TechnoRobbo Posted August 29, 2013 Author Share Posted August 29, 2013 (edited) PDNNOOB,DD & RED, Thank You (One thing to note: For me, it only works with the right 'Ctrl' key - probably just my rubbish keyboard!) the rest of my reply is in XML: <Puns> <pun>Maybe you have a "Conservative" keyboard.</pun> <pun>Maybe it's one of those keyboard that always thinks it's "Right". </pun> <pun>At least it's not the "Wrong" Control Key.</pun> </Puns> Weird. Since I read CTRL using C#'s ModifierKeys it should detect both. Can you control Ctrl+C, Ctrl+V from both left and right? Edited August 29, 2013 by TechnoRobbo Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
nitenurse79 Posted August 29, 2013 Share Posted August 29, 2013 All is needed now is a vanishing point plugin that PS has. Very good update and very useful, thank you Quote Link to comment Share on other sites More sharing options...
skullbonz Posted August 31, 2013 Share Posted August 31, 2013 Awesome plugin!! It saves so much time with photo manips,very nice. Here's one I whipped up for my avatar at FB,lol. Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
TechnoRobbo Posted August 31, 2013 Author Share Posted August 31, 2013 NiteNurse79 ....All is needed now is a vanishing point plugin that PS has. Vanishing Point? Holy Christmas Nuts! Vanishing Point is a whole applet. That would take a long time considering all the tools it has. How about a Smudger instead? Cause that's what I wrote. (Smudger is Coming real soon!!!!) Skull, Does that come in a 4 door? Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
dug Posted September 7, 2013 Share Posted September 7, 2013 Just catching up. This is magic. Thank you so much TR.Off to play. Quote MY GALLERYD.A.TheRawAtom Link to comment Share on other sites More sharing options...
TechnoRobbo Posted October 18, 2013 Author Share Posted October 18, 2013 -Updated for Paint.net 4.0 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted January 15, 2014 Share Posted January 15, 2014 I have downloaded and played with this plug-in. I think out of the plug-ins you have wrote, this one has the most potential to be unleashed, so kudos for writing and publishing it. However, there's one thing I don't like about this plug-in, and that's using the angle to draw the edge around an object I wish to mask. Is it possible for you to create a plug-in where I could draw the edge directly on the plug-in's canvas (similar to using pryochild's smudge and lquidify plug-ins)? I think, coupling this ability with using CTRL key to lock the edge, this plug-in would be right up there with smudge and liquidfy. Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted January 15, 2014 Author Share Posted January 15, 2014 (edited) However, there's one thing I don't like about this plug-in, and that's using the angle to draw the edge around an object I wish to mask. Is it possible for you to create a plug-in where I could draw the edge directly on the plug-in's canvas (similar to using pryochild's smudge and lquidify plug-ins)? I think, coupling this ability with using CTRL key to lock the edge, this plug-in would be right up there with smudge and liquidfy. Have you seen: http://forums.getpaint.net/index.php?/topic/27512-trs-splinemaster-v134-a-line-maker-jan-5th-2014utc/?p=400634 It has been my intention since I wrote the handle system for SplineMaster to employ and editable save-able mask system for Alpha Cutter. Spline Master has a masking system but does not employee Auto Follower or Zoom, like Alpha Cutter does. I decided not to clutter SplineMaster and create a similar system in Alpha Cutter. I wrote Alpha Cutter in Code Lab but I feel I can't push IndirectUI to do what I need, so I am writing it under a Windows Form interface. Yes I have started writing it. By the way TR's Fuego and TR's Smudger both have full-image interfaces also. Edited January 15, 2014 by TechnoRobbo Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TechnoRobbo Posted January 21, 2014 Author Share Posted January 21, 2014 (edited) For those of you who hate reading instructions here is Update 3.0 Pre-Release - I am working on instruction videos and tutorials so I haven't updated the original post. Simple intuitive controls - improved tracking algorithm (whiskers!). Soft edge masked with curvature control. Left-Click : Inserts a new Control Point Selects and moves Control Point Inserts Control Point after selection <Escape> De-selects Control Point <Delete> Deletes selected Control Point <BackpSpace> Deletes Last Mouse Wheel: Zooms in and out Right-Click: Pans View Try it out - tell me if you break it. I'll do my best to fixit. Pre release moved to last post Edited December 28, 2015 by TechnoRobbo Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted January 21, 2014 Share Posted January 21, 2014 (edited) For the most part...it does its job. There's some edges I will have to clean up, naturally. Hmm...would it be possible to add the ability to automatically zoom out instead of being zoomed all the way in? Edit: The only way I was able to get a "zoomed out" view was to resize my photograph. Also, I noticed when panning using the stylus' "right-click" function, it would add points instead of just panning around. Maybe it's the stylus and me doing it. If you need to know, I have a Wacom Bamboo drawing tablet. Edited January 21, 2014 by TrevorOutlaw Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted January 22, 2014 Author Share Posted January 22, 2014 (edited) For the most part...it does its job. There's some edges I will have to clean up, naturally. this is why you can move add delete handles on the fly Hmm...would it be possible to add the ability to automatically zoom out instead of being zoomed all the way in? Edit: The only way I was able to get a "zoomed out" view was to resize my photograph. I'll experiment with that sounds like a good idea Edited January 22, 2014 by TechnoRobbo Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TechnoRobbo Posted January 24, 2014 Author Share Posted January 24, 2014 (edited) Hmm...would it be possible to add the ability to automatically zoom out instead of being zoomed all the way in? Edit: The only way I was able to get a "zoomed out" view was to resize my photograph. Here's Version 3.0.1 Pre-release - tell me if it's enough zoom. Also, I noticed when panning using the stylus' "right-click" function, it would add points instead of just panning around. Maybe it's the stylus and me doing it. If you need to know, I have a Wacom Bamboo drawing tablet. On my tablet - that has to do with putting pressure on the tip. If you haven't solved it I can use a modifier key like CTRL of Shift to initiate a pan. Let me know please. Download in Original Post http://forums.getpaint.net/index.php?/topic/26966-trs-alpha-cutter-v301-jan-242014/?p=395803 Edited January 25, 2014 by TechnoRobbo 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted January 24, 2014 Share Posted January 24, 2014 (edited) I just tested the update as you asked. Well done. The photograph I use is quite large, 4608x3072, which was taken with a Nikon D3100 DSLR camera, and that's probably why it does not automatically zoom out to "Window" size as it does in the PDN enivornment. However, using the zoom slider, I was able to zoom in and out. I think that was an issue, because I cannot recall if I was able to use the slider to zoom out. I think you have fixed it. The pan, I think, was actually my own fault. The pen, when touching the drawing tablet's surface, acts like a left click, and when I use the "right-click" button of the pen, I would actually be dragging and clicking the points on the image I was trying to mask. I figured that if I hover the pen slighty above the drawing tablet's surface, and use right-click, I was able to pan accordingly. The plug in does behave slow, but I suspect this is due to the size of the photograph itself, and the fact the computer is working hard calculating everything as I am tracing the object I am trying to mask. Edit: I can confirm that size indeed does play a factor. When I reduced the size of the photograph by 40% the speed was noticably faster. Edit 2: WOW. I love this plug-in. I love I can click "Enable Mask" to see if I have missed an edge, and fine tune the edge. Marvelous plug-in! Edited January 24, 2014 by TrevorOutlaw Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted January 24, 2014 Author Share Posted January 24, 2014 (edited) Great!!!!, I'll finish up the tutorials and post the release version this weekend. Edit: Release 3.0.1 - Posted Edited January 25, 2014 by TechnoRobbo 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TechnoRobbo Posted February 8, 2014 Author Share Posted February 8, 2014 Version 3.0.2 Update posted - new mask leave old masks intact so you can create complex transparencies Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted March 23, 2014 Share Posted March 23, 2014 I'm experiencing some difficulty in using the Alpha Cutter. Yes, I have the v3.0.2, but here's the issue...I can't seem to move around the image I'm trying to cut. I would like to be able to zoom in to fine tune, and then move to the bottom of the image, and I can't seem to do that. I'm using the 2nd 4.0 beta version. Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted March 23, 2014 Author Share Posted March 23, 2014 Trevor - I uploaded 3.03 - hopefully it fixes the problem Also - Make sure you zoom in using Alpha Cutter not PDN Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
ratty redemption Posted April 7, 2014 Share Posted April 7, 2014 (edited) hi tr, i think i just found a couple of bugs with your latest version, i don't know if they were present in earlier versions? 1. invert mask appears to disable smooth edge (anti aliasing) until the mask is inverted back to normal. 2. the zoom slider's zoom is not centered, it appears with the 16:9 image i'm working on to always zoom to the upper left of the image. although i'm aware we can thankfully pan with right mouse/touchpad button. Edited April 7, 2014 by ratty redemption 1 Quote ratty redemption deviantart.com Link to comment Share on other sites More sharing options...
TechnoRobbo Posted April 8, 2014 Author Share Posted April 8, 2014 (edited) 1. invert mask appears to disable smooth edge (anti aliasing) until the mask is inverted back to normal. 2. the zoom slider's zoom is not centered, it appears with the 16:9 image i'm working on to always zoom to the upper left of the image. although i'm aware we can thankfully pan with right mouse/touchpad button. ratty 1.,thanks for spotting the bug - Fixed 2 When you zoom out full it resets to upper left since the center is not decided. but if you don't zoom out beyond 100% it retains center. Edited April 8, 2014 by TechnoRobbo Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
ratty redemption Posted April 8, 2014 Share Posted April 8, 2014 understood, thanks. Quote ratty redemption deviantart.com Link to comment Share on other sites More sharing options...
ScifiGirl Posted May 6, 2014 Share Posted May 6, 2014 thanks for the great plug in. I used it and it works reasonably well. Although I may have missed something, as I still have some small white areas along the edges of my cut out? Do I need to adjust the settings on the Alpha Cutter tool panel? Quote "Geek is me" Link to comment Share on other sites More sharing options...
TechnoRobbo Posted May 6, 2014 Author Share Posted May 6, 2014 (edited) you can move the round a handle manually to suit your image. Try applying TR's EFX (Edge Fader Extreme) or another feather program to blend the image with the background. Edited May 6, 2014 by TechnoRobbo Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
ScifiGirl Posted May 7, 2014 Share Posted May 7, 2014 I will and thank you. I actually never thought of feathering Lol.... Quote "Geek is me" Link to comment Share on other sites More sharing options...
nickdwaters Posted May 14, 2014 Share Posted May 14, 2014 (edited) Seriously, this is simply a phenomenal plugin. Thank you for developing it. It is the finest selection tool I've seen. Suggestions: 1) Please preserve the state of the plugin; the settings and points, etc. If I make a booboo, and return, I have to start all over again. Sometimes there can be dozens / hundreds and it would be incredibly helpful for the mask to be there right where I'd left it to make a revision. This makes me really sad. - I realize there is a Review, but when you see the result in context with another image, it is still necessary to make adjustments. 2) Please implement zoom using the position of the mouse. Right now it zooms to the center of the image so one must "drag" the image back to where you were working. 3) Allow fine control over the selected point via the arrow keys. Thank you so much. Nick Edited May 14, 2014 by nickdwaters 1 Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted May 15, 2014 Author Share Posted May 15, 2014 Nick, These are all really good suggestion - presently I'm in the middle of 2 other plugin projects ,but I will be sure to revisit this one in the future. Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
