Sonoroho Posted April 9, 2019 Share Posted April 9, 2019 How would I achieve this effect in PDN? I want to learn how to make the boxed look basically. https://www.deviantart.com/rainingknote/art/Pokemon-Signature-Boxed-407778125 -Sonoroho Quote Link to comment Share on other sites More sharing options...
BoltBait Posted April 9, 2019 Share Posted April 9, 2019 Start with a standard picture in the right size. You'll need my plugin pack installed and your primary color should be black and secondary color white. Select your starting picture layer. Use the selection tool to select one rectangle. Press Ctrl+X followed by Ctrl+Shift+V. Run the Effects > Selection > Outline Selection (Outline width: 1, Color: black) Repeat for each rectangle you wish to have in your final image. Start with the squares you want as the top most layers. Select your starting picture layer. Press Ctrl+A followed by Shift+Backspace (This should fill your background layer with white.) Save as PNG file (flattening as required.) For an advanced look, before saving, press Ctrl+D, then select one of the square layers and run Effects > Object > Object Shadow (all defaults). Repeat for a handful of those layers... the ones that look like they're at the top most level. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Sonoroho Posted April 9, 2019 Author Share Posted April 9, 2019 (edited) Well...it isn't horrible. XD Thank you BoltBait for the help. Edit: I just need to figure out how to make it look neater and more boxes. XD Ok, I tried again. Hmmm. Edited April 9, 2019 by Sonoroho Added a second comment. Quote Link to comment Share on other sites More sharing options...
HyReZ Posted April 9, 2019 Share Posted April 9, 2019 I would start by creating a Canvas with the dimensions of your desired end result and fill the space with a chroma-key type green. Create a new layer that is transparent. Disable anti-aliasing Select Black for primary color and White for your secondary color Select the appropriate Brush width for the outline of your assorted Rectangles Select Draw Fill Shape With Outline and draw your assorted overlapped rectangles Merge top and bottom layers Make White transparent Globally Import your cartoon layer and move under your rectangle layer and merge Make the chroma-key green color transparent Globally Done! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted April 9, 2019 Share Posted April 9, 2019 36 minutes ago, Sonoroho said: Well...it isn't horrible. It is a good start. Here's the thing: As you start out, select the squares you want on the top most layer and do those. Then, when you go back to the source layer, select overlapping squares and process those. You'll see that they neatly work fine as the overlapping part is already processed from above. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Sonoroho Posted April 9, 2019 Author Share Posted April 9, 2019 Ok, here is my attempt using HyReZ's way. I guess I just can't make anything that dainty. XD Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 9, 2019 Author Share Posted April 9, 2019 Ohhh, thanks for the advice Bolt. Quote Link to comment Share on other sites More sharing options...
Woodsy Posted April 9, 2019 Share Posted April 9, 2019 2 hours ago, Sonoroho said: Well...it isn't horrible. XD Thank you BoltBait for the help. Edit: I just need to figure out how to make it look neater and more boxes. XD Ok, I tried again. Hmmm. Hi @Sonoroho, excuse me for eavesdropping. Your attempt at what Boltbait told you is good just try taking your first picture and put it on top of your second picture then flatten it and see what you have. Or try the other way around. 1 Quote My PDN Gallery Link to comment Share on other sites More sharing options...
HyReZ Posted April 9, 2019 Share Posted April 9, 2019 I put all of my overlapping rectangles on a single layer, but if you use BaitBolt's advice you can use a variety of layers and this will allow you to re-stack the rectangle layers to get the overlapping that is most pleasing before merging down. Save your work to a PND first so that you may rearrange layers if you change your mind about the composition. 1 Quote Link to comment Share on other sites More sharing options...
HyReZ Posted April 9, 2019 Share Posted April 9, 2019 Here is my variation on a theme: 5 1 Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 10, 2019 Author Share Posted April 10, 2019 Ohhh, I like that. Also, np Woodsy. I will try that next!! Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 10, 2019 Share Posted April 10, 2019 Not quite the same effect, but worthy of inclusion in this discussion is my Woven Photo plugin. Run it multiple times over the same image. Each time use a different spacing and size. 2 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Woodsy Posted April 10, 2019 Share Posted April 10, 2019 (edited) And after you flatten it take the Magic Wand and select an empty part of the picture, go to Edit and select invert selection. And invert it and choose the Outline Object plugin with probably a 2 pixel width. Or you might prefer to do something else. It's just something to jazz it up that you might like. The Woven Photo plugin is a good idea also. Edited April 10, 2019 by Woodsy 1 Quote My PDN Gallery Link to comment Share on other sites More sharing options...
Sonoroho Posted April 13, 2019 Author Share Posted April 13, 2019 On 4/9/2019 at 4:52 PM, HyReZ said: Here is my variation on a theme: I definitely want something like this. It looks amazing. 1 Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 13, 2019 Author Share Posted April 13, 2019 \ The background pic is just to dark. Bah. Also, thanks welshblue for the suggestion. 1 Quote Link to comment Share on other sites More sharing options...
HyReZ Posted April 13, 2019 Share Posted April 13, 2019 (edited) @Sonoroho I used the Adjusments > Black and White to convert my background to gray scale and I used the Adjusments > Brightnes / Contrast to alter the values of the gray scaled backgrounds Keep pressing on! Edited April 13, 2019 by HyReZ Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 14, 2019 Author Share Posted April 14, 2019 I will look into it Welsh. Ty. Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 14, 2019 Author Share Posted April 14, 2019 Also, Hyrez...what do I do after grey-scaling it? I tried using curves...but didn't get much from it. Is there any chance you could do a tutorial for me on how you did yours? Quote Link to comment Share on other sites More sharing options...
HyReZ Posted April 14, 2019 Share Posted April 14, 2019 (edited) In my composition I converted my background layer to gray scale and the boxed layer that is in full color is placed on top. I did not use curves, I used the brightness / contrast plugin sliders to get the levels that I thought were pleasing. I am working on a few tee-shirt design projects now and won't have the time to work on a tutorial. You have the baics already. Just play around with it. Total immersion is a good way to learn sometimes. Edited April 14, 2019 by HyReZ Correcting spelling and adding more nfo! 1 Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 14, 2019 Author Share Posted April 14, 2019 Nfo. XD Anyways, I can't get it to look right. Which layers do I merge after the background is grey-scale and as bright as I want it? Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 14, 2019 Author Share Posted April 14, 2019 How did you merge them keeping the color in the boxes? Quote Link to comment Share on other sites More sharing options...
Sonoroho Posted April 14, 2019 Author Share Posted April 14, 2019 (edited) Something like this? O.o Or this? I suck at using the magic wand. XD Edited April 14, 2019 by Sonoroho Quote Link to comment Share on other sites More sharing options...
HyReZ Posted April 14, 2019 Share Posted April 14, 2019 (edited) It appears that you have gotten the hang of it to me! It is a good idea to disable anti-aliasing in the early stages of the design it makes it difficult for the Wand tool to do a neat job and it makes the squares outline neater also! I also suggest that you make your shadows less opaque and soften them a bit. Press on! Edited April 14, 2019 by HyReZ Quote Link to comment Share on other sites More sharing options...
