I need help related to a size of text issue.
Update on my mental breakdown
So I go in to settings, user interface, and disabled GPU. Then I restarted.
It fixed itself.
I literally panicked over nothing.
Please make an example out of my dumb < no swearing > to go in to paint.net settings before flipping out. I hope you got a kick out of me being stupid, I really do.
@JustAThrowawayForQuestions  Welcome.  It happens to all of us at some point.  Don't worry about it.  :)
A simple reboot usually fixes a lot of issues.  That's the first thing I do when things go a little wonky.  Glad it fixed your issue.
You mean you turn it off then turn it on again. :)
That might be the IT support advice cliche fix, ridiculed to death in TV sit-coms and the like, but it does often work.
