picklerick Posted April 14, 2018 Share Posted April 14, 2018 I recently started messing around with drawings in ms paint and today while working on a new drawing my paint bucket tool stopped working properly. When i try to fill in an area it leaves botches of white around the edges. Does anyone know why this is happening? I tried googling it but to no avail.. I'm sure its just a rookie mistake and hoping there's a quick fix. Thank you Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 14, 2018 Share Posted April 14, 2018 You have noise in your Solenya image. Most likely compression artifacts from using the JPG format. If you zoom-in, you'll be able to see those regions are not solid white, but have a bunch off off-white dots. You could try increasing the Tolerance when using the Paint Bucket. Remember to save your non-photo images in the PNG format. https://www.getpaint.net/doc/latest/PaintBucket.html#4 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
picklerick Posted April 14, 2018 Author Share Posted April 14, 2018 Thanks for the reply. I zoomed all the way in and the area is solid white but when i use the paint bucket tool it only fills a small area in a random pattern. I don't think my version of paint has the option to change the tolerance. Is there a way I can fix this drawing or will i have to start over? Quote Link to comment Share on other sites More sharing options...
lynxster4 Posted April 14, 2018 Share Posted April 14, 2018 11 hours ago, picklerick said: drawings in ms paint Are you using ms paint or Paint.Net?? If using PDN, it has a tolerance slider bar for the adjustment. If you're using ms paint, you are asking on the wrong forum. Quote My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to comment Share on other sites More sharing options...
picklerick Posted April 14, 2018 Author Share Posted April 14, 2018 i didn't realize paint.net was a different program so i downloaded it and transferred my image and it fixed the issue! thanks guys and i found a cool new program to use! sweeeeeet 1 Quote Link to comment Share on other sites More sharing options...
lynxster4 Posted April 15, 2018 Share Posted April 15, 2018 19 hours ago, picklerick said: i didn't realize paint.net was a different program so i downloaded it and transferred my image and it fixed the issue! thanks guys and i found a cool new program to use! sweeeeeet Glad we could help! Enjoy PDN. Quote My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to comment Share on other sites More sharing options...
picklerick Posted April 20, 2018 Author Share Posted April 20, 2018 i was able to complete my painting.. quite happy with the way it turned out and wanted to share :) can't wait to do more.. hoping i can gain some artistic talent to do original drawings soon 1 1 Quote Link to comment Share on other sites More sharing options...
Pixey Posted April 20, 2018 Share Posted April 20, 2018 You did great @picklerick Don't forget that you can start your own Gallery in the Pictorium and then add every new piece in the same place. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
