I was trying to save a gradient but I got this instead . What exactly is the problem? It`s fine until I try saving the gradient.Is there a special folder needed by any chance?
Share this post
Link to post
Do you have pyrochild.effects.common.dll? If so, make sure that both Gradient Mapping.dll and the common DLL are the latest versions.
Share this post
Link to post
I`ve just installed the latest versions of both files but I still can`t save any gradients. Do I have to create a file in PDN`s User Files like with Custom Brushes? At least this time it never crashed when I tried to save. The only problem now is where.
Btw - the name of this thread gives the old version number, which is why I thought I was up to date.
Share this post
Link to post
I`ve just installed the latest versions of both files but I still can`t save any gradients. ... At least this time it never crashed when I tried to save.
If it's not crashing, what's happening?
No
2.2 is the current version.
Share this post
Link to post
I get the window shown below. When I chose a folder the first time( in my case I chose my textures file to try it out) that was when it crashed.
I`ve tried saving again to the same place and it seems to be fine now. Updating the plug in must have done the trick.
Thanks for your help.
Sorry about the confusion with version numbers. The date of the mapping plug in is different to the date of the plug in pack.That`s what threw me. :oops:
Share this post
Link to post
The set will always show the date of the most recent update among all of the plugins. Individual plugins will carry the date of their own last update. Or at least that's the idea. I kind of failed at that with Borders N' Shapes...
Share this post
Link to post
$500 says you didn't put pyrochild.effects.common.dll in the Effects directory with Gradient Mapping.dll or are using an unsupported version of Paint.NET (anything except 3.36).
Share this post
Link to post
1.) I don't have any money.
2.) Where can I find pyrochild.effects.common.dll?
3.) I have Paint.NET v3.5 and the version PC I'm using is Windows Vista.
Share this post
Link to post
The file does, actually, "came with it." And if you'd follow the download link in the first post of this thread, you'd quickly find where to download it again.
Share this post
Link to post
I guess the new version of paint.net is a Beta, so you may be unwilling to help out, but paint crashes when I try and change the color on Gradient Mapping.
I get an error that reads:
"There was an unhandled error, and Paint.NET must be closed..."
Hidden Content:
Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem.
Application version: Paint.NET v3.5 (Beta Release build 3.50.3550.40197)
Time of crash: 9/30/2009 4:39:40 PM
Application uptime: 00:04:55.1610081
Command line: "C:\Program Files\Paint.NET\PaintDotNet.exe"
OS Version: 5.1.2600.131072 Service Pack 2 Workstation x86
.NET version: CLR 2.0.50727.3082 x86, FX 2.0 2.0SP1 2.0SP2 3.0 3.0SP1 3.0SP2 3.5 3.5SP1 3.5SP1_Client
Processor: 2x "IntelĀ® Core2 Duo CPU E8400 @ 3.00GHz" @ ~2992MHz (DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1)
Physical memory: 3053 MB
UI Theme class: Luna
Updates: true, 9/30/2009
Locale: pdnr.c: en-US, hklm: en-US, hkcu: n/a, cc: en-US, cuic: en-US
Managed assemblies:
mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll
PaintDotNet, Version=3.50.3550.40202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
PaintDotNet.Core, Version=3.50.3550.40198, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
PaintDotNet.Base, Version=3.50.3550.40190, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\WINDOWS\assembly\GAC_MSIL\WindowsBase\3.0.0.0__31bf3856ad364e35\WindowsBase.dll
System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System.Core\3.5.0.0__b77a5c561934e089\System.Core.dll
PaintDotNet.SystemLayer, Version=3.50.3550.40196, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
PaintDotNet.Resources, Version=3.50.3550.40197, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
PaintDotNet.Data, Version=3.50.3550.40199, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
PaintDotNet.Effects, Version=3.50.3550.40201, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
AdvancedTools, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AdvancedTools.dll
AlphaBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaBlur.dll
AlphaMaskBrush, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMaskBrush.dll
Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bars.dll
BasicPhotoAdjustments, Version=1.5.3472.42856, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicPhotoAdjustments.dll
BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Black and White Converter.dll
"Borders N' Shapes", Version=1.7.3106.38770, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll
Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll
Bullet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bullet.dll
Channels, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channels.dll
Color Match, Version=1.0.3106.38961, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll
ColorMixer, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMixer.dll
ColorModulo, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll
ColorToAlpha, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorToAlpha.dll
ConditionalPen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ConditionalPen.dll
CreateImageMap, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CreateImageMap.dll
Curves+, Version=2.10.3298.41852, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll
CustomBrushesMini, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll
DesktopBackgroundPreview, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DesktopBackgroundPreview.dll
Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll
Film, Version=2.0.3106.38770, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll
FilmNoir, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FilmNoir.dll
FindEdges, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll
Fire, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fire.dll
Flags, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flags.dll
Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frame.dll
GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GenTree.dll
Gradient Bars, Version=3.0.3106.38771, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll
GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll
Gradient Mapping, Version=2.2.3106.38961, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll
Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll
GridMaker, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll
HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll
Hue_Saturation+, Version=1.0.3277.32208, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Hue_Saturation+.dll
ImageShackUpload, Version=2.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll
Jitter, Version=3.0.3106.38769, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll
KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll
Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll
LensFlare, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll
LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll
LocalContrast, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalContrast.dll
Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll
Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll
MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll
Nebulous, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll
NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll
Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll
Olden, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll
Outline Object, Version=2.6.3284.30852, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll
PageCurl, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll
Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Panelling.dll
PDNWatermark, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PDNWatermark.dll
Pixelate+, Version=1.0.3106.38767, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll
PixelatedFrame, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PixelatedFrame.dll
Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll
Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll
PrinterPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll
pyrochild.effects.common, Version=2.5.3298.19513, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pyrochild.effects.common.dll
Radialcolors, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll
RainbowTwist, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll
Random Effect, Version=1.2.3284.30866, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll
RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random lines.dll
RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze1.dll
RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze2.dll
Random Shape Fill, Version=1.0.3106.41337, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll
RedEyeQuickFix, Version=1.1.3161.39688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RedEyeQuickFix.dll
EditableText, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Re_Editable_Text_BETA_by_sabrown100.dll
Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll
ScriptLab, Version=2.4.3284.31448, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll
SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll
ShadowHighlight, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowHighlight.dll
Sharpen+, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sharpen+.dll
SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll
Smudge, Version=2.2.3298.1545, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll
Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkles.dll
Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Spiral.dll
SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll
SpiroShapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll
Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll
Splatter, Version=1.5.3284.30867, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll
Stars, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll
Stitch, Version=1.0.3106.38769, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll
StockLibrary, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StockLibrary.dll
SubtleEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SubtleEffect.dll
Texture, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture.dll
ThreadsMarker, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll
Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll
Transitional Brush, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transitional Brush.dll
TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll
TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll
TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll
Vibrato, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll
Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll
WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll
Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll
WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll
System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll
System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll
XYCoords, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll
PresentationCore, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\WINDOWS\assembly\GAC_32\PresentationCore\3.0.0.0__31bf3856ad364e35\PresentationCore.dll
Native modules:
C:\WINDOWS\system32\ntdll.dll
C:\WINDOWS\system32\mscoree.dll
C:\WINDOWS\system32\KERNEL32.dll
C:\WINDOWS\system32\ADVAPI32.dll
C:\WINDOWS\system32\RPCRT4.dll
C:\WINDOWS\system32\Secur32.dll
C:\WINDOWS\system32\SHLWAPI.dll
C:\WINDOWS\system32\GDI32.dll
C:\WINDOWS\system32\USER32.dll
C:\WINDOWS\system32\msvcrt.dll
C:\WINDOWS\system32\IMM32.DLL
C:\WINDOWS\system32\wbsys.dll
C:\Program Files\AlienGUIse\wbhelp.dll
c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca\MSVCR80.dll
C:\WINDOWS\system32\shell32.dll
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
C:\WINDOWS\system32\comctl32.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\mscorlib\6d667f19d687361886990f3ca0f49816\mscorlib.ni.dll
C:\WINDOWS\system32\ole32.dll
C:\Program Files\AlienGUIse\WBlind.dll
C:\WINDOWS\system32\WINMM.dll
C:\WINDOWS\system32\UXTHEME.DLL
C:\WINDOWS\system32\msimg32.dll
C:\Program Files\AlienGUIse\AlienwareDock\DockShellHookOEM.dll
C:\WINDOWS\system32\MSCTF.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System\80978a322d7dd39f0a71be1251ae395a\System.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Core\47d87251e93256c635eb73403b8db33e\System.Core.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\WindowsBase\14cd5f4b61d35f9b76327d6be9853755\WindowsBase.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Base\1f7a9b68dfe2b709f05f1aba8012246d\PaintDotNet.Base.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing\3da96ee075bab9202626ae44c18d226c\System.Drawing.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\63406259e94d5c0ff5b79401dfe113ce\System.Windows.Forms.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet.SystemL#\bd248c16eabe5230f5ef546ce7359d9a\PaintDotNet.SystemLayer.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Resourc#\54050ee437e57131c9edcd323ebb051c\PaintDotNet.Resources.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Core\d9a41936719225bc1c6f5deec04aca6f\PaintDotNet.Core.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Data\4151e2698560d33b3646627677017e5b\PaintDotNet.Data.ni.dll
C:\WINDOWS\system32\rsaenh.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet\c9f7c7a0f34afae8164ceb8fae0a41d0\PaintDotNet.ni.exe
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Interop.WIA\5032a7db356619fd5c44843d46dc470a\Interop.WIA.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet.SystemL#\8c08255ea8f6d226ccf17ab26cb7b758\PaintDotNet.SystemLayer.Native.x86.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Effects\51eeb72711eecd8ab4d7888d51322015\PaintDotNet.Effects.ni.dll
C:\Program Files\Paint.NET\Native.x86\PaintDotNet.Native.x86.dll
C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\MSVCR90.dll
C:\WINDOWS\WinSxS\x86_Microsoft.VC90.OpenMP_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_f0ccd4aa\VCOMP90.DLL
C:\WINDOWS\system32\msctfime.ime
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.3352_x-ww_81af8e88\gdiplus.dll
C:\WINDOWS\system32\oleaut32.dll
C:\WINDOWS\system32\xpsp2res.dll
C:\WINDOWS\system32\wtsapi32.dll
C:\WINDOWS\system32\WINSTA.dll
C:\WINDOWS\system32\NETAPI32.dll
C:\WINDOWS\system32\version.dll
C:\WINDOWS\system32\winhttp.dll
C:\WINDOWS\system32\RASAPI32.DLL
C:\WINDOWS\system32\rasman.dll
C:\WINDOWS\system32\WS2_32.dll
C:\WINDOWS\system32\WS2HELP.dll
C:\WINDOWS\system32\TAPI32.dll
C:\WINDOWS\system32\rtutils.dll
C:\WINDOWS\system32\msv1_0.dll
C:\WINDOWS\system32\iphlpapi.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Configuration\b82c00e2d24305ad6cb08556e3779b75\System.Configuration.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Xml\773a9786013451d3baaeff003dc4230f\System.Xml.ni.dll
C:\WINDOWS\system32\mswsock.dll
C:\WINDOWS\system32\hnetcfg.dll
C:\WINDOWS\System32\wshtcpip.dll
C:\WINDOWS\system32\DNSAPI.dll
C:\WINDOWS\System32\winrnr.dll
C:\WINDOWS\system32\WLDAP32.dll
C:\WINDOWS\system32\rasadhlp.dll
c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PresentationCore\956375d487cbef36165b3250030e3574\PresentationCore.ni.dll
c:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\wpfgfx_v0300.dll
C:\WINDOWS\system32\dciman32.dll
C:\WINDOWS\system32\SetupApi.dll
C:\WINDOWS\system32\WINTRUST.dll
C:\WINDOWS\system32\CRYPT32.dll
C:\WINDOWS\system32\MSASN1.dll
C:\WINDOWS\system32\IMAGEHLP.dll
C:\WINDOWS\system32\psapi.dll
Exception details:
System.MissingMethodException: Method not found: 'Void PaintDotNet.SnapObstacleController.SetBounds(System.Drawing.Rectangle)'.
at pyrochild.effects.common.FloatingToolForm.UpdateSnapObstacleBounds()
at pyrochild.effects.common.FloatingToolForm.OnSizeChanged(EventArgs e)
at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height)
at System.Windows.Forms.Control.SetBoundsCore(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
at System.Windows.Forms.Form.SetBoundsCore(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
at System.Windows.Forms.Control.SetBounds(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
at System.Windows.Forms.Control.set_Size(Size value)
at System.Windows.Forms.Control.SetClientSizeCore(Int32 x, Int32 y)
at System.Windows.Forms.Form.SetClientSizeCore(Int32 x, Int32 y)
at System.Windows.Forms.Control.set_ClientSize(Size value)
at System.Windows.Forms.Form.set_ClientSize(Size value)
at PaintDotNet.PdnBaseForm.InitializeComponent() in D:\src\pdn\paintdotnet\src\Core\PdnBaseForm.cs:line 1266
at PaintDotNet.PdnBaseForm..ctor() in D:\src\pdn\paintdotnet\src\Core\PdnBaseForm.cs:line 984
at pyrochild.effects.common.FloatingToolForm..ctor()
at pyrochild.effects.common.ColorsForm..ctor()
at pyrochild.effects.common.ColorsDialog..ctor(Boolean UseTwoColors)
at pyrochild.effects.common.GradientControl.ChangeColor()
at pyrochild.effects.common.GradientControl.OnMouseDoubleClick(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
Any idea what is wrong?
Share this post
Link to post
Pyro,
With the latest edition of Paint.net Gradient Mapping doesn't even appear under 'Adjustments.'
I checked my effects' folder and it is still there. I even downloaded/installed it a second time and it still doesn't show.
I don't think paint.net developers like your plug-ins, haha.
Yes, I know this is a beta version of paint.net but isn't it about time for an update for your plug-ins?
Thanks
Share this post
Link to post
Hey Pyrochild, I've been using this plugin since i first used paint.net (v3.36)
the plugin you used on that version was the greatest, made a lot of my work with that plugin :)
But the down side for this updated plugin is just not the same plugin as the one you made for the v3.36
To be honest, i find the plugin much better when you made it for the v3.36
Share this post
Link to post
