Sparkles Effect Plugin (ymd:100725)
  • Please log in to reply
36 replies to this topic
#1 MadJik
MadJik
  • Members
  • 2,428 posts
  • LocationLille;France
Posted 12 April 2008 - 08:49 AM
What's this?
First of all, the initial idea belongs to kshotts: scanning the picture to find out the little shinning stars to add them some sparkles.
Second I'm calling flaRe the circle and flaKe the star.
This is a plugin under Effect/Render menu.
Download the DLL
Plugin Sparkles.dll
Posted ImageHere is the DLLPosted Image
The source is available with the plugins package!
http://forums.getpaint.net/index.php?showtopic=7186
How to install?
Close Paint.net
Unzip and place the DLL in your Effect folder usually: C:/Program Files/Paint.NET/Effects
The User interface
This plugin is added to the menu Effects, submenu Render.
Posted Image
Maximum quantity of sparkles to add (security limit):
If the image is too light (white) the plugin was hanging, because all and every pixels were considered as a brilliant spot to add a sparkle to!
And so it was running for hours/days/weeks!
The limit is here to avoid this problem.
Play between the limit and the brightness threshold to have a good coverage over the image...
Brightness Threshold:
Increase the value to select only the brightest pixels.
Maximum Glitter Size:
Maximum (if random checked) radius.
Glitter Possibility :
Possibility (0=none, 100=all) for a bright pixel to receive a glitter.
Flare/Flake ratio:
0=only flares, 100=only flakes, other=ratio between flares & flakes.
Flare normal/invert ratio:
0=only normals, 100=only inverts. Normals are brighter in the center.
Flake normal/invert ratio:
Flare number of vertices:
Quantity of rays to draw for the flare (0=perfect circle).
Flake number of vertices:
Quantity of vertices for the flake (star).
Random size:
If checked all glitters have a random radius up to the selected maximum size. Else they all have the same size to the maximum.
Some examples:
Original model:
Posted Image
Only flakes:
Posted Image
Only flares:
Posted Image
Fireworks!
Posted Image
Shooting stars!
Posted Image
____________________________________________
Caviar:
Posted Image
Some tips:
__The glitters are created from the top-left corner to the bottom-right corner. The last one overwrites the first one.
__A spot with a small radius is made with several pixels and each pixel of the spot could receive a glitter.
#2 IceFusion
IceFusion
  • Members
  • 394 posts
  • LocationSouth Africa
Posted 12 April 2008 - 10:20 AM
Shooting stars! Jay, it looks great.
Do you sleep at night or keep on writing plugins? :D
Thanks!
Posted Image
:) Visit-> My Website <-Visit :)
Please Call Me Elite Override
The trick to flying is throwing yourself at the floor and missing.
#3 pipp92
pipp92
  • Members
  • 1,297 posts
Posted 04 May 2008 - 01:00 PM
Great plugin thanks!
#4 tekkaro
tekkaro
  • Newbies
  • 3 posts
  • Locationi forget ):
Posted 13 May 2008 - 02:51 AM
Can be used in SO MANY ways. Thanks :AddNoise:
Posted Image
#5 Dalton
Dalton
  • Members
  • 572 posts
Posted 15 May 2008 - 08:09 PM
Shooting stars!
:lol:
I like that. Looks awesome.
I'm gonna definitely use this sometime. :D
MyBB Tutorials, check out my site. :)
#6 hossa_x
hossa_x
  • Newbies
  • 6 posts
Posted 25 May 2008 - 05:16 PM
after u go to effects where do u go :?:
#7 Simon Brown
Simon Brown
  • Members
  • 10,186 posts
Posted 25 May 2008 - 05:21 PM
Try This: viewtopic.php?f=16&t=2023
I recommend using search next time, it will save karma and allow you to reach the answer without waiting for a response.
Welcome to the forums. :)
Posted Image
#8 Division
Division
  • Newbies
  • 7 posts
Posted 11 June 2008 - 10:45 AM
I actually tried adding this to a black background, and nothing happened.
#9 MadJik
MadJik
  • Members
  • 2,428 posts
Posted 12 June 2008 - 02:19 PM
You need to spot some white dots on a dark background to see the effect...
#10 old-scouse
old-scouse
  • Members
  • 18 posts
  • LocationDoncaster England
Posted 17 August 2008 - 05:17 PM
Brilliant Madjik, Thanks. :D :D
#11 tulip
tulip
  • Members
  • 24 posts
Posted 26 November 2008 - 11:55 AM
This is a great effect but I can't seem to get the controls to render the same effects as your examples above!
Failing to prepare for a Yeti attack is preparing to fail a Yeti attack.
http://listen2missy.blogspot.com
http://paintdotnet.f...hp?f=26&t=27828
Posted Image
#12 MadJik
MadJik
  • Members
  • 2,428 posts
Posted 26 November 2008 - 02:21 PM
So the settings for my examples are:
Only flakes:
Flakes/Flares Ratio: 100
Flakes Normal/Inverted Ratio: 0
others at default
Only flares:
Flakes/Flares Ratio: 0
Flares Normal/Inverted Ratio: 0
others at default
Fireworks!
Flakes Normal/Inverted Ratio: 100
Flakes number of vertices: 50
others at default
Shooting stars!
Maximun Glitter size: 400
Glitter Possibility: 100
Flakes number of vertices: 1
others at default
Caviar:
Put some white dots on a black background (no image used)
others at default
#13 m2lucky
m2lucky
  • Members
  • 164 posts
Posted 05 January 2009 - 04:28 AM
ooo this is a cool effect that I will beable to use alot
Music Brings color to the world
Posted Image
My Gallery|Frozen Text|Snowy Font|MSNBC Effect
#14 Sirzach
Sirzach
  • Newbies
  • 4 posts
Posted 19 January 2009 - 02:09 AM
Nice plug-in! Ill definatly use this one. This could be used...in like, 1000 ways for me! Thanks again!
Posted Image
#15 Possum Roadkill
Possum Roadkill
  • Competition Hosts
  • 2,051 posts
  • LocationHenry County Indiana USA
Posted 14 February 2009 - 08:43 AM
This is the first plugin I downloaded. I don't quite have it down just yet, but it is exactly what I was looking for. I know after I work with it for a while, I'll get the hang of it. Very very nice effect. Thanks so much, I know I will use this a lot. My geography website is all open source except for the logos and other graphics on the Home Page, I use MapServer for the GIS mapping, but I am committed to using Open Source software just to prove that the entire site can be done with Open Source. Everyone said I couldn't do a mapping site with Open Source but I did and now I want to complete the project and replace all the graphics with images from Paint.NET. Thanks again !
Posted Image
My Gallery
To visit the Comps click HERE
#16 MadJik
MadJik
  • Members
  • 2,428 posts
Posted 20 February 2009 - 08:53 AM
You're welcome! Please give a link to you website...
#17 boogster1
boogster1
  • Members
  • 69 posts
  • LocationScottsdale, Arizona
Posted 09 March 2009 - 03:42 PM
Nice plugin! Now let's sparkle our teeth, without any brushing!! :mrgreen:
Posted Image
BoogsterSU~Killer's Korner~Photobucket~The 600th User!!! :P
"Yep! Everyone loves dogs! And most of us love to know what heaven looks like! But however, there's one who thinks that "All Dogs Go to Heaven"! And that's me!" --Myself
#18 MadJik
MadJik
  • Members
  • 2,428 posts
Posted 09 September 2009 - 04:24 AM
If the image is too light (white) the plugin is hanging, because all and every pixels are considered as a brilliant spot to add a sparkle to! And so it could be running for hours/days/weeks if the limit is high!
The glitters are created from the top-left corner to the bottom-right corner. So if the limit is too low only the top of the image is covered.
Read the post 1 for more details.
#19 nemo
nemo
  • Members
  • 1,428 posts
  • Locationin your periphery
Posted 09 September 2009 - 07:44 AM
That has some nice possibilities :shock:
Posted Image
My Gallery ------------------------------------Skin painting tutorial
We can push out, sell out, die out.
#20 MadJik
MadJik
  • Members
  • 2,428 posts
