Mick Berg Posted September 29, 2022 Share Posted September 29, 2022 (edited) Hi Not quite sure how to describe this behaviour. When I am using the paintbrush, and I have the picture enlarged, if I get near to the edge of the frame, it shifts, and draws all over the image. It is a disaster. How do I stop this "feature"? Thanks Michael Edited September 29, 2022 by Mick Berg typo Quote Link to comment Share on other sites More sharing options...
MJW Posted September 29, 2022 Share Posted September 29, 2022 3 hours ago, Mick Berg said: Not quite sure how to describe this behaviour. Yes, I believe I know what you're referring to. When you hit the edge, the canvas starts rapidly auto-scrolling, resulting in a long line in the direction you're moving the paintbrush (or whatever other tool). It can be quite irksome. The only workaround I know of is to make sure whenever you get near an edge, you stop and manually scroll the canvas to move the location you're painting away from the edge, before continuing. It's inconvenient, but on the other hand, I think it's usually a good idea to break up painting into a number of steps, so that when you make a mistake and have to undo, you don't undo all your work. I suppose this (unintentionally) helps encourage that behavior. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 30, 2022 Share Posted September 30, 2022 It might help to turn the overscrolling off (Setttings > User Interface > 5th checkbox). It won't stop the image scrolling, but will limit the damage by stopping at the image edge. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
IdaMan Posted October 14, 2022 Share Posted October 14, 2022 I have the same issue and its maddening!!!!! I am so upset! I have wasted hours trying everything to stop the canvas jerking here and there, streaking splotches and lines unless I catch it in time! I rarely use paint.net these days and liked it. I still miss being able to sample color just by using the mouse et al photoshop. But the canvas lurching in paint.net when trying to paint is a game stopper. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 14, 2022 Share Posted October 14, 2022 Yes, it would be nice to have an option to disable the feature. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
BoltBait Posted October 14, 2022 Share Posted October 14, 2022 I agree. I would also like to turn this feature off. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
MJW Posted October 15, 2022 Share Posted October 15, 2022 What really should happen, I think, is that when the edge is reached, the tool continues to move at the same speed across the canvas as it was moving, rather than going into hyperdrive. I have no idea how easy or difficult it would be to make it work that way. 1 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 15, 2022 Share Posted October 15, 2022 Configuring the sensitivity of the auto-scroll has proven challenging when I've looked at it in the past But things are in a really good spot right now and y'all have lobbied me successfully such that I just added this for the upcoming 5.0 release: (it took more time to write up this comment than to implement the feature) You might notice another nice new setting in this screenshot that I added a month or so back when I was in a particularly good mood and the morning coffee was working just right If all goes well I should be able to have a public alpha release around the time of .NET 7.0's release in mid-ish-November. I'm currently wrapping up a massive new effect plugin system that has been in development this year, and it's important to get it absolutely right, so I can't make any hard promises about release dates, but I'm currently optimistic. It may be that this should be more than just a checkbox, but we'll start with the checkbox and adjust it from there. 3 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 15, 2022 Share Posted October 15, 2022 As a reminder, PDN 5.0 will have updated system requirements -- Windows 10 v1809+ (64-bit) -- so make sure you've updated your OS if you're still holding on to Windows 7 or 8.1. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
