gwnguy Posted July 22, 2020 Share Posted July 22, 2020 This is a real stupid question - sorry. I put RawFileType.dll, dcraw.exe and RawFileTypeOptions.txt in the Paint.NET FileTypes folder and started paint.net. Now for the stupid question: where do I find the plugin in paint.net? I'm using 4.2.12 Thank you Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted July 22, 2020 Share Posted July 22, 2020 4 minutes ago, gwnguy said: where do I find the plugin in paint.net? File -> Open Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
gwnguy Posted July 22, 2020 Share Posted July 22, 2020 Okay thank you. I actually dragged the files onto paint.net and they displayed fine. So I guess my question should have been how do you see each layer in the raw file? Or are there any specific RAW editing tools in paint.net I need to add? Quote Link to comment Share on other sites More sharing options...
gwnguy Posted July 22, 2020 Share Posted July 22, 2020 Is the GUI below associated with this plugin? Quote Link to comment Share on other sites More sharing options...
null54 Posted July 22, 2020 Author Share Posted July 22, 2020 6 minutes ago, gwnguy said: Is the GUI below associated with this plugin? No, that is a different RAW file plugin. 14 minutes ago, gwnguy said: So I guess my question should have been how do you see each layer in the raw file? What do you mean by layers? All RAW formats that I am aware of contain only a single image. If you are referring to the individual color channels, Paint.NET does not currently have that feature. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
gwnguy Posted July 22, 2020 Share Posted July 22, 2020 okay thank you for both answers. Brand new to using RAW - sorry. Quote Link to comment Share on other sites More sharing options...
null54 Posted August 21, 2021 Author Share Posted August 21, 2021 Release version 1.3.0. Changes: Replaced DCRaw with LibRaw's dcraw_emu example program. LibRaw is more frequently updated than DCRaw, so it should provide improved support for newer cameras. Breaking Change: The following DCRaw command line switches are not supported by dcraw_emu: -D, -d, -P, -K, -i or -e. A list of the dcraw_emu-specific commands can be found at libraw.org/docs/Samples-LibRaw.html 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
chatbubbles Posted August 26, 2021 Share Posted August 26, 2021 Thank you for creating this plugin. It seems somewhat slow in opening files -- even when using the half-size option. Also, could you please add support for extracting the thumbnail from a raw file? The documentation for the original dcraw states that "You'll get either a JPEG or a PPM file, depending on the camera." Quote Link to comment Share on other sites More sharing options...
null54 Posted August 26, 2021 Author Share Posted August 26, 2021 10 hours ago, chatbubbles said: It seems somewhat slow in opening files -- even when using the half-size option. I made a few improvements in the file I/O code that should make the next version faster. 10 hours ago, chatbubbles said: Also, could you please add support for extracting the thumbnail from a raw file? This option is not implemented by dcraw-emu, and the plugin does not support reading JPEG files (only TIFF and PPM). 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted August 27, 2021 Author Share Posted August 27, 2021 Release version 1.3.1. Changes: Rebuilt dcraw_emu to use multi-threaded decoding. Improved performance when writing the temporary input file. Improved performance when reading the decoded PPM files. Added CR3 to the file extension list. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
chatbubbles Posted January 12, 2022 Share Posted January 12, 2022 On 8/28/2021 at 5:30 AM, null54 said: Release version 1.3.1. Changes: Rebuilt dcraw_emu to use multi-threaded decoding. Improved performance when writing the temporary input file. Improved performance when reading the decoded PPM files. Added CR3 to the file extension list. Could you please update this plugin with the current LibRaw snapshot? It supports photos from Canon's R5. Quote Link to comment Share on other sites More sharing options...
null54 Posted January 12, 2022 Author Share Posted January 12, 2022 2 hours ago, chatbubbles said: Could you please update this plugin with the current LibRaw snapshot? Done. Release version 1.3.2. Changes: Updated LibRaw to the 2021-10-22 development snapshot. 2 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
chatbubbles Posted January 12, 2022 Share Posted January 12, 2022 4 hours ago, null54 said: Done. Release version 1.3.2. Changes: Updated LibRaw to the 2021-10-22 development snapshot. Thank you. Impressive turnaround, can now see R5 photos correctly Quote Link to comment Share on other sites More sharing options...
NigelM Posted February 21, 2022 Share Posted February 21, 2022 Hi, I'm new to paint dot net so please forgive any idiocy here. I've added your plugin (many thanks) and can now successfully open a Sony .arw file as I wanted to. It lets me edit and save the file, with an arw extension. But then if I try to open it again with paint it fails with an error? Should I be able to save in any raw format? Or only the file types in the drop down save menu? Quote Link to comment Share on other sites More sharing options...
HyReZ Posted February 21, 2022 Share Posted February 21, 2022 (edited) When you select 'Save As...' it will provide a listing of all the formats it can write. Edited February 21, 2022 by HyReZ Quote Link to comment Share on other sites More sharing options...
stan Posted April 11, 2022 Share Posted April 11, 2022 One of the comments in RawFileTypeOptions.txt states: "The default settings are to the camera white balance (-w) and AHD interpolation (-q 3)." I guess that should read something like: "The default settings are related to the camera white balance (-w) and AHD interpolation (-q 3)." Thanks for the plugin! Quote Link to comment Share on other sites More sharing options...
null54 Posted December 26, 2022 Author Share Posted December 26, 2022 Release version 1.3.3. Changes: Updated LibRaw to the 0.21.0 release. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
StephanP Posted December 27, 2022 Share Posted December 27, 2022 Windows defender reports Trojan:Win32/Wacatac.H!ml and blocks the download. No way to circumvent this, it seems. Quote Link to comment Share on other sites More sharing options...
null54 Posted December 28, 2022 Author Share Posted December 28, 2022 14 hours ago, StephanP said: Windows defender reports Trojan:Win32/Wacatac.H!ml and blocks the download. Looks like a false positive, none of the other vendors on VirusTotal have an issue with the file. https://www.virustotal.com/gui/file/50863cd88deb6215613d27138c36c751a834422d860370d0b3c27d14a65bc58c?nocache=1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
StephanP Posted December 28, 2022 Share Posted December 28, 2022 I'll try again after a couple of days Quote Link to comment Share on other sites More sharing options...
StephanP Posted December 28, 2022 Share Posted December 28, 2022 Got it! MS fixed their issue. Quote Link to comment Share on other sites More sharing options...
PJ Noxon Posted December 29, 2022 Share Posted December 29, 2022 This essential plug-in seems to have been replaced with a virus file according to my McAfee, who notifys GitHub and null54? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 29, 2022 Share Posted December 29, 2022 4 minutes ago, PJ Noxon said: This essential plug-in seems to have been replaced with a virus file according to my McAfee, who notifys GitHub and null54? The more appropriate action is to notify you to remove McAfee from your computer. 1 1 2 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
null54 Posted January 5, 2023 Author Share Posted January 5, 2023 Release version 1.3.4. Changes: Updated LibRaw to the 0.21.1 release. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted January 20, 2023 Author Share Posted January 20, 2023 Release version 1.3.5. This release is for Paint.NET 5.0+. Changes: Improved metadata handling when loading TIFF images. Report dcraw_emu error messages. Improved performance when loading PPM files. 3 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
