Auron Posted May 20, 2018 Share Posted May 20, 2018 Every time I want to install paint.net, I keep getting the stopped working message. I have the latest version .net install. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 20, 2018 Share Posted May 20, 2018 Try rebooting your system and make sure you are all caught up with all of your Windows Updates. Then, try running the Paint.NET installer again. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Auron Posted May 20, 2018 Author Share Posted May 20, 2018 Try that and it still doesn't work. Quote Link to comment Share on other sites More sharing options...
NinthDesertDude Posted May 20, 2018 Share Posted May 20, 2018 You can try some solutions listed on Google; maybe the stack overflow suggestions if you're on Windows 10 and you think your .net installation might be corrupt somehow. It's a thought, anyway. Quote Link to comment Share on other sites More sharing options...
Auron Posted May 21, 2018 Author Share Posted May 21, 2018 I'm not sure what else to do. Literally can't install it. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted May 21, 2018 Share Posted May 21, 2018 1 hour ago, Auron said: I'm not sure what else to do. Literally can't install it. Try to install paint.net while in Windows Safe Mode. Let us know how it goes. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Auron Posted May 21, 2018 Author Share Posted May 21, 2018 How do you do windows in safe mode on windows 10? Quote Link to comment Share on other sites More sharing options...
null54 Posted May 21, 2018 Share Posted May 21, 2018 1 hour ago, Auron said: How do you do windows in safe mode on windows 10? See the following Microsoft support page: https://support.microsoft.com/en-us/help/12376/windows-10-start-your-pc-in-safe-mode Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Auron Posted May 22, 2018 Author Share Posted May 22, 2018 Ok so outta the blue after 3 or 4 days of refusing to work, it installs fine now. Thank you all for the time and advice given. Quote Link to comment Share on other sites More sharing options...
cornemuse Posted May 31, 2018 Share Posted May 31, 2018 Try turning off win's firewall, then install. This worked, finally, for me, , , , , (turn it back on!) Quote 'Where's my plinth?' Link to comment Share on other sites More sharing options...
