paint.net 4.0 beta build 5226
Rick Brewster
Confirmed.
In 3.5.11 Left Mouse = opaque to transparent. Right Mouse = transparent to opaque.
In 4.0.5226 Left AND Right = opaque to transparent.
Also: You used to be able to swap the gradient direction by clicking on a nub. This doesn't work in 4.0.5226.
To change to transparent to opaque, set your primary and secondary colors to transparent.
Ok, so... if I'm understanding correctly, for the radial gradient,
Setting it to transparency mode with solid primary/secondary colors, makes it so the center is solid, right?
While setting it to transparency mode, but changing the primary/secondary colors to Opacity Alpha 0, makes it so the center is transparent, is that correct?
It seems a bit complicated vs just right clicking and left clicking. Oh well, at least we do still have ways to have both kinds of transparent radial gradients, which is good to know. :)
Edited by Cc4FuzzyHuggles
When Pasting a picture (2748 x 3712) in a new one (1600 x 1900 with 100 pixels/cm) with no change of the size of the destination file, when I resize the layer to have all I want visible, it crops the visible part. I can move the big picture but can't resize the layer without loosing as if it was crop. So it's impossible to use bigger picture in a smaller document without loosing a big part of the picture.
I tryed the same manipulation with the same pictures (different tests with different resolutions) on the previous stable version of Paint.net, and it works perfectly.
1) I left my laptop unattended for a while and it went to hibernate (not standby).
After I had rebooted the system, the whole canvas area (the picture as well as the gray surrounding area) remained white until I resized the paint.net window to force a full repaint of the UI.
Not sure this is reproducible since it needs some time until my laptop goes into hibernate. I'd appreciate someone else trying this, too.
2) When you copy anything at the bottom or righthand border of an image and paste it, it will not be pasted where it was copied but with 1 pixel margin. Reproducible: always.
Edited by LWChris
What is your operating system?
You can also force to hibernate, it's possible that you have to enable the option from your menu, you can find the procedure online.
There are 2 types of hibernation, classical and hybrid suspension. The second is just like normal stand by, but it also saves date on hard drive in case of power failure. You may need to enable that from power settings (advanced mode).
What did you use?
I tried both mode (I have enabled hybrid suspension and I've tried first without unplugging power cable, and the second unplugging it) but I've returned with the canvas still visible (I've pasted a screenshot, no levels or anything else).
Windows 8.1.
Emh...
It's 4 posts before your (with workaround!).
Emh...
...i saw but they resized the layer and i didn't... and i knew that workaround before i saw your post... but it's stil very annoying
Edited by tditdatdwt
