Base64 FileType (2022-06-03)
null54
Hmmm... plugin may have a bug in it...
The bug was that the Load method would remove the second = that is used in base 64 padding, fixed in 1.0.0.5.
IsReflexive would not be appropriate for a FileType that saves indexed color images without user interaction, it should only be used for FileTypes that are lossless.
Determines if saving with a given SaveConfigToken would alter the image in any way.
Put another way, if the document is saved with these settings and then immediately loaded, would it have exactly the same pixel values?
Any lossy codec should return 'false'.
This value is used to optimizing preview rendering memory usage, and as such flattening should not be taken in to consideration.
For example, the codec for PNG returns true, even though it flattens the image.
Improved compatibility with Paint.NET's Dark theme, file version updated to 1.0.0.8.
  • 2 years later...
Using the current version of this plugin with Paint.NET 4.2.14 on Windows 10 Pro I am experiencing a display issue:
The Controls on save dialogue are mashed together
Probably due to me using a scaling of 200% within Windows display settings the save dialogue looks like 01_save.png
  • null54 changed the title to Base64 FileType (2020-12-16)
This should be fixed in version 1.0.0.9.
  • null54 changed the title to Base64 FileType (2021-07-23)
Release version 1.0.0.10.
Changes:
  • Fixed a crash when reading some Base64 encoded data.
  • 5 months later...
  • null54 changed the title to Base64 FileType (2022-06-03)
Release version 1.0.0.11.
Changes:
  • Fixed a crash when loading quoted Base64 strings
  • Added support for loading JPEG and GIF images
  • Like 2
