Peter M Posted January 9, 2012 Share Posted January 9, 2012 Hi All, Been using Paint.NET for years, but mainly very simple stuff all revolving around making buttons for various touch screen remotes I've had over the years. I'm now doing a whole new set of buttons for an iPad app I'm using and one thing's got me stuck. I've downloaded a bunch of TV channel logos (130 x 90) and I want to put them on buttons. The logos all have white backgrounds, but my buttons are dark grey. I can get rid of the white backgound no problem using the magic wand, but that leaves me with the dither to white around the image, and when I put this onto the dark backgound it looks terrible. The dither seems very important due to the small image size. I guess what I'm trying to do is change a 'dither to white' to a 'dither to dark grey'. How do I do this ? Apologies if I've got the terminology wrong ... I hope my intent is clear. Cheers, Peter M Quote Link to comment Share on other sites More sharing options...
yellowman Posted January 9, 2012 Share Posted January 9, 2012 Grim Color Reaper works very well to remove the white background if the TV logo has no white in it, but you can subtract the white spots from the selection then apply the Grim Color Reaper so they don't affect. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
BoltBait Posted January 9, 2012 Share Posted January 9, 2012 After deleting the background, have you tried one of the feather plugins in my plugin pack? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
HELEN Posted January 9, 2012 Share Posted January 9, 2012 You can do the above and you can also try AA's Assistant. Quote Don't spit into the well, you might drink from it later. -----Yiddish ProverbGlossy Galaxy Ball---How to Make FoliageMy Gallery PDN Fans--My DA Link to comment Share on other sites More sharing options...
Peter M Posted January 9, 2012 Author Share Posted January 9, 2012 Thanks very much for the replies and suggestions. I downloaded BoltBait's plugins and feather worked brilliantly for some, not so well for others. I now realise that every logo will require a different approach. As I work through them, hopefully experience should help me to decide the best method for each. It's going to be a long process !! Cheers, Peter M Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted January 9, 2012 Share Posted January 9, 2012 From what I can tell, Grim Color Reaper should work perfectly for all of them. If there is any white in the button logo, just grab your lasso select and circle it, then hit "ctrl+i" to invert selection before you run the plugin. It doesn't even have to be a perfect selection! Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Peter M Posted January 10, 2012 Author Share Posted January 10, 2012 Thanks again for the suggestion, but I've tried Grim Color Reaper and that doesn't seem to work either. I probably should have added that the original images are .jpg so the existing dither to white is with color only and not transparency. As an example one of the logos is a large red '7' on a white background. Getting rid of the backgound leaves dither to white on the diagonals. Feather did a great job with changing this to a dither using transparency. Grim Color Reaper didn't seem to work on this one at all as the diagonals looked terrible when put over the dark backgound. Again I must emphasise that these are small images and so the dither on diagonals is critical to having them look sharp at 100%. Should I post a couple of the images ? Cheers, Peter M Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 10, 2012 Share Posted January 10, 2012 Try AlphaSpace Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Peter M Posted January 10, 2012 Author Share Posted January 10, 2012 OK tried AlphaSpace and so far it seems to be working brilliantly !!! Thanks to all for the assistance. Cheers, Peter M Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted January 10, 2012 Share Posted January 10, 2012 A couple of image would help...I can't figure out why Grim Color Reaper isn't working and Alpha Space is Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
