Simulate Color Depth: Updated 13-07-11
  • Please log in to reply
6 replies to this topic
#1 Cookies
Cookies
  • Members
  • 111 posts
  • LocationSomewhere in Denmark
Posted 11 October 2010 - 03:41 PM
This plugin simulate images as if they had X count of bits in total both monochrome and RGB are included
screenshot:
Posted Image
before:
Posted Image
after (dithering - Bayer 8x8):
Posted Image
after (dithering - Floyd Steinberg):
Posted Image
after (no dithering):
Posted Image
As you see the colors got reduced when the setting is 3bit RGB but with dithering enabled it doesn't look that harsh as if there wasn't dithering enabled.
If you are wondering why i didn't include 8bit then press Ctrl+Shift+G when you have a colored image open, 8bit monochrome is the same greyscaling an image everything from 9bit and above is colored, in 16bit mode it add's an extra bit to the green component because the human eye is more sensitive to green then red and blue (which can be read in the wiki page linked to below)
Click here to download
Put the DLL into Paint.NET/Effects folder and "Paint.NET User Files" folder in the zip into your documents folder
i used this wiki page as guideline, although the results i get is nothing like the ones on the page i do still believe my results are good i also got the test image from that wiki page
Hidden Content: Change log
Edited by Cookies, 16 July 2011 - 02:24 PM.
Posted Image
#2 Sarkut
Sarkut
  • Competition Hosts
  • 3,206 posts
Posted 11 October 2010 - 05:17 PM
Very nice.
Thanks !
Posted Image
#3 Cookies
Cookies
  • Members
  • 111 posts
Posted 14 October 2010 - 07:56 PM
Very nice.
Thanks !
Thank you :)
Updated, added dithering and 4 different dithering modes for you  B)
Posted Image
#4 Cookies
Cookies
  • Members
  • 111 posts
Posted 15 October 2010 - 05:02 PM
another little update adding 3 new dithering's made by using my head :P
Edited by Cookies, 11 July 2011 - 07:14 PM.
Posted Image
#5 Cookies
Cookies
  • Members
  • 111 posts
Posted 13 July 2011 - 03:46 PM
Updated, completely changed how this thing works. Will work on another plugin for making dither algorithms for this later, also might make this multithreaded later
(Plugin update on my birthday ... Wooo!)
Edited by Cookies, 13 July 2011 - 03:50 PM.
Posted Image
#6 pdnnoob
pdnnoob
    Paint.NET's Rabbi for 2012
  • Moderators
  • 1,807 posts
Posted 13 July 2011 - 05:22 PM
Happy birthday and thx for the plugin! This may actually come in handy sometime soon...
Posted Image
what I do all summer Emote Cursor Pack Paint Job Competition 'noob gallery
#7 wakanayumi
wakanayumi
  • Newbies
  • 3 posts
Posted 25 April 2012 - 08:35 PM
I'm not sure if I should post this in this topic or in a new topic in the "Bug reports" section, but I'll try posting it here first.
My OS is Windows 7 Home Premium 32-bit, & my version of PDN is 3.5.10 portable. Anyway, on 4-25-2012, I downloaded "Simulate color depth" from here. It works very well mostly, except for this bug. You need to have the "Dither" box checked. Then, if you try to use "Stucki" dithering (which doesn't seem to work at all), it will ignore your attempt to use it, & changing the dithering from "Stucki" to a different dither crashes the plug-in. I'm surprised that nobody has posted this before now (I would've posted about it earlier, but my circumstances kept me away from the internet for a very long time).
Also, the only ditherings that I can find are "Floyd-Steinberg", "Stucki", & "Bayer Ordered 8x8". Any help with that?
Finally, I hope that in a future version, you add color versions of all of the bit modes. I trust that I won't have to try too hard to convince you that the option of keeping your color images colored is as important as making them gray-scaled.
Edited by wakanayumi, 04 May 2012 - 01:15 AM.
