Base64 FileType (2022-06-03)
null54
This plugin loads and saves Base64 encoded images.
Only BMP and PNG format images can be saved.
The format of the text file is UTF8.
This plugin is compatible with Paint.NET 3.5.11 and 4.0.x.
On 8/12/2015 at 7:45 AM, midora said:
The file extension is .b64
A b64 file contains a png or a bmp image encoded as base64 text.
Open a .b64: The filetype plugin decodes the text of the file back to the contained png or bmp image and then opens this image in paint.net.
Save as .b64: The filetype plugin takes the open image, converts it to png or bmp (there is an option in the dialog), converts the result to base64 text and then saves the text.
Download:
Base64FileType.zip
Source Code:
https://github.com/0xC0000054/pdn-base64
  • Upvote 4
Great.
Can you add a few setting to prepend the code with the correct base64 syntax "data:image/png;base64,".
And maybe an option to build the HTML tag for an image or CSS for background image...
Added a Data URI format check box, HTML and CSS formats can be selected from a list.
File version updated to 1.0.0.1.
What's about a raw option (just the BGRA data)?
Do you mean encoding the raw pixel data without saving as BMP or PNG first?
  • 7 months later...
Sorry I totally missed your response.
Sometimes I need a  raw base64 BGR or RGB stream. But I can always use a tool to convert it.
Two non-important issues:
1)  If you are using file format BMP and set the HTML or CSS option then the loader part is not always able to load the file (you can also see this in the save dialog that the file size always tells "computing...". )
2) If you are setting URI data type to HTML and then switch off DATA URI encoding then the Insert line break checkbox stays disabled. You first have to set URI data type to None. Seems to be a small issues with the IndirectUI rules.
Thanks. But now in both cases (html and css) the plugin is not able to load and does not stop computing.
>>The input is not a valid Base-64 string as it contains a non-base 64 character, more than two padding characters, or an illegal character among the padding characters.
There is an other thing you may think about. It's about the extension. I would prefer that the plugin uses .b64 instead of .txt.
In my case .txt conflicts with a plugin which loads .txt files as bitmaps. So I always have to decide what to install.
I cannot reproduce that error.
As for the extension it would be en easy change.
Maybe it depends on the file. So here is a file which is always showing computing (in 3.5.11 and 4.0) if HTML or CSS is selected.
FLAG_B24.zip
I verified that in both cases 1.0.0.3 is in the FileTypes folder.
I would prefer the change of the extension. Especially because it is not a standard user file content.
Edited by midora
That issue is fixed, and the file extension has been changed.
File version updated to 1.0.0.4.
  • 1 year later...
  • 2 months later...
This is a filetype plugin. It should be placed in the \Filetypes\ folder. You access the new file types via the list of extensions in the load/save dialogs.
The description of the filetype is quite compact, I agree ;-)
Excellent summary Midora! I've added this to the first post.
  • 7 months later...
I needed to save a file in b64 today (to embed it into a web page) and I thought I would have to download some spyware laden "freeware" program to do the conversion. Ugh. Then I thought... I bet someone has written a filetype plugin for paint.net!
null54, thanks for making this plugin. It worked like a charm!
Click to play:
Hmmm... plugin may have a bug in it...
I'm trying to do about 20 of these little images and I notice that many times when I go to save one, it will never show me the preview. It sticks saying, "(computing)" and never finishes. If I press Save when it is in this state, it never saves the file and I have to kill paint.net with the task manager.
Can you look into it and possibly fix?
The files I'm trying to save are small, 16x16 icons with some transparency which is why I can't use BMP format (which always seems to work).
I've used it successfully to save larger images, so I'm not sure what the problem is.
Click to play:
  • null54 changed the title to Base64 FileType (2022-06-03)
