Sign in to follow this
pyrochild
Gradient Mapping
Uh huh. Right.
Really, though, I have no idea what you're talking about. All you're saying is "it's different." Well, yes. That's the point of having new versions.
Share this post
Link to post
ok, the reason why i like the older version better then the new one is because it made my pictures look really good
I can show you some of my work, but i don't think it's has any relivent to this topic and, i don't know how to post picture on here (im kinda a newbie on this)
Share this post
Link to post
Could you possibly be any more vague? Nothing has changed as far as "making your pictures look good." The only real difference between this version and the last is the addition of a preset system. And keyboard shortcuts.
In other words, it sounds like a personal issue you're having. PEBCAK.
Share this post
Link to post
Yes, I've been sending them in and that's all I need to do? Is that correct?
Pyro's sig implies he doesn't want to be bothered with it.
Edited by PeterPawn
Share this post
Link to post
No. Reread Simon's reply. If you send in the crash log, Rick receives it. Rick only want crash logs that are a result of PDN itself crashing.
If a plugin crashes, post the crash log in the thread of that plugin or PM it to the plugin author. In Pyrochilds case, post the crash log in the thread boltbait.wink.png
Share this post
Link to post
I sent it in because this was the message that was produced when it crashed.
"This text file was created because Paint.NET crashed.
Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem."
Share this post
Link to post
....Rick only want crash logs that are a result of PDN itself crashing.
If a plugin crashes, post the crash log in the thread of that plugin or PM it to the plugin author.....
My emphasis to indicate the difference. What causes the crash determines what you should do with the crash report.
Share this post
Link to post
Okay. I was using the plugin when PdN closed down. How do I know if the plugin was at fault or PdN was at fault? Further, the crash log is huge. Do you really want me to post it here?
Share this post
Link to post
pyrochild.effects.common.dll can be removed.
Be sure that you have the latest version of pyrochild.effects.REQUIRED.dll
Edited by Sarkut
Share this post
Link to post
All right. I don't want to misunderstand anything. You're saying, remove that dll file from the effects folder, correct?
I'll do that now and try the plugin again.
Edited by PeterPawn
Share this post
Link to post
