Gradient Mapping
32 minutes ago, Pixey said:
now 4.3.3
4.3.3 isn't out yet.  Maybe this issue is only affecting some people.  🙂
Hello guys; I have a quescion too. Yes Gradient Mapping working but effects don't loading / working. Also effects were same in 2 folders one paint.net UserFiles\Effect Presets\Gradients Mapping and other one  paint.net UserFiles\Effect Preset\System.Private.CoreLib. Then i deleted paint.net UserFiles\Effect Preset\System.Private.CoreLib folder but result again same. Don't working? I couldnt find Why!
Edited by user.by
1 hour ago, ReMake said:
Probably by the word effects you mean presets with an extension .xml?
From which source did you download Gradient Mapping.dll?
Beforehand it was normal, i can load to .xml files but now pluging working not problem, it's just not load .xml files.
Edited by user.by
@user.by  Put your .xml files in the 'Sysytem.Private.CoreLib' folder (as I stated above).  Then they will appear in the drop-down menu.
I got it, i was using as GradientMapping.dll and GradientMapping folder then i gave space to Gradient Mapping.dll and Gradient Mapping folder, then reason resolved.
Edited by user.by
