\psapi.dll
Exception details:
System.InvalidOperationException: Invoke or BeginInvoke cannot be called on a control until the window handle has been created.
  at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
  at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
  at PSFilterPdn.PsFilterPdnConfigDialog.Run32BitFilterProxy(EffectEnvironmentParameters eep, PluginData data)
  at PSFilterPdn.PsFilterPdnConfigDialog.<>c__DisplayClass3.<runFltrBtn_Click>b__1()
  at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
  at System.Threading.ExecutionContext.runTryCode(Object userData)
  at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
  at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
  at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
  at System.Threading.ThreadHelper.ThreadStart()
Edited by YARDofSTUF
Awesome work!
The crash is because the dialog was closed before the filter was done rendering, this will fixed in the next update.
That filter works for me unless it is at 100% zoom then it displays a "Memory access violation" dialog, this seems to happen to certain Filter Meister filters
and I have been unable to find what the problem is. >:O
Also according to that crash log you need to update Paint.NET to 3.5.7. :)
Sorry, I'm slow... But how do I get this to work?
This plugin does nothing by itself, you have to put Photoshop 8bf filter(s) in the "Effects" folder and use this plugin to run them.
Edited by null54
I got the Photoshop thing in effects, but what do I do with the effects I downloaded from Flaming Pear?
You can also add the directory that any Photoshop filters are located in to the "Search Directories" list, this is useful if the Photoshop filters use an installer for example.
I dont get it....
How do I use the effects? What files do I put in the "Effects" folder, from the folder I downloaded?
greenAndBlue1.png?t=1299275824
You can just put the folder that you downloaded in the "Effects" folder, the plugin will find any filters it can use inside any folder in the Effects folder.
You just select the effect you want to use in the list and click "Run Filter".
I can't get to that part, I'm not sure what I put into the "Effects" folder. Do I put the whole folder that I downloaded from Flaming Pear, or is there a specific file that I only put in there?
You put the whole folder, it is easier and more organized than copying all the *.8bf files inside the folder.
  • null54 changed the title to PSFilterPdn (2023-01-25)
  • Rick Brewster featured this topic
