jtdurland Posted July 12, 2012 Share Posted July 12, 2012 Is there ANYWAY to make a whole single color (without attaching to other colors that are not that color) turn transparent? Quote Everyone is entitled to their own opinion. It's just that your's is stupid. Link to comment Share on other sites More sharing options...
BoltBait Posted July 12, 2012 Share Posted July 12, 2012 The easiest way is to select the magic wand tool and Shift-Click on the color you wish to change to transparent. When all the pixels are selected, press the Delete key on your keyboard. You may need to adjust the tolerance slider before using the magic wand. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 12, 2012 Share Posted July 12, 2012 You may need to adjust the tolerance slider before using the magic wand. To select all instances of a single color set the wand Tolerance to zero, then shift-click & delete as BoltBait said. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
toe_head2001 Posted July 12, 2012 Share Posted July 12, 2012 How about the Grim Color Reaper plugin. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 12, 2012 Share Posted July 12, 2012 There are numerous ways to skin this particular cat Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
nitenurse79 Posted July 12, 2012 Share Posted July 12, 2012 There are numerous ways to skin this particular cat Poor cat 1 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 12, 2012 Share Posted July 12, 2012 No they're EVIL! Look at how much fun they have when playing with SOCKS! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
