dipstick Posted December 22, 2018 Share Posted December 22, 2018 This tutorial is available as a PDF. Click here to view or download it You can use G'mic's Inpaint filter to help fix a photo bomb image. Example: You'll need null54's G'mic plugin It's a 2-step process: 1) Paint on a mask over offending object. Use Red at 255. Use brush hardness at 100. Disable Anti-Aliasing. 2) Run G'mic and go to Repair/Inpaint. I used [Multi-Scale] 3) Inpaint might not get everything, you can finish off with Clone Stamp. Enjoy... 2 1 Quote Link to comment Share on other sites More sharing options...
lynxster4 Posted December 22, 2018 Share Posted December 22, 2018 Good tip to know. Thanks @dipstick Quote My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to comment Share on other sites More sharing options...
Robert Smith Posted July 30, 2020 Share Posted July 30, 2020 What about the shadows behind them. You didn't try to remove it or forgot? Quote Link to comment Share on other sites More sharing options...
Robert Smith Posted August 4, 2020 Share Posted August 4, 2020 You did well, But Marked areas don't look like natural. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted August 4, 2020 Share Posted August 4, 2020 15 minutes ago, Robert Smith said: Marked areas don't look like natural. I can't believe you're complaining about this. This was an automatic job done by a piece of software (amazing software)! So, you have two small areas to clean up manually. Do you not understand how incredibly complicated an algorithm like this is? That fact that it looks even remotely normal is an amazing feat! It's comments like this that make me want to give up coding all together. ...NEVER SATISFIED... 4 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Reptillian Posted August 4, 2020 Share Posted August 4, 2020 (edited) 16 hours ago, Robert Smith said: You did well, But Marked areas don't look like natural. All you needed to do was to work with clone brush right after and some bit of painting. The thing is that there's no good solution to this sort of task. On shadow, would play with lighting to solve that. The OP only is pointing to a step to the right direction. Edited August 4, 2020 by Reptillian 1 Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
Robert Smith Posted August 5, 2020 Share Posted August 5, 2020 22 hours ago, BoltBait said: I can't believe you're complaining about this. This was an automatic job done by a piece of software (amazing software)! So, you have two small areas to clean up manually. Do you not understand how incredibly complicated an algorithm like this is? That fact that it looks even remotely normal is an amazing feat! It's comments like this that make me want to give up coding all together. ...NEVER SATISFIED... I am not complaining 😊 just saying that it could be better Quote Link to comment Share on other sites More sharing options...
BoltBait Posted August 5, 2020 Share Posted August 5, 2020 14 minutes ago, Robert Smith said: it could be better If you have an idea on how to improve the automatic algorithm, I'm excited to see your results. Please show us your code! 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Waterfall Posted March 13, 2021 Share Posted March 13, 2021 This is AWESOME! I can finally remove some objects that are not needed! Quote Link to comment Share on other sites More sharing options...
