Rick Brewster Posted June 14, 2019 Share Posted June 14, 2019 This should be the final alpha release of 4.1.7. Next up I'll be integrating translation updates, fixing any last issues, and releasing the final build. A lot more work went in this build than I was expecting! I decided to take on the work of making sure effect plugins could have good access to the clipboard, which is otherwise a very buggy area to navigate. A lot of other bugs and things were sorted out as well. Download link: https://www.getpaint.net/files/zip/test/paint.net.4.107.7104.37431.install.zip Note: I'll be adding this to the built-in updater later today. For now, please use the download link above. Changes since build 7079: * New: Keyboard shortcuts for changing the current layer. You can see these in the Layers menu with the "Go to ..." commands. Alt+PgUp/PgDown will go to the layer above/below, and Ctrl+Alt+PgUp/PgDown will go to the top/bottom layer. * New: PNGs can now be saved as "interlaced" * New: Plugins that use IndirectUI can now use a UriProperty with a LinkLabel control (thanks @null54!) * New: Effect plugins can now more easily make use of the clipboard via the IClipboardService. It will handle all of the tricky clipboard issues such as threading, native data marshaling, and avoiding security vulnerabilities that exist in the standard WinForms and WPF clipboard APIs. * Improved: When using Edit->Copy, a 32-bit BGRA bitmap in the DIBV5 format is now placed onto the clipboard so that other apps can read the alpha channel. * Improved: When using Edit->Paste, DIBV5's are now supported if they have an alpha channel. If they don't, then the regular DIB loader is used which has some heuristics for detecting an incorrectly defined alpha channel and correcting for it. * Improved: When using Edit->Paste, PNG is now the highest priority format. This maximizes the ability to maintain alpha/transparency, but it does mean that images coming from Microsoft Office apps will appear larger than they used to. This is either a bug or a feature of Microsoft Office. For some reason it places PNGs on the clipboard that are 25%+ larger than the DIB/DIBV5 bitmap that it also places on the clipboard (but which don't have alpha/transparency). * Fixed: 8-bit TGA images should now load correctly (thanks @null54 for the fix!) * Fixed: Some 32-bit TGA images were showing up as completely transparent due to their use of an obscure alpha channel type (thanks @null54 for the fix!) * Fixed: Simple message boxes can now be closed with the ESC key * Fixed: Some TIFFs could not be resaved as a JPEG due to having too much metadata (usually from Adobe Photoshop). The metadata is now discarded if necessary. * Changed: Blocked the WebP FileType v1.1.0.0 plugin due to instability. An update is already available. * Changed: Blocked the ImAgif FileType v0.12.0.1084 plugin due to incompatibility. An update will hopefully soon be available. Enjoy! 3 1 The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
null54 Posted June 14, 2019 Share Posted June 14, 2019 Bug: The TryGetText and TryGetSurface extension methods cannot be accessed by plugins because they are defined in an internal class. I did not discover this during my earlier testing because I was using a built-in effect to test the API. Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15, 2019 Author Share Posted June 15, 2019 Oh, well that should be easy enough to fix The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
BoltBait Posted June 15, 2019 Share Posted June 15, 2019 13 hours ago, Rick Brewster said: * New: Plugins that use IndirectUI can now use a UriProperty with a LinkLabel control Support for this will be in the next release of CodeLab. 1 Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
Seerose Posted June 15, 2019 Share Posted June 15, 2019 @Rick Brewster! I have problems. After the new update, if I want to import or save image crashes the program. What should I do now? Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
Pixey Posted June 15, 2019 Share Posted June 15, 2019 Downloaded! (Just noticed Rick's new car ) How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Seerose Posted June 15, 2019 Share Posted June 15, 2019 (edited) ~ deleted the huge highlighted text per request of @Seerosewho had a problem posting an error message ~ Edited June 15, 2019 by Pixey deleted per request of Seerose Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15, 2019 Author Share Posted June 15, 2019 47 minutes ago, Seerose said: @Rick Brewster! I have problems. After the new update, if I want to import or save image crashes the program. What should I do now? Post here with exactly what you're doing, any crashlogs, steps to reproduce the problem (video if necessary, always helpful), and include sample images if necessary. 1 The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Pixey Posted June 15, 2019 Share Posted June 15, 2019 Hello @Rick Brewster A few minutes ago @Seerose requested I delete her crash log as it appeared in very strange highlighted text. Whilst working with it my computer acted very strangely. Anyway, I deleted it, but I copied it to word and you can view it from my Dropbox link: https://www.dropbox.com/s/su0z6470jlngiho/Seerose Crash Log.doc?dl=0 1 How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15, 2019 Author Share Posted June 15, 2019 It's extremely difficult to look through that, and I think it's missing the top part which is what I really need. Do you still have the original? Or @Seerose can just post a new one if it's always happening. It seems to be related to loading FileType plugins at startup, but I can't see the full cause. For future reference, crash logs can be posted successfully if they are put in-between [ code ] tags 1 The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Pixey Posted June 15, 2019 Share Posted June 15, 2019 4 minutes ago, Rick Brewster said: It's extremely difficult to look through that, and I think it's missing the top part which is what I really need. Do you still have the original? Or @Seerose can just post a new one if it's always happening. It seems to be related to loading FileType plugins at startup, but I can't see the full cause. For future reference, crash logs can be posted successfully if they are put in-between [ code ] tags The first part was missing when she posted. Hopefully she will try to post the error again, if the trouble continues. I have tested this newer version and it's working fine with importing and saving for me 1 How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Seerose Posted June 15, 2019 Share Posted June 15, 2019 Dear @Pixey and @Rick Brewster! Thank you so much. Is that enough crash report? Spoiler This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem. Application version: paint.net 4.1.7 (α 4.107.7104.37431) Time of crash: 15.06.2019 17:07:11 Application uptime: 00:06:35.4476183 Application state: Running Working set: 261.820 KiB Handles and threads: 2108 handles, 38 threads, 197 gdi, 227 user Install type: Classic Application directory: C:\Program Files\Paint.NET Current directory: C:\Program Files\Paint.NET Install directory: C:\Program Files\Paint.NET\ OS Version: Windows 7 Home Premium 6.1.7601.65536 Service Pack 1 x64 (0x3) .NET version: CLR 4.0.30319.42000 x64 Processor: "Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz" @ ~2294MHz (2C/4T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX) Physical memory: 4010 MB Video card: Intel(R) HD Graphics Family (v:8086, d:116, r:9) Hardware acceleration: False (default: False) UI animations: True UI DPI: 96 dpi (1,00x scale) UI theme: VisualStyleClass=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Dark, ThemeFileName=Aero.msstyles Updates: True, 15.06.2019 Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: de-DE, cuic: en-US Flags: Exception details: Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
Seerose Posted June 15, 2019 Share Posted June 15, 2019 Spoiler This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem. Application version: paint.net 4.1.7 (α 4.107.7104.37431) Time of crash: 15.06.2019 16:59:41 Application uptime: 00:17:58.9755543 Application state: Running Working set: 249.296 KiB Handles and threads: 2056 handles, 32 threads, 202 gdi, 228 user Install type: Classic Application directory: C:\Program Files\Paint.NET Current directory: C:\Program Files\Paint.NET Install directory: C:\Program Files\Paint.NET\ OS Version: Windows 7 Home Premium 6.1.7601.65536 Service Pack 1 x64 (0x3) .NET version: CLR 4.0.30319.42000 x64 Processor: "Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz" @ ~2294MHz (2C/4T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX) Physical memory: 4010 MB Video card: Intel(R) HD Graphics Family (v:8086, d:116, r:9) Hardware acceleration: False (default: False) UI animations: True UI DPI: 96 dpi (1,00x scale) UI theme: VisualStyleClass=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Dark, ThemeFileName=Aero.msstyles Updates: True, 15.06.2019 Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: de-DE, cuic: en-US Flags: Exception details: System.ArgumentNullException: Value cannot be null. Parameter name: type at PaintDotNet.ExceptionUtil.ThrowArgumentNullException(String paramName) in D:\src\pdn\src\Base\ExceptionUtil.cs:line 48 at PaintDotNet.AppModel.PluginErrorInfo..ctor(PluginType pluginType, Assembly assembly, String filePath, Type type, Exception error) in D:\src\pdn\src\PaintDotNet\AppModel\PluginErrorInfo.cs:line 154 at PaintDotNet.AppModel.PluginErrorService.ReportPluginLoadError(PluginType pluginType, Assembly assembly, Type type, Exception error) in D:\src\pdn\src\PaintDotNet\AppModel\PluginErrorService.cs:line 59 at PaintDotNet.Data.FileTypesCollection.<GetFileTypeFactoryTypesFromAssembly>d__14.MoveNext() in D:\src\pdn\src\PaintDotNet\Data\FileTypesCollection.cs:line 238 at PaintDotNet.Data.FileTypesCollection.<LoadFileTypes>d__13.MoveNext() in D:\src\pdn\src\PaintDotNet\Data\FileTypesCollection.cs:line 165 at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) at PaintDotNet.Collections.EnumerableExtensions.ToArrayEx[T](IEnumerable`1 items) in D:\src\pdn\src\Base\Collections\EnumerableExtensions.cs:line 40 at PaintDotNet.Data.FileTypesCollection.InitializeWhileLocked() in D:\src\pdn\src\PaintDotNet\Data\FileTypesCollection.cs:line 88 at PaintDotNet.Data.FileTypesCollection.EnsureInitialized() in D:\src\pdn\src\PaintDotNet\Data\FileTypesCollection.cs:line 78 at PaintDotNet.Dialogs.FileDialogUtil.ChooseFiles(Control owner, Boolean multiselect, String startingDir, String[]& fileNames) in D:\src\pdn\src\PaintDotNet\Dialogs\FileDialogUtil.cs:line 30 at PaintDotNet.Actions.ImportFromFileAction.PerformAction(DocumentWorkspace documentWorkspace) in D:\src\pdn\src\PaintDotNet\Actions\ImportFromFileAction.cs:line 352 at PaintDotNet.Controls.DocumentWorkspace.PerformAction(DocumentWorkspaceAction action) in D:\src\pdn\src\PaintDotNet\Controls\DocumentWorkspace.cs:line 977 at PaintDotNet.Menus.LayersMenu.OnMenuLayersImportFromFileClick(Object sender, EventArgs e) in D:\src\pdn\src\PaintDotNet\Menus\LayersMenu.cs:line 371 at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Managed assemblies: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll PaintDotNet, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe PaintDotNet.Core, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll PaintDotNet.Base, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_64\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll PaintDotNet.SystemLayer, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll PaintDotNet.Framework, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Framework.dll PaintDotNet.Resources, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll PaintDotNet.Effects, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll PaintDotNet.Data, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll PaintDotNet.SystemLayer.Native.x64, Version=4.107.7104.37431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Program Files\Paint.NET\System.Runtime.CompilerServices.Unsafe.dll System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Runtime\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.dll Cell-CS Maker Rev1, Version=1.0.7007.17477, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\379925714_Cell-CSMakerRev1.dll Trail Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\808091270_TrailBlur.dll "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll Aardvark, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Aardvark.dll ABRFileType, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ABRFileType.dll Add Depth, Version=1.0.4247.30168, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Add Depth.dll AdvancedRotate, Version=1.0.3663.28009, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AdvancedRotate.dll advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\advcolorrep.dll AdvGrey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AdvGrey.dll AForge, Version=2.2.5.0, Culture=neutral, PublicKeyToken=c1db6ff4eaa06aeb @ C:\Program Files\Paint.NET\Effects\AForge.dll AForge.Imaging, Version=2.2.5.0, Culture=neutral, PublicKeyToken=ba8ddea9676ca48b @ C:\Program Files\Paint.NET\Effects\AForge.Imaging.dll Alias, Version=2.0.3167.14578, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alias.dll Align, Version=1.0.1.7, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Align.dll AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPlugin.dll Alpha Transform, Version=1.1.3545.21589, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha Transform.dll Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha-Displacement Mask.dll Alpha2Gray, Version=4.5.6832.21862, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha2Gray.dll AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaBlur.dll AlphaContrast, Version=1.0.3813.18307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaContrast.dll alphalevels, Version=1.4.6830.2789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\alphalevels.dll Alphalizer, Version=2.0.5434.24240, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alphalizer.dll AlphaMap2, Version=1.3.3286.22738, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMap2.dll AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMask.dll AlphaMaskBrush, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMaskBrush.dll AlphaSpace, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaSpace.dll AlphaThreshold, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaThreshold.dll AlphaToDots, Version=1.0.4675.19955, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaToDots.dll Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_0.dll Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_255.dll Angled Gradient, Version=1.0.6166.41233, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Angled Gradient.dll Animal, Version=2.2.5.20384, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Animal.dll AnimationEffect, Version=1.0.0.10, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AnimationEffect.dll Antialias, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Antialias_v1.5.8.0.dll Apply Color, Version=1.0.4406.25220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Apply Color.dll Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Apply Texture.dll ArgusPaintNet.Convolution, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPaintNet.Convolution.dll ArgusPaintNet.Shared, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPaintNet.Shared.dll ArgusPDN.Barcode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.Barcode.dll ArgusPDN.EdgeDetect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.EdgeDetect.dll ArgusPDN.FFTEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.FFTEffects.dll ArgusPDN.Unblend, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.Unblend.dll ArtyThing, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArtyThing.dll AutoChrome, Version=1.2.5.19669, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChrome.dll AutoChromeNoise, Version=1.2.5.23331, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll Average Object Color, Version=1.0.6225.37409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Average Object Color.dll AveragedColorBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AveragedColorBlur.dll AverageEdgeBlur, Version=1.0.3991.32409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AverageEdgeBlur.dll AverageSelectionColor, Version=1.1.3256.33886, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AverageSelectionColor.dll BandWPlus, Version=1.1.6909.27136, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BandWPlus.dll Barcode, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Barcode.dll Bars, Version=1.2.5.23704, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bars.dll Base64FileType, Version=1.0.0.4, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Base64FileType.dll BasicPhotoAdjustments, Version=2.1.4020.485, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicPhotoAdjustments.dll OutlinedGradientText, Version=1.1.6826.41783, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BBOutlinedGradientText.dll BevelObject, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BevelObject.dll Bezncurve, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bezncurve.dll Bidirectional Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bidirectional Blur.dll Bizarro-Negation, Version=1.0.4617.21771, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bizarro-Negation.dll BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Black and White Converter.dll BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll BlackAndWhite+, Version=1.1.6744.2631, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackAndWhite+.dll BlackAndWhite, Version=1.2.3526.15024, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackAndWhite.dll BlendModesPlus, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlendModesPlus.dll BlendSeams, Version=1.1.6021.34867, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlendSeams.dll BlurBlend, Version=1.1.6601.26020, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlurBlend.dll BlurFill, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlurFill.dll "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll Boutons, Version=1.2.5.23747, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll boxfitting, Version=1.1.6164.32856, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\boxfitting.dll BrushFactory, Version=1.8.0.12212, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BrushFactory.dll BulletinBoardTrim, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BulletinBoardTrim.dll Burninate, Version=4.5.6827.39185, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll Calendar, Version=4.6.6909.25747, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Calendar.dll CalliColour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CalliColour.dll CameraTrouserFlareV3, Version=1.1.4600.41268, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CameraTrouserFlareV3.dll Cartoonize, Version=1.0.4629.37393, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cartoonize.dll CellMaker, Version=1.1.6139.29120, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellMaker.dll CellMakerRev, Version=1.0.3626.24472, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellMakerRev.dll CellTexture, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellTexture.dll CenterLines, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CenterLines (2).dll ChangeExtremeColors, Version=1.2.6.30674, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChangeExtremeColors.dll Channel Swap, Version=1.0.4602.41418, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channel Swap.dll Channels, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channels.dll Channel Ops, Version=1.1.5347.28486, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channel_Ops.dll ChartWhiteBalance, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChartWhiteBalance.dll ChessFEN, Version=1.1.6139.31083, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChessFEN.dll ChopUp, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChopUp.dll ChromaKeyPlugin, Version=1.0.0.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChromaKeyPlugin.dll Circle Text 2, Version=1.3.6806.39405, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Circle Text 2.dll CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircleText.dll CircularText, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircularText.dll CK_Plugin, Version=1.5.5345.24808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CK_Plugin.dll ClampedGaussianBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClampedGaussianBlur.dll ClipDisplace, Version=1.0.5763.42010, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipDisplace.dll AnimateIt.Effect, Version=0.3.0.436, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AnimateIt.Effect.dll ClipDisplaceAA, Version=1.2.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipDisplaceAA.dll ClipWarp, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipWarp.dll ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipWarpNew.dll OptionBasedLibrary v0.4, Version=0.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\OptionBasedLibrary v0.4.dll Clock, Version=1.1.6245.30896, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Clock.dll CloudEffect, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CloudEffect.dll CMY Ghost, Version=1.0.4909.35063, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CMY Ghost.dll Cobweb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cobweb.dll Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Microsoft.VisualBasic\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll AnimGIF, Version=2.4.4119.28305, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AnimGIF.dll CodeArtEng.DspToolbox, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeArtEng.DspToolbox.dll Color Dimmer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Dimmer.dll Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll ArgusPDN.AppIconSet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ArgusPDN.AppIconSet.dll Color2Alpha, Version=1.0.4975.22238, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color2Alpha.dll coloraberation, Version=1.2.5.15647, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coloraberation.dll ColorBalance, Version=4.5.6832.41698, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll ColorClearer, Version=1.1.6009.41762, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorClearer.dll OptionBasedLibrary v0.7.9, Version=0.7.9.1561, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\OptionBasedLibrary v0.7.9.dll ColorCount, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorCount.dll ColorCut, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorCut.dll colorintensifier plugin, Version=1.0.6941.36918, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorIntensifier.dll ColorMatrix, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMatrix.dll ColorMatrix.Effect, Version=1.1.0.22, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMatrix.Effect.dll ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMixer.dll ColorModulo, Version=1.2.5.25136, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll ColorRange, Version=0.1.5913.41260, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorRange.dll ColorRange2, Version=0.2.5918.38396, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorRange2.dll ColorSketch_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorSketch_en.dll ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorToAlpha.dll ColorZoomBlur, Version=1.2.5.17431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll Colour Distort2, Version=1.0.3564.18753, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Colour Distort.dll complement, Version=0.1.7021.39134, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\complement.dll CompoGrids, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CompoGrids.dll Compotool, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Compotool.dll CSVFiletype, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\CSVFiletype.dll ConditionalEffects, Version=1.3.3919.30824, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ConditionalEffects.dll ContentAwareFill, Version=1.3.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ContentAwareFill.dll Contour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Contour.dll CopyAlpha, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CopyAlpha.dll CopySelectionCoords, Version=1.0.5917.18057, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CopySelectionCoords.dll Cuboids, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cuboids.dll LightningCurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurlyLines.dll OptionBasedLibrary v0.5, Version=0.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\OptionBasedLibrary v0.5.dll CurtisBlack.Common, Version=1.0.3142.30104, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll CurtisBlack.Effects, Version=11.0.3142.30301, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll CurtisBlack.Resources, Version=1.0.3142.30103, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll Curves+, Version=4.0.6119.31044, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll CustomBrushesMini, Version=2.2.5286.39584, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll CycleHSV, Version=1.0.4909.35068, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CycleHSV.dll DHShapeMaker, Version=1.4.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DHShapeMaker.dll Diagonal Lines, Version=1.0.4800.36619, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Diagonal Lines.dll DdsFileTypePlus, Version=1.9.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\DdsFileTypePlus.dll Diffuse, Version=1.0.3254.27766, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Diffuse.dll Dimensions, Version=1.3.6826.38472, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dimensions.dll Displacement, Version=1.3.5.15773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll Display Color Change Direction, Version=2.0.5622.8022, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Display Color Change Direction.dll DispMap, Version=2.0.4919.36181, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DispMap.dll Dissolve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dissolve.dll DistortingMirror, Version=1.2.5.15788, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortingMirror.dll DistortThis, Version=2.9.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortThis.dll Donut, Version=1.2.5.15739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Donut.dll Dot, Version=1.0.4673.202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dot.dll DotMatrix, Version=1.0.6178.27733, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DotMatrix.dll DPL KAL, Version=1.0.3937.11496, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DPL KAL.dll DPL KALsmall2, Version=1.0.3937.11517, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DPL KALsmall2.dll DPLNightVision, Version=1.0.4004.18455, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DPLNightVision.dll dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll DraganEffect_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DraganEffect_en.dll DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DragFrom.dll Dream, Version=4.5.6832.41729, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dream.dll Droste, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Droste.dll Dryad, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dryad.dll EarthsAndGreys, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EarthsAndGreys.dll EdgeBlur, Version=1.1.6578.2673, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeBlur.dll EdgeBlurRGB, Version=1.0.6569.11096, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeBlurRGB.dll EdgeExpander, Version=1.0.5863.38192, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeExpander.dll EdgeFader, Version=5.3.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeFader.dll edgemaster, Version=1.0.3880.5859, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\edgemaster.dll EdgeShaderMJW, Version=1.1.5849.39125, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeShaderMJW.dll EdHarvey.Effects.Archive.PolarInversionPlus, Version=3.22.3024.37811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.Archive.PolarInversionPlus.dll EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll EdHarvey.Effects.Egregious, Version=0.7.2815.9664, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.Egregious.dll EdHarvey.FastFx, Version=4.0.5120.35262, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.FastFx.dll EigenBlur, Version=1.3.3555.24648, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EigenBlur.dll EliminateDarkLight, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EliminateDarkLight.dll Emboss+, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Emboss+.dll EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EngraveEmboss.dll EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EOEffects.dll Equirectangular Viewer, Version=1.0.0.42271, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Equirectangular Viewer.dll ErodeDilate, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ErodeDilate_v0.2.dll ExpandColor, Version=1.2.5.15745, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExpandColor.dll ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtendBorder.dll Facet, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Facet.dll FibonacciFill, Version=1.1.6139.28851, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FibonacciFill.dll FillFromClipboard, Version=4.6.6909.25430, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromClipboard.dll FillFromClipboard_by_YellowAfterlife, Version=1.1.4052.29336, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromClipboard_eff_render.dll FillFromFile, Version=4.6.6909.24920, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromFile.dll FillPalette, Version=1.2.5.32012, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillPalette.dll Film, Version=4.0.4642.26607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll Fisheye, Version=2.2.5533.12794, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fisheye.dll Flip, Version=4.5.6832.41809, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll Flourish, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flourish.dll FloydSteinbergDithering, Version=4.5.6828.38953, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FloydSteinbergDithering.dll MyScript, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FlySwatter.dll ForCrossMirror, Version=1.0.6943.23603, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ForCrossMirror.dll Fractal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fractal.dll FractalAttractor, Version=1.3.5.27448, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FractalAttractor.dll FractalFern, Version=1.2.0.28378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FractalFern.dll FractalTree, Version=1.2.0.38806, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FractalTree.dll Frames, Version=1.2.5.27903, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frames.dll FSPost, Version=1.0.4913.8979, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FSPost.dll FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FurBlur.dll Edge Detect And Affect3, Version=1.0.5885.13123, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FuzzyEdgeDetect.dll GaussianBlurPlus, Version=4.2.5691.27401, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll Gears, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gears.dll Gen96Colors, Version=1.2.0.15608, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gen96Colors.dll Gingham, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gingham.dll Gmic, Version=2.6.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gmic.dll Gossamer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gossamer.dll Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll Gradient Grid, Version=4.0.6436.36068, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Grid.dll Gradient Mapping, Version=4.0.6547.33963, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll Gradient, Version=2.0.2477.21844, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient.dll GradientBlur, Version=1.2.5.28179, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientBlur.dll System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll GradientsGalore, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientsGalore.dll GradientsGaloreMoveable, Version=1.0.4635.28251, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientsGaloreMoveable.dll GradientShapes, Version=1.0.6636.39820, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientShapes.dll Gradual_Stripes_c, Version=1.0.6597.38103, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradual_Stripes_1.3.dll Grain, Version=1.0.3854.25523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grain.dll Gralpha, Version=1.0.3684.31203, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gralpha.dll GraphMaker, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GraphMaker.dll GraphPaper, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GraphPaper.dll Gravity, Version=1.2.5.29548, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll Gray2Alpha, Version=4.5.6826.36897, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gray2Alpha.dll GreenTintReduction, Version=1.0.6484.29238, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GreenTintReduction.dll Grid Warp, Version=4.0.6544.34496, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grid Warp.dll FSHfiletype, Version=1.2.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\FSHfiletype.dll GridCheckerboard, Version=4.5.6828.36789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridCheckerboard.dll GridGrad, Version=1.0.4172.25342, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridGrad.dll GridMaker, Version=5.2.5.29827, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GrimColorReaper.dll ImAGIF.FileType, Version=0.12.1.1088, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImAGIF.FileType.dll GS_Plugin, Version=1.3.5345.24516, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GS_Plugin.dll GuideLines, Version=1.0.6239.35558, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GuideLines.dll hdr1, Version=1.0.6942.26611, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HDR.dll Heightmap plugin v1, Version=1.3.4261.22267, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Heightmap v1.3.dll HeightToNormal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HeightToNormal.dll Helix, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Helix.dll HexaGrid, Version=4.1.0.40699, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll Highlight, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Highlight.dll HighPass, Version=1.2.3903.27501, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HighPass.dll HighPass_rec, Version=1.3.6135.23156, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HighPass_rec.dll HilbertCurve, Version=1.2.0.32151, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HilbertCurve.dll Histogram, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Histogram.dll HotMetalGlow, Version=1.2.5985.32923, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HotMetalGlow.dll IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IniFile.dll HsvEraser, Version=1.1.5625.39352, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HsvEraser.dll HSVGradients, Version=4.5.6832.41864, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HSVGradients.dll ImAPNG.FileType, Version=0.3.0.19, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImAPNG.FileType.dll HsvScrambler, Version=1.0.5670.36729, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HsvScrambler.dll HueSatPlus, Version=4.5.6832.41926, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HueSatPlus.dll IcoCur, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IcoCur.dll ICSharpCode.SharpZipLib, Version=0.85.4.369, Culture=neutral, PublicKeyToken=1b03e6acf1164f73 @ C:\Program Files\Paint.NET\Effects\ICSharpCode.SharpZipLib.dll PluginCompilation, Version=1.1.2992.32335, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\illnabPlugins.dll ImageInText, Version=0.0.1.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageInText.dll InnerShadow, Version=3.0.5509.2925, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InnerShadow.dll InputToOutput, Version=1.0.3167.14695, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InputToOutput.dll InsetBoxShadow, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InsetBoxShadow.dll InterlockingTiles, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InterlockingTiles.dll invert channels, Version=1.0.3509.14656, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\invert channels.dll InvertAlpha, Version=1.0.3040.33378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InvertAlpha.dll invert_around_primcol, Version=1.1.3402.30348, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\invert_around_primcol.dll isolate, Version=1.0.3303.3202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\isolate.dll IsolateWhiteBlack, Version=1.3.3676.24989, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IsolateWhiteBlack.dll IsometricCuboid, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IsometricCuboid.dll IsometricTiled, Version=1.0.6827.41632, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IsometricTiled.dll PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\jchunn.dll JigsawPuzzle, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JigsawPuzzle.dll Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll JuliaPlus, Version=1.2.5.13821, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JuliaPlus.dll JustifyText, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JustifyText.dll ImIFF.FileType, Version=1.0.0.21, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImIFF.FileType.dll KaleidoGen, Version=1.3.5.30504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll Kaleidoscope, Version=1.6.1.27167, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll Kill Color Keeper, Version=1.0.6641.13453, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kill Color Keeper.dll KillColor, Version=1.0.3498.8108, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KillColor.dll ImPDF.FileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImPDF.FileType.dll KlumpNoiz, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KlumpNoiz.dll Koch_Snowflake, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Koch_Snowflake.dll Kuwahara, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kuwahara.dll Lameography, Version=4.0.5285.19635, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lameography.dll Landscape, Version=4.5.6826.38591, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll LaplacianPyramidFilter, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LaplacianPyramidFilter.dll LavEnt.Effects.Mosaic, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LavEnt.Effects.Mosaic.dll LavEnt.Effects.RoundedRectangle, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LavEnt.Effects.RoundedRectangle.dll Layer Cake, Version=1.0.4911.8147, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Layer Cake.dll ImSVG.FileType, Version=0.7.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImSVG.FileType.dll LensFlare, Version=2.2.12.35124, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll LevelHorizon, Version=4.5.6826.37471, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LevelHorizon.dll Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lightning.dll LightRays, Version=2.1.5.14276, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll Line Tracer, Version=1.0.4911.29141, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Line Tracer.dll LinesGrid, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LinesGrid_en.dll Linocut_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Linocut_en.dll Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Liquify.dll ListOfPalettes, Version=1.0.0.32564, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ListOfPalettes.dll LocalContrast, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalContrast.dll LocalNoise, Version=1.0.4674.29909, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalNoise.dll LookAtIt.Effect, Version=0.5.0.742, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LookAtIt.Effect.dll LowColor, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LowColor.dll Magnifier, Version=1.3.5.14308, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Magnifier.dll Majority, Version=1.2.5.14328, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll MakeTransparent, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MakeTransparent.dll MandalaCreator, Version=1.2.6946.21792, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MandalaCreator.dll MarkupRenderer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MarkupRenderer.dll MathNet.Iridium, Version=2007.3.8.35795, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MathNet.Iridium.dll MeasureObject, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MeasureObject.dll Melting, Version=1.3.6550.31783, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Melting.dll MemeMaker, Version=4.5.6828.38061, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MemeMaker.dll Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Metallize.dll MirrorRotate, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotate.dll MirrorRotateMenu, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll MismatchEraser, Version=1.0.5641.31839, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MismatchEraser.dll ModifyChannels, Version=1.0.6201.10839, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ModifyChannels.dll Moire, Version=1.2.5.14350, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll Morphologic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Morphologic.dll MosaicManiac, Version=1.0.906.8, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MosaicManiac.dll ImSVG.Open.FileType, Version=0.18.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImSVG.Open.FileType.dll MotionSharpen, Version=1.2.5.19059, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll MultiColorGradient, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiColorGradient.dll MultiSpline, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiSpline.dll MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiThreshold.dll Nebulous, Version=1.2.5.19527, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll ImXcf.FileType, Version=1.4.0.95, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImXCF.FileType.dll NeonEdges, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NeonEdges.dll NeonEdges_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NeonEdges_en.dll NeutralWire, Version=1.0.6333.34789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NeutralWire.dll NewtonFractal, Version=2.2.5.19770, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll NoiseBleach, Version=1.0.4909.35542, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NoiseBleach.dll NoiseChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NoiseChoice.dll NormalMapPlus, Version=1.4.6422.43071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NormalMapPlus.dll Object Pruner, Version=1.0.7020.41772, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Object Pruner.dll Jpeg2000Filetype, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\Jpeg2000Filetype.dll Object2Colour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Object2Colour.dll ObjectBevel, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectBevel.dll ObjectEdge, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Objectedge.dll ObjectFeather, Version=4.0.5284.38364, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectFeather.dll ObjectTools, Version=4.5.6832.42044, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectTools.dll Oblique, Version=1.2.5.15730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll Offset Shadow, Version=1.0.4247.30184, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Offset Shadow.dll Offset, Version=1.0.4914.19410, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Offset.dll OffsetAlternatingStripes, Version=1.0.6025.41452, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OffsetAlternatingStripes.dll OilPaintingPlus, Version=4.5.6832.21777, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OilPaintingPlus.dll Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OldFeather.dll OptionBasedLibrary v0.7.3, Version=0.7.0.229, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OptionBasedLibrary v0.7.3.dll Organigram, Version=1.3.6565.29874, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Organigram.dll Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll OutlineObject, Version=1.1.3160.31739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline.dll OutlinedGradientText1, Version=1.2.6631.35197, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OutlinedGradientText.dll OutlineSelection, Version=1.0.3055.21360, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OutlineSelection.dll Overblur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overblur.dll Overliner, Version=1.2.5.25545, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overliner.dll PageCurl, Version=1.5.5.23162, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll PaintDotNet.Framework, Version=4.21.6589.7045, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PaintDotNet.Framework.dll Paneling, Version=1.2.5.23448, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Paneling.dll ParallelLines.Effect, Version=1.6.0.575, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ParallelLines.Effect.dll Paste Warp Plus, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Paste Warp Plus.dll PasteAlpha, Version=4.5.6826.36532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteAlpha.dll PasteFill, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteFill.dll PasteFromClipboard, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteFromClipboard.dll Pastel, Version=4.5.6832.42132, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll PatternFileType, Version=1.0.0.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PatternFileType.dll PdnManualColorFilter, Version=1.0.3704.35071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PdnManualColorFilter.dll PerlinTexture, Version=2.2.5.23710, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerlinTexture.dll Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Perspective.dll PerspectiveLines, Version=1.0.3676.3747, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerspectiveLines.dll OptionBasedLibrary v0.6, Version=0.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\OptionBasedLibrary v0.6.dll PerspectiveTransformation, Version=1.2.5795.41799, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerspectiveTransformation.dll phips_fill_gaps, Version=1.0.3307.18956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_fill_gaps.dll phips_kill_color, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_kill_color.dll phips_selective_enhancer, Version=1.1.3302.33189, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_selective_enhancer.dll phips_selective_toning, Version=1.0.3304.32827, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_selective_toning.dll PhotoAdjustments, Version=4.5.6826.37237, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll PixelatedFrame, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PixelatedFrame.dll pixelcounter, Version=1.0.4975.14577, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pixelcounter.dll pixelcounter2, Version=2.0.5755.13021, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pixelcounter2.dll Planetoid, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Planetoid.dll PlugInData, Version=1.3.0.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PlugInData.dll PNGSpriteMatrix, Version=1.0.2.32048, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PNGSpriteMatrix.dll PNG Preprocessor, Version=1.0.3876.32360, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PNG_Preprocessor.dll OpenRasterFiletype, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\OpenRasterFiletype.dll PointBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PointBlur.dll pointwarp, Version=1.2.5709.42172, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PointWarpEffect.dll Polar, Version=1.2.5.24467, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll PolaroidFrame, Version=1.2.6565.30489, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PolaroidFrame.dll PolarRect, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PolarRect.dll Polygon, Version=4.5.6828.38648, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon.dll Polygones, Version=1.3.5.31866, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll PostageStamp, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PostageStamp.dll Poster, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Poster.dll posterize+, Version=1.0.4629.2600, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\posterize+.dll PowerStretch20Beta, Version=1.9.3045.14671, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PowerStretch.dll PSEmboss, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PSEmboss.dll PSFilterPdn, Version=1.0.7.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PSFilterPdn.dll Psychocolour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Psychocolour.dll pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pxEexpansion.dll QuadrilateralCorrection, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\QuadrilateralCorrection.dll Quick Gravity, Version=1.0.4408.25818, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Quick Gravity.dll RadialBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadialBlurDeluxe_v0.1.dll Radialcolors, Version=1.2.5.21672, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll RadialFade, Version=1.3.5401.38798, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadialFade.dll RadiusFillCorners, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadiusFillCorners.dll rainball, Version=1.0.4907.41850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainball.dll rainbow loom, Version=3.0.3530.27322, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainbow loom.dll Rainbow-Splitter, Version=1.0.4639.2372, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rainbow-Splitter.dll rainbow3, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainbow3.dll RainbowTwist, Version=1.2.5.25218, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll RandDots, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Dots.dll Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll RandomLines, Version=1.2.5.25981, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RandomLines.dll RandomMaze1, Version=1.2.5.26409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RandomMaze1.dll RandomMaze2, Version=1.2.5.26820, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RandomMaze2.dll OptimizedJPEG, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\OptimizedJPEG.dll Recolor Using Palette, Version=1.0.6382.573, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Recolor Using Palette.dll RecolorGray, Version=1.2.5.27251, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RecolorGray.dll RecolourChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RecolourChoice.dll RegularNoise, Version=1.2.5.29080, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RegularNoise.dll RemoveBrightDark, Version=1.1.3063.36415, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveBrightDark.dll OptiPngFileType, Version=11.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\OptiPngFileType.dll RemoveDust, Version=4.5.6826.37862, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveDust.dll RenderColorWheel, Version=1.1.3258.28607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RenderColorWheel.dll Replace Colors, Version=1.1.5767.26297, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Replace Colors.dll Reticulation, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Reticulation.dll ReverseColors, Version=1.2.5.29336, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseColors.dll ReverseFisheye, Version=1.0.5146.26176, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseFisheye.dll RGBCompositor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RGBCompositor.dll Rosaces, Version=1.2.5.29635, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll RotateText, Version=1.1.4415.32628, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateText.dll RotateTextSUI, Version=1.1.4415.32713, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateTextSUI.dll Rotate_Zoom+, Version=1.11.5237.17779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rotate_Zoom+.dll PaintShopProFiletype, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PaintShopProFiletype.dll RotationBilinear, Version=1.1.3594.29946, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotationBilinear.dll RoundedRectangle, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RoundedRectangle.dll RubberStamp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RubberStamp.dll SaturationRGB, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SaturationRGB.dll SaveForWebRIOT, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SaveForWebRIOT.dll SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scintillate.dll ScratchArt_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScratchArt_en.dll ScreenPixel, Version=1.1.5534.1997, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScreenPixel.dll Scribble, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scribble.dll ScriptLab, Version=4.0.6107.18914, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll SeamCarving, Version=4.5.6838.35770, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamCarving.dll SeamlessHelper, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessHelper.dll SeamlessTextureMaker, Version=1.2.5.29984, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll Selection2Clear, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Selection2Clear.dll SelectionObscure, Version=1.1.4602.34476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionObscure.dll SelectionTools, Version=4.5.6832.22117, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll Shadow, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shadow.dll ShadowEffect, Version=1.3.0.23429, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowEffect.dll ShadowHighlight, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowHighlight.dll Shape3D, Version=1.2.6.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll shapegradient, Version=1.5.3886.6574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\shapegradient.dll Shapes, Version=1.6.5.30197, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shapes.dll Shape_umabob, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape_umabob.dll Sharpen+, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sharpen+.dll Sierpinski, Version=2.2.5.30414, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sierpinski.dll Signature, Version=1.5.6617.21474, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Signature.dll silhouetteplus, Version=1.1.3131.17586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\silhouetteplus.dll SinWaves, Version=1.2.5.30582, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll Slinky, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Slinky.dll Smooth, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smooth.dll SmoothNoise, Version=1.0.0.28227, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SmoothNoise.dll Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll SoftProofing, Version=1.1.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SoftProofing.dll SpacedTextPlugin, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpacedTextPlugin.dll Sparkles, Version=1.2.5.12788, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkles.dll Specular, Version=1.0.3254.27778, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Specular.dll SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpeechBubble.dll Spiral, Version=1.2.5.12809, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Spiral.dll SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiralText.dll SpiritLevel.Effect, Version=1.0.0.40, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiritLevel.Effect.dll SpiroGraph, Version=1.2.5.12972, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll SpiroShapes, Version=2.2.5.16659, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll Splashes, Version=1.2.5.13040, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll Splatter, Version=4.0.5873.25083, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll SpokedWheel, Version=1.1.5908.19821, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpokedWheel.dll Sponge_en, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sponge_en.dll SpotCenter, Version=1.2.0.17265, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpotCenter.dll Squirkle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Squirkle.dll SquirkleWarp, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SquirkleWarp.dll StarGlow, Version=1.3.5.17930, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StarGlow.dll Stars, Version=2.0.0.25701, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll Stencil, Version=1.0.5670.20443, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stencil.dll Stickman, Version=1.2.2.30005, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stickman.dll Stipple, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stipple.dll Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll StrayPixelRemover, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StrayPixelRemover.dll StringAndPin, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StringAndPin.dll SubLCD, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SubLCD.dll SVGImport, Version=2.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SVGImport.dll Table, Version=1.1.5847.38905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Table.dll Tartan, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tartan.dll Tattersall, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tattersall.dll Temperature, Version=4.5.6832.41128, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Temperature.dll PdnFF, Version=1.0.3.6, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PdnFF.dll Tesserae, Version=1.0.6200.27517, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tesserae.dll TextDistortion, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextDistortion.dll TextMask, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextMask.dll Texture Object Rounder, Version=1.0.6464.41586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture Object Rounder.dll Texture Scaler, Version=1.2.6430.41316, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture Scaler.dll TextureShader, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextureShader.dll TextureSmoother, Version=1.0.6096.31689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextureSmoother.dll TextureViewSkewer, Version=1.0.5713.42082, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextureViewSkewer.dll Texturize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texturize.dll TextWindow, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextWindow.dll TGAngle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TGAngle.dll TGMagnitude, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TGMagnitude.dll ThatOtherApp, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll ThermalHeatMapEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThermalHeatMapEffect.dll Threshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Threshold.dll TileImageFileType, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TileImageFileType.dll Tiles, Version=1.2.5.13094, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll TileWorld, Version=1.0.2.30273, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TileWorld.dll Toggle Alpha Channel, Version=1.0.5407.38943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Toggle Alpha Channel.dll Toon Shader, Version=1.0.3470.28696, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Toon Shader.dll Tournesol, Version=1.2.5.13128, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tournesol.dll "TR's Pixel Push", Version=1.0.4954.37564, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TR's Pixel Push.dll "TR'sColorizerHMS", Version=1.0.4937.30626, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TR'sColorizerHMS.dll Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Trail.dll trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\trail3d.dll Transparency, Version=4.5.6832.41213, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll TransparentToTransparentWhite, Version=1.0.6963.30396, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TransparentToTransparentWhite.dll TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll TrippyRainbow, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TrippyRainbow.dll TRs Scatter, Version=1.3.4949.23250, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRs Scatter.dll TRsAlphaCutter, Version=3.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsAlphaCutter.dll TRsAlphaMapper, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsAlphaMapper.dll TRsBokeh, Version=2.0.5457.42261, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBokeh.dll TRsBrushStrokes, Version=1.0.6.11937, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBrushStrokes.dll TRsBWPhoto, Version=1.0.4949.38907, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBWPhoto.dll TRsCloudControl, Version=2.0.4968.34489, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCloudControl.dll TRsColorReducer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsColorReducer.dll TRsContourFiller, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsContourFiller.dll TRsCoquin, Version=1.0.4960.31131, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCoquin.dll TRsCroquis, Version=1.4.5634.10354, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCroquis.dll TRsCustomPaletteMatch, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCustomPaletteMatch.dll TRsCustomRandomFill, Version=1.5.1.31287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCustomRandomFill.dll TRsDodgeBurn, Version=1.4.0.33503, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDodgeBurn.dll TRsDodgeBurn.resources, Version=1.3.26.12436, Culture=zh-CN, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDodgeBurn.resources.dll PDNIFFPlugin, Version=2.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PDNIFFPlugin.dll TRsDoodleMatic, Version=1.4.5045.31846, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDoodleMatic.dll TRsDrumSkin, Version=1.4.5199.15427, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDrumSkin.dll TRsExportSelection, Version=1.0.5668.9645, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsExportSelection.dll PDNJPEGXRPlugin, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PDNJPEGXRPlugin.dll TRsFilaments, Version=1.0.15.11399, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilaments.dll TRsFilmStock, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilmStock.dll TRsFilmStripPlgIn, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilmStripPlgIn.dll TRsFireWorks, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFireWorks.dll TRsFreeWarp, Version=1.9.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFreeWarp.dll TRsFuego, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFuego.dll PhotoShop, Version=2.5.0.40665, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll TRsGlassVignette, Version=1.1.5239.30797, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsGlassVignette.dll TRsHalfTone, Version=1.0.4937.7773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsHalfTone.dll TRsIntenseFilteration, Version=1.3.5390.22367, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIntenseFilteration.dll TRsIntensityWarp, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIntensityWarp.dll TRsiPollock, Version=1.0.3.11944, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIPollock.dll TRsKaboom, Version=1.0.5118.21464, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsKaboom.dll TRsKeyFrame, Version=1.2.5693.38036, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsKeyFrame.dll TRsMonolithic, Version=1.0.5.26132, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsMonolithic.dll TRsMorpher, Version=1.1.10.8959, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsMorpher.dll TRsPanoPDN, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPanoPDN.dll TRsPasteFrame, Version=1.3.10.13270, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPasteFrame.dll TRsPasteWarp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPasteWarp.dll TRsPixelPuller, Version=1.1.4994.29625, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPixelPuller.dll TRsPixelSharp, Version=2.0.5467.31590, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPixelSharp.dll TRsPlasmatix, Version=1.0.5220.31660, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPlasmatix.dll TRsPSnap, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPSnap.dll TRsQuickOutline, Version=1.5.5713.19293, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsQuickOutline.dll TRsRadialExtruder, Version=1.2.5609.8244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsRadialExtruder.dll TRsRetouch, Version=1.0.5684.16160, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsRetouch.dll TRsSmudger, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSmudger.dll TRsSnowFlakeMaker, Version=1.0.3.10409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSnowFlakeMaker.dll TRsSplineMaster, Version=1.4.2.18310, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSplineMaster.dll TRsStarFilter, Version=1.0.4930.9612, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStarFilter.dll QuickBASIC BSAVE Graphics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\QuickBASIC BSAVE Graphics.dll TRsStr8Edge, Version=1.1.5045.31905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStr8Edge.dll RawFileType, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\RawFileType.dll TRsStrangeAttractor, Version=1.1.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStrangeAttractor.dll TRsStrobeMotion, Version=1.2.4962.30523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStrobeMotion.dll TRsTeslaCoil, Version=1.0.4935.18219, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTeslaCoil.dll RawLoader, Version=0.1.0.7, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\RawLoader.dll TRsThirdDimension, Version=1.7.13.38717, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsThirdDimension.dll TRsTiledPixels, Version=1.2.4942.13226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTiledPixels.dll TRsTiltShift, Version=1.0.4957.12341, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTiltShift.dll TRsTreeMaker, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTreeMaker.dll RawReader, Version=0.9.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\RawReader.dll TRsZigZag, Version=1.1.4929.6773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsZigZag.dll TubeOblique, Version=1.2.5.15697, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll TurbulentCircles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TurbulentCircles.dll TurbulentLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TurbulentLines.dll Tweakedges, Version=1.0.4252.39711, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tweakedges.dll Tweaktrans2, Version=2.0.4252.27152, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tweaktrans2.dll Twist, Version=4.0.5873.25056, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Twist.dll TwistZ, Version=1.2.5.13350, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll TwoColorMixer, Version=1.1.5616.26437, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoColorMixer.dll TwoPointPerspective, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoPointPerspective.dll TwoToneThreshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoToneThreshold.dll UnselectedRectangleKeeper, Version=1.0.5669.36271, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\UnselectedRectangleKeeper.dll Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll SpriteSheet, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\SpriteSheet.dll Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Grid.dll Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll VanishPoint, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\VanishPoint.dll Varicose2, Version=2.1.1.42085, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Varicose2.dll Vibrato, Version=2.0.5.13530, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll ViewFramer, Version=1.0.6074.42436, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ViewFramer.dll Vignette1, Version=1.0.3538.14367, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vignette1.dll VignettePlus, Version=4.5.6826.39332, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\VignettePlus.dll Volutes, Version=1.3.5.13753, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll WaterReflection, Version=1.2.5.15754, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll Waves, Version=1.2.5.14072, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll WaveText, Version=1.2.4415.32811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveText.dll WetFloor, Version=1.2.5.14166, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll WhatIsIt.Effect, Version=0.1.0.111, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WhatIsIt.Effect.dll WhichSymbolRedux, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WhichSymbolRedux.dll Whitepoint, Version=1.0.4412.42187, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Whitepoint.dll WovenPhoto94, Version=1.94.6505.33087, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WovenPhoto94.dll WovenPhoto95, Version=1.94.6529.30892, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WovenPhoto95.dll XYCoords, Version=1.2.6.20985, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll Zoom Blur Deluxe, Version=1.1.5709.42909, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ZoomBlurDeluxe.dll ZoomBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ZoomBlurDeluxe_v0.2.dll TomsPaletteFormatFileType, Version=0.9.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\TomsPaletteFormatFileType.dll WebPFileType, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\WebPFiletype.dll Native modules: C:\Program Files\Paint.NET\PaintDotNet.exe, version=4.107.7104.37431 C:\Windows\SYSTEM32\ntdll.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\SYSTEM32\MSCOREE.DLL, version=4.0.40305.0 (Main.040305-0000) C:\Windows\system32\KERNEL32.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) C:\Windows\system32\KERNELBASE.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) C:\Windows\system32\ADVAPI32.dll, version=6.1.7601.24475 (win7sp1_ldr.190516-0600) C:\Windows\system32\msvcrt.dll, version=7.0.7601.17744 (win7sp1_gdr.111215-1535) C:\Windows\SYSTEM32\sechost.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\RPCRT4.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.7.3221.0 built by: NET472REL1LAST_C C:\Windows\system32\SHLWAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\GDI32.dll, version=6.1.7601.24467 (win7sp1_ldr_escrow.190522-1700) C:\Windows\system32\USER32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\LPK.dll, version=6.1.7601.24439 (win7sp1_ldr.190413-2027) C:\Windows\system32\USP10.dll, version=1.0626.7601.24467 (win7sp1_ldr_escrow.190522-1700) C:\Windows\system32\IMM32.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\MSCTF.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\VERSION.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.7.3416.0 built by: NET472REL1LAST_B C:\Windows\system32\MSVCR120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\bef0a43af1bb9a52ee47a6f60bec2961\mscorlib.ni.dll, version=4.7.3416.0 built by: NET472REL1LAST_B C:\Windows\system32\ole32.dll, version=6.1.7601.24440 (win7sp1_ldr.190416-0600) C:\Windows\system32\CRYPTBASE.dll, version=6.1.7601.24475 (win7sp1_ldr.190516-0600) C:\Windows\system32\uxtheme.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\assembly\NativeImages_v4.0.30319_64\System\b80650dd502e75f37b9c1b49ff63d631\System.ni.dll, version=4.7.3416.0 built by: NET472REL1LAST_B C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Core\99ae2b466bc88b94d46242fb240f0a2c\System.Core.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C C:\Windows\assembly\NativeImages_v4.0.30319_64\WindowsBase\e04e70761f95d0efc8106a111f1eeeb1\WindowsBase.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C C:\Windows\system32\CRYPTSP.dll, version=6.1.7601.24460 (win7sp1_ldr.190509-0600) C:\Windows\system32\rsaenh.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Drawing\a56a8e5dd4ff430f3fe7eaabd1212806\System.Drawing.ni.dll, version=4.7.3221.0 built by: NET472REL1LAST_C C:\Windows\assembly\NativeImages_v4.0.30319_64\PresentationCore\44469ebbb500ab1da1c6dc3e5287bff7\PresentationCore.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C C:\Windows\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\c2f2b2960b51b6bf1e3e9e0db6bb7d2b\PresentationFramework.ni.dll, version=4.7.3362.0 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\19f636b8b8d3ce23bd478bef6a49ea04\PaintDotNet.Base.ni.dll, version=4.107.7104.37431 C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\79a89f8eacc86aaceaf1328d774a9f8e\System.Windows.Forms.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\bd86546ae15e3829db641c49f3524554\PaintDotNet.SystemLayer.ni.dll, version=4.107.7104.37431 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\9ee9d5b9f1a368166b51cb69736c375a\PaintDotNet.Core.ni.dll, version=4.107.7104.37431 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\3ba3afd1c6f3baac44018ddcc8a17f2e\PaintDotNet.Resources.ni.dll, version=4.107.7104.37431 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\5cc62bcbf3cf1a957bfc2887713f379e\PaintDotNet.Framework.ni.dll, version=4.107.7104.37431 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\367cd4ddd9c125ff011034b7130a9b99\PaintDotNet.Data.ni.dll, version=4.107.7104.37431 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\4149a35caca8805cd21079b480ae9beb\PaintDotNet.Effects.ni.dll, version=4.107.7104.37431 C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet\4a117a7b1c942c878441f1ea94d7d7d2\PaintDotNet.ni.exe, version=4.107.7104.37431 C:\Windows\system32\dwrite.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.7.3362.0 built by: NET472REL1LAST_C C:\Windows\system32\MSVCP120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING C:\Windows\system32\OLEAUT32.dll, version=6.1.7601.24440 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.7.3362.0 built by: NET472REL1LAST_C C:\Windows\Microsoft.NET\Framework64\v4.0.30319\nlssorting.dll, version=4.7.3062.0 built by: NET472REL1 C:\Windows\system32\shell32.dll, version=6.1.7601.23338 (win7sp1_ldr.160121-1716) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-console-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-datetime-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-debug-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-errorhandling-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-file-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-file-l1-2-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-file-l2-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-handle-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-heap-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-interlocked-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-libraryloader-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-localization-l1-2-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-memory-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-namedpipe-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-processenvironment-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-processthreads-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-processthreads-l1-1-1.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-profile-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-rtlsupport-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-string-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-synch-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-synch-l1-2-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-sysinfo-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-timezone-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-core-util-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-conio-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-convert-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-environment-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-filesystem-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-heap-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-locale-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-math-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-multibyte-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-private-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-process-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-runtime-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-stdio-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-string-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-time-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\api-ms-win-crt-utility-l1-1-0.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\ucrtbase.dll, version=10.0.17134.12 (WinBuild.160101.0800) C:\Program Files\Paint.NET\SxS\X64\vcruntime140.dll, version=14.20.27508.1 built by: vcwrkspc C:\Program Files\Paint.NET\SxS\X64\vcruntime140_1.dll, version=14.20.27508.1 built by: vcwrkspc C:\Program Files\Paint.NET\SxS\X64\msvcp140.dll, version=14.20.27508.1 built by: vcwrkspc C:\Program Files\Paint.NET\SxS\X64\msvcp140_1.dll, version=14.20.27508.1 built by: vcwrkspc C:\Program Files\Paint.NET\SxS\X64\msvcp140_2.dll, version=14.20.27508.1 built by: vcwrkspc C:\Program Files\Paint.NET\SxS\X64\vcomp140.dll, version=14.20.27508.1 built by: vcwrkspc C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Configuration\69a748a6a5c5997e8457524828866eb5\System.Configuration.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xml\da7cdea27be9d3db3c58dcd7f407b684\System.Xml.ni.dll, version=4.7.3221.0 built by: NET472REL1LAST_C C:\Windows\system32\profapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\bcrypt.dll, version=6.1.7601.24475 (win7sp1_ldr.190516-0600) C:\Windows\system32\api-ms-win-core-xstate-l2-1-0.dll, version=10.0.14393.2990 (rs1_release_1.190410-1803) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.7.3416.0 built by: NET472REL1LAST_B C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\23fcecce91694141f1924e78074c95d6\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.107.7104.37431 C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll, version=4.107.7104.37431 C:\Windows\system32\PROPSYS.dll, version=7.00.7600.16385 (win7_rtm.090713-1255) C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.24467_none_145b6fc08b9065e9\gdiplus.dll, version=6.1.7601.24467 (win7sp1_ldr_escrow.190522-1700) C:\Windows\system32\dxgi.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\dwmapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WINTRUST.dll, version=6.1.7601.24460 (win7sp1_ldr.190509-0600) C:\Windows\system32\CRYPT32.dll, version=6.1.7601.24460 (win7sp1_ldr.190509-0600) C:\Windows\system32\MSASN1.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\d2d1.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\CLBCatQ.DLL, version=2001.12.8530.16385 (win7_rtm.090713-1255) C:\Windows\System32\UIAnimation.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24460_none_e3711c5330fd38b4\comctl32.dll, version=6.10 (win7_rtm.090713-1255) C:\Windows\system32\WindowsCodecs.dll, version=6.2.9200.22551 (win8_ldr_escrow.180828-1117) C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\9764b3b7d173404ea18c571586183b16\System.Runtime.CompilerServices.Unsafe.ni.dll, version=4.6.26919.02 C:\Windows\system32\wtsapi32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WINSTA.dll, version=6.1.7601.18540 (win7sp1_gdr.140716-1508) C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xaml\ec8feca6356a64dd15bf5c318ec167df\System.Xaml.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Runtime\5f9f1107f71b8c8f0e05308ef73d12b3\System.Runtime.ni.dll, version=4.7.3062.0 C:\Windows\system32\d3d11.dll, version=6.2.9200.16570 (win8_gdr.130327-1526) C:\Windows\system32\D3D10Warp.dll, version=6.2.9200.22592 (win8_ldr.181005-0600) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.7.3062.0 built by: NET472REL1 C:\Windows\system32\winmm.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\explorerframe.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\DUser.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\DUI70.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\RpcRtRemote.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\assembly\NativeImages_v4.0.30319_64\Microsoft.V9921e851#\1b7ed1937d819568db405ab3a1159d13\Microsoft.VisualBasic.ni.dll, version=14.7.3062.0 built by: NET472REL1 C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Design\525cd5f56c082d6fd1c7c276eeb9465b\System.Design.ni.dll, version=4.7.3062.0 built by: NET472REL1 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrcompression.dll, version=4.7.3062.0 built by: NET472REL1 C:\Windows\system32\XmlLite.dll, version=1.3.1001.0 C:\Windows\system32\SetupApi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\CFGMGR32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\DEVOBJ.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\psapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) ------------------------------------------------------------------------------ Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15, 2019 Author Share Posted June 15, 2019 Okay perfect, that gives me what I need, thanks 1 The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 17, 2019 Author Share Posted June 17, 2019 Locking thread -- new build incoming The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
