Rick Brewster Posted December 22, 2019 Share Posted December 22, 2019 @Ferdari, you're asking others to do a lot of work on your behalf, and making assumptions about a lot of other people's decisions and motivations to fit your personal narrative and agenda. Chill out! @Ego Eram Reputo's suggestion is the best one. If you truly are an "advanced user" as you claim to be, you'll figure out a solution. Maybe you fork the plugin, maybe you just find or write a little command-line utility to automate stripping out the metadata. Maybe you'll even come full circle and share your solution with us. Stop expecting everyone else to cater to your demands, and stop expecting everything to be super easy. That's not how you make progress, here or in life. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
null54 Posted January 8, 2020 Author Share Posted January 8, 2020 Updated to use WebP version 1.1.0. 1 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
cosmonautti Posted April 26, 2020 Share Posted April 26, 2020 Hey. Im trying to open an animated webp but I get this error, can you help? Spoiler Application version: paint.net 4.2.10 WebPFileType.WebPException: The file is not a valid WebP Image. at WebPFileType.WebPNative.WebPLoad(Byte[] webpBytes, BitmapData output) at WebPFileType.WebPFile.Load(Byte[] webpBytes) at WebPFileType.WebPFileType.GetOrientedDocument(Byte[] bytes, ExifValueCollection& exifMetadata) at WebPFileType.WebPFileType.OnLoad(Stream input) at PaintDotNet.FileType.Load(Stream input) in D:\src\pdn\src\Data\FileType.cs:line 522 at PaintDotNet.FileType.Load(Stream input) in D:\src\pdn\src\Data\FileType.cs:line 522 at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in D:\src\pdn\src\Base\Functional\Func.cs:line 158 Quote Link to comment Share on other sites More sharing options...
null54 Posted April 26, 2020 Author Share Posted April 26, 2020 18 hours ago, cosmonautti said: Im trying to open an animated webp but I get this error, can you help? This plugin does not support creating or editing animated WebP images, it is designed for single frame images. I will add a better error message in the next version. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
cosmonautti Posted April 27, 2020 Share Posted April 27, 2020 20 hours ago, null54 said: This plugin does not support creating or editing animated WebP images, it is designed for single frame images. Oh, apologies. this blog is suggesting otherwise, so that's why i posted, thanks for clearing that up, and thanks for the plugin. Quote Link to comment Share on other sites More sharing options...
null54 Posted February 6, 2021 Author Share Posted February 6, 2021 Release version 1.3.5. Changes: Updated to libwebp version 1.2.0. 2 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted September 5, 2021 Author Share Posted September 5, 2021 Release version 1.3.7. Changes: Updated to libwebp version 1.2.1. Enabled hardware acceleration (ARM NEON) for the ARM64 build. As of version 1.3.7, Paint.NET 3.5.11 and 4.0.X are no longer supported. 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
user.by Posted September 28, 2021 Share Posted September 28, 2021 Anymore no need 4.3.1 and up. Quote Link to comment Share on other sites More sharing options...
midora Posted December 26, 2021 Share Posted December 26, 2021 Opening a webp A without an embedded exif chunk shows a dpi value of 120. I expected 72 dpi (the exif default value). Setting the dpi value to 150, saving as B and opening B shows 150. So this works. A and B show a dpi value of 72 in properties/details dialog of Windows Explorer. The difference is that B shows the ResolutionUnit. Looks like an explorer issue. Quote Link to comment Share on other sites More sharing options...
null54 Posted January 24, 2022 Author Share Posted January 24, 2022 Release version 1.3.8. Changes: Updated to libwebp version 1.2.2. Fixed a bug with the EXIF ColorSpace property handling. I also added a note to the first post about animated images not being supported, and a link to the Animated WebP plugin. 1 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
midora Posted January 24, 2022 Share Posted January 24, 2022 More than 10 years of providing updates for this plugin. From the first WebP beta libraries to the now most stable version. Thanks for that. Let's see which image format will win the competition in the future. WebP, Avif, Jpeg XL, or maybe WebP2? Quote Link to comment Share on other sites More sharing options...
null54 Posted January 24, 2022 Author Share Posted January 24, 2022 16 minutes ago, midora said: Let's see which image format will win the competition in the future. WebP, Avif, Jpeg XL, or maybe WebP2? I suspect that all of those image formats will be competing against one another without a clear winner. XKCD has a comic about competing standards: https://xkcd.com/927 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted January 25, 2022 Author Share Posted January 25, 2022 Release version 1.3.9. Changes: Fixed compliance issue in the EXIF writer. A few required tags were being removed immediately after adding them. 🙄 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted February 6, 2022 Author Share Posted February 6, 2022 Release version 1.3.10. Changes: Fixed an issue with the EXIF rotation code. Fixed a few issues when writing the EXIF metadata. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted February 7, 2022 Author Share Posted February 7, 2022 Release version 1.3.11. Changes: Fixed an issue with the 180 degree EXIF rotation code. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
sirdaniel Posted April 11, 2022 Share Posted April 11, 2022 (edited) Hello, I try to convert very large picture from PNG with alpha channel to WEBP . This picture is really large, just near max resolution 16383x16383 but does not exceed maximum yet. Paint net works with smaller pictures. This one stops at 52% and after a while throws exception. I have 20 GB free space on disc C. The message: Quote Exception: WebPFileType.WebPException: Partition #0 is larger than 512 Kb. at WebPFileType.WebPNative.WebPSave(Surface input, Stream output, EncodeParams parameters, MetadataParams metadata, WebPReportProgress callback) at WebPFileType.WebPFile.Save(Document input, Stream output, Int32 quality, WebPPreset preset, Surface scratchSurface, ProgressEventHandler progressCallback) at WebPFileType.WebPFileType.OnSaveT(Document input, Stream output, PropertyBasedSaveConfigToken token, Surface scratchSurface, ProgressEventHandler progressCallback) at PaintDotNet.FileType`2.OnSave(Document input, Stream output, SaveConfigToken token, Surface scratchSurface, ProgressEventHandler callback) in D:\src\pdn\src_4_3_x\Data\FileType`2.cs:line 39 at PaintDotNet.Data.FileTypeProxy.OnSave(Document input, Stream output, SaveConfigToken token, Surface scratchSurface, ProgressEventHandler callback) in D:\src\pdn\src_4_3_x\PaintDotNet\Data\FileTypeProxy.cs:line 68 at PaintDotNet.FileType.Save(Document input, Stream output, SaveConfigToken token, Surface scratchSurface, ProgressEventHandler callback, Boolean rememberToken) in D:\src\pdn\src_4_3_x\Data\FileType.cs:line 261 at PaintDotNet.Controls.DocumentWorkspace.<>c__DisplayClass248_1.<DoSaveImpl>b__7() in D:\src\pdn\src_4_3_x\PaintDotNet\Controls\DocumentWorkspace.cs:line 2791 at PaintDotNet.Functional.Func.Try(Action f) in D:\src\pdn\src_4_3_x\Base\Functional\Func.cs:line 181 Diagnostics: Application paint.net 4.3.10 (Stable 4.310.8103.32785) I am sorry, actually Gimp throws same WebP error: 'partition is bigger than 512K' Edit. Okay, found the culprit: -partition_limit int Degrade quality by limiting the number of bits used by some macroblocks. Range is 0 (no degradation, the default) to 100 (full degradation). Useful values are usually around 30-70 for moderately large images. In the VP8 format, the so-called control partition has a limit of 512k and is used to store the following information: whether the macroblock is skipped, which segment it belongs to, whether it is coded as intra 4x4 or intra 16x16 mode, and finally the prediction modes to use for each of the sub-blocks. For a very large image, 512k only leaves room to few bits per 16x16 macroblock. The absolute minimum is 4 bits per macroblock. Skip, segment, and mode information can use up almost all these 4 bits (although the case is unlikely), which is problematic for very large images. The partition_limit factor controls how frequently the most bit-costly mode (intra 4x4) will be used. This is useful in case the 512k limit is reached and the following message is displayed: Error code: 6 (PARTITION0_OVERFLOW: Partition #0 is too big to fit 512k). If using -partition_limit is not enough to meet the 512k constraint, one should use less segments in order to save more header bits per macroblock. See the -segments option. Is it possible to add more options to the Plugin? Edited April 12, 2022 by sirdaniel Quote Link to comment Share on other sites More sharing options...
null54 Posted April 12, 2022 Author Share Posted April 12, 2022 1 hour ago, sirdaniel said: Is it possible to add more options to the Plugin? Those advanced encoding options are unlikely to be added, this plugin was never intended to expose all of the options that are available in Google's cwebp utility. I recommend that you use cwebp if you need control over metadata or the other advanced WebP encoding options it provides. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
sirdaniel Posted April 12, 2022 Share Posted April 12, 2022 Thats okay. It is likely I met up rare problem. Quote Link to comment Share on other sites More sharing options...
null54 Posted April 15, 2022 Author Share Posted April 15, 2022 Release version 1.3.12 Changes: Detect if the image is a misnamed JPEG/PNG file and load it using GDI+. 3 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted June 8, 2022 Author Share Posted June 8, 2022 Release version 1.3.13. Changes: Added a check box for lossless compression. This replaces the previous behavior of silently using lossless compression when the quality is 100. Improved metadata handling when loading files with the wrong extension. Detect BMP files with the wrong extension. 1 1 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted August 14, 2022 Author Share Posted August 14, 2022 Release version 1.3.14. Changes: Updated to libwebp version 1.2.4. 3 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted January 17, 2023 Author Share Posted January 17, 2023 Release version 1.3.15. This release is for Paint.NET 5.0+. Changes: Updated to libwebp version 1.3.0. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted January 20, 2023 Author Share Posted January 20, 2023 Release version 1.3.16. This release is for Paint.NET 5.0+. Changes: Fixed the detection of misnamed files. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
x-54 Posted February 24, 2023 Share Posted February 24, 2023 I downloaded P.N version 4.3.12 with bundled webp format support. I also download and install webp files into FileType folder. But webp image can't be open. I got message like this: D:\Programy\Paint.NET\paintdotnet.dll, wersja 4.312.8267.29064 Typ: PaintDotNet.Data.WebPFileType System.InvalidOperationException: No FileTypes were provided by D:\Programy\Paint.NET\Bundled\WebPFileType\WebPFileType.dll at PaintDotNet.Data.BundledFileTypeLoader.LoadFileTypePlugin(IPluginErrorService pluginErrorService) in D:\src\pdn\src_4_3_x\PaintDotNet\Data\BundledFileTypeLoader.cs:line 130 at PaintDotNet.Data.BundledFileTypeLoader.EnsureInitialized() in D:\src\pdn\src_4_3_x\PaintDotNet\Data\BundledFileTypeLoader.cs:line 76 at PaintDotNet.Data.WebPFileType..ctor(IFileTypeHost fileTypeHost) in D:\src\pdn\src_4_3_x\PaintDotNet\Data\WebPFileType.cs:line 26 at PaintDotNet.Data.PdnFileTypes.<>c__DisplayClass1_0.<GetFileTypeInstances>b__6() in D:\src\pdn\src_4_3_x\PaintDotNet\Data\PdnFileTypes.cs:line 42 at PaintDotNet.Data.FileTypeHelpers.TryCreateWithErrorReporting[T](IFileTypeHost host, Func`1 factoryFn) in D:\src\pdn\src_4_3_x\PaintDotNet\Data\FileTypeHelpers.cs:line 82 Any idea how it can be fixed? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted February 24, 2023 Share Posted February 24, 2023 10 minutes ago, x-54 said: I downloaded P.N version 4.3.12 with bundled webp format support. I also download and install webp files into FileType folder. The plugin requires paint.net v5. We don't offer any support for old versions of paint.net here on the forum. 1 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
