SPONGEBOBFAN12000 Posted October 23 Share Posted October 23 i cant find where the plugins are Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 23 Share Posted October 23 24 minutes ago, SPONGEBOBFAN12000 said: i cant find where the plugins are Go to the first post in this thread. There is a Zip file next to the word Downloads. If you mean you can't find them in PDN, look in the Effects > PDN v5 Samples menu. If you can't find them there, ensure you're using the latest version of PDN. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
SPONGEBOBFAN12000 Posted October 23 Share Posted October 23 it wont appear is there any way to fix it??? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 23 Share Posted October 23 Did you build them using Visual Studio? Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
Roger the Dodger Posted October 24 Share Posted October 24 File: C:\Program Files\paint.net\Effects\PDNv5EffectSamples.2023.01.07\PdnV5EffectSamples.dll Effect Name: PaintDotNet.Effects.Samples.Gpu.PolarizedMandelleavesShaderEffect Full error message: PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> PaintDotNet.Direct2D1.InsufficientDeviceCapabilitiesException (0x88990026): Exception of type 'PaintDotNet.Direct2D1.InsufficientDeviceCapabilitiesException' was thrown. (Direct2D1Error.InsufficientDeviceCapabilities 0x88990026) at PaintDotNet.Interop.ExceptionFactory.ThrowError(Int32 hr, String message, Exception innerEx) in D:\src\pdn\src\Windows\Interop\ExceptionFactory.cs:line 54 at PaintDotNet.Direct2D1.D2D1DeviceContext6.CreateEffect(DeviceEffectID& effectID) in D:\src\pdn\src\Windows\Direct2D1\D2D1DeviceContext6.cs:line 762 at PaintDotNet.Direct2D1.D2D1DeviceContext6.PaintDotNet.Direct2D1.IDeviceEffectFactory.CreateEffect(DeviceEffectID& effectID) at PaintDotNet.Direct2D1.DeviceContextWrapper.CreateEffect(DeviceEffectID& effectID) in D:\src\pdn\src\Windows.Core\Direct2D1\DeviceContextWrapper.cs:line 217 at PaintDotNet.Effects.Samples.Gpu.PolarizedMandelleavesShaderEffect.OnCreateOutput(IDeviceContext deviceContext) in D:\src\github\PdnGpuEffectSamples\Gpu\PolarizedMandelleavesShaderEffect.cs:line 142 at PaintDotNet.Effects.Gpu.GpuImageEffect.CreateOutput(IDeviceContext deviceContext) in D:\src\pdn\src\Effects.Core\Effects\Gpu\GpuImageEffect.cs:line 215 at PaintDotNet.Effects.Gpu.GpuImageEffect.OnBeforeDraw(IDeviceContext2 deviceContext, RectInt32 renderRect) in D:\src\pdn\src\Effects.Core\Effects\Gpu\GpuImageEffect.cs:line 182 at PaintDotNet.Effects.Gpu.GpuEffect.BeforeDraw(IDeviceContext2 deviceContext, RectInt32 renderRect) in D:\src\pdn\src\Effects.Core\Effects\Gpu\GpuEffect.cs:line 691 at PaintDotNet.Effects.Gpu.GpuEffect.Renderer.OnBeforeDraw(IDeviceContext deviceContext, RectInt32 renderRect) in D:\src\pdn\src\Effects.Core\Effects\Gpu\GpuEffect.cs:line 1116 at PaintDotNet.Direct2D1.Direct2DBitmapSourceBgra32.PaintDotNet.Direct2D1.IDirect2DDrawer.BeforeDraw(IDeviceContext deviceContext, RectInt32 renderRect) in D:\src\pdn\src\Framework\Direct2D1\Direct2DBitmapSourceBgra32.cs:line 100 at PaintDotNet.Direct2D1.BufferedDeviceContext.DrawerDraw.BeforeDraw(IDeviceContext deviceContext, RectInt32 renderRect) in D:\src\pdn\src\Framework\Direct2D1\BufferedDeviceContext.cs:line 603 at PaintDotNet.Direct2D1.BufferedDeviceContext.RenderImpl[TPixel,TDrawer,TDrawerDraw](RegionPtr`1 dst, Point2Int32 renderOffset, TDrawer drawer, TDrawerDraw drawerDraw, Boolean trackDrawer, ICancellationToken cancelToken) in D:\src\pdn\src\Framework\Direct2D1\BufferedDeviceContext.cs:line 326 at PaintDotNet.Direct2D1.BufferedDeviceContext.Render[TPixel,TDrawer,TDrawerDraw](RegionPtr`1 dst, Point2Int32 renderOffset, TDrawer drawer, TDrawerDraw drawerDraw, Boolean trackDrawer, ICancellationToken cancelToken) in D:\src\pdn\src\Framework\Direct2D1\BufferedDeviceContext.cs:line 260 at PaintDotNet.Direct2D1.BufferedDeviceContext.Render[TPixel](RegionPtr`1 dst, Point2Int32 renderOffset, IDirect2DDrawer drawer, ICancellationToken cancelToken) in D:\src\pdn\src\Framework\Direct2D1\BufferedDeviceContext.cs:line 230 at PaintDotNet.Direct2D1.Direct2DBitmapSourceBgra32.OnCopyPixels(RegionPtr`1 dst, Point2Int32 srcOffset) in D:\src\pdn\src\Framework\Direct2D1\Direct2DBitmapSourceBgra32.cs:line 86 at PaintDotNet.Effects.Gpu.GpuEffect.Renderer.OnCopyPixels(RegionPtr`1 dst, Point2Int32 srcOffset) in D:\src\pdn\src\Effects.Core\Effects\Gpu\GpuEffect.cs:line 1063 at PaintDotNet.Imaging.BitmapSourceBase`1.OnCopyPixels(Void* pBuffer, Int32 bufferStride, UInt32 bufferSize, RectInt32 srcRect) in D:\src\pdn\src\Windows.Core\Imaging\BitmapSourceBase`1.cs:line 42 at PaintDotNet.Imaging.BitmapSourceBase.CopyPixels(Void* buffer, Int32 bufferStride, UInt32 bufferSize, Nullable`1& srcRect) in D:\src\pdn\src\Windows.Core\Imaging\BitmapSourceBase.cs:line 126 at PaintDotNet.Imaging.BitmapSourceBase`1.PaintDotNet.Imaging.IBitmapSource.CopyPixels(Void* pBuffer, Int32 bufferStride, UInt32 bufferSize, Nullable`1& srcRect) at PaintDotNet.Imaging.BitmapSourceExtensions.CopyPixels64(IBitmapSource source, Void* pBuffer, Int32 bufferStride, Nullable`1& sourceRect, Nullable`1 bpp) in D:\src\pdn\src\Windows.Core\Imaging\BitmapSourceExtensions.cs:line 203 at PaintDotNet.Effects.Gpu.GpuEffect.Render(IBitmapEffectOutput output) in D:\src\pdn\src\Effects.Core\Effects\Gpu\GpuEffect.cs:line 664 at PaintDotNet.Effects.Gpu.GpuEffect.PaintDotNet.Effects.ISupportBitmapEffectRenderer.Render(Void* pBuffer, Int32 bufferStride, IntPtr bufferSize, PixelFormat& bufferPixelFormat, RectInt32 renderRect) in D:\src\pdn\src\Effects.Core\Effects\Gpu\GpuEffect.cs:line 656 at PaintDotNet.Effects.Proxies.ISupportBitmapEffectRendererProxy.PaintDotNet.Effects.ISupportBitmapEffectRenderer.Render(Void* pBuffer, Int32 bufferStride, IntPtr bufferSize, PixelFormat& bufferPixelFormat, RectInt32 renderRect) at PaintDotNet.Effects.BitmapEffectRenderer.Render(Void* pBuffer, Int32 bufferStride, IntPtr bufferSize, PixelFormat& bufferFormat, RectInt32 renderRect) in D:\src\pdn\src\Effects.Core\Effects\BitmapEffectRenderer.cs:line 75 at PaintDotNet.Effects.BitmapEffectRenderer.PaintDotNet.Effects.IBitmapEffectRenderer.Render(Void* pBuffer, Int32 bufferStride, IntPtr bufferSize, PixelFormat& bufferPixelFormat, RectInt32 renderRect) at PaintDotNet.Effects.BitmapEffectRendererExtensions.Render[TPixel](IBitmapEffectRenderer renderer, RegionPtr`1 buffer, Point2Int32 renderOffset) in D:\src\pdn\src\Effects.Core\Effects\BitmapEffectRendererExtensions.cs:line 20 at PaintDotNet.Effects.BitmapEffectDriver.OnRendererRender(IBitmapEffectRenderer renderer, ILockedBitmap`1 dstBitmap, ReadOnlySpan`1 renderRects) in D:\src\pdn\src\PaintDotNet\Effects\BitmapEffectDriver.cs:line 81 at PaintDotNet.Effects.EffectDriver`1.RenderWithClipMask(PooledNativeList`1 rois, Result`1 lazyClipMaskRenderer) in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 282 at PaintDotNet.Effects.EffectDriver`1.RendererContext.RenderTile(Int32 tileIndex) in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 255 at PaintDotNet.Effects.EffectDriver`1.RendererContext.RenderNextTile() in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 248 at PaintDotNet.Effects.EffectDriver`1.<>c__DisplayClass51_0.<ThreadFunction>b__0() in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 378 --- End of inner exception stack trace --- at PaintDotNet.Effects.EffectDriver`1.DrainExceptions() in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 538 at PaintDotNet.Effects.EffectDriver`1.Join() in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 529 at PaintDotNet.Effects.EffectDriver`1.Abort() in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 494 at PaintDotNet.Effects.EffectDriver`1.Start(EffectConfigToken effectToken) in D:\src\pdn\src\PaintDotNet\Effects\EffectDriver`1.cs:line 437 at PaintDotNet.Menus.EffectMenuBase.<>c__DisplayClass47_3.<RunEffectImpl>b__6() in D:\src\pdn\src\PaintDotNet\Menus\EffectMenuBase.cs:line 1003 Diagnostics: Application paint.net 5.0.11 (Stable 5.11.8685.3093) Build Date 12 October 2023 Install type Classic Language: en-GB DPI 1 (1.00x scale) UI/Canvas GPU True Rendering GPU 🚀 Performance (AMD Radeon HD 5450) Remote session False Animations True Translucent windows True Windows Ink True OS Windows 10 Pro x64 (10.0.19045.0) Runtime .NET 7.0.12 x64 Physical Memory 4,094 MB (1,458 MB free) Paging File 5,502 MB (1,410 MB free) CPU AMD Phenom(tm) II X4 840 Processor Speed ~3215 MHz Cores / Threads 4 / 4 Features SSE, SSE2, SSE3 Monitor 1 Resolution 1680 x 1050, 60 Hz DPI 96 (1.00x scale) Coordinates (L=0, T=0, R=1680, B=1050) Bit depth 8 Color space RgbFullGamma22NoneP709 Connected to AMD Radeon HD 5450 Video Card AMD Radeon HD 5450 Hardware Acceleration Supported Dedicated Video RAM 1,014 MB Dedicated System RAM 0 MB Shared System RAM 1,792 MB Vendor ID 0x1002 Device ID 0x68F9 Subsystem ID 0x03861043 Revision 0 LUID 0x0000D73D Flags SupportNonMonitoredFences, KeyedMutexConformance Graphics Preemption DmaBufferBoundary Compute Preemption DmaBufferBoundary Outputs 1 Feature Level Level_11_0 Features ComputeShadersEtc DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precisions UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32 Maximum Bitmap Size 16384 Video Card Microsoft Basic Render Driver Hardware Acceleration N/A Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 2,047 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000DD64 Flags Software, AcgCompatible, SupportMonitoredFences, SupportNonMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Level_12_1 Features Doubles, ComputeShadersEtc DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precisions UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32 Maximum Bitmap Size 8388608 Managed assemblies 428 System.Private.CoreLib .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet .\paintdotnet.dll, Version=5.11.8685.3093 System.Runtime .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=5.11.8685.3093 System.Windows.Forms .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Base .\PaintDotNet.Base.dll, Version=5.11.8685.3093 PaintDotNet.Fundamentals .\PaintDotNet.Fundamentals.dll, Version=5.11.8685.3093 System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Collections .\PaintDotNet.Collections.dll, Version=5.11.8685.3093 System.Linq .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Core .\PaintDotNet.Core.dll, Version=5.11.8685.3093 PaintDotNet.ComponentModel .\PaintDotNet.ComponentModel.dll, Version=5.11.8685.3093 PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=5.11.8685.3093 PaintDotNet.Runtime .\PaintDotNet.Runtime.dll, Version=5.11.8685.3093 PaintDotNet.Windows .\PaintDotNet.Windows.dll, Version=5.11.8685.3093 TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.22621.2, PublicKeyToken=35b01b53313a6f7e PaintDotNet.Primitives .\PaintDotNet.Primitives.dll, Version=5.11.8685.3093 System.Threading .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PointerToolkit .\PointerToolkit.dll, Version=1.0.0.0 PaintDotNet.Systrace .\PaintDotNet.Systrace.dll, Version=5.11.8685.3093 System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Windows.Core .\PaintDotNet.Windows.Core.dll, Version=5.11.8685.3093 System.Private.Uri .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WindowsBase .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.ObjectModel .\PaintDotNet.ObjectModel.dll, Version=5.11.8685.3093 System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data .\PaintDotNet.Data.dll, Version=5.11.8685.3093 CommunityToolkit.HighPerformance .\CommunityToolkit.HighPerformance.dll, Version=8.2.0.0, PublicKeyToken=4aff67a105548ee2 PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=5.11.8685.3093 System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Specialized .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Windows.Framework .\PaintDotNet.Windows.Framework.dll, Version=5.11.8685.3093 System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.UI .\PaintDotNet.UI.dll, Version=5.11.8685.3093 System.Net.WebClient .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Memory .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.Encoding.Extensions .\System.Text.Encoding.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Drawing.Common .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Immutable .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ComputeSharp.D2D1 .\ComputeSharp.D2D1.dll, Version=2.1.0.0, PublicKeyToken=dc35fa229f6881d8 PointerToolkit.TerraFX.Interop.Windows .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.2 System.Security.Principal.Windows .\System.Security.Principal.Windows.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Claims .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.PropertySystem .\PaintDotNet.PropertySystem.dll, Version=5.11.8685.3093 PresentationCore .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.Packaging .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects.Core .\PaintDotNet.Effects.Core.dll, Version=5.11.8685.3093 UIAutomationTypes .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.Hashing .\System.IO.Hashing.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Effects.Gpu .\PaintDotNet.Effects.Gpu.dll, Version=5.11.8685.3093 PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=5.11.8685.3093 System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.Metadata .\System.Reflection.Metadata.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.MemoryMappedFiles .\System.IO.MemoryMappedFiles.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Mono.Cecil .\Mono.Cecil.dll, Version=0.11.5.0, PublicKeyToken=50cebf1cceb9d05e System.Reflection.MetadataLoadContext .\System.Reflection.MetadataLoadContext.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Console .\System.Console.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Newtonsoft.Json .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Runtime.Serialization.Formatters .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Linq.Expressions .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics .\System.Runtime.Numerics.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PhotoSauce.MagicScaler .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481 System.Runtime.Loader .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a netstandard .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51 ABRFileType .\FileTypes\ABRFileType.dll, Version=1.3.0.0 PhotoShop .\FileTypes\PhotoShop.dll, Version=2.5.0.40665 AnimGIF .\FileTypes\AnimGIF.dll, Version=2.4.4119.28305 RawFileType .\FileTypes\RawFileType.dll, Version=1.2.2.0 mscorlib .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.Drawing .\System.Drawing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Cryptography .\System.Security.Cryptography.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.26.0 DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.12.8.0 WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.20.0 PaintDotNet.Effects.Legacy .\PaintDotNet.Effects.Legacy.dll, Version=5.11.8685.3093 PaintDotNet.Plugins.Compatibility .\PaintDotNet.Plugins.Compatibility.dll, Version=5.11.8685.3093 Vandermotten.PaintDotNetEffects.ObjectAlign C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 System.Resources.Extensions .\System.Resources.Extensions.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Vandermotten.PaintDotNetEffects.Monochromes C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.MakeTransparent C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.Grid C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.Gradient C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.FadeEdge C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.Duotones C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.DropShadow C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.ColorAccent C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects.Blurs C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, Version=5.0.0.0 Vandermotten.PaintDotNetEffects C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0 System.Windows.Forms.Legacy .\System.Windows.Forms.Legacy.dll, Version=1.0.0.0 WetFloor .\Effects\WetFloor.dll, Version=1.2.5.14166 WaveTextSUI .\Effects\WaveTextSUI.dll, Version=1.2.4415.33440 WaveText .\Effects\WaveText.dll, Version=1.2.4415.32811 WaterReflection .\Effects\WaterReflection.dll, Version=1.2.5.15754 WallOfText .\Effects\WallOfText.dll, Version=1.0.8385.29743 VignettePlus .\Effects\VignettePlus.dll, Version=6.0.8407.22549 VanishPoint .\Effects\VanishPoint.dll, Version=1.0.3.0 TwoToneThreshold .\Effects\TwoToneThreshold.dll, Version=1.0.0.0 Twist .\Effects\Twist.dll, Version=4.0.5873.25056 TRsZigZag .\Effects\TRsZigZag.dll, Version=1.1.4929.6773 TRsTeslaCoil .\Effects\TRsTeslaCoil.dll, Version=1.0.4935.18219 TRsStrobeMotion .\Effects\TRsStrobeMotion.dll, Version=1.2.4962.30523 TRsSnowFlakeMaker .\Effects\TRsSnowFlakeMaker.dll, Version=1.0.3.10409 TRsRadialExtruder .\Effects\TRsRadialExtruder.dll, Version=1.2.5609.8244 TRsMorpher .\Effects\TRsMorpher.dll, Version=1.1.10.8959 TRsMonolithic .\Effects\TRsMonolithic.dll, Version=1.0.6.24412 TRsKaboom .\Effects\TRsKaboom.dll, Version=1.0.5118.21464 TRsIntensityWarp .\Effects\TRsIntensityWarp.dll, Version=1.3.0.0 TRsFireWorks .\Effects\TRsFireWorks.dll, Version=1.2.0.0 TRsAlphaCutter .\Effects\TRsAlphaCutter.dll, Version=3.0.4.0 TRs Scatter .\Effects\TRs Scatter.dll, Version=1.3.4949.23250 Transparency .\Effects\Transparency.dll, Version=6.0.8407.22532 Trail .\Effects\Trail.dll, Version=4.0.4642.26791 TR's Pixel Push .\Effects\TR's Pixel Push.dll, Version=1.0.4954.37564 Tiles .\Effects\Tiles.dll, Version=1.2.5.13094 ThatOtherApp .\Effects\ThatOtherApp.dll, Version=2.2.0.0 EditableText .\Effects\EditableText.dll, Version=1.0.1.0 CustomBrushesMini .\Effects\CustomBrushesMini.dll, Version=2.2.5286.39584 AA's_Assistant .\Effects\AA's_Assistant.dll, Version=1.1.4329.33034 Aardvark .\Effects\Aardvark.dll, Version=1.0.6.0 Advanced Julia Fractal .\Effects\Advanced Julia Fractal.dll, Version=1.0.7702.38303 Alias .\Effects\Alias.dll, Version=1.0.3056.38522 Align Object .\Effects\Align Object.dll, Version=1.0.1.9 Alpha2Gray .\Effects\Alpha2Gray.dll, Version=6.0.8407.21872 Sierpinski .\Effects\MadJikPack\Sierpinski.dll, Version=2.2.5.30414 Sierpinski .\Effects\Sierpinski.dll, Version=2.2.5.30414 Polygon .\Effects\Polygon.dll, Version=4.5.6828.38648 Gradient Mapping .\Effects\Gradient Mapping.dll, Version=4.0.6547.33963 SBCommon .\Effects\SBCommon.dll, Version=3.0.0.0 TGAngle .\Effects\TGAngle.dll, Version=1.0.1.0 BrushFactory .\Effects\BrushFactory.dll, Version=2.0.0.29094 System.Core .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 TextureShader .\Effects\TextureShader.dll, Version=2.3.0.0 SBCommon .\Effects\SBCommon.dll, Version=3.0.0.0 Texture Object Rounder .\Effects\Texture Object Rounder.dll, Version=1.0.6464.41586 TextPlus .\Effects\Textplus.dll, Version=1.0.0.0 ComputeSharp.Core .\ComputeSharp.Core.dll, Version=2.1.0.0, PublicKeyToken=dc35fa229f6881d8 AlphaThreshold .\Effects\AlphaThreshold.dll, Version=1.0.1.0 AlphaMask .\Effects\AlphaMask.dll, Version=2.0.3574.41943 AlphaBlur .\Effects\AlphaBlur.dll, Version=2.0.0.0 Alpha_to_0 .\Effects\Alpha_to_0.dll, Version=1.0.4452.22746 ApplyMask .\Effects\ApplyMask.dll, Version=6.0.8609.2294 ArtyThing .\Effects\ArtyThing.dll, Version=1.0.5.0 Bezncurve .\Effects\Bezncurve.dll, Version=4.0.1.0 Bidirectional Blur .\Effects\Bidirectional Blur.dll, Version=1.0.0.0 BBOutlinedGradientText .\Effects\BBOutlinedGradientText.dll, Version=6.0.8426.37652 Alpha_to_255 .\Effects\Alpha_to_255.dll, Version=1.0.4452.22782 BlackAndWhiteConverter .\Effects\Black and White Converter.dll, Version=1.1.3472.36275 BasicPhotoAdjustments .\Effects\BasicPhotoAdjustments.dll, Version=2.1.4020.485 BlackandAlpha+ .\Effects\BlackandAlpha+.dll, Version=1.2.4329.272 Borders N' Shapes .\Effects\Borders N' Shapes.dll, Version=4.0.4642.26476 Burninate .\Effects\Burninate.dll, Version=6.0.8407.22069 CalliColour .\Effects\CalliColour.dll, Version=1.0.1.0 CameraTrouserFlareV3 .\Effects\CameraTrouserFlareV3.dll, Version=1.1.4600.41268 ClipDisplaceAA .\Effects\ClipDisplaceAA.dll, Version=1.2.4.0 ReverseColors .\Effects\MadJikPack\ReverseColors.dll, Version=1.2.5.29336 circleFractal2 .\Effects\circleFractal2.dll, Version=1.1.5613.38521 CircleText .\Effects\CircleText.dll, Version=1.4.4415.32488 CellTexture .\Effects\CellTexture.dll, Version=1.1.0.0 ClipWarpNew .\Effects\ClipWarpNew.dll, Version=1.0.1.0 ClipWarp .\Effects\ClipWarp.dll, Version=1.0.9.0 Cobweb .\Effects\Cobweb.dll, Version=1.0.1.0 CloudsEffect .\Effects\CloudsEffect.dll, Version=1.1.1.0 Color Match .\Effects\Color Match.dll, Version=4.0.4642.26532 ColorMixer .\Effects\ColorMixer.dll, Version=1.3.0.0 ColorSketch_en .\Effects\ColorSketch_en.dll, Version=1.0.0.0 ColorToAlpha .\Effects\ColorToAlpha.dll, Version=2.3.0.0 CompoGrids .\Effects\CompoGrids.dll, Version=1.0.2.0 Compotool .\Effects\Compotool.dll, Version=1.0.1.0 CreativeTextPro .\Effects\CreativeTextPro.dll, Version=6.0.8407.22165 a_rectangle_transform .\Effects\Cubic_Transformation.dll, Version=1.0.7197.12790 Cuboids .\Effects\Cuboids.dll, Version=1.1.1.0 Curves+ .\Effects\Curves+.dll, Version=4.0.6119.31044 Diagonal Lines .\Effects\Diagonal Lines.dll, Version=1.0.4800.36619 Diffuse .\Effects\Diffuse.dll, Version=1.0.3254.27766 Dimensions .\Effects\Dimensions.dll, Version=1.3.6826.38472 DispMap .\Effects\DispMap.dll, Version=2.1.7197.13119 DistortThis .\Effects\DistortThis.dll, Version=2.7.5.37343 dpyColorBalance .\Effects\dpyColorBalance.dll, Version=1.1.4330.37850 DragFrom .\Effects\DragFrom.dll, Version=1.1.0.0 Dream .\Effects\Dream.dll, Version=6.0.8414.36727 Dryad .\Effects\Dryad.dll, Version=1.0.2.0 Contour .\Effects\Contour.dll, Version=1.0.1.0 EarthsAndGreys .\Effects\EarthsAndGreys.dll, Version=1.0.1.0 EdgeExpander .\Effects\EdgeExpander.dll, Version=1.0.5863.38192 EdgeDetectClassic .\Effects\EdgeDetectClassic.dll, Version=1.0.8424.19432 EdgeShaderMJW .\Effects\EdgeShaderMJW.dll, Version=1.1.5849.39125 EdHarvey.Edfects .\Effects\EdHarvey.Edfects.dll, Version=5.0.0.0 Eyeshine .\Effects\Eyeshine.dll, Version=1.0.3700.25905 Facet .\Effects\Facet.dll, Version=1.0.3.0 FillFromClipboard .\Effects\FillFromClipboard.dll, Version=6.0.8407.22397 FillFromFile .\Effects\FillFromFile.dll, Version=6.0.8407.22418 Film .\Effects\Film.dll, Version=4.0.4642.26607 FindEdges .\Effects\FindEdges.dll, Version=1.2.0.0 Flip .\Effects\Flip.dll, Version=4.6.7358.36953 Flourish .\Effects\Flourish.dll, Version=1.0.3.0 FurBlur .\Effects\FurBlur.dll, Version=1.0.1.0 GaussianBlurPlus .\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401 FloydSteinbergDithering .\Effects\FloydSteinbergDithering.dll, Version=5.2.8174.39918 __blur .\Effects\Glass_Blur.dll, Version=1.1.7212.26179 Gmic .\Effects\Gmic.dll, Version=3.3.0.0 Gossamer .\Effects\Gossamer.dll, Version=1.0.2.0 Gradient Bars .\Effects\Gradient Bars.dll, Version=4.0.5152.23084 Gradient Blocks .\Effects\Gradient Blocks.dll, Version=4.0.4642.26658 Gradient Grid .\Effects\Gradient Grid.dll, Version=4.0.6436.36068 GradientsGalore .\Effects\GradientsGalore.dll, Version=1.0.5.0 Gray2Alpha .\Effects\Gray2Alpha.dll, Version=6.0.8407.22439 Emboss+ .\Effects\Emboss+.dll, Version=1.2.0.0 Grid Warp .\Effects\Grid Warp.dll, Version=4.0.6544.34496 Gears .\Effects\Gears.dll, Version=1.0.2.0 Grow .\Effects\Grow.dll, Version=1.0.7.0 Helix .\Effects\Helix.dll, Version=1.0.1.0 Highlight .\Effects\Highlight.dll, Version=1.0.1.0 InnerShadow .\Effects\InnerShadow.dll, Version=3.0.5509.3391 IntensityRGB_beta .\Effects\IntensityRGB_beta.dll, Version=0.0.0.0 Jitter .\Effects\Jitter.dll, Version=4.0.4642.26986 Kill Color Keeper .\Effects\Kill Color Keeper.dll, Version=1.0.6641.13453 Kuwahara .\Effects\Kuwahara.dll, Version=1.0.0.0 Landscape .\Effects\Landscape.dll, Version=5.2.8174.40347 __lattice .\Effects\Lattice_Transform.dll, Version=1.0.7215.30711 Grain .\Effects\Grain.dll, Version=1.0.3854.25523 LevelHorizon .\Effects\LevelHorizon.dll, Version=6.0.8407.22459 LightRays .\Effects\LightRays.dll, Version=2.1.5.14276 LocalContrast .\Effects\LocalContrast.dll, Version=3.0.0.0 Liquify .\Effects\Liquify.dll, Version=4.0.5873.25113 LocalStatsDenoisingFilter .\Effects\LocalStatsDenoisingFilter.dll, Version=2.0.0.0 LongiStripes .\Effects\LongiStripes.dll, Version=1.0.6337.34025 Animal .\Effects\MadJikPack\Animal.dll, Version=2.2.5.20384 AutoChrome .\Effects\MadJikPack\AutoChrome.dll, Version=1.2.5.19669 Bars .\Effects\MadJikPack\Bars.dll, Version=1.2.5.23704 Boutons .\Effects\MadJikPack\Boutons.dll, Version=1.2.5.23747 ChangeExtremeColors .\Effects\MadJikPack\ChangeExtremeColors.dll, Version=1.2.6.30674 ColorModulo .\Effects\MadJikPack\ColorModulo.dll, Version=1.2.5.25136 ColorZoomBlur .\Effects\MadJikPack\ColorZoomBlur.dll, Version=1.2.5.17431 Displacement .\Effects\MadJikPack\Displacement.dll, Version=1.3.5.15773 DistortingMirror .\Effects\MadJikPack\DistortingMirror.dll, Version=1.2.5.15788 Donut .\Effects\MadJikPack\Donut.dll, Version=1.2.5.15739 ExpandColor .\Effects\MadJikPack\ExpandColor.dll, Version=1.2.5.15745 FillPalette .\Effects\MadJikPack\FillPalette.dll, Version=1.2.5.32012 FractalAttractor .\Effects\MadJikPack\FractalAttractor.dll, Version=1.3.5.27448 FractalFern .\Effects\MadJikPack\FractalFern.dll, Version=1.2.0.28378 FractalTree .\Effects\MadJikPack\FractalTree.dll, Version=1.2.0.38806 Frames .\Effects\MadJikPack\Frames.dll, Version=1.2.5.27903 Gen96Colors .\Effects\MadJikPack\Gen96Colors.dll, Version=1.2.0.15608 GradientBlur .\Effects\MadJikPack\GradientBlur.dll, Version=1.2.5.28179 Gravity .\Effects\MadJikPack\Gravity.dll, Version=1.2.5.29548 GridMaker .\Effects\MadJikPack\GridMaker.dll, Version=5.2.5.29827 HilbertCurve .\Effects\MadJikPack\HilbertCurve.dll, Version=1.2.0.32151 JuliaPlus .\Effects\MadJikPack\JuliaPlus.dll, Version=1.2.5.13821 KaleidoGen .\Effects\MadJikPack\KaleidoGen.dll, Version=1.3.5.30504 LensFlare .\Effects\MadJikPack\LensFlare.dll, Version=2.2.12.35124 Kaleidoscope .\Effects\MadJikPack\Kaleidoscope.dll, Version=1.6.1.27167 coloraberation .\Effects\MadJikPack\coloraberation.dll, Version=1.2.5.15647 ListOfPalettes .\Effects\MadJikPack\ListOfPalettes.dll, Version=1.0.0.32564 Magnifier .\Effects\MadJikPack\Magnifier.dll, Version=1.3.5.14308 HexaGrid .\Effects\MadJikPack\HexaGrid.dll, Version=4.1.0.40699 Majority .\Effects\MadJikPack\Majority.dll, Version=1.2.5.14328 LightRays .\Effects\MadJikPack\LightRays.dll, Version=2.1.5.14276 Moire .\Effects\MadJikPack\Moire.dll, Version=1.2.5.14350 Melting .\Effects\MadJikPack\Melting.dll, Version=1.3.6550.31783 HexaGrid .\Effects\HexaGrid.dll, Version=4.1.0.40699 MotionSharpen .\Effects\MadJikPack\MotionSharpen.dll, Version=1.2.5.19059 Nebulous .\Effects\MadJikPack\Nebulous.dll, Version=1.2.5.19527 NewtonFractal .\Effects\MadJikPack\NewtonFractal.dll, Version=2.2.5.19770 Oblique .\Effects\MadJikPack\Oblique.dll, Version=1.2.5.15730 Overliner .\Effects\MadJikPack\Overliner.dll, Version=1.2.5.25545 PageCurl .\Effects\MadJikPack\PageCurl.dll, Version=1.5.5.23162 AutoChromeNoise .\Effects\MadJikPack\AutoChromeNoise.dll, Version=1.2.5.23331 Paneling .\Effects\MadJikPack\Paneling.dll, Version=1.2.5.23448 PerlinTexture .\Effects\MadJikPack\PerlinTexture.dll, Version=2.2.5.23710 Polar .\Effects\MadJikPack\Polar.dll, Version=1.2.5.24467 Polygones .\Effects\MadJikPack\Polygones.dll, Version=1.3.5.31866 Radialcolors .\Effects\MadJikPack\Radialcolors.dll, Version=1.2.5.21672 RainbowTwist .\Effects\MadJikPack\RainbowTwist.dll, Version=1.2.5.25218 RandomLines .\Effects\MadJikPack\RandomLines.dll, Version=1.2.5.25981 RandomMaze1 .\Effects\MadJikPack\RandomMaze1.dll, Version=1.2.5.26409 RandomMaze2 .\Effects\MadJikPack\RandomMaze2.dll, Version=1.2.5.26820 RecolorGray .\Effects\MadJikPack\RecolorGray.dll, Version=1.2.5.27251 RegularNoise .\Effects\MadJikPack\RegularNoise.dll, Version=1.2.5.29080 Rosaces .\Effects\MadJikPack\Rosaces.dll, Version=1.2.5.29635 SeamlessTextureMaker .\Effects\MadJikPack\SeamlessTextureMaker.dll, Version=1.2.5.29984 Shapes .\Effects\MadJikPack\Shapes.dll, Version=1.6.5.30197 Signature .\Effects\MadJikPack\Signature.dll, Version=1.5.6617.21474 SmoothNoise .\Effects\MadJikPack\SmoothNoise.dll, Version=1.0.0.28227 SinWaves .\Effects\MadJikPack\SinWaves.dll, Version=1.2.5.30582 Sparkles .\Effects\MadJikPack\Sparkles.dll, Version=1.2.5.12788 Spiral .\Effects\MadJikPack\Spiral.dll, Version=1.2.5.12809 SpiroShapes .\Effects\MadJikPack\SpiroShapes.dll, Version=2.2.5.16659 SpiroGraph .\Effects\MadJikPack\SpiroGraph.dll, Version=1.2.5.12972 Splashes .\Effects\MadJikPack\Splashes.dll, Version=1.2.5.13040 StarGlow .\Effects\MadJikPack\StarGlow.dll, Version=1.3.5.17930 SpotCenter .\Effects\MadJikPack\SpotCenter.dll, Version=1.2.0.17265 Stars .\Effects\MadJikPack\Stars.dll, Version=2.0.0.25701 Tiles .\Effects\MadJikPack\Tiles.dll, Version=1.2.5.13094 Tournesol .\Effects\MadJikPack\Tournesol.dll, Version=1.2.5.13128 TubeOblique .\Effects\MadJikPack\TubeOblique.dll, Version=1.2.5.15697 TwistZ .\Effects\MadJikPack\TwistZ.dll, Version=1.2.5.13350 Vibrato .\Effects\MadJikPack\Vibrato.dll, Version=2.0.5.13530 Waves .\Effects\MadJikPack\Waves.dll, Version=1.2.5.14072 Volutes .\Effects\MadJikPack\Volutes.dll, Version=1.3.5.13753 XYCoords .\Effects\MadJikPack\XYCoords.dll, Version=1.2.6.20985 MemeMaker .\Effects\MemeMaker.dll, Version=6.0.8407.22476 Metallize .\Effects\Metallize.dll, Version=1.2.4415.32969 Mise En Abyme .\Effects\Mise En Abyme.dll, Version=1.1.0.0 MultiColorGradient .\Effects\MultiColorGradient.dll, Version=1.0.0.0 MultiSpline .\Effects\MultiSpline.dll, Version=1.0.4.0 WaterReflection .\Effects\MadJikPack\WaterReflection.dll, Version=1.2.5.15754 MultiThreshold .\Effects\MultiThreshold.dll, Version=1.1.4330.38982 WetFloor .\Effects\MadJikPack\WetFloor.dll, Version=1.2.5.14166 NoiseChoice .\Effects\NoiseChoice.dll, Version=1.0.1.0 ObjectBevel .\Effects\ObjectBevel.dll, Version=1.0.6.0 ObjectEdge .\Effects\Objectedge.dll, Version=1.0.1.0 ObjectShadowPro .\Effects\ObjectShadowPro.dll, Version=1.0.7421.614 ObjectTools .\Effects\ObjectTools.dll, Version=6.0.8482.2565 OilPaintingPlus .\Effects\OilPaintingPlus.dll, Version=5.2.8141.27893 Feather .\Effects\OldFeather.dll, Version=2.3.4315.37038 Olden .\Effects\Olden.dll, Version=1.5.0.0 Outline Object .\Effects\Outline Object.dll, Version=4.0.4642.26954 Object2Colour .\Effects\Object2Colour.dll, Version=1.0.1.0 Overblur .\Effects\Overblur.dll, Version=1.0.1.0 PasteAlpha .\Effects\PasteAlpha.dll, Version=5.2.8174.40450 Pastel .\Effects\Pastel.dll, Version=5.2.8174.40506 perlin_noise .\Effects\perlin_noise.dll, Version=1.1.7172.28890 PdnV5EffectSamples .\Effects\PDNv5EffectSamples.2023.01.07\PdnV5EffectSamples.dll, Version=1.0.8407.28476 ComputeSharp.D2D1 .\Effects\PDNv5EffectSamples.2023.01.07\ComputeSharp.D2D1.dll, Version=2.0.0.0 ComputeSharp.Core .\Effects\PDNv5EffectSamples.2023.01.07\ComputeSharp.Core.dll, Version=2.0.0.0 Perspective .\Effects\Perspective.dll, Version=2.1.4415.36116 PhotoAdjustments .\Effects\PhotoAdjustments.dll, Version=6.0.8416.38377 Polar .\Effects\Polar.dll, Version=1.2.5.24467 PolyGlitch.Effects .\Effects\PolyGlitch.Effects.dll, Version=1.4.0.0 a_polar_test .\Effects\Polar_Kaleidoscope.dll, Version=1.0.7188.40229 PointBlur .\Effects\PointBlur.dll, Version=1.0.0.0 Poster .\Effects\Poster.dll, Version=1.0.2.0 Pixelate+ .\Effects\Pixelate+.dll, Version=4.0.4642.26940 PowerStretch .\Effects\PowerStretch.dll, Version=0.0.0.0 Psychocolour .\Effects\Psychocolour.dll, Version=1.0.1.0 pxEexpansion .\Effects\pxEexpansion.dll, Version=1.0.4437.36287 PSFilterPdn .\Effects\PSFilterPdn.dll, Version=2.0.2.0 rainball .\Effects\rainball.dll, Version=1.0.4907.41850 Random Effect .\Effects\Random Effect.dll, Version=4.0.4642.26928 Random Shape Fill .\Effects\Random Shape Fill.dll, Version=4.0.4642.26910 RecolourChoice .\Effects\RecolourChoice.dll, Version=1.0.1.0 RedEyeQuickFix .\Effects\RedEyeQuickFix.dll, Version=1.1.3161.39688 RemoveTransparency .\Effects\RemoveTransparency.dll, Version=1.0.0.0 __killblack .\Effects\Remove_Black.dll, Version=1.0.7212.28737 Rosaces .\Effects\Rosaces.dll, Version=1.2.5.29635 RotateText .\Effects\RotateText.dll, Version=1.1.4415.32628 RotateTextSUI .\Effects\RotateTextSUI.dll, Version=1.1.4415.32713 RemoveDust .\Effects\RemoveDust.dll, Version=6.0.8407.22513 Rotate_Zoom+ .\Effects\Rotate_Zoom+.dll, Version=1.11.5237.17779 Scintillate .\Effects\Scintillate.dll, Version=1.0.1.0 Scribble .\Effects\Scribble.dll, Version=1.0.1.0 System.IO.Compression .\System.IO.Compression.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 SeamCarving .\Effects\SeamCarving.dll, Version=5.2.8176.39366 SeamlessTextureMaker .\Effects\SeamlessTextureMaker.dll, Version=1.2.5.29984 Selection2Clear .\Effects\Selection2Clear.dll, Version=1.0.1.0 SelectionTools .\Effects\SelectionTools.dll, Version=6.0.8412.38725 ShadowHighlight .\Effects\ShadowHighlight.dll, Version=3.0.0.0 Shape3D .\Effects\Shape3D.dll, Version=1.2.6.0 shapegradient .\Effects\shapegradient.dll, Version=1.5.3886.6574 Sharpen+ .\Effects\Sharpen+.dll, Version=4.0.0.0 SharpenClassic .\Effects\SharpenClassic.dll, Version=1.0.8420.39106 SinWaves .\Effects\SinWaves.dll, Version=1.2.5.30582 Slinky .\Effects\Slinky.dll, Version=1.0.1.0 Smudge .\Effects\Smudge.dll, Version=4.0.5873.25097 Specular .\Effects\Specular.dll, Version=1.0.3254.27778 __bulge2 .\Effects\Spherical_Bulge.dll, Version=1.0.7224.336 Spiral .\Effects\Spiral.dll, Version=1.2.5.12809 SpeechBubble .\Effects\SpeechBubble.dll, Version=2.1.4445.42029 SpiralText .\Effects\SpiralText.dll, Version=1.4.4415.32775 SpiroGraph .\Effects\SpiroGraph.dll, Version=1.2.5.12972 Splatter .\Effects\Splatter.dll, Version=4.0.5873.25083 SpotCenter .\Effects\SpotCenter.dll, Version=1.2.0.17265 Squirkle .\Effects\Squirkle.dll, Version=1.0.1.0 SquirkleWarp .\Effects\SquirkleWarp.dll, Version=1.0.1.0 Stitch .\Effects\Stitch.dll, Version=4.0.4642.26808 StringAndPin .\Effects\StringAndPin.dll, Version=1.0.1.0 Table .\Effects\Table.dll, Version=1.1.5847.38905 TextDistortion .\Effects\TextDistortion.dll, Version=1.1.0.0 OutlineGradientText .\Effects\OutlineGradientText.dll, Version=1.0.0.0 TextMask .\Effects\TextMask.dll, Version=1.0.0.0 RoundedRectangle .\Effects\RoundedRectangle.dll, Version=1.1.0.0 OptionBasedLibrary v0.7.9 .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561 OptionBasedLibrary v0.7.9 .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561 OptionBasedLibrary v0.7.9 .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561 OptionBasedLibrary v0.7.9 .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561 K4os.Compression.LZ4 .\K4os.Compression.LZ4.dll, Version=1.2.16.0, PublicKeyToken=2186fa9121ef231d System.CodeDom .\System.CodeDom.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Runtime.CompilerServices.Unsafe .\System.Runtime.CompilerServices.Unsafe.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.StackTrace .\System.Diagnostics.StackTrace.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Native modules 501 paintdotnet.exe .\paintdotnet.exe, version=5.11.8685.3093 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.3570 (WinBuild.160101.0800) KERNEL32.DLL C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.3570 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.3570 (WinBuild.160101.0800) SHELL32.dll C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.3570 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.3570 (WinBuild.160101.0800) USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.3570 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.3570 (WinBuild.160101.0800) ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.3570 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.3570 (WinBuild.160101.0800) OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) SHLWAPI.dll C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.3570 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.3570 (WinBuild.160101.0800) VCRUNTIME140_1.dll .\VCRUNTIME140_1.dll, version=14.38.33126.1 VCRUNTIME140.dll .\VCRUNTIME140.dll, version=14.38.33126.1 IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.3570 (WinBuild.160101.0800) shcore.dll C:\WINDOWS\System32\shcore.dll, version=10.0.19041.3570 (WinBuild.160101.0800) hostfxr.dll .\hostfxr.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) hostpolicy.dll .\hostpolicy.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca coreclr.dll .\coreclr.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.3570 (WinBuild.160101.0800) System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=7.0.1223.47720 clrjit.dll .\clrjit.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.3570 (WinBuild.160101.0800) paintdotnet.dll .\paintdotnet.dll, version=5.11.8685.3093 System.Runtime.dll .\System.Runtime.dll, version=7.0.1223.47720 uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.3570 (WinBuild.160101.0800) System.Threading.Thread.dll .\System.Threading.Thread.dll, version=7.0.1223.47720 PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=5.11.8685.3093 System.Windows.Forms.dll .\System.Windows.Forms.dll, version=7.0.1223.47803 System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=7.0.1223.47720 System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=7.0.1223.47803 System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=7.0.1223.47720 System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=7.0.1223.47720 PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=5.11.8685.3093 PaintDotNet.Fundamentals.dll .\PaintDotNet.Fundamentals.dll, version=5.11.8685.3093 System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=7.0.1223.47720 icu.dll C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) System.Collections.dll .\System.Collections.dll, version=7.0.1223.47720 PaintDotNet.Collections.dll .\PaintDotNet.Collections.dll, version=5.11.8685.3093 System.Linq.dll .\System.Linq.dll, version=7.0.1223.47720 System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=7.0.1223.47720 PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=5.11.8685.3093 PaintDotNet.ComponentModel.dll .\PaintDotNet.ComponentModel.dll, version=5.11.8685.3093 PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=5.11.8685.3093 PaintDotNet.Runtime.dll .\PaintDotNet.Runtime.dll, version=5.11.8685.3093 PaintDotNet.Windows.dll .\PaintDotNet.Windows.dll, version=5.11.8685.3093 TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.22621.2 PaintDotNet.Primitives.dll .\PaintDotNet.Primitives.dll, version=5.11.8685.3093 System.Threading.dll .\System.Threading.dll, version=7.0.1223.47720 PointerToolkit.dll .\PointerToolkit.dll, version=1.0.0.0 PaintDotNet.Systrace.dll .\PaintDotNet.Systrace.dll, version=5.11.8685.3093 System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=7.0.1223.47720 windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.3570 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) PaintDotNet.Windows.Core.dll .\PaintDotNet.Windows.Core.dll, version=5.11.8685.3093 System.Private.Uri.dll .\System.Private.Uri.dll, version=7.0.1223.47720 BCrypt.dll C:\WINDOWS\System32\BCrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) WindowsBase.dll .\WindowsBase.dll, version=7.0.1223.47802 System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=7.0.1223.47720 PaintDotNet.ObjectModel.dll .\PaintDotNet.ObjectModel.dll, version=5.11.8685.3093 System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=7.0.1223.47720 System.ObjectModel.dll .\System.ObjectModel.dll, version=7.0.1223.47720 Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=7.0.1223.47720 PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=5.11.8685.3093 CommunityToolkit.HighPerformance.dll .\CommunityToolkit.HighPerformance.dll, version=8.2.1.1 PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=5.11.8685.3093 System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=7.0.1223.47720 PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=7,0,23,40905 @Commit: 62999eb1848d22a5271ae178aa2b92383e1df544 System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=7.0.1223.47720 System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=7.0.1223.47720 PaintDotNet.Windows.Framework.dll .\PaintDotNet.Windows.Framework.dll, version=5.11.8685.3093 System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=7.0.1223.47720 System.Private.Xml.dll .\System.Private.Xml.dll, version=7.0.1223.47720 PaintDotNet.UI.dll .\PaintDotNet.UI.dll, version=5.11.8685.3093 System.Net.WebClient.dll .\System.Net.WebClient.dll, version=7.0.1223.47720 System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=7.0.1223.47720 System.Memory.dll .\System.Memory.dll, version=7.0.1223.47720 System.Text.Encoding.Extensions.dll .\System.Text.Encoding.Extensions.dll, version=7.0.1223.47720 Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=7.0.1223.47720 System.Drawing.Common.dll .\System.Drawing.Common.dll, version=7.0.1223.47720 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.3570 (WinBuild.160101.0800) Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=7.0.1223.47720 System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=7.0.1223.47720 dxgi.DLL C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.19041.3570 (WinBuild.160101.0800) ComputeSharp.D2D1.dll .\ComputeSharp.D2D1.dll, version=2.1.0.0 PointerToolkit.TerraFX.Interop.Windows.dll .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.2 System.Security.Principal.Windows.dll .\System.Security.Principal.Windows.dll, version=7.0.1223.47720 System.Security.Claims.dll .\System.Security.Claims.dll, version=7.0.1223.47720 System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=7.0.1223.47720 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.3570 (WinBuild.160101.0800) version.dll C:\WINDOWS\SYSTEM32\version.dll, version=10.0.19041.3570 (WinBuild.160101.0800) PresentationFramework.dll .\PresentationFramework.dll, version=7.0.1223.47802 d3d11.DLL C:\WINDOWS\SYSTEM32\d3d11.DLL, version=10.0.19041.3570 (WinBuild.160101.0800) aticfx64.dll C:\WINDOWS\SYSTEM32\aticfx64.dll, version=8.17.10.1404 WINMM.dll C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=7.0.1223.47720 System.ComponentModel.dll .\System.ComponentModel.dll, version=7.0.1223.47720 System.Xaml.dll .\System.Xaml.dll, version=7.0.1223.47802 PaintDotNet.PropertySystem.dll .\PaintDotNet.PropertySystem.dll, version=5.11.8685.3093 atiuxp64.dll C:\WINDOWS\SYSTEM32\atiuxp64.dll, version=8.14.01.6463 PresentationCore.dll .\PresentationCore.dll, version=7.0.1223.47802 atidxx64.dll C:\WINDOWS\SYSTEM32\atidxx64.dll, version=8.17.10.0625 apphelp.dll C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800) DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=7,0,1223,47802 @Commit: c94bac748138456f4feef271b3dc18e4b46453e6 System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=7.0.1223.47720 dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.3570 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=7.0.1223.47720 System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.1223.47720 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=7.0.1223.47720 d2d1.DLL C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.19041.1 (WinBuild.160101.0800) clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.3570 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.3570_none_91a61d1ecc865de8\gdiplus.dll, version=10.0.19041.3570 (WinBuild.160101.0800) WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.3570 (WinBuild.160101.0800) System.IO.Packaging.dll .\System.IO.Packaging.dll, version=7.0.1223.47720 XmlLite.dll C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.3570 (WinBuild.160101.0800) PaintDotNet.Effects.Core.dll .\PaintDotNet.Effects.Core.dll, version=5.11.8685.3093 UIAutomationTypes.dll .\UIAutomationTypes.dll, version=7.0.1223.47802 comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.3570_none_60bb2a3971f3e41a\comctl32.dll, version=6.10 (WinBuild.160101.0800) Accessibility.dll .\Accessibility.dll, version=7.0.1223.47803 System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=7.0.1223.47720 System.IO.Hashing.dll .\System.IO.Hashing.dll, version=7.0.22.51805 PaintDotNet.Effects.Gpu.dll .\PaintDotNet.Effects.Gpu.dll, version=5.11.8685.3093 PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=5.11.8685.3093 System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=7.0.1223.47720 System.Reflection.Metadata.dll .\System.Reflection.Metadata.dll, version=7.0.1223.47720 System.IO.MemoryMappedFiles.dll .\System.IO.MemoryMappedFiles.dll, version=7.0.1223.47720 Mono.Cecil.dll .\Mono.Cecil.dll, version=0.11.5.0 System.Reflection.MetadataLoadContext.dll .\System.Reflection.MetadataLoadContext.dll, version=7.0.22.51805 System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=7.0.1223.47720 System.Console.dll .\System.Console.dll, version=7.0.1223.47720 Newtonsoft.Json.dll .\Newtonsoft.Json.dll, version=13.0.3.27908 System.Runtime.Serialization.Formatters.dll .\System.Runtime.Serialization.Formatters.dll, version=7.0.1223.47720 System.Linq.Expressions.dll .\System.Linq.Expressions.dll, version=7.0.1223.47720 System.Runtime.Numerics.dll .\System.Runtime.Numerics.dll, version=7.0.1223.47720 System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=7.0.1223.47720 PhotoSauce.MagicScaler.dll .\PhotoSauce.MagicScaler.dll, version=0.13.2.0 TextShaping.dll C:\WINDOWS\SYSTEM32\TextShaping.dll, version= System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=7.0.1223.47720 netstandard.dll .\netstandard.dll, version=7.0.1223.47720 wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.3570 (WinBuild.160101.0800) D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.3570 (WinBuild.160101.0800) ABRFileType.dll .\FileTypes\ABRFileType.dll, version=1.3.0.0 PhotoShop.dll .\FileTypes\PhotoShop.dll, version=2.5.0.0 AnimGIF.dll .\FileTypes\AnimGIF.dll, version=2.4.4119.28305 UIAutomationCore.dll C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.3570 (WinBuild.160101.0800) PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.3570 (WinBuild.160101.0800) RawFileType.dll .\FileTypes\RawFileType.dll, version=1.2.2.0 mscorlib.dll .\mscorlib.dll, version=7.0.1223.47720 System.dll .\System.dll, version=7.0.1223.47720 System.Drawing.dll .\System.Drawing.dll, version=7.0.1223.47803 mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.3570 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) System.Security.Cryptography.dll .\System.Security.Cryptography.dll, version=7.0.1223.47720 CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.3570 (WinBuild.160101.0800) Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.3570 (WinBuild.160101.0800) AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.26.0 DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.12.8.0 WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.3570 (WinBuild.160101.0800) WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.20.0 dwmapi.DLL C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.3570 (WinBuild.160101.0800) dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.3570 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.3570 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.3570 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.3570 CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.3570 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.3570 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= PaintDotNet.Effects.Legacy.dll .\PaintDotNet.Effects.Legacy.dll, version=5.11.8685.3093 PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.11.8685.3093 PaintDotNet.Plugins.Compatibility.dll .\PaintDotNet.Plugins.Compatibility.dll, version=5.11.8685.3093 Vandermotten.PaintDotNetEffects.ObjectAlign.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, version=5.0.2.0 System.Resources.Extensions.dll .\System.Resources.Extensions.dll, version=7.0.1223.47720 Vandermotten.PaintDotNetEffects.Monochromes.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.MakeTransparent.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.Grid.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.Gradient.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.FadeEdge.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.Duotones.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.DropShadow.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.ColorAccent.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=5.0.2.0 Vandermotten.PaintDotNetEffects.Blurs.dll C:\Users\User\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=5.0.2.0 System.Windows.Forms.Legacy.dll .\System.Windows.Forms.Legacy.dll, version=1.0.0.0 WetFloor.dll .\Effects\WetFloor.dll, version=1.2.5.0 WaveTextSUI.dll .\Effects\WaveTextSUI.dll, version=1.2.4415.33440 WaveText.dll .\Effects\WaveText.dll, version=1.2.4415.32811 WaterReflection.dll .\Effects\WaterReflection.dll, version=1.2.5.0 WallOfText.dll .\Effects\WallOfText.dll, version=1.0.8385.29743 VignettePlus.dll .\Effects\VignettePlus.dll, version=6.0.8407.22549 VanishPoint.dll .\Effects\VanishPoint.dll, version=1.0.3.0 TwoToneThreshold.dll .\Effects\TwoToneThreshold.dll, version=1.0.0.0 Twist.dll .\Effects\Twist.dll, version=4.0.5873.25056 TRsZigZag.dll .\Effects\TRsZigZag.dll, version=1.1.4929.6773 TRsTeslaCoil.dll .\Effects\TRsTeslaCoil.dll, version=1.0.4935.18219 TRsStrobeMotion.dll .\Effects\TRsStrobeMotion.dll, version=1.2.4962.30523 TRsSnowFlakeMaker.dll .\Effects\TRsSnowFlakeMaker.dll, version=1.0.3.10409 TRsRadialExtruder.dll .\Effects\TRsRadialExtruder.dll, version=1.2.5609.8244 TRsMorpher.dll .\Effects\TRsMorpher.dll, version=1.1.10.8959 TRsMonolithic.dll .\Effects\TRsMonolithic.dll, version=1.0.6.24412 TRsKaboom.dll .\Effects\TRsKaboom.dll, version=1.0.5118.21464 TRsIntensityWarp.dll .\Effects\TRsIntensityWarp.dll, version=1.3.0.0 TRsFireWorks.dll .\Effects\TRsFireWorks.dll, version=1.2.0.0 TRsAlphaCutter.dll .\Effects\TRsAlphaCutter.dll, version=3.0.4.0 TRs Scatter.dll .\Effects\TRs Scatter.dll, version=1.3.4949.23250 Transparency.dll .\Effects\Transparency.dll, version=6.0.8407.22532 Trail.dll .\Effects\Trail.dll, version=4.0.4642.26791 TR's Pixel Push.dll .\Effects\TR's Pixel Push.dll, version=1.0.4954.37564 explorerframe.dll C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.3570 (WinBuild.160101.0800) Tiles.dll .\Effects\Tiles.dll, version=1.2.5.0 ThatOtherApp.dll .\Effects\ThatOtherApp.dll, version=2.2.0.0 amsi.dll C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.19041.3570 (WinBuild.160101.0800) USERENV.dll C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800) MpOav.dll C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.23090.2008-0\MpOav.dll, version=4.18.23090.2008 (b0d7cf273f4b179b8031bda447c0e07aca8eb8b4) MPCLIENT.DLL C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.23090.2008-0\MPCLIENT.DLL, version=4.18.23090.2008 (b0d7cf273f4b179b8031bda447c0e07aca8eb8b4) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.3570 (WinBuild.160101.0800) WINTRUST.dll C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.3570 (WinBuild.160101.0800) MSASN1.dll C:\WINDOWS\System32\MSASN1.dll, version=10.0.19041.3570 (WinBuild.160101.0800) gpapi.dll C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.19041.3570 (WinBuild.160101.0800) AA's_Assistant.dll .\Effects\AA's_Assistant.dll, version=1.1.4329.33034 Aardvark.dll .\Effects\Aardvark.dll, version=1.0.6.0 Advanced Julia Fractal.dll .\Effects\Advanced Julia Fractal.dll, version=1.0.7702.38303 Alias.dll .\Effects\Alias.dll, version=1.0.3056.38522 Align Object.dll .\Effects\Align Object.dll, version=1.0.1.9 Alpha2Gray.dll .\Effects\Alpha2Gray.dll, version=6.0.8407.21872 Cabinet.dll C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800) d3dcompiler_47.dll C:\WINDOWS\SYSTEM32\d3dcompiler_47.dll, version=10.0.19041.3570 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.3570 (WinBuild.160101.0800) TGAngle.dll .\Effects\TGAngle.dll, version=1.0.1.0 System.Core.dll .\System.Core.dll, version=7.0.1223.47720 TextureShader.dll .\Effects\TextureShader.dll, version=2.3.0.0 Texture Object Rounder.dll .\Effects\Texture Object Rounder.dll, version=1.0.6464.41586 Textplus.dll .\Effects\Textplus.dll, version=1.0.0.0 ComputeSharp.Core.dll .\ComputeSharp.Core.dll, version=2.1.0.0 AlphaThreshold.dll .\Effects\AlphaThreshold.dll, version=1.0.0.0 AlphaMask.dll .\Effects\AlphaMask.dll, version=2.0.3574.41943 AlphaBlur.dll .\Effects\AlphaBlur.dll, version=2.0.0.0 Alpha_to_0.dll .\Effects\Alpha_to_0.dll, version=1.0.4452.22746 ApplyMask.dll .\Effects\ApplyMask.dll, version=6.0.8609.2294 ArtyThing.dll .\Effects\ArtyThing.dll, version=1.0.5.0 Bezncurve.dll .\Effects\Bezncurve.dll, version=4.0.1.0 Bidirectional Blur.dll .\Effects\Bidirectional Blur.dll, version=1.0.0.0 BBOutlinedGradientText.dll .\Effects\BBOutlinedGradientText.dll, version=6.0.8426.37652 Alpha_to_255.dll .\Effects\Alpha_to_255.dll, version=1.0.4452.22782 Black and White Converter.dll .\Effects\Black and White Converter.dll, version=1.1.0.0 BasicPhotoAdjustments.dll .\Effects\BasicPhotoAdjustments.dll, version=2.1.4020.485 BlackandAlpha+.dll .\Effects\BlackandAlpha+.dll, version=1.2.4329.272 Borders N' Shapes.dll .\Effects\Borders N' Shapes.dll, version=4.0.4642.26476 Burninate.dll .\Effects\Burninate.dll, version=6.0.8407.22069 CalliColour.dll .\Effects\CalliColour.dll, version=1.0.1.0 CameraTrouserFlareV3.dll .\Effects\CameraTrouserFlareV3.dll, version=1.1.4600.41268 ClipDisplaceAA.dll .\Effects\ClipDisplaceAA.dll, version=1.2.4.0 BlendModesPlus.dll .\Effects\BlendModesPlus.dll, version=2.1.0.0 circleFractal2.dll .\Effects\circleFractal2.dll, version=1.1.5613.38521 CircleText.dll .\Effects\CircleText.dll, version=1.4.4415.32488 CellTexture.dll .\Effects\CellTexture.dll, version=1.0.0.0 ClipWarpNew.dll .\Effects\ClipWarpNew.dll, version=1.0.1.0 ClipWarp.dll .\Effects\ClipWarp.dll, version=1.0.9.0 Cobweb.dll .\Effects\Cobweb.dll, version=1.0.1.0 CloudsEffect.dll .\Effects\CloudsEffect.dll, version=1.1.1.0 Color Match.dll .\Effects\Color Match.dll, version=4.0.4642.26532 ColorMixer.dll .\Effects\ColorMixer.dll, version=1.3.0.0 ColorSketch_en.dll .\Effects\ColorSketch_en.dll, version=1.0.0.0 ColorToAlpha.dll .\Effects\ColorToAlpha.dll, version=2.3.0.0 CompoGrids.dll .\Effects\CompoGrids.dll, version=1.0.2.0 Compotool.dll .\Effects\Compotool.dll, version=1.0.1.0 CreativeTextPro.dll .\Effects\CreativeTextPro.dll, version=6.0.8407.22165 Cubic_Transformation.dll .\Effects\Cubic_Transformation.dll, version=1.0.7197.12790 Cuboids.dll .\Effects\Cuboids.dll, version=1.1.1.0 Curves+.dll .\Effects\Curves+.dll, version=4.0.6119.31044 Diagonal Lines.dll .\Effects\Diagonal Lines.dll, version=1.0.4800.36619 Diffuse.dll .\Effects\Diffuse.dll, version=1.0.3254.27766 Dimensions.dll .\Effects\Dimensions.dll, version=1.3.6826.38472 DispMap.dll .\Effects\DispMap.dll, version=2.1.7197.13119 DistortThis.dll .\Effects\DistortThis.dll, version=2.7.5.37343 dpyColorBalance.dll .\Effects\dpyColorBalance.dll, version=1.1.4330.37850 DragFrom.dll .\Effects\DragFrom.dll, version=1.1.0.0 Dream.dll .\Effects\Dream.dll, version=6.0.8414.36727 Dryad.dll .\Effects\Dryad.dll, version=1.0.2.0 Contour.dll .\Effects\Contour.dll, version=1.0.1.0 EarthsAndGreys.dll .\Effects\EarthsAndGreys.dll, version=1.0.1.0 EdgeExpander.dll .\Effects\EdgeExpander.dll, version=1.0.5863.38192 EdgeDetectClassic.dll .\Effects\EdgeDetectClassic.dll, version=1.0.8424.19432 EdgeShaderMJW.dll .\Effects\EdgeShaderMJW.dll, version=1.1.5849.39125 EdHarvey.Edfects.dll .\Effects\EdHarvey.Edfects.dll, version=5.0.0.0 Eyeshine.dll .\Effects\Eyeshine.dll, version=1.0.3700.25905 Facet.dll .\Effects\Facet.dll, version=1.0.3.0 FillFromClipboard.dll .\Effects\FillFromClipboard.dll, version=6.0.8407.22397 FillFromFile.dll .\Effects\FillFromFile.dll, version=6.0.8407.22418 Film.dll .\Effects\Film.dll, version=4.0.4642.26607 FindEdges.dll .\Effects\FindEdges.dll, version=1.2.0.0 Flip.dll .\Effects\Flip.dll, version=4.6.7358.36953 Flourish.dll .\Effects\Flourish.dll, version=1.0.3.0 FurBlur.dll .\Effects\FurBlur.dll, version=1.0.1.0 GaussianBlurPlus.dll .\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401 FloydSteinbergDithering.dll .\Effects\FloydSteinbergDithering.dll, version=5.2.8174.39918 Glass_Blur.dll .\Effects\Glass_Blur.dll, version=1.1.7212.26179 Gmic.dll .\Effects\Gmic.dll, version=3.3.0.0 Gossamer.dll .\Effects\Gossamer.dll, version=1.0.2.0 Gradient Bars.dll .\Effects\Gradient Bars.dll, version=4.0.5152.23084 Gradient Blocks.dll .\Effects\Gradient Blocks.dll, version=4.0.4642.26658 Gradient Grid.dll .\Effects\Gradient Grid.dll, version=4.0.6436.36068 GradientsGalore.dll .\Effects\GradientsGalore.dll, version=1.0.5.0 Grain.dll .\Effects\Grain.dll, version=1.0.3854.25523 Gray2Alpha.dll .\Effects\Gray2Alpha.dll, version=6.0.8407.22439 Emboss+.dll .\Effects\Emboss+.dll, version=1.2.0.0 Grid Warp.dll .\Effects\Grid Warp.dll, version=4.0.6544.34496 Gears.dll .\Effects\Gears.dll, version=1.0.2.0 Grow.dll .\Effects\Grow.dll, version=1.0.7.0 Helix.dll .\Effects\Helix.dll, version=1.0.1.0 Highlight.dll .\Effects\Highlight.dll, version=1.0.1.0 InnerShadow.dll .\Effects\InnerShadow.dll, version=3.0.5509.3391 IntensityRGB_beta.dll .\Effects\IntensityRGB_beta.dll, version=0.0.0.0 Jitter.dll .\Effects\Jitter.dll, version=4.0.4642.26986 Kill Color Keeper.dll .\Effects\Kill Color Keeper.dll, version=1.0.6641.13453 Kuwahara.dll .\Effects\Kuwahara.dll, version=1.0.0.0 Landscape.dll .\Effects\Landscape.dll, version=5.2.8174.40347 Lattice_Transform.dll .\Effects\Lattice_Transform.dll, version=1.0.7215.30711 LevelHorizon.dll .\Effects\LevelHorizon.dll, version=6.0.8407.22459 LightRays.dll .\Effects\LightRays.dll, version=2.1.5.0 LocalContrast.dll .\Effects\LocalContrast.dll, version=3.0.0.0 Liquify.dll .\Effects\Liquify.dll, version=4.0.5873.25113 LocalStatsDenoisingFilter.dll .\Effects\LocalStatsDenoisingFilter.dll, version=2.0.0 LongiStripes.dll .\Effects\LongiStripes.dll, version=1.0.6337.34025 Animal.dll .\Effects\MadJikPack\Animal.dll, version=2.2.5.0 AutoChrome.dll .\Effects\MadJikPack\AutoChrome.dll, version=1.2.5.0 Bars.dll .\Effects\MadJikPack\Bars.dll, version=1.2.5.0 Boutons.dll .\Effects\MadJikPack\Boutons.dll, version=1.2.5.0 ChangeExtremeColors.dll .\Effects\MadJikPack\ChangeExtremeColors.dll, version=1.2.6.0 ColorModulo.dll .\Effects\MadJikPack\ColorModulo.dll, version=1.2.5.0 ColorZoomBlur.dll .\Effects\MadJikPack\ColorZoomBlur.dll, version=1.2.5.0 Displacement.dll .\Effects\MadJikPack\Displacement.dll, version=1.3.5.0 DistortingMirror.dll .\Effects\MadJikPack\DistortingMirror.dll, version=1.2.5.0 Donut.dll .\Effects\MadJikPack\Donut.dll, version=1.2.5.0 ExpandColor.dll .\Effects\MadJikPack\ExpandColor.dll, version=1.2.5.0 FillPalette.dll .\Effects\MadJikPack\FillPalette.dll, version=1.2.5.0 FractalAttractor.dll .\Effects\MadJikPack\FractalAttractor.dll, version=1.3.5.0 FractalFern.dll .\Effects\MadJikPack\FractalFern.dll, version=1.2.0.0 FractalTree.dll .\Effects\MadJikPack\FractalTree.dll, version=1.2.0.0 Frames.dll .\Effects\MadJikPack\Frames.dll, version=1.2.5.0 Gen96Colors.dll .\Effects\MadJikPack\Gen96Colors.dll, version=1.2.0.0 GradientBlur.dll .\Effects\MadJikPack\GradientBlur.dll, version=1.2.5.0 Gravity.dll .\Effects\MadJikPack\Gravity.dll, version=1.2.5.0 GridMaker.dll .\Effects\MadJikPack\GridMaker.dll, version=5.2.5.0 HilbertCurve.dll .\Effects\MadJikPack\HilbertCurve.dll, version=1.2.0.0 JuliaPlus.dll .\Effects\MadJikPack\JuliaPlus.dll, version=1.2.5.0 coloraberation.dll .\Effects\MadJikPack\coloraberation.dll, version=1.2.5.0 KaleidoGen.dll .\Effects\MadJikPack\KaleidoGen.dll, version=1.3.5.0 LensFlare.dll .\Effects\MadJikPack\LensFlare.dll, version=2.2.12.0 Kaleidoscope.dll .\Effects\MadJikPack\Kaleidoscope.dll, version=1.6.1.0 ListOfPalettes.dll .\Effects\MadJikPack\ListOfPalettes.dll, version=1.0.0.0 Magnifier.dll .\Effects\MadJikPack\Magnifier.dll, version=1.3.5.0 HexaGrid.dll .\Effects\MadJikPack\HexaGrid.dll, version=4.1.0.0 Majority.dll .\Effects\MadJikPack\Majority.dll, version=1.2.5.0 LightRays.dll .\Effects\MadJikPack\LightRays.dll, version=2.1.5.0 Moire.dll .\Effects\MadJikPack\Moire.dll, version=1.2.5.0 Melting.dll .\Effects\MadJikPack\Melting.dll, version=1.3.0.0 HexaGrid.dll .\Effects\HexaGrid.dll, version=4.1.0.0 MotionSharpen.dll .\Effects\MadJikPack\MotionSharpen.dll, version=1.2.5.0 Nebulous.dll .\Effects\MadJikPack\Nebulous.dll, version=1.2.5.0 NewtonFractal.dll .\Effects\MadJikPack\NewtonFractal.dll, version=2.2.5.0 Oblique.dll .\Effects\MadJikPack\Oblique.dll, version=1.2.5.0 Overliner.dll .\Effects\MadJikPack\Overliner.dll, version=1.2.5.0 PageCurl.dll .\Effects\MadJikPack\PageCurl.dll, version=1.5.5.0 AutoChromeNoise.dll .\Effects\MadJikPack\AutoChromeNoise.dll, version=1.2.5.0 Paneling.dll .\Effects\MadJikPack\Paneling.dll, version=1.2.5.0 PerlinTexture.dll .\Effects\MadJikPack\PerlinTexture.dll, version=2.2.5.0 Polar.dll .\Effects\MadJikPack\Polar.dll, version=1.2.5.0 Polygones.dll .\Effects\MadJikPack\Polygones.dll, version=1.3.5.0 Radialcolors.dll .\Effects\MadJikPack\Radialcolors.dll, version=1.2.5.0 RainbowTwist.dll .\Effects\MadJikPack\RainbowTwist.dll, version=1.2.5.0 RandomLines.dll .\Effects\MadJikPack\RandomLines.dll, version=1.2.5.0 RandomMaze1.dll .\Effects\MadJikPack\RandomMaze1.dll, version=1.2.5.0 RandomMaze2.dll .\Effects\MadJikPack\RandomMaze2.dll, version=1.2.5.0 RecolorGray.dll .\Effects\MadJikPack\RecolorGray.dll, version=1.2.5.0 RegularNoise.dll .\Effects\MadJikPack\RegularNoise.dll, version=1.2.5.0 ReverseColors.dll .\Effects\MadJikPack\ReverseColors.dll, version=1.2.5.0 Rosaces.dll .\Effects\MadJikPack\Rosaces.dll, version=1.2.5.0 SeamlessTextureMaker.dll .\Effects\MadJikPack\SeamlessTextureMaker.dll, version=1.2.5.0 Shapes.dll .\Effects\MadJikPack\Shapes.dll, version=1.6.5.0 Signature.dll .\Effects\MadJikPack\Signature.dll, version=1.5.6617.21474 SmoothNoise.dll .\Effects\MadJikPack\SmoothNoise.dll, version=1.0.0.0 SinWaves.dll .\Effects\MadJikPack\SinWaves.dll, version=1.2.5.0 Sparkles.dll .\Effects\MadJikPack\Sparkles.dll, version=1.2.5.0 Spiral.dll .\Effects\MadJikPack\Spiral.dll, version=1.2.5.0 SpiroShapes.dll .\Effects\MadJikPack\SpiroShapes.dll, version=2.2.5.0 SpiroGraph.dll .\Effects\MadJikPack\SpiroGraph.dll, version=1.2.5.0 Splashes.dll .\Effects\MadJikPack\Splashes.dll, version=1.2.5.0 StarGlow.dll .\Effects\MadJikPack\StarGlow.dll, version=1.3.5.0 SpotCenter.dll .\Effects\MadJikPack\SpotCenter.dll, version=1.2.0.0 Stars.dll .\Effects\MadJikPack\Stars.dll, version=2.0.0.0 Tiles.dll .\Effects\MadJikPack\Tiles.dll, version=1.2.5.0 Tournesol.dll .\Effects\MadJikPack\Tournesol.dll, version=1.2.5.0 TubeOblique.dll .\Effects\MadJikPack\TubeOblique.dll, version=1.2.5.0 TwistZ.dll .\Effects\MadJikPack\TwistZ.dll, version=1.2.5.0 Vibrato.dll .\Effects\MadJikPack\Vibrato.dll, version=2.0.5.0 Waves.dll .\Effects\MadJikPack\Waves.dll, version=1.2.5.0 Volutes.dll .\Effects\MadJikPack\Volutes.dll, version=1.3.5.0 XYCoords.dll .\Effects\MadJikPack\XYCoords.dll, version=1.2.6.0 MemeMaker.dll .\Effects\MemeMaker.dll, version=6.0.8407.22476 Metallize.dll .\Effects\Metallize.dll, version=1.2.4415.32969 Mise En Abyme.dll .\Effects\Mise En Abyme.dll, version=1.1.0.0 MultiColorGradient.dll .\Effects\MultiColorGradient.dll, version=1.0.0.0 MultiSpline.dll .\Effects\MultiSpline.dll, version=1.0.4.0 WaterReflection.dll .\Effects\MadJikPack\WaterReflection.dll, version=1.2.5.0 MultiThreshold.dll .\Effects\MultiThreshold.dll, version=1.1.4330.38982 WetFloor.dll .\Effects\MadJikPack\WetFloor.dll, version=1.2.5.0 NoiseChoice.dll .\Effects\NoiseChoice.dll, version=1.0.1.0 ObjectBevel.dll .\Effects\ObjectBevel.dll, version=1.0.6.0 Objectedge.dll .\Effects\Objectedge.dll, version=1.0.1.0 ObjectShadowPro.dll .\Effects\ObjectShadowPro.dll, version=1.0.7421.614 ObjectTools.dll .\Effects\ObjectTools.dll, version=6.0.8482.2565 OilPaintingPlus.dll .\Effects\OilPaintingPlus.dll, version=5.2.8141.27893 OldFeather.dll .\Effects\OldFeather.dll, version=2.3.4315.37038 Olden.dll .\Effects\Olden.dll, version=1.5.0.0 Outline Object.dll .\Effects\Outline Object.dll, version=4.0.4642.26954 Object2Colour.dll .\Effects\Object2Colour.dll, version=1.0.1.0 Overblur.dll .\Effects\Overblur.dll, version=1.0.1.0 PasteAlpha.dll .\Effects\PasteAlpha.dll, version=5.2.8174.40450 Pastel.dll .\Effects\Pastel.dll, version=5.2.8174.40506 perlin_noise.dll .\Effects\perlin_noise.dll, version=1.1.7172.28890 PdnV5EffectSamples.dll .\Effects\PDNv5EffectSamples.2023.01.07\PdnV5EffectSamples.dll, version=1.0.* ComputeSharp.D2D1.dll .\Effects\PDNv5EffectSamples.2023.01.07\ComputeSharp.D2D1.dll, version=2.0.0.0 ComputeSharp.Core.dll .\Effects\PDNv5EffectSamples.2023.01.07\ComputeSharp.Core.dll, version=2.0.0.0 Perspective.dll .\Effects\Perspective.dll, version=2.1.4415.36116 PhotoAdjustments.dll .\Effects\PhotoAdjustments.dll, version=6.0.8416.38377 Polar.dll .\Effects\Polar.dll, version=1.2.5.0 PolyGlitch.Effects.dll .\Effects\PolyGlitch.Effects.dll, version=1.4.0.0 Polar_Kaleidoscope.dll .\Effects\Polar_Kaleidoscope.dll, version=1.0.7188.40229 PointBlur.dll .\Effects\PointBlur.dll, version=1.0.0.0 Poster.dll .\Effects\Poster.dll, version=1.0.2.0 Pixelate+.dll .\Effects\Pixelate+.dll, version=4.0.4642.26940 PowerStretch.dll .\Effects\PowerStretch.dll, version=0.0.0.0 Psychocolour.dll .\Effects\Psychocolour.dll, version=1.0.1.0 pxEexpansion.dll .\Effects\pxEexpansion.dll, version=1.0.4437.36287 PSFilterPdn.dll .\Effects\PSFilterPdn.dll, version=2.0.2.0 rainball.dll .\Effects\rainball.dll, version=1.0.4907.41850 Random Effect.dll .\Effects\Random Effect.dll, version=4.0.4642.26928 Random Shape Fill.dll .\Effects\Random Shape Fill.dll, version=4.0.4642.26910 RecolourChoice.dll .\Effects\RecolourChoice.dll, version=1.0.1.0 RedEyeQuickFix.dll .\Effects\RedEyeQuickFix.dll, version=1.1.3161.39688 RemoveTransparency.dll .\Effects\RemoveTransparency.dll, version=1.0.0.0 Remove_Black.dll .\Effects\Remove_Black.dll, version=1.0.7212.28737 Rosaces.dll .\Effects\Rosaces.dll, version=1.2.5.0 RotateText.dll .\Effects\RotateText.dll, version=1.1.4415.32628 RotateTextSUI.dll .\Effects\RotateTextSUI.dll, version=1.1.4415.32713 RemoveDust.dll .\Effects\RemoveDust.dll, version=6.0.8407.22513 Rotate_Zoom+.dll .\Effects\Rotate_Zoom+.dll, version=1.11.5237.17779 Scintillate.dll .\Effects\Scintillate.dll, version=1.0.1.0 Scribble.dll .\Effects\Scribble.dll, version=1.0.1.0 ScriptLab.dll .\Effects\ScriptLab.dll, version=4.0.6107.18914 SeamCarving.dll .\Effects\SeamCarving.dll, version=5.2.8176.39366 SeamlessTextureMaker.dll .\Effects\SeamlessTextureMaker.dll, version=1.2.5.0 Selection2Clear.dll .\Effects\Selection2Clear.dll, version=1.0.1.0 SelectionTools.dll .\Effects\SelectionTools.dll, version=6.0.8412.38725 ShadowHighlight.dll .\Effects\ShadowHighlight.dll, version=3.0.0.0 Shape3D.dll .\Effects\Shape3D.dll, version=1.2.6.0 shapegradient.dll .\Effects\shapegradient.dll, version=1.5.3886.6574 Sharpen+.dll .\Effects\Sharpen+.dll, version=4.0.0.0 SharpenClassic.dll .\Effects\SharpenClassic.dll, version=1.0.8420.39106 SinWaves.dll .\Effects\SinWaves.dll, version=1.2.5.0 Slinky.dll .\Effects\Slinky.dll, version=1.0.1.0 Smudge.dll .\Effects\Smudge.dll, version=4.0.5873.25097 Specular.dll .\Effects\Specular.dll, version=1.0.3254.27778 Spherical_Bulge.dll .\Effects\Spherical_Bulge.dll, version=1.0.7224.336 Spiral.dll .\Effects\Spiral.dll, version=1.2.5.0 SpeechBubble.dll .\Effects\SpeechBubble.dll, version=2.1.4445.42029 SpiralText.dll .\Effects\SpiralText.dll, version=1.4.4415.32775 SpiroGraph.dll .\Effects\SpiroGraph.dll, version=1.2.5.0 Splatter.dll .\Effects\Splatter.dll, version=4.0.5873.25083 SpotCenter.dll .\Effects\SpotCenter.dll, version=1.2.0.0 Squirkle.dll .\Effects\Squirkle.dll, version=1.0.1.0 SquirkleWarp.dll .\Effects\SquirkleWarp.dll, version=1.0.1.0 Stitch.dll .\Effects\Stitch.dll, version=4.0.4642.26808 StringAndPin.dll .\Effects\StringAndPin.dll, version=1.0.1.0 Table.dll .\Effects\Table.dll, version=1.1.5847.38905 TextDistortion.dll .\Effects\TextDistortion.dll, version=1.1.0.0 OutlineGradientText.dll .\Effects\OutlineGradientText.dll, version=1.0.0.0 TextMask.dll .\Effects\TextMask.dll, version=1.0.0.0 RoundedRectangle.dll .\Effects\RoundedRectangle.dll, version=1.1.0.0 System.IO.Compression.dll .\System.IO.Compression.dll, version=7.0.1223.47720 K4os.Compression.LZ4.dll .\K4os.Compression.LZ4.dll, version=1.2.16 System.CodeDom.dll .\System.CodeDom.dll, version=7.0.1223.47720 System.Runtime.CompilerServices.Unsafe.dll .\System.Runtime.CompilerServices.Unsafe.dll, version=7.0.1223.47720 sxs.dll C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Diagnostics.StackTrace.dll .\System.Diagnostics.StackTrace.dll, version=7.0.1223.47720 setupapi.DLL C:\WINDOWS\System32\setupapi.DLL, version=10.0.19041.3570 (WinBuild.160101.0800) DEVOBJ.dll C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.3570 (WinBuild.160101.0800) Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 25 Author Share Posted October 25 On 10/23/2023 at 5:28 PM, Roger the Dodger said: Exception of type 'PaintDotNet.Direct2D1.InsufficientDeviceCapabilitiesException' was thrown. (Direct2D1Error.InsufficientDeviceCapabilities 0x88990026) Are you using an ARM system? Please post the diagnostics info from Settings (gear icon at top right of main window) -> Diagnostics. Tyere's a "Copy to clipboard" button, click that and paste it here. Edit: For some reason I missed/forgot that the crash info has the diagnostics info already 🤦♂️ There might accidentally be some use of double-precision floats in the pixel shader code, which are not supported on some older AMD GPUs. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
AndrewDavid Posted October 26 Share Posted October 26 @Rick Brewster This error just appeared today. Spoiler deviceContext.Factory.RegisterEffectFromBlob( D2D1PixelShaderEffect.GetRegistrationBlob<SquareBlurShader, SquareBlurTransformMapper>(out Guid effectID)); SquareBlurGpuEffect.cs Lines 57 & 58 Severity Code Description Project File Line Suppression State Error CS0305 Using the generic method 'D2D1PixelShaderEffect.GetRegistrationBlob<T>(out Guid)' requires 1 type arguments AndrewDavidsPlugins C:\Users\Andrew\Desktop\AndrewDavidsPlugins\SquareBlurGpuEffect.cs 57 Active Its not a problem with your solution - Its a problem with my Visual Studio. 1 Quote Link to comment Share on other sites More sharing options...
Roger the Dodger Posted October 26 Share Posted October 26 Thanks Rick these are sterling plug-ins all the same and thankfully all the others work fine😊 Quote Link to comment Share on other sites More sharing options...
