9ale7 Posted July 8, 2008 Share Posted July 8, 2008 realy amazing!! good work Quote Link to comment Share on other sites More sharing options...
Carrito Posted July 13, 2008 Share Posted July 13, 2008 thank you very much Quote Ingenieros TenerifePeritos Tenerife Link to comment Share on other sites More sharing options...
softone Posted August 30, 2008 Share Posted August 30, 2008 Does not seem to be compatible with Paint.NET v3.36. Give horizontal lines etc. Please fix! :wink: Thanks. Quote Link to comment Share on other sites More sharing options...
rscomp Posted August 30, 2008 Share Posted August 30, 2008 Just istald new version of paint.net and like lik softtone i get horizontal lines and blures the image .Wanted to rollback to version 3.31 but can not find it. Please make this work agian .!!!! thanks Quote Link to comment Share on other sites More sharing options...
softone Posted August 30, 2008 Share Posted August 30, 2008 Just noticed on the developer's forum the fix is on the way. Soon I quess (and hope) Quote Link to comment Share on other sites More sharing options...
emer Posted February 10, 2009 Share Posted February 10, 2009 Any chance of a source code for this amazing plug-in? Yes, in some time. Any news about that? Quote Link to comment Share on other sites More sharing options...
Tanel Posted February 11, 2009 Author Share Posted February 11, 2009 Well, the code itself is not particularly elegant nor educative. Most part of the rendering is just brutal math, without comments about ongoing. That's because I modelled the effect in Excel and just translated the formulas into C#. Anyway, here is the rough description of the process. 1. Blur the image from src to dst 2. Calculate the brightness of blurred pixels on dst 3. Define a tone curve for brightening/darkening 4. Calculate the amount of brightening/darkening needed for particular pixel, by evaluating the blurred pixel value in relation to the tone curve 5. Apply brightening/darkening to original src pixels and put them to dst Blur is the key of that effect. Calculating the needed amount of brightening from blurred surface helps to preserve original contrast and texture of the subjects. Downside is the halos appearing sometimes around large high-contrast subjects. Here is the main render class from the VS2005 project. I warned you! :wink: using System; using System.Collections; using System.Drawing; using PaintDotNet; using PaintDotNet.Effects; using PaintDotNet.PropertySystem; namespace ShadowHighlight { // [EffectCategory(EffectCategory.Adjustment)] // used to be in Adjustments menu public class EffectPlugin : PaintDotNet.Effects.Effect { public static string StaticName { get { return "Shadow / Highlight Recovery"; } } public static Bitmap StaticImage { get { return new Bitmap(typeof(EffectPlugin), "EffectPluginIcon.png"); } } //public static string StaticSubMenuName { get { return null; } } // Use for no submenu public static string StaticSubMenuName { get { return SubmenuNames.Photo; } } public EffectPlugin() : base(StaticName, StaticImage, StaticSubMenuName, EffectFlags.Configurable) { this.blurEffect = new GaussianBlurEffect(); this.blurProps = this.blurEffect.CreatePropertyCollection(); } public override EffectConfigDialog CreateConfigDialog() { return new EffectPluginConfigDialog(); } private GaussianBlurEffect blurEffect; private PropertyCollection blurProps; private UnaryPixelOps.Identity Nop = new UnaryPixelOps.Identity(); // this op returns original image when "Review" button is pressed public override unsafe void Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, int startIndex, int length) { EffectPluginConfigToken token = (EffectPluginConfigToken)parameters; int myred = token.Redvalue; // Color mask int mygreen = token.Greenvalue; // Color mask int myblue = token.Bluevalue; // Color mask int ha0 = token.Highlights; int ht = token.High_T; // Highlights tonal range int sa0 = token.Shadows; int st = token.Shadows_T; // Shadows tonal range int lvl = token.Slevels; // Smoothing int sat0 = token.Hsaturation; // Highlights saturation int sats0 = token.Ssaturation; // Shadows saturation int amp = token.Deepshadow; // Compression bool check = token.checkBox2; // that's linked to Review button pressed state int rad = token.Radius; PropertyBasedEffectConfigToken blurToken = new PropertyBasedEffectConfigToken(this.blurProps); blurToken.SetPropertyValue(GaussianBlurEffect.PropertyNames.Radius, token.Radius); this.blurEffect.SetRenderInfo(blurToken, dstArgs, srcArgs); base.OnSetRenderInfo(blurToken, dstArgs, srcArgs); Surface dst = dstArgs.Surface; Surface src = srcArgs.Surface; if (check == false) // "REVIEW" BUTTON IS PRESSED -> ORIGINAL IMAGE IS SHOWN { Nop.Apply(dst, src, rois, startIndex, length); } else // "REVIEW" BUTTON IS NOT PRESSED -> EFFECT IS RUNNING { this.blurEffect.Render(rois, startIndex, length); for (int i = startIndex; i < startIndex + length; ++i) { Rectangle roi = rois[i]; for (int y = roi.Top; y < roi.Bottom; ++y) { ColorBgra* srcPtr = src.GetPointAddressUnchecked(roi.Left, y); ColorBgra* dstPtr = dst.GetPointAddressUnchecked(roi.Left, y); ColorBgra CurrentPixel; ColorBgra OrigPixel; byte ao, ry, by, gy; float r, g, b, ro, go, bo, vf, vfo, cr, cg, cb, c0, ampx, rx, bx, gx, ha00, sa00, ha, sa, hs, vfoh, cr1, cg1, cb1, cx, rh00, rh1, rhx, gh00, gh1, ghx, bh00, bh1, bhx, sat, sats, satgs, satgs1, rs00, rs1, rs2, rs3, rsx, gs00, gs1, gs2, gs3, gsx, bs00, bs1, bs2, bs3, bsx, stx, htx, dsa0, dsa1, dsa12, dsax, dsax1, dha1, dha0, dha12, dhax, vfx00, vfx0, vfx; for (int x = roi.Left; x < roi.Right; ++x) { CurrentPixel = *dstPtr; r = (float)CurrentPixel.R; g = (float)CurrentPixel.G; b = (float)CurrentPixel.B; vf = ((r + g + / 3f); OrigPixel = *srcPtr; ro = (float)OrigPixel.R; go = (float)OrigPixel.G; bo = (float)OrigPixel.B; ao = OrigPixel.A; ampx = amp / 10f; ha = ha0 / 100f; ha00 = ha0 * 1f; stx = st * 1.1f; htx = ht * 1f; sa = sa0 / 100f; sa00 = sa0 * 1f; sat = sat0 / 100f; sats = sats0 / 100f; vfo = ((ro + go + bo) / 3f); // HALO INTENSITY vfx00 = (vf - vfo); vfx0 = (vfx00 * (float)lvl / 100f); vfx = (vfo + vfx0); // COLOR MASK cr = myred / 100f; cg = mygreen / 100f; cb = myblue / 100f; c0 = vf; cr1 = (r * cr / c0); cg1 = (g * cg / c0); cb1 = (b * cb / c0); cx = ((cr1 + cg1 + cb1) / 3f); // SHADOWS satgs = 1f; // thought I might want to tune this float s0 = 0; if (sa0 > 0) s0 = 1f; dsa0 = (1f + (100f - stx) * 2f / 100f); dsa1 = (50f / (vfx + 10f) - 0.3f * dsa0); // this is our "tone cuve" (actually factor by which Amount control is pre-amplified) if (dsa1 < 0) dsa1 = 0; dsa12 = Math.Min((ampx + 1f) / 3f, dsa1); dsax = (1f + dsa12 * satgs); dsax1 = (1f + dsa12 * cx * sa); satgs1 = (s0 * dsax1 + (satgs + 1f) * (1f - s0)); rs00 = (ro + vfo * (satgs1 - 1f)); rs1 = (ro * satgs1 - rs00); rs2 = (rs00 + rs1 * sats); rs3 = (ro + (ro - vfo) * sats * dsa12 * cx * (satgs1 - 1f)); rsx = ((rs2 * s0 + rs3 * (1f - s0)) / ro); gs00 = (go + vfo * (satgs1 - 1f)); gs1 = (go * satgs1 - gs00); gs2 = (gs00 + gs1 * sats); gs3 = (go + (go - vfo) * sats * dsa12 * cx * (satgs1 - 1f)); gsx = ((gs2 * s0 + gs3 * (1f - s0)) / go); bs00 = (bo + vfo * (satgs1 - 1f)); bs1 = (bo * satgs1 - bs00); bs2 = (bs00 + bs1 * sats); bs3 = (bo + (bo - vfo) * sats * dsa12 * cx * (satgs1 - 1f)); bsx = ((bs2 * s0 + bs3 * (1f - s0)) / bo); //HIGHLIGHTS vfoh = (255f - vfo); dha0 = (1f + (100f - htx) * 2f / 100f); dha1 = (50f / (255f - vfx + 10f) - 0.3f * dha0); if (dha1 < 0) dha1 = 0; dha12 = Math.Min((ampx + 1f) / 3f, dha1); dhax = (1f + dha12 * satgs * cx * ha); hs = (vfoh * dhax - vfoh); rh00 = (vfo - (vfo - ro * rsx) * sat * dha12 * cx); rh1 = (hs + vfo - rh00); rhx = (1f - rh1 / rh00); gh00 = (vfo - (vfo - go * gsx) * sat * dha12 * cx); gh1 = (hs + vfo - gh00); ghx = (1f - gh1 / gh00); bh00 = (vfo - (vfo - bo * bsx) * sat * dha12 * cx); bh1 = (hs + vfo - bh00); bhx = (1f - bh1 / bh00); // FINAL RGB VALUES rx = ro * rsx * rhx; gx = go * gsx * ghx; bx = bo * bsx * bhx; ry = Utility.ClampToByte(rx); gy = Utility.ClampToByte(gx); by = Utility.ClampToByte(bx); OrigPixel = ColorBgra.FromBgra(by, gy, ry, ao); *dstPtr = OrigPixel; ++srcPtr; ++dstPtr; } } } } } } } Quote Link to comment Share on other sites More sharing options...
Jaykaye Posted August 23, 2009 Share Posted August 23, 2009 Hi, I'm kinda new to Paint.net and I haven't gotten quite used to everything. I want to learn how to remove the shine from my face, but I'm stuck. Nothing I've tried seems to work, so I did a search and someone mentioned using the Shadows and Highlights plugin you created. Can you please help me? Quote Link to comment Share on other sites More sharing options...
007 Nab Posted August 24, 2009 Share Posted August 24, 2009 I've had this plugin for over a year, and have neglected commenting on it - but what a great one it is! I use this all the time in photo editing - and the results are so high quality! Thanks for a wonderful tool Jaykaye - you might want to try using the Clone Stamp tool - play around with it and I think you'll be able to find the results you are looking for. This plugin is more for restoration in my opinion. Quote "pyrochild, you're my favorite person ever. We should go snowboarding some time."~ 007 Nab. Ish. PDN Gallery | I Made a Deviant Art! Link to comment Share on other sites More sharing options...
Axle Posted September 4, 2009 Share Posted September 4, 2009 hadn't seen this plugin but seems pretty cool. :goes to download: Quote My Deviant Art | My Gallery Link to comment Share on other sites More sharing options...
dj1551 Posted February 7, 2011 Share Posted February 7, 2011 I downloaded this plugin today and there is a problem with the UI. In the Basic Mode, the upper half of the slider knob for the Highlights adjustment is missing and there is no "Highlights" label to indicate that's what the middle slider is for. In the Adavanced Mode, the upper half of the slider knob for the Tonal Range adjustment is missing and there is no "Tonal Range" label to indicate that's what that slider is for. (I am including a screen capture file showing this) It's not clear whether the plugin is malfunctioning as well. It doesn't seem to remove shadows and highlights as portrayed in your screen shots, but that could be the result my own failings I've downloaded the plugin pack several times, thinking maybe I made a mistake in the process that could have corrupted the plugins, but the result was the same each time; and the color mixer plugin works fine. Any suggestions ? . Quote Link to comment Share on other sites More sharing options...
Sarkut Posted February 7, 2011 Share Posted February 7, 2011 a mistake in the process that could have corrupted the plugins Try clearing your browser cache before downloading again. Clear Browser Cache Quote Link to comment Share on other sites More sharing options...
pyrochild Posted February 7, 2011 Share Posted February 7, 2011 I downloaded this plugin today and there is a problem with the Looks like you're using some sort of custom theme. Disable it and everything should be fine. Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
arana Posted November 13 Share Posted November 13 Any similar or updated version of this plugin? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted November 13 Share Posted November 13 35 minutes ago, arana said: Any similar or updated version of this plugin? No need for an update... it works perfectly. Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
